17-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command Reference(V7)-6W60217-Network Management and Monitoring Command Reference
04-NetStream commands
04-NetStream commands 66.29 KB
Session-based NetStream commands
display session-based netstream aggregation-cache
Use display session-based netstream aggregation-cache to display session-based NetStream statistics.
display session-based netstream aggregation-cache { app | app-profile | app-user } *
context-admin
context-operator
app: Specifies the app aggregation mode.
app-profile: Specifies the app-profile aggregation mode.
app-user: Specifies the app-user aggregation mode.
To display session-based NetStream statistics in an aggregation mode, you must enable the aggregation mode by using the session-based netstream aggregation command.
# Display statistics about session-based NetStream in app aggregation mode.
<Sysname> display session-based netstream aggregation-cache app
Active entries                                   :1
Timeout time for session-based NetStream entries :10
AppID      InPkts     InBytes    OutPkts    OutBytes
22742      4          240        4          240
Total   Sessions : 1
Current Sessions : 1
SubsCribers      : 1
# Display statistics about session-based NetStream in app-profile aggregation mode.
<Sysname> display session-based netstream aggregation-cache app-profile
Active entries                                   :1
AppID      ProfileID  InPkts     InBytes    OutPkts    OutBytes
22742      0          4          240        4          240
New     Sessions : 0
# Display statistics about session-based NetStream in app-user aggregation mode.
<Sysname> display session-based netstream aggregation-cache app-user
Active entries                                   :1
AppID      UserIp           InPkts     InBytes    OutPkts    OutBytes
22742      8.8.8.8          4          240        4          240
Total   Sessions : 1
Active entries
Number of active session-based NetStream entries.
Maximum period of time in minutes a session-based NetStream entry can be cached before being exported to NetStream servers.
App ID
Application layer protocol ID.
UserIP
User IP address.
ProfileID
Traffic rule ID in bandwidth management.
InPkts
Number of upstream packets.
InBytes
Number of upstream bytes.
OutPkts
Number of downstream packets.
OutBytes
Number of downstream bytes.
Total sessions
Total number of sessions.
New sessions
Number of new sessions established in the current statistics collection interval.
Current sessions
Number of concurrent sessions at the time the display session-based netstream aggregation-cache command was executed.
SubsCribers
Total number of users in the current statistics collection interval.
Use session-based netstream aggregation to enable session-based NetStream aggregation modes.
Use undo session-based netstream aggregation to disable session-based NetStream aggregation modes.
session-based netstream aggregation { app | app-profile | app-user } *
undo session-based netstream aggregation { app | app-profile | app-user } *
All session-based NetStream aggregation modes are disabled.
context-admin
app: Specifies the app aggregation mode, which aggregates traffic by application layer protocol ID.
app-profile: Specifies the app-profile aggregation mode, which aggregates traffic by application layer protocol ID and profile ID.
app-user: Specifies the app-user aggregation mode, which aggregates traffic by application layer protocol ID and user IP address.
# Enable the app aggregation mode for session-based NetStream aggregation.
[Sysname] session-based netstream aggregation app
session-based netstream enable
Use session-based netstream enable to enable session-based NetStream.
Use undo session-based netstream enable to disable session-based NetStream.
Session-based NetStream is disabled.
context-admin
# Enable session-based NetStream.
[Sysname] session-based netstream enable
session-based netstream export host
Use session-based netstream export host to specify a destination host for session-based NetStream data export.
Use undo session-based netstream export host to restore the default.
session-based netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
No destination host is specified for session-based NetStream data export.
context-admin
ip-address: Specifies the IP address of the destination host.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination host is on the public network, do not specify this option.
# Export session-based NetStream data to UDP port 9020 on host 172.16.1.1.
[Sysname] session-based netstream export host 172.16.1.1 9020
session-based netstream export source ip
Use session-based netstream export source ip to specify a source IP address for session-based NetStream packets.
Use undo session-based netstream export source ip to restore the default.
session-based netstream export source ip ip-address
The source IP address of session-based NetStream packets is the primary IP address of the output interface.
context-admin
ip-address: Specifies an IP address.
# Specify 172.16.1.1 as the source IP address for session-based NetStream packets.
[Sysname] session-based netstream export source ip 172.16.1.1
session-based netstream timeout
Use session-based netstream timeout to set the aging timer for session-based NetStream entries.
Use undo session-based netstream timeout to restore the default.
session-based netstream timeout minutes
A session-based NetStream entry is automatically aged out and exported after being cached for 5 minutes.
context-admin
minutes: Sets the aging timer in minutes. The value range is 1 to 10.
When the aging timer for a session-based NetStream entry expires, statistics about the entry is cleared from the cache and exported to the NetStream servers.
# Set the aging timer for session-based NetStream entries to 5 minutes.
[Sysname] session-based netstream timeout 10
