- 03-Security Command Reference
- 01-Security zone commands
- 02-Security policy commands
- 03-ASPF commands
- 04-Session management commands
- 05-Object group commands
- 06-IP source guard commands
- 07-AAA commands
- 08-802.1X commands
- 09-User identification commands
- 10-Password control commands
- 11-Portal commands
- 12-MAC authentication commands
- 13-IPoE commands
- 14-Public key management commands
- 15-PKI commands
- 16-SSH commands
- 17-SSL commands
- 18-Connection limit commands
- 19-Attack detection and prevention commands
- 20-Server connection detection commands
- 21-ARP attack protection commands
- 22-ND attack defense commands
- 23-uRPF commands
- 24-IP-MAC binding commands
- 25-APR commands
- 26-Keychain commands
- 27-Crypto engine commands
- 28-MAC learning through a Layer 3 device commands
- 29-SMS commands
13-IPoE commands | 712.27 KB |
display ip subscriber interface-leased
display ip subscriber interface-leased statistics
display ip subscriber offline statistics
display ip subscriber session statistics
display ip subscriber subnet-leased
display ip subscriber subnet-leased statistics
ip subscriber access-user log enable
ip subscriber dhcp max-session
ip subscriber dhcp password option60
ip subscriber initiator dhcp enable
ip subscriber initiator unclassified-ip enable
ip subscriber nas-port-id format
ip subscriber nas-port-id nasinfo-insert
ip subscriber service-identify
ip subscriber unclassified-ip domain
ip subscriber unclassified-ip max-session
ip subscriber unclassified-ip username
ip subscriber whitelist enable
reset ip subscriber offline statistics
display ipv6 subscriber interface-leased
display ipv6 subscriber interface-leased statistics
display ipv6 subscriber offline statistics
display ipv6 subscriber session
display ipv6 subscriber session statistics
display ipv6 subscriber subnet-leased
display ipv6 subscriber subnet-leased statistics
ipv6 subscriber access-user log enable
ipv6 subscriber dhcp max-session
ipv6 subscriber dhcp password option16
ipv6 subscriber initiator dhcp enable
ipv6 subscriber initiator ndrs enable
ipv6 subscriber initiator unclassified-ip enable
ipv6 subscriber nas-port-id format
ipv6 subscriber nas-port-id nasinfo-insert
ipv6 subscriber ndrs max-session
ipv6 subscriber service-identify
ipv6 subscriber session static
ipv6 subscriber unclassified-ip domain
ipv6 subscriber unclassified-ip max-session
ipv6 subscriber unclassified-ip username
ipv6 subscriber whitelist enable
reset ipv6 subscriber offline statistics
IPoE commands
IPv4 IPoE commands
Use display ip subscriber interface-leased to display information about IPv4 interface-leased users.
display ip subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IPv4 interface-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv4 interface-leased users for all member devices.
# Display information about the IPv4 interface-leased user on GigabitEthernet 1/0/1.
<Sysname> display ip subscriber interface-leased interface gigabitethernet 1/0/1
Basic:
Access interface : GE1/0/1
VPN instance : N/A
Username : a
User ID : 0x30000000
State : Online
Service node : Slot 1 CPU 0
Domain : radius
Login time : May 14 20:04:42 2014
Online time (hh:mm:ss) : 00:16:37
AAA:
IP pool : ipoe
Session idle time : N/A
Session duration : N/A, remaining: N/A
Remaining traffic : N/A
Max multicast addresses : 4
Multicast address list : N/A
QoS:
User profile : h3c (active)
Session group profile : N/A
Inbound CAR : CIR 1000bps PIR 2000bps CBS 500bit (active)
Outbound CAR : CIR 3000bps PIR 4000bps CBS 500bit (active)
Flow statistic:
Uplink packets/bytes : 0/0
Downlink packets/bytes : 0/0
ITA:
Level-1 Uplink packets/bytes: 0/0
Downlink packets/bytes: 0/0
Level-2 Uplink packets/bytes: 0/0
Basic |
Basic session information. |
Access interface |
Interface that connects the user. |
VPN instance |
MPLS L3VPN instance of the user. If the user is not in a VPN, this field displays N/A. |
Username |
Username for authentication. |
User ID |
User ID assigned after the user came online. If no user ID is assigned, this field displays 0xffffffff. |
State |
User state: · Init—The user is being initiated. · Offline—The user is going offline. · Auth—The user is being authenticated. · AuthFail—The user failed authentication. · AuthPass—The user passed authentication. · AssignedIP—The user has an IP address. · Online—The user is online. · Backup—Backup information about the user on the primary BRAS. |
Service node |
Slot number and CPU number of the card that connects the user. |
Domain |
ISP domain. |
Online time (hh:mm:ss) |
Online duration for the user. |
Login time |
Time when the user passed authentication and logged in, in the format of MM-DD hh:mm:ss YYYY. |
AAA |
AAA authorization information. |
IP pool |
AAA-authorized DHCP address pool. If no DHCP address pool is authorized, this field displays N/A. |
Session idle time |
Idle time in seconds specified for online users. If the idle time expires, the user is logged out. If no idle time is specified, this field displays N/A and the user can remain idle without being logged out. |
Session duration |
AAA-authorized IPoE session duration in seconds: · N/A—No IPoE session duration is authorized. · Unlimited—The IPoE session duration is unlimited. |
remaining |
Remaining AAA-authorized IPoE session duration. If no session duration is authorized, this field displays N/A. ¡ For users on Layer 3 Ethernet interfaces and subinterfaces, this field displays the remaining time or Unlimited. ¡ For users on Layer 3 aggregate interfaces and subinterfaces, this field displays the remaining time or Unlimited only when the slot or interface is specified. If you do not specify the slot or interface, this field displays N/A. |
Remaining traffic |
Remaining AAA-authorized traffic in bytes. If no traffic is authorized, this field displays N/A. |
Max multicast addresses |
Maximum number of AAA-authorized multicast groups that a user can join. |
Multicast address list |
List of AAA-authorized multicast group addresses. If no multicast group is authorized, this field displays N/A. |
QoS |
QoS information. |
User profile |
AAA-authorized user profile: · N/A—No user profile is authorized. · inactive—User profile authorization failed or the user profile does not exist on the BRAS. · active—The user profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
Session group profile |
AAA-authorized session group profile: · N/A—No session group profile is authorized. · inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS. · active—The session group profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
Inbound CAR |
Inbound CIR and PIR in bps and CBS in bits: · N/A—Inbound CAR is not authorized. · inactive—Inbound CAR is not authorized successfully. · active—Inbound CAR is authorized successfully. |
Outbound CAR |
Outbound CIR and PIR in bps and CBS in bits: · N/A—Outbound CAR is not authorized. · inactive—Outbound CAR is not authorized successfully. · active—Outbound CAR is authorized successfully. |
Flow statistic |
Session flow statistics. |
Uplink packets/bytes |
Total number and size of uplink packets. |
Downlink packets/bytes |
Total number and size of downlink packets. |
ITA |
Intelligent target accounting (ITA) information. |
Level-n Uplink packets/bytes |
Number and size of uplink packets for level n accounting (1 ≤ n ≤ 8). |
Number and size of downlink packets for level n accounting (1 ≤ n ≤ 8). |
ip subscriber enable
Use display ip subscriber interface-leased statistics to display IPoE session statistics for IPv4 interface-leased users.
display ip subscriber interface-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE session statistics for IPv4 interface-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPoE session statistics for IPv4 interface-leased users for all member devices.
# Display IPoE session statistics for IPv4 interface-leased users on the BRAS.
<Sysname> display ip subscriber interface-leased statistics
Total : 100
Init : 0
Authenticating : 20
Authenticate fail : 0
Authenticate pass : 20
Assigned IP : 10
Online : 50
Backup : 0
Total |
Total number of hosts on the interface. |
Init |
Number of users who initiated sessions. |
Authenticating |
Number of users being authenticated. |
Authenticate fail |
Number of users who failed authentication. |
Authenticate pass |
Number of users who passed authentication. |
Assigned IP |
Number of users who have IP addresses. |
Online |
Number of online users. |
Backup |
Number of users whose information was backed up. |
Use display ip subscriber offline statistics to display offline statistics for IPv4 users.
display ip subscriber offline statistics [ interface interface-type interface-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays offline statistics for IPv4 users for all interfaces.
# Display offline statistics for IPv4 users on GigabitEthernet 1/0/1.
<Sysname> display ip subscriber offline statistics interface gigabitethernet 1/0/1
Total : 100
User request : 0
DHCP lease expire : 0
AAA lease expire : 0
Command cut : 80
AAA terminate : 0
Authorization fail : 0
Idle timeout : 10
Detect fail : 10
Not enough resource : 0
Interface down : 0
Interface shutdown : 0
VSRP event : 0
DHCP notify : 0
Other : 0
Total |
Total number of offline users. |
User request |
Number of users requesting to go offline. |
DHCP lease expire |
Number of users with expired DHCP leases. |
AAA lease expire |
Number of users with expired AAA leases. |
Command cut |
Number of users logged out by commands. |
AAA terminate |
Number of users logged out by AAA. |
Authenticate fail |
Authorization fail |
Number of users who failed authorization. |
Idle timeout |
Number of users with an expired idle timeout timer. |
Detect fail |
Number of users who failed online detection. |
Not enough resource |
Number of users with insufficient hardware resources. |
Interface down |
Number of users on an interface that went down. |
Interface shutdown |
Number of users on an interface that was shut down. |
VSRP event |
Number of users disconnected by the VSRP event. |
DHCP notify |
Number of users disconnected by DHCP. |
Other |
Number of users disconnected from the network because of unknown causes. |
Use display ip subscriber session to display session information for IPv4 individual users.
display ip subscriber session [ interface interface-type interface-number ] [ domain domain-name | ip ip-address [ vpn-instance vpn-instance-name ] | mac mac-address | static | username name ] [ slot slot-number ] [ verbose ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays session information for IPv4 individual users for all interfaces.
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
ip ip-address: Specifies the source IP address of the IPv4 individual user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays session information for IPv4 individual users on the public network.
mac mac-address: Specifies the MAC address of an IPv4 individual user, in the format of H-H-H.
static: Specifies static IPoE sessions. If this parameter is not specified, this command displays information about static and dynamic sessions for IPv4 individual users.
username name: Specifies a username for authentication, a case-sensitive string of 1 to 255 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays session information for IPv4 individual users for all member devices.
verbose: Displays detailed session information for IPv4 individual users. If this parameter is not specified, this command displays general session information.
# Display general session information for the IPv4 individual user with an IP address of 1.1.1.1 in vpn1.
<Sysname> display ip subscriber session ip 1.1.1.1 vpn-instance vpn1
Type: D-DHCP S-Static U-Unclassified-IP
Interface IP address MAC address Type State
GE1/0/1 1.1.1.1 000d-88f8-0eab D Online
# Displays detailed session information for IPv4 individual users.
<Sysname> display ip subscriber session verbose
Basic:
Description : -
Username : abc
Domain : radius
VPN instance : N/A
IP address : 1.1.1.1
MAC address : 000d-88f8-0eab
Service-VLAN/Customer-VLAN : -/-
User ID : 0x380800b5
VPI/VCI(for ATM) : -/-
DHCP lease : N/A
DHCP remain lease : N/A
Login time : May 9 08:56:29 2014
Type : Static
State : Online
AAA:
IP pool : N/A
QoS:
User profile : abc (active)
Flow statistic:
Uplink packets/bytes : 594341/76075648
ITA:
Level-1 Uplink packets/bytes: 66038/8452864
Level-2 Uplink packets/bytes: 66038/8452864
Basic |
Description of the IPoE session. If the IPoE session does not have a description, this field displays a hyphen (-). |
Username |
Domain |
ISP domain of the user. |
VPN instance |
IP address |
IP address of the user. |
MAC address |
MAC address of the user. |
Service-VLAN/Customer-VLAN |
Public and private VLANs of the user. If the user is not a VLAN user, this field displays -. |
Access interface |
User ID |
VPI/VCI(for ATM) |
PVC information about the ATM. |
DHCP lease |
DHCP-authorized IP lease in seconds: · N/A—No IP lease is authorized. · Unlimited—The IP lease is unlimited. |
DHCP remain lease |
Remaining DHCP-authorized IP lease. This field is valid only on the card that connects the user. On other cards, this field displays N/A. |
Login time |
Service node |
Type |
IPoE session types: · DHCP—Dynamic IPoE sessions for DHCP users. · Unclassified-IP—Dynamic IPoE sessions for unclassified-IP users. · Static—Static sessions. |
State |
AAA |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
QoS information. |
User profile |
Inbound CAR |
Outbound CAR |
Flow statistic |
ITA |
Use display ip subscriber session statistics to display IPoE session statistics for IPv4 individual users.
display ip subscriber session statistics [ session-type { dhcp | static | unclassified-ip } ] [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
session-type: Specifies a user type. If you do not specify a user type, this command displays IPoE session statistics for all types of IPv4 individual users.
dhcp: Specifies DHCP users.
static: Specifies static users.
unclassified-ip: Specifies unclassified-IP users.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE session statistics for IPv4 individual users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPoE session statistics for IPv4 individual users for all member devices.
# Display IPoE session statistics for IPv4 individual users on GigabitEthernet 1/0/1.
<Sysname> display ip subscriber session statistics session-type dhcp interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 5 Command output
Total |
Total number of users on the interface. |
Init |
Authenticating |
Authenticate fail |
Authenticate pass |
Assigned IP |
Online |
Backup |
reset ip subscriber session
Use display ip subscriber subnet-leased to display information about IPv4 subnet-leased users.
display ip subscriber subnet-leased [ interface interface-type interface-number ] [ slot slot-number ]
display ip subscriber subnet-leased [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IPv4 subnet-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv4 subnet-leased users for all member devices.
# Display information about the IPv4 subnet-leased user on GigabitEthernet 1/0/1.
<Sysname> display ip subscriber subnet-leased interface gigabitethernet 1/0/1
Basic:
VPN instance : N/A
Username : a
Network : 11.11.11.0/24
User ID : 0x30000001
State : Online
Domain : radius
Login time : May 14 20:08:35 2014
AAA:
IP pool : N/A
QoS:
User profile : cc (active)
Flow statistic:
ITA:
Table 6 Command output
Basic |
Access interface |
VPN instance |
User name |
Network |
Subnet of the user. |
User ID |
State |
Service node |
Domain |
Login time |
AAA |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
QoS information. |
User profile |
Inbound CAR |
Outbound CAR |
Flow statistic |
ITA |
Use display ip subscriber subnet-leased statistics to display IPoE session statistics for IPv4 subnet-leased users.
display ip subscriber subnet-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE session statistics for IPv4 subnet-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPoE session statistics for IPv4 subnet-leased users for all member devices.
# Display IPoE session statistics for IPv4 subnet-leased users on GigabitEthernet 1/0/1.
<Sysname> display ip subscriber subnet-leased statistics interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 7 Command output
Total |
Init |
Authenticating |
Authenticate fail |
Authenticate pass |
Assigned IP |
Online |
Backup |
ip subscriber 8021p
Use ip subscriber 8021p to bind an ISP domain to an 802.1p list for IPv4 unclassified-IP users, static individual users, and leased users.
Use undo ip subscriber 8021p to remove the binding between an ISP domain and an 802.1p list.
ip subscriber 8021p 8021p-list domain domain-name
undo ip subscriber 8021p 8021p-list
No ISP domain is bound to an 802.1p list for IPv4 unclassified-IP users, static individual users, and leased users.
context-admin
8021p-list: Specifies a space-separated list of up to eight 802.1p value items. Each item specifies a 802.1p value or a range of 802.1p values in the form of start-802.1p-value to end-802.1p-value. The 802.1p value is in the range of 0 to 7.
This command configures an ISP domain for IPv4 unclassified-IP users, static individual users, and leased users who send IP packets with the specified 802.1p values.
# Configure ISP domain 1pdm for IPv4 unclassified-IP users, static individual users, and leased users who send IP packets with the specified 802.1p values on GigabitEthernet 1/0/1.100. The specified 802.1p values are in the range of 2 to 5.
[Sysname] interface gigabitethernet 1/0/1.100
[Sysname-GigabitEthernet1/0/1.100] ip subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet1/0/1.100] ip subscriber 8021p 2 to 5 domain 1pdm
Use ip subscriber access-user log enable to enable IPv4 IPoE user logging.
Use undo ip subscriber access-user log enable to disable IPv4 IPoE user logging.
ip subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
undo ip subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
IPv4 IPoE user logging is disabled.
context-admin
successful-login: Specifies login success logs.
failed-login: Specifies login failure logs.
logout: Specifies logout logs.
normal: Specifies normal logout logs.
abnormal: Specifies abnormal logout logs.
IMPORTANT: Typically, disable this feature to prevent excessive IPv4 IPoE log output. |
The IPv4 IPoE user logging feature enables the device to generate IPv4 IPoE logs and send them to the information center. Logs are generated after a user comes online successfully, fails to come online, normally goes offline, or abnormally goes offline. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
When you execute this command without specifying any keyword, this command enables or disables logging for login successes, login failures, normal logouts, and abnormal logouts.
# Enable IPv4 IPoE user logging.
[Sysname] ip subscriber access-user log enable
ip subscriber dhcp domain
Use ip subscriber dhcp domain to configure an ISP domain for DHCPv4 users.
Use undo ip subscriber dhcp domain to restore the default.
ip subscriber dhcp domain domain-name
DHCPv4 users use the default system domain.
Layer 3 aggregate interface/subinterface view
Layer 3 Ethernet interface/subinterface view
context-admin
This command configures an ISP domain for DHCPv4 users. The specified ISP domain must exist on the BRAS.
If multiple ISP domains are available for an DHCPv4 user, the ISP domains are used in the following order:
1. Domain specified in Option 60 if the BRAS trusts Option 60 and Option 60 does not include null terminators and non-printable characters.
2. Domain specified by this command.
3. Default system domain.
# Configure ISP domain ipoe for DHCPv4 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp domain ipoe
ip subscriber trust
Use ip subscriber dhcp max-session to configure the maximum number of IPoE sessions for DHCPv4 users on an interface.
Use undo ip subscriber dhcp max-session to restore the default.
ip subscriber dhcp max-session max-number
The maximum number of IPoE sessions for DHCPv4 users on an interface is not configured.
context-admin
max-number: Specifies the maximum number of IPoE sessions for DHCPv4 users. The value range for this argument is 1 to 64000
If IPoE sessions for DHCPv4 users reach the maximum, no more IPoE session can be established for DHCPv4 users.
# Set the maximum number of IPoE sessions to 100 for DHCPv4 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp max-session 100
Use ip subscriber dhcp password option60 to specify a string from Option 60 as the password for DHCPv4 users.
Use undo ip subscriber dhcp password option60 to restore the default.
ip subscriber dhcp password option60 [ offset offset ] [ length length ]
The BRAS does not use the password specified in Option 60 for DHCPv4 users.
context-admin
offset offset: Specifies an offset for the password starting byte, in the range of 1 to 63. If you do not specify this option, the first byte of the option is the starting byte.
length length: Specifies the length of the password string, in the range of 1 to 63. If you do not specify this option, all bytes following the starting byte are used as the password.
Passwords configured by this command are used for authentication, and must be the same as those configured on the AAA server.
A DHCPv4 user can obtain a password in various ways. If multiple passwords are available for an DHCPv4 user, the passwords are used in the following order:
1. Password configured by this command if the BRAS trusts Option 60 and Option 60 does not contain null terminators or non-printable characters.
2. Password configured by using the ip subscriber password command.
3. Default password: vlan.
# Specify the string with an offset of 10 and a length of 20 bytes from Option 60 as the password for DHCPv4 users.
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp password option60 offset 10 length 20
ip subscriber trust
ip subscriber dhcp username
Use ip subscriber dhcp username to configure an authentication user naming convention for DHCPv4 users.
Use undo ip subscriber dhcp username to restore the default.
ip subscriber dhcp username include { circuit-id [ separator separator ] | client-id [ separator separator ] | nas-port-id [ separator separator ] | port [ separator separator ] | remote-id [ separator separator ] | second-vlan [separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [separator separator ] | sysname [separator separator ] | vendor-class [ separator separator ] | vendor-specific [ separator separator ] | vlan [separator separator ] } *
A DHCPv4 user uses its source MAC address as the authentication username.
context-admin
circuit-id: Includes the Option 82 sub-option 1 information in a username.
client-id: Includes the Option 61 information in a username.
nas-port-id: Includes the NAS-Port-ID attribute carried in the authentication request packet in a username.
port: Includes the number of the port that receives the user packets in a username.
remote-id: Includes the Option 82 sub-option 2 information in a username.
second-vlan: Includes the inner VLAN ID in a username.
slot: Includes the number of the slot that receives the user packets in a username.
source-mac: Includes the source MAC address in a username.
address-separator address-separator: Specifies any printable character as the separator for the MAC address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated MAC address (xxxx-xxxx-xxxx). If you do not specify a separator, the username is the non-separated MAC address (xxxxxxxxxxxx). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
subslot: Includes the number of the subslot that receives the user packets in a username.
sysname: Includes the name of the device that receives the user packets in a username.
vendor-class: Includes the Option 60 information in a username.
vendor-specific: Includes the Option 82 sub-option 9 information in a username.
vlan: Includes the outer VLAN ID in a username.
separator separator: Specifies a character for separating an option and the option that follows. Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
Usernames obtained based on the naming convention are used for authentication, authorization, and accounting, and must be the same as those configured on the AAA server.
You can specify one or more keywords in a naming convention. If you use a combination of keywords, a username obtained based on the naming convention includes the specified options in the configuration order.
Options used as the username information cannot include null terminators or non-printable characters.
# Configure information carried in the Client Identifier Option as the authentication usernames for DHCPv4 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp username include client-id
# Configure an authentication user naming convention for DHCPv4 users on GigabitEthernet 1/0/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet1/0/1] ip subscriber dhcp username include sysname separator # slot separator # subslot separator # port separator # vlan
ip subscriber dscp
Use ip subscriber dscp to bind an ISP domain to a DSCP list for IPv4 unclassified-IP users, static individual users, and leased users.
Use undo ip subscriber dscp to remove the binding between an ISP domain and a DSCP list.
ip subscriber dscp dscp-value-list domain domain-name
undo ip subscriber dscp dscp-value-list
No ISP domain is bound to a DSCP list for IPv4 unclassified-IP users, static individual users, and leased users.
context-admin
dscp-value-list: Specifies a space-separated list of up to eight DSCP value items. Each item specifies a DSCP value or a range of DSCP values in the form of start-DSCP-value to end-DSCP-value. The DSCP value is in the range of 0 to 63.
This command configures an ISP domain for IPv4 unclassified-IP users, static individual users, and leased users who send IP packets with the specified DSCP values.
# Configure ISP domain dscpdm for IPv4 unclassified-IP users, static individual users, and leased users who send IP packets with the specified DSCP values on GigabitEthernet 1/0/1. The specified DSCP values are in the range of 1 to 4.
[Sysname-GigabitEthernet1/0/1] ip subscriber service-identify dscp
[Sysname-GigabitEthernet1/0/1] ip subscriber dscp 1 to 4 domain dscpdm
Use ip subscriber enable to enable IPoE and configure an IPoE access mode for IPv4 users.
Use undo ip subscriber enable to disable IPoE for IPv4 users.
ip subscriber { l2-connected | routed } enable
undo ip subscriber { l2-connected | routed } enable
IPoE is disabled for IPv4 users.
context-admin
l2-connected: Specifies the Layer 2 access mode.
routed: Specifies the Layer 3 access mode.
All IPoE configurations take effect on an interface only when IPoE is enabled on the interface.
To change the IPoE access mode on an interface, you must disable IPoE, and then enable IPoE with a new IPoE access mode.
To ensure successful traffic statistics in aggregate interface view, use the service command to specify a service card for traffic statistics. For more information about the service command, see Layer 2—LAN Switching Command Reference.
# Enable IPoE and configure the Layer 2 access mode for IPv4 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber l2-connected enable
service (Layer 2—LAN Switching Command Reference)
Use ip subscriber initiator dhcp enable to enable the DHCPv4 user.
Use undo ip subscriber initiator dhcp enable to disable the DHCPv4 user.
The DHCPv4 user is disabled.
context-admin
If you enable the DHCP user, the first DHCP Discover or the DHCP Request packet initiates the IPoE session. If you disable the DHCP user, DHCP packets cannot initiate IPoE sessions, but existing IPoE sessions for DHCP are not affected.
You can enable the DHCP user and unclassified-IP user on the same interface.
# Enable the DHCPv4 user on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber initiator dhcp enable
Use ip subscriber initiator unclassified-ip enable to enable the IPv4 unclassified-IP user.
Use undo ip subscriber initiator unclassified-ip enable to disable the IPv4 unclassified-IP user.
The IPv4 unclassified-IP user is disabled.
context-admin
If you enable the unclassified-IP user, the first IPv4 packet from a host initiates an IPoE session. If you disable the unclassified-IP user, IPv4 packets cannot initiate IPoE sessions, but existing IPoE sessions for unclassified-IP are not affected.
# Enable the IPv4 unclassified-IP user on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber initiator unclassified-ip enable
Use ip subscriber interface-leased to configure IPv4 interface-leased users.
Use undo ip subscriber interface-leased to restore the default.
ip subscriber interface-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
No IPv4 interface-leased user exists.
context-admin
password ciphertext string: Specifies a ciphertext password, a case-sensitive string of 1 to 117 characters.
password plaintext string: Specifies a plaintext password, a case-sensitive string of 1 to 63 characters. For security purposes, the password specified in plaintext form will be stored in encrypted form.
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). If you do not specify an ISP domain, the default system domain is used. For more information about the default system domain, see Security Configuration Guide.
An IPv4 interface-leased user is a group of IPv4 hosts that rent the same interface and share the same IPoE session. The BRAS authenticates, authorizes, and bills all hosts of the same interface-leased user.
You can configure only one IPv4 interface-leased user on one interface. To change the parameters of an existing IPv4 interface-leased user, use the undo form of the command to delete the user, and then reconfigure it with new parameter settings.
You cannot configure an interface-leased user on an interface configured with individual users or subnet-leased users.
# Configure an IPv4 interface-leased user with a username of intuser and a plaintext password of pw123 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber interface-leased username intuser password plaintext pw123
Use ip subscriber nas-port-id format to configure NAS-Port-ID formats for IPv4 users.
Use undo ip subscriber nas-port-id format to restore the default.
ip subscriber nas-port-id format cn-telecom { version1.0 | version2.0 }
NAS-Port-ID for IPv4 users is encapsulated in the format of version 1.0.
context-admin
version 1.0: Specifies the China Telecom format.
· The version 1.0 encapsulation format varies by interface type.
Table 8 Version 1.0 encapsulation formats
Interface type |
Encapsulation format |
Layer 3 Ethernet interface and Layer 3 aggregate interface |
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=0 |
Layer 3 Ethernet subinterface and Layer 3 aggregate subinterface (single VLAN tag) |
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=vlan_id |
Layer 3 Ethernet subinterface and Layer 3 aggregate subinterface (Dual VLAN tags) |
slot=slot_num;subslot=subslot_num;port=port_num;vlanid=inner-vlan;vlanid2=outer-vlan |
ATM-based virtual Layer 3 Ethernet interface (IPoEoA) |
slot=slot_num;subslot=subslot_num;port=port_num;vpi=vpi;vci=vci |
· Version 1.0 format parameters
Table 9 Version 1.0 format parameter description
Parameter |
slot_num |
Specifies the slot number of the access interface on the BRAS. |
subslot_num |
Specifies the subslot number of the access interface on the BRAS. |
port_num |
Specifies the port number of the access interface on the BRAS. |
vlan_id |
Specifies the ID of the user's VLAN. |
inner-vlan |
Specifies the ID of the inner VLAN. |
outer-vlan |
Specifies the ID of the outer VLAN. |
vpi |
Specifies the VPI of the access interface on the BRAS. |
vci |
Specifies the VCI of the access interface on the BRAS. |
version 2.0: Specifies the format described in YDT 2275-2011 Subscriber Access Loop (Port) Identification in Broadband Access Networks.
· Version 2.0 encapsulation format:
{eth|trunk|atm} NAS_slot/NAS_subslot/NAS_port:svlan.cvlan AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port
· Version 2.0 format parameters:
Table 10 Version 2.0 format parameter description
Parameter |
{eth|trunk|atm} |
Specifies the type of the access interface on the BRAS as Ethernet, trunk, or ATM. |
NAS_slot |
NAS_subslot |
NAS_port |
svlan |
Specifies the ID of the user's SVLAN. |
cvlan |
Specifies the ID of the user's CVLAN. |
AccessNodeIdentifier |
Specifies the identifier of the access node. |
ANI_rack |
Specifies the rack number of the access node. |
ANI_frame |
Specifies the frame number of the access node. |
ANI_slot |
Specifies the slot number of the access node. |
ANI_subslot |
Specifies the subslot number of the access node. |
ANI_port |
Specifies the port number of the access node. |
# Configure version 2.0 as the format for encapsulating NAS-Port-ID on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber nas-port-id format cn-telecom version2.0
ip subscriber trust
Use ip subscriber nas-port-id nasinfo-insert to include NAS information and information obtained from DHCPv4 Option 82 in NAS-Port-ID.
Use undo ip subscriber nas-port-id nasinfo-insert to restore the default.
The BRAS uses information obtained from DHCPv4 Option 82 as NAS-Port-ID.
context-admin
Configure version 2.0 format and the trusted DHCP option before you use this command.
· If DHCP packets contain Option 82 Suboption Circuit-ID, this command includes NAS information and the obtained option information in NAS-Port-ID. Suboption Circuit-ID is not affected.
· If DHCP packets do not contain Option 82 Suboption Circuit-ID, this command includes NAS information in NAS-Port-ID and sets non-NAS parts to zeros in the following format:
NAS_slot/NAS_subslot/NAS_port:svlan.cvlan 0/0/0/0/0/0
# Include NAS information and the obtained Option 82 information in NAS-Port-ID on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber nas-port-id nasinfo-insert
ip subscriber trust
ip subscriber nas-port-type
Use ip subscriber nas-port-type to configure NAS-Port-Type for an IPv4 interface.
Use undo ip subscriber nas-port-type to restore the default.
ip subscriber nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
NAS-Port-Type for an IPv4 interface is Ethernet.
context-admin
802.11: Specifies the port type complying with Wireless-IEEE 802.11. The type ID is 19.
adsl-cap: Specifies the ADSL-CAP port type, including Asymmetric DSL and Carrierless Amplitude Phase Modulation. The type ID is 12.
adsl-dmt: Specifies the ADSL-DMT port type, including Asymmetric DSL and Discrete Multi-Tone. The type ID is 13.
async: Specifies the Async port type with a type ID of 0.
cable: Specifies the Cable port type with a type ID of 17.
ethernet: Specifies the Ethernet port type with a type ID of 15.
g.3-fax: Specifies the G.3 Fax port type with a type ID of 10.
hdlc: Specifies the HDLC port type with a type ID of 7.
idsl: Specifies the IDSL port type with a type ID of 14.
isdn-async-v110: Specifies the ISDN Async V.110 port type with a type ID of 4.
ISDN Async V.110: Specifies the ISDN Async V.120 port type with a type ID of 3.
isdn-sync: Specifies the ISDN Sync port type with a type ID of 2.
piafs: Specifies the port type complying with PIAFS. The type ID is 6.
sdsl: Specifies the SDSL port type with a type ID of 11.
sync: Specifies the Sync port type with a type ID of 1.
virtual: Specifies the Virtual port type with a type ID of 5.
wireless-other: Specifies the Wireless-other port type with a type ID of 18.
x.25: Specifies the X.25 port type with a type ID of 8.
x.75: Specifies the X.75 port type with a type ID of 9.
xdsl: Specifies the XDSL port type with a type ID of 16.
The NAS-Port-Type attribute carries information about the access interface. The BRAS includes the configured NAS-Port-Type in RADIUS requests sent to the RADIUS server.
# Configure the port type as sdsl for IPv4 interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber nas-port-type sdsl
Use ip subscriber password to configure passwords for IPv4 individual users.
Use undo ip subscriber password to restore the default.
ip subscriber password { ciphertext | plaintext } string
The password for IPv4 individual users is vlan.
context-admin
A DHCPv4 user can obtain a password in various ways. For password priority, see "ip subscriber dhcp password option60."
# Configure the plaintext password as 123 for IPv4 individual users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber password plaintext 123
Use ip subscriber service-identify to configure service identifiers for IPv4 unclassified-IP users, static individual users, and leased users.
Use undo ip subscriber service-identify to restore the default.
Layer 3 Ethernet interface view, Layer 3 aggregate interface view, L3VE interface view, VEth interface view:
Layer 3 Ethernet subinterface view, Layer 3 aggregate subinterface view, L3VE subinterface view, VEth subinterface view:
ip subscriber service-identify { 8021p { second-vlan | vlan } | dscp | second-vlan | vlan }
VLAN interface view:
ip subscriber service-identify { 8021p vlan } | dscp | vlan }
No service identifier is configured for IPv4 unclassified-IP users, static individual users, and leased users.
context-admin
8021p second-vlan: Specifies the 802.1p value of the inner VLAN tag in QinQ mode as the service identifier.
8021p vlan: Specifies the 802.1p value of the VLAN tag or the 802.1p value of the outer VLAN tag in QinQ mode as the service identifier.
dscp: Specifies the DSCP value as the service identifier.
second-vlan: Specifies the inner VLAN ID in QinQ mode as the service identifier.
vlan: Specifies the VLAN ID or the outer VLAN ID in QinQ mode as the service identifier.
You must specify an identifier for a service before you bind an ISP domain to the service. Otherwise, the binding does not take effect.
IPv4 unclassified-IP users, static individual users, and leased users whose IP packets containing the specified service identifier will be assigned a service-specific ISP domain.
You can configure only one service identifier on each interface.
# Configure dscp as the service identifier on GigabitEthernet 1/0/1 for IPv4 unclassified-IP users, static individual users, and leased users.
ip subscriber 8021p
ip subscriber dscp
ip subscriber vlan
ip subscriber session static
Use ip subscriber session static to configure IPv4 static IPoE sessions.
Use undo ip subscriber session static to delete IPv4 static IPoE sessions.
ip subscriber session static ip ip-address [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ description string ]
undo ip subscriber session static ip ip-address [ vlan vlan-id [ second-vlan vlan-id ] ]
No IPv4 static IPoE session exists.
context-admin
ip ip-address: Specifies a user IPv4 address.
vlan vlan-id: Specifies an outer VLAN ID of the user packet, in the range of 1 to 4094. This option is available only for subinterfaces.
second-vlan vlan-id: Specifies an inner VLAN ID of the user packet, in the range of 1 to 4094. This option is available only for subinterfaces.
mac mac-address: Specifies a user MAC address in the form of H-H-H.
description string: Specifies the static session description, a case-insensitive string of 1 to 31 characters. If this option is not specified, the static session does not have a description. The description cannot contain the following characters: forward slashes (/), backslashes (\), vertical bars (|), quotation marks ("), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@).
Static IPoE sessions have higher priority than dynamic IPoE sessions. If a user IP or DHCP packet matches a static IPoE session, the static IPoE session overwrites the existing dynamic IPoE session.
When the IP address specified in a static session overlaps with the assignable IP addresses in the DHCP address pool, you must use the dhcp server forbidden-ip or forbidden-ip command to exclude the overlapping IP address in the DHCPv4 address pool from dynamic address allocation. For more information about excluding IP addresses from dynamic allocation, see DHCP configuration in Layer 3—IP Services Configuration Guide.
You can configure multiple static IPoE sessions on an interface. Static IPv4 IPoE sessions include the following types:
· A session with a specified IPv4 address.
· A session with a specified IPv4 address and outer VLAN ID.
· A session with a specified IPv4 address, outer VLAN ID, and inner VLAN ID.
For each session type, configuration fails if the settings are identical to the settings of an existing session.
To change the parameters of an existing IPoE session, use the undo form of the command to delete the session, and then reconfigure it with new parameter settings.
You cannot configure a static IPoE session on an interface configured with dedicated-interface or subnet-leased users.
# Configure an IPv4 static IPoE session with an IP address of 1.1.1.1 and an ISP domain of dm1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber session static ip 1.1.1.1 domain dm1
Use ip subscriber subnet-leased to configure IPv4 subnet-leased users.
Use undo ip subscriber subnet-leased to delete IPv4 subnet-leased users.
ip subscriber subnet-leased ip ip-address { mask | mask-length } username name password { ciphertext | plaintext } string [ domain domain-name ]
undo ip subscriber subnet-leased ip ip-address { mask | mask-length }
No IPv4 subnet-leased user exists.
context-admin
mask: Specifies an IP address mask in dotted decimal notation.
mask-length: Specifies a mask length, an integer in the range of 0 to 32.
password: Specifies a password for authentication.
An IPv4 subnet-leased user is a group of IPv4 hosts that rent the same subnet of an interface and share the same IPoE session. The BRAS authenticates, authorizes, and bills all hosts of the same subnet-leased user.
You can configure only one IPv4 subnet-leased user on each subnet.
You cannot configure a subnet-leased user on an interface configured with individual users or interface-leased users.
# Configure an IPv4 subnet-leased user for subnet 1.1.1.1/24 with a username of netuser and a plaintext password of pw123 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber subnet-leased ip 1.1.1.1 24 username netuser password plaintext pw123
ip subscriber timer quiet
Use ip subscriber timer quiet to configure a quiet timer for IPv4 users.
Use undo ip subscriber timer quiet to restore the default.
ip subscriber timer quiet time
No quite timer is configured for IPv4 users.
context-admin
time: Specifies the quiet timer in the range of 10 to 3600 seconds.
IPoE starts the quiet timer after a user fails authentication. It discards packets from the user during the quiet time. After the quiet timer expires, IPoE performs authentication upon receiving a packet from the user.
# Set the quiet time to 100 seconds for IPv4 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber timer quiet 100
ip subscriber trust
Use ip subscriber trust to configure a trusted option for DHCPv4 users.
Use undo ip subscriber trust to cancel a trusted option.
ip subscriber trust { option60 | option82 }
undo ip subscriber trust { option60 | option82 }
No trusted options are configured for DHCPv4 users.
context-admin
option60: Specifies Option 60 as the trusted option.
option82: Specifies Option 82 as the trusted option.
If the BRAS trusts DHCPv4 Option 60, the following option information is used as the ISP domain:
· All information in Option 60 if the option does not contain invalid characters or the at sign (@).
Invalid characters include the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), and right angle bracket (>).
· Information that follows the last at sign (@) if the option contains at signs (@) and does not contain invalid characters.
If the BRAS does not trust DHCPv4 Option 60, the ISP domains are used in the following order:
1. Domain specified in the ip subscriber dhcp domain command.
2. Default system domain.
If the BRAS trusts DHCPv4 Option 82, it obtains the following information from the option and uses the information to encapsulate RADIUS attributes:
· Obtains the Circuit-ID information and uses it to encapsulate NAS-Port-ID that adopts version 2.0 as the encapsulation format.
· Obtains the Circuit-ID information and uses it to encapsulate DSL_AGENT_CIRCUIT_ID.
· Obtains the Remote-ID information and uses it to encapsulate DSL_AGENT_REMOTE_ID.
If the BRAS does not trust DHCPv4 Option 82, it does not use the Option 82 to encapsulate RADIUS attributes.
# Configure DHCPv4 Option 82 as a trusted option on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber trust option82
Use ip subscriber unclassified-ip domain to configure an ISP domain for IPv4 unclassified-IP users, static individual users, and leased users.
Use undo ip subscriber unclassified-ip domain to restore the default.
ip subscriber unclassified-ip domain domain-name
IPv4 unclassified-IP users, static individual users, and leased users use the default system ISP domain.
context-admin
This command configures an ISP domain for IPv4 unclassified-IP users, static individual users, and leased users. The configured ISP domain must exist on the BRAS.
The BRAS selects an ISP domain for an IPv4 unclassified-IP user, static individual user, or leased user in the following order:
1. Service-specific domain.
# Configure ISP domain ipoe for IPv4 unclassified-IP users, static individual users, and leased users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip domain ipoe
Use ip subscriber unclassified-ip max-session to configure the maximum number of IPoE sessions for IPv4 unclassified-IP users on an interface.
Use undo ip subscriber unclassified-ip max-session to restore the default.
ip subscriber unclassified-ip max-session max-number
The maximum number of IPoE sessions for IPv4 unclassified-IP users on an interface is not configured.
context-admin
max-number: Specifies the maximum number of IPoE sessions for IPv4 unclassified-IP users. The value range for this argument is 1 to 64000.
If IPoE sessions for IPv4 unclassified-IP users reach the maximum, no more IPoE session can be initiated for IPv4 unclassified-IP users.
# Set the maximum number of IPoE sessions to 100 for IPv4 unclassified-IP users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip max-session 100
Use ip subscriber unclassified-ip username to configure an authentication user naming convention for IPv4 unclassified-IP users and static individual users.
Use undo ip subscriber unclassified-ip username to restore the default.
ip subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
An IPv4 unclassified-IP user or static individual user uses its source IPv4 address as the authentication username.
context-admin
nas-port-id: Includes the NAS-Port-ID attribute in a username.
source-ip: Includes the source IP address in a username.
address-separator address-separator: Specifies any printable character as the separator for the IPv4 address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated IP address (xxxx-xxxx-xxxx). If you do not specify a separator, the username is the dot-separated IP address (x.x.x.x). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
Usernames obtained based on the naming convention are used for authentication and must be the same as those configured on the AAA server.
# Configure the source IPv4 address as the authentication usernames for IPv4 unclassified-IP users and static individual users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip username include source-ip
# Configure an authentication user naming convention for IPv4 unclassified-IP users and static individual users on GigabitEthernet 1/0/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet1/0/1] ip subscriber unclassified-ip username include sysname separator # slot separator # subslot separator # port separator # vlan
ip subscriber user-detect
Use ip subscriber user-detect to configure online detection for IPv4 individual users.
Use undo ip subscriber user-detect to restore the default.
ip subscriber user-detect { arp | icmp } retry retries interval interval
Online detection for IPv4 individual users is disabled.
context-admin
arp: Specifies the ARP request packet as detection packets.
icmp: Specifies the ICMP request packet as detection packets.
retry retries: Specifies the maximum number of detection attempts following the first detection attempt, in the range of 2 to 5.
interval interval: Configures the detection timer for each attempt, in the range of 30 to 1200 seconds.
Online detection enables the BRAS to periodically detect the status of an IPv4 individual user. It uses ARP and ICMP requests to detect IPv4 individual users. If IPv4 individual users and the interface are in different subnets, only ICMP request packets can be used for detection.
After you configure online detection, the BRAS starts a detection timer to detect online users. If the BRAS does not receive user packets before the detection timer expires, it sends a detection packet to the user.
· If the BRAS receives user packets within the maximum detection attempts, the BRAS assumes that the user is online. It resets the detection timer, and starts the next detection attempt.
· If the BRAS does not receive user packets after detection attempts reach the maximum, the BRAS assumes that the user is offline and deletes the user session.
# Configure online detection on GigabitEthernet 1/0/1. The maximum number of detection attempts is 5, the detection timer is 100 seconds, and the detection packet type is ARP.
[Sysname-GigabitEthernet1/0/1] ip subscriber user-detect arp retry 5 interval 100
ip subscriber vlan
Use ip subscriber vlan to bind an ISP domain to a VLAN list for IPv4 unclassified-IP users, static individual users, and leased users.
Use undo ip subscriber vlan to remove the binding between an ISP domain and a VLAN list.
ip subscriber vlan vlan-list domain domain-name
undo ip subscriber vlan vlan-list
No ISP domain is bound to a VLAN list for IPv4 unclassified-IP users, static individual users, and leased users.
context-admin
vlan-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-VLAN-ID to end-VLAN-ID. The VLAN ID is in the range of 1 to 4094.
This command configures an ISP domain for IPv4 unclassified-IP users, static individual users, and leased users who send IP packets with the specified VLAN IDs.
# Configure an ISP domain for IPv4 unclassified-IP users, static individual users, and leased users who send IP packets with the specified VLAN IDs on GigabitEthernet 1/0/1.100. The specified VLAN IDs are in the range of 2 to 100.
[Sysname-GigabitEthernet1/0/1.100] ip subscriber service-identify second-vlan
[Sysname-GigabitEthernet1/0/1.100] ip subscriber vlan 2 to 100 domain vlandm
Use ip subscriber whitelist enable to enable the IPv4 IPoE whitelist feature.
Use undo ip subscriber whitelist enable to disable the IPv4 IPoE whitelist feature.
The IPv4 IPoE whitelist feature is disabled.
context-admin
With this feature enabled, only IPv4 traffic matching static IPv4 IPoE sessions can initiate IPoE authentication, and IPoE directly permits the other traffic without any processing.
In some scenarios, an interface might need to have both IPoE and portal authentication enabled. For example, both dumb terminals and broadband dial-up users exist on an interface. Dumb terminals (for example, monitoring cameras) need to come online through IPoE without portal authentication, and broadband dial-up users need to come online through portal Web authentication. In this case, you can enable the IPv4 IPoE whitelist feature on the interface. When both the IPv4 IPoE whitelist feature and portal authentication are enabled on an interface, the following rules apply:
· If the IPv4 traffic of a user matches a static IPv4 IPoE session, the user is processed by the static IPv4 IPoE authentication flow. For an IPoE user to bypass authentication, specify the authentication and authorization modes as none in the ISP domain of the IPoE user.
· If the IPv4 traffic of a user does not match any IPv4 IPoE session, the user is processed by portal authentication.
# Enable the IPv4 IPoE whitelist feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip subscriber whitelist enable
Use reset ip subscriber offline statistics to remove offline statistics for IPv4 users.
reset ip subscriber offline statistics [ interface interface-type interface-number ]
context-admin
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command removes offline statistics for IPv4 users for all interfaces.
# Remove offline statistics for all IPv4 users on GigabitEthernet 1/0/1.
<Sysname> reset ip subscriber offline statistics interface gigabitethernet 1/0/1
Use reset ip subscriber session to delete dynamic IPv4 IPoE sessions and log out the users.
reset ip subscriber session [ interface interface-type interface-number ] [ domain domain-name | ip ip-address [ vpn-instance vpn-instance-name ] | mac mac-address | username name ]
context-admin
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command deletes dynamic IPv4 IPoE sessions for all interfaces.
ip ip-address: Specifies the IP address of the IPoE session to be deleted.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command deletes IPv4 IPoE sessions on the public network.
mac mac-address: Specifies the MAC address of an IPv4 IPoE session to be deleted, in the format of H-H-H.
username name: Specifies the username of the IPv4 IPoE session to be deleted, a case-sensitive string of 1 to 255 characters.
If you do not specify any parameters, this command deletes all dynamic IPv4 IPoE sessions.
To delete static IPoE sessions for static users and leased users, use the undo commands.
# Delete dynamic IPv4 IPoE sessions and log out the users on GigabitEthernet 1/0/1.
<Sysname> reset ip subscriber session interface gigabitethernet 1/0/1
IPv6 IPoE commands
display ipv6 subscriber interface-leased
Use display ipv6 subscriber interface-leased to display information about IPv6 interface-leased users.
display ipv6 subscriber interface-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IPv6 interface-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv6 interface-leased users for all member devices.
# Display information about the IPv6 interface-leased user on GigabitEthernet 1/0/1.
<Sysname> display ipv6 subscriber interface-leased interface gigabitethernet 1/0/1
Basic:
Access interface : GE1/0/1
VPN instance : N/A
Username : a
User ID : 0x40000000
State : Online
Service node : Slot 1 CPU 0
Domain : radius6
Login time : May 14 20:20:11 2014
Online time (hh:mm:ss) : 00:16:37
AAA:
IP pool : ipoe
Session idle time : N/A
Session duration : N/A, remaining: N/A
Remaining traffic : N/A
Max multicast addresses : 4
Multicast address list : N/A
QoS:
User profile : h3c6 (active)
Session group profile : N/A
Inbound CAR : CIR 1000bps PIR 2000bps CBS 500bit (active)
Outbound CAR : CIR 3000bps PIR 4000bps CBS 500bit (active)
Flow statistic:
Uplink packets/bytes : 0/0
Downlink packets/bytes : 0/0
ITA:
Level-1 Uplink packets/bytes: 0/0
Downlink packets/bytes: 0/0
Level-2 Uplink packets/bytes: 0/0
Table 11 Command output
Basic |
Basic session information. |
Access interface |
Interface that connects the user. |
VPN instance |
MPLS L3VPN instance of the user. If the user is not in a VPN, this field displays N/A. |
Username |
Username for authentication. |
User ID |
User ID assigned after the user came online. If no user ID is assigned, this field displays 0xffffffff. |
State |
User state: · Init—The user is being initiated. · Offline—The user is going offline. · Auth—The user is being authenticated. · AuthFail—The user failed authentication. · AuthPass—The user passed authentication. · AssignedIP—The user has an IP address. · Online—The user is online. · Backup—Backup information about the user on the primary BRAS. |
Service node |
Slot number and CPU number of the card that connects the user. |
Domain |
ISP domain. |
Login time |
Time when the user passed authentication and logged in, in the format of MM-DD hh:mm:ss YYYY. |
Online time (hh:mm:ss) |
Online duration for the user. |
AAA |
AAA authorization information. |
IP pool |
AAA-authorized DHCP address pool. If no DHCP address pool is authorized, this field displays N/A. |
Session idle time |
Idle time in seconds specified for online users. If the idle time expires, the user is logged out. If no idle time is specified, this field displays N/A and the user can remain idle without being logged out. |
Session duration |
AAA-authorized IPoE session duration in seconds: · N/A—No IPoE session duration is authorized. · Unlimited—The IPoE session duration is unlimited. |
remaining |
Remaining AAA-authorized IPoE session duration. If no session duration is authorized, this field displays N/A. ¡ For users on Layer 3 Ethernet interfaces and subinterfaces, this field displays the remaining time or Unlimited. ¡ For users on Layer 3 aggregate interfaces and subinterfaces, this field displays the remaining time or Unlimited only when the slot or interface is specified. If you do not specify the slot or interface, this field displays N/A. |
Remaining traffic |
Remaining AAA-authorized traffic in bytes. If no traffic is authorized, this field displays N/A. |
Max multicast addresses |
Maximum number of AAA-authorized multicast groups that a user can join. |
Multicast address list |
List of AAA-authorized multicast group addresses. If no multicast group is authorized, this field displays N/A. |
QoS |
QoS information. |
User profile |
AAA-authorized user profile: · N/A—No user profile is authorized. · inactive—User profile authorization failed or the user profile does not exist on the BRAS. · active—The user profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
Session group profile |
AAA-authorized session group profile: · N/A—No session group profile is authorized. · inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS. · active—The session group profile is authorized successfully. If the authorization result has not been updated, nothing is displayed. |
Inbound CAR |
Inbound CIR and PIR in bps and CBS in bits: · N/A—Inbound CAR is not authorized. · inactive—Inbound CAR is not authorized successfully. · active—Inbound CAR is authorized successfully. |
Outbound CAR |
Outbound CIR and PIR in bps and CBS in bits: · N/A—Outbound CAR is not authorized. · inactive—Outbound CAR is not authorized successfully. · active—Outbound CAR is authorized successfully. |
Flow statistic |
Session flow statistics. |
Total number and size of uplink packets. |
Downlink packets/bytes |
Total number and size of downlink packets. |
ITA |
Intelligent target accounting (ITA) information. |
Level-n Uplink packets/bytes |
Number and size of uplink packets for level n accounting (1 ≤ n ≤ 8). |
Number and size of downlink packets for level n accounting (1 ≤ n ≤ 8). |
ipv6 subscriber enable
display ipv6 subscriber interface-leased statistics
Use display ipv6 subscriber interface-leased statistics to display IPoE session statistics for IPv6 interface-leased users.
display ipv6 subscriber interface-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE session statistics for IPv6 interface-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPoE session statistics for IPv6 interface-leased users for all member devices.
# Display IPoE session statistics for IPv6 interface-leased users on the BRAS.
<Sysname> display ipv6 subscriber interface-leased statistics
Total : 100
Init : 0
Authenticating : 20
Authenticate fail : 0
Authenticate pass : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 12 Command output
Total |
Init |
Number of users who initiated sessions. |
Authenticating |
Number of users being authenticated. |
Authenticate fail |
Number of users who failed authentication. |
Authenticate pass |
Number of users who passed authentication. |
Assigned IP |
Number of users who have IP addresses. |
Online |
Number of online users. |
Backup |
Number of users whose information was backed up. |
display ipv6 subscriber offline statistics
Use display ipv6 subscriber offline statistics to display offline statistics for IPv6 users.
display ipv6 subscriber offline statistics [ interface interface-type interface-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays offline statistics for IPv6 users for all interfaces.
# Display offline statistics for IPv6 users on GigabitEthernet 1/0/1.
<Sysname> display ipv6 subscriber offline statistics interface gigabitethernet 1/0/1
Total : 100
User request : 0
DHCP lease expire : 0
AAA lease expire : 0
Command cut : 80
AAA terminate : 0
Authorization fail : 0
Idle timeout : 10
Detect fail : 10
Not enough resource : 0
Interface down : 0
Interface shutdown : 0
VSRP event : 0
DHCP notify : 0
Other : 0
Table 13 Command output
Total |
Total number of offline users. |
User request |
Number of users requesting to go offline. |
DHCP lease expired |
Number of users with expired DHCP leases. |
AAA lease expired |
Number of users with expired AAA leases. |
Command cut |
Number of users logged out by commands. |
AAA terminate |
Number of users logged out by AAA. |
Authenticate fail |
Authorization fail |
Number of users who failed authorization. |
Idle timeout |
Number of users with an expired idle timeout timer. |
Detect fail |
Number of users who failed online detection. |
Not enough resource |
Number of users with insufficient hardware resources. |
Interface down |
Number of users on an interface that went down. |
Interface shutdown |
Number of users on an interface that was shut down. |
VSRP event |
Number of users disconnected as requested by the VSRP event. |
DHCP notify |
Number of users disconnected by DHCP. |
Other |
Number of users disconnected from the network because of unknown causes. |
reset ipv6 subscriber offline statistics
display ipv6 subscriber session
Use display ipv6 subscriber session to display session information for IPv6 individual users.
display ipv6 subscriber session [ interface interface-type interface-number ] [ domain domain-name | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] | mac mac-address | static | username name ] [ slot slot-number ] [ verbose ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays session information for IPv6 individual users for all interfaces.
ip ip-address: Specifies the source IP address of the IPv6 individual user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays session information for IPv6 individual users on the public network.
mac mac-address: Specifies the MAC address of an IPv6 individual user, in the format of H-H-H.
static: Specifies static IPoE sessions. If this parameter is not specified, this command displays information about static and dynamic sessions for IPv6 individual users.
username name: Specifies the username of the IPv6 individual user, a case-sensitive string of 1 to 255 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays session information for IPv6 individual users for all member devices.
verbose: Displays detailed session information for IPv6 individual users. If this parameter is not specified, this command displays general session information.
# Display general session information for the IPv6 individual user with an IP address of 2000::1 in vpn1.
<Sysname> display ipv6 subscriber session ipv6 2000::1 vpn-instance vpn1
Type: D-DHCP S-Static U-Unclassified-IP N-NDRS
Interface IP address MAC address Type State
RAGG1024 2000::1 000d-88f8-0eab D Online
# Displays detailed session information for IPv6 individual users.
<Sysname> display ipv6 subscriber session verbose
Basic:
Description : -
Username : abc
Domain : radius6
VPN instance : N/A
IP address : 2000::1
MAC address : 000d-88f8-0eab
Service-VLAN/Customer-VLAN : -/-
User ID : 0x48080008
VPI/VCI(for ATM) : -/-
DHCP lease : N/A
DHCP remain lease : N/A
Login time : May 9 09:10:01 2014
Type : Unclassified-IP
State : Online
AAA:
IP pool : N/A
QoS:
Flow statistic:
ITA:
Figure 1 Command output
Basic |
Username |
Domain |
VPN instance |
IP address |
MAC address |
Access interface |
User ID |
VPI/VCI(for ATM) |
DHCP lease |
DHCP remain lease |
Login time |
Service node |
Type |
IPoE session types: · DHCP—Dynamic IPoE sessions for DHCP users. · Unclassified-IP—Dynamic IPoE sessions for unclassified-IP users. · Static—Static sessions. · NDRS—Dynamic sessions for IPv6-ND-RS users. |
State |
AAA |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
QoS information. |
User profile |
Inbound CAR |
Outbound CAR |
Flow statistic |
ITA |
display ipv6 subscriber session statistics
Use display ipv6 subscriber session statistics to display IPoE session statistics for IPv6 individual users.
display ipv6 subscriber session statistics [ session-type { dhcp | ndrs | static | unclassified-ip } ] [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
session-type: Specifies a user type. If you do not specify a user type, this command displays IPoE session statistics for all types of IPv6 individual users.
ndrs: Specifies IPv6-ND-RS users.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE session statistics for IPv6 individual users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPoE session statistics for IPv6 individual users for all member devices.
# Display IPoE session statistics for IPv6 individual users on GigabitEthernet 1/0/1.
<Sysname> display ipv6 subscriber session statistics session-type dhcp interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 14 Command output
Total |
Init |
Authenticating |
Authenticate fail |
Authenticate pass |
Assigned IP |
Online |
Backup |
reset ipv6 subscriber session
display ipv6 subscriber subnet-leased
Use display ipv6 subscriber subnet-leased to display information about IPv6 subnet-leased users.
display ipv6 subscriber subnet-leased [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IPv6 subnet-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv6 subnet-leased users for all member devices.
# Display information about the IPv6 subnet-leased user on GigabitEthernet 1/0/1.
<Sysname> display ipv6 subscriber subnet-leased interface gigabitethernet 1/0/1
Basic:
VPN instance : N/A
Username : a
Network : 99::/64
User ID : 0x40000001
State : Online
Domain : radius6
Login time : May 14 20:22:14 2014
AAA:
IP pool : N/A
QoS:
Flow statistic:
ITA:
Table 15 Command output
Basic |
Access interface |
VPN instance |
User name |
Network |
User ID |
User ID assigned after the user came online. If no user ID is assigned, this field displays N/A. |
State |
Service node |
Domain |
ISP domain of the user. |
Login time |
AAA |
IP pool |
Session idle time |
Session duration |
remaining |
Remaining traffic |
QoS |
QoS information. |
User profile |
Inbound CAR |
Outbound CAR |
Flow statistic |
ITA |
display ipv6 subscriber subnet-leased statistics
Use display ipv6 subscriber subnet-leased statistics to display IPoE session statistics for IPv6 subnet-leased users.
display ipv6 subscriber subnet-leased statistics [ interface interface-type interface-number ] [ slot slot-number ]
context-admin
context-operator
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPoE session statistics for IPv6 subnet-leased users for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPoE session statistics for IPv6 subnet-leased users for all member devices.
# Display IPoE session statistics for IPv6 subnet-leased users on GigabitEthernet 1/0/1.
<Sysname> display ipv6 subscriber subnet-leased statistics interface gigabitethernet 1/0/1
Total : 100
Init : 0
Authenticating : 20
Assigned IP : 10
Online : 50
Backup : 0
Table 16 Command output
Total |
Total number of users on the interface. |
Init |
Authenticating |
Authenticate fail |
Authenticate pass |
Assigned IP |
Online |
Backup |
ipv6 subscriber 8021p
Use ipv6 subscriber 8021p to bind an ISP domain to an 802.1p list for IPv6 unclassified-IP users, static individual users, and leased users.
Use undo ipv6 subscriber 8021p to remove the binding between an ISP domain and an 802.1p list.
ipv6 subscriber 8021p 8021p-list domain domain-name
undo ipv6 subscriber 8021p 8021p-list
No ISP domain is bound to an 802.1p list for IPv6 unclassified-IP users, static individual users, and leased users.
context-admin
This command configures an ISP domain for IPv6 unclassified-IP users, static individual users, and leased users who send IP packets with the specified 802.1p values.
# Configure ISP domain 1pdm for IPv6 unclassified-IP users, static individual users, and leased users who send IP packets with the specified 802.1p values on GigabitEthernet 1/0/1.100. The specified 802.1p values are in the range of 2 to 5.
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber service-identify 8021p second-vlan
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber 8021p 2 to 5 domain 1pdm
ipv6 subscriber access-user log enable
Use ipv6 subscriber access-user log enable to enable IPv6 IPoE user logging.
Use undo ipv6 subscriber access-user log enable to disable IPv6 IPoE user logging.
ipv6 subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
undo ipv6 subscriber access-user log enable [ successful-login | failed-login | logout [ normal ] [ abnormal ] ] *
IPv6 IPoE user logging is disabled.
context-admin
IMPORTANT: Typically, disable this feature to prevent excessive IPoE log output. |
The IPv6 IPoE user logging feature enables the device to generate IPv6 IPoE logs and send them to the information center. Logs are generated after a user comes online successfully, fails to come online, normally goes offline, or abnormally goes offline. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
# Enable IPv6 IPoE user logging.
ipv6 subscriber dhcp domain
Use ipv6 subscriber dhcp domain to configure an ISP domain for DHCPv6 users.
Use undo ipv6 subscriber dhcp domain to restore the default.
ipv6 subscriber dhcp domain domain-name
DHCPv6 users use the default system domain.
context-admin
This command specifies an ISP domain for DHCPv6 users. The specified ISP domain must exist on the BRAS.
If multiple ISP domains are available for an DHCPv6 user, the ISP domains are used in the following order:
1. Domain specified in Option 16 if the BRAS trusts Option 16 and Option 16 does not include null terminators and non-printable characters.
# Configure ISP domain ipoe for DHCPv6 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp domain ipoe
ipv6 subscriber dhcp username
ipv6 subscriber initiator dhcp enable
ipv6 subscriber trust
ipv6 subscriber dhcp max-session
Use ipv6 subscriber dhcp max-session to configure the maximum number of IPoE sessions for DHCPv6 users on an interface.
ipv6 subscriber dhcp max-session max-number
undo ipv6 subscriber dhcp max-session
The maximum number of IPoE sessions for DHCPv6 users on an interface is not configured.
context-admin
max-number: Specifies the maximum number of IPoE sessions for DHCPv6 users. The value range for this argument is 1 to 64000.
If IPoE sessions for DHCPv6 users reach the maximum, no more IPoE session can be established for DHCPv6 users.
# Set the maximum number of IPoE sessions to 100 for DHCPv6 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp max-session 100
ipv6 subscriber dhcp password option16
Use ipv6 subscriber dhcp password option16 to specify a string from Option 16 as the password for DHCPv6 users.
Use undo ipv6 subscriber dhcp password option16 to restore the default.
ipv6 subscriber dhcp password option16 [ offset offset ] [ length length ]
The BRAS does not use the password specified in Option 16 for DHCPv6 users.
Layer 3 aggregate interface/subinterface view
Layer 3 Ethernet interface/subinterface view
context-admin
Passwords configured by using this command are used for authentication, and must be the same as those configured on the AAA server.
A DHCPv6 user can obtain a password in various ways. If multiple passwords are available for an DHCPv6 user, the passwords are used in the following order:
1. Password configured by using this command if the BRAS trusts Option 16 and Option 16 does not contain null terminators or non-printable characters.
2. Password configured by using the ipv6 subscriber password command.
# Specify the string with an offset of 10 and a length of 20 bytes from Option 16 as the password for DHCPv6 users.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp password option16 offset 10 length 20
Use ipv6 subscriber dhcp username to configure an authentication user naming convention for DHCPv6 users.
Use undo ipv6 subscriber dhcp username to restore the default.
ipv6 subscriber dhcp username include { circuit-id [ separator separator ] | client-id [ separator separator ] | nas-port-id [ separator separator ] | port [ separator separator ] | remote-id [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vendor-class [ separator separator ] | vendor-specific [ separator separator ] | vlan [ separator separator ] } *
A DHCPv6 user uses its source MAC address as the authentication username.
context-admin
circuit-id: Includes the Option 18 information in a username.
client-id: Includes the Option 1 information in a username.
remote-id: Includes the Option 37 information in a username.
vendor-class: Includes the Option 16 information in a username.
vendor-specific: Includes the Option 17 information in a username.
# Configure information carried in the client-id option as the authentication usernames for DHCPv6 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp username include client-id
# Configure an authentication user naming convention for DHCPv6 users on GigabitEthernet 1/0/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dhcp username include sysname separator # slot separator # subslot separator # port separator # vlan
ipv6 subscriber dscp
Use ipv6 subscriber dscp to bind an ISP domain to a DSCP list for IPv6 unclassified-IP users, static individual users, and leased users.
Use undo ipv6 subscriber dscp to remove the binding between an ISP domain and a DSCP list.
ipv6 subscriber dscp dscp-value-list domain domain-name
undo ipv6 subscriber dscp dscp-value-list
No ISP domain is bound to a DSCP list for IPv6 unclassified-IP users, static individual users, and leased users.
context-admin
This command configures an ISP domain for IPv6 unclassified-IP users, static individual users, and leased users who send IP packets with the specified DSCP values.
# Configure ISP domain dscpdm for IPv6 unclassified-IP users, static individual users, and leased users who send IP packets with the specified DSCP values on GigabitEthernet 1/0/1. The specified DSCP values are in the range of 1 to 4.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber service-identify dscp
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber dscp 1 to 4 domain dscpdm
Use ipv6 subscriber enable to enable IPoE and configure an IPoE access mode for IPv6 users.
Use undo ipv6 subscriber enable to disable IPoE.
ipv6 subscriber { l2-connected | routed } enable
undo ipv6 subscriber { l2-connected | routed } enable
IPoE is disabled for IPv6 users.
context-admin
# Enable IPoE and configure the Layer 2 access mode for IPv6 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber l2-connected enable
Use ipv6 subscriber initiator dhcp enable to enable the DHCPv6 user.
Use undo ipv6 subscriber initiator dhcp enable to disable the DHCPv6 user.
The DHCPv6 user is disabled.
context-admin
If you enable the DHCP user, the first DHCP Solicitor or the DHCP Request packet initiates the IPoE session. If you disable the DHCP user, DHCP packets cannot initiate IPoE sessions, but existing IPoE sessions for DHCPv6 are not affected.
You can enable the DHCP user, IPv6-ND-RS user, and unclassified-IP user on the same interface.
# Enable the DHCPv6 user on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber initiator dhcp enable
ipv6 subscriber initiator ndrs enable
ipv6 subscriber initiator unclassified-ip enable
Use ipv6 subscriber initiator ndrs enable to enable the IPv6-ND-RS user.
Use undo ipv6 subscriber initiator ndrs enable to disable the IPv6-ND-RS user.
The IPv6-ND-RS user is disabled.
context-admin
If you enable the IPV6-ND-RS user, the first IPv6 ND RS packet initiates the IPoE session. If you disable the IPV6-ND-RS user, IPv6 ND RS packets cannot initiate IPoE sessions, but existing IPoE sessions for IPv6-ND-RS are not affected.
# Enable the IPv6-ND-RS user on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber initiator ndrs enable
Use ipv6 subscriber initiator unclassified-ip enable to enable the IPv6 unclassified-IP user.
Use undo ipv6 subscriber initiator unclassified-ip enable to disable the IPv6 unclassified-IP user.
The IPv6 unclassified-IP user is disabled.
context-admin
If you enable the unclassified-IP user, the first IPv6 packet from a host initiates an IPoE session. If you disable the unclassified-IP user, IPv6 packets cannot initiate IPoE sessions, but existing IPoE sessions for IPv6 unclassified-IP are not affected.
# Enable the IPv6 unclassified-IP user on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber initiator unclassified-ip enable
Use ipv6 subscriber interface-leased to configure IPv6 interface-leased users.
Use undo ipv6 subscriber interface-leased to restore the default.
ipv6 subscriber interface-leased username name password { ciphertext | plaintext } string [ domain domain-name ]
No IPv6 interface-leased user exists.
context-admin
username name: Specifies a username for authentication, a case-sensitive string of 1 to 255 characters.
An IPv6 interface-leased user is a group of IPv6 hosts that rent the same interface and share the same IPoE session. The BRAS authenticates, authorizes, and bills all hosts of the same interface-leased user.
You can configure only one IPv6 interface-leased user on each interface. To change the parameters of an existing IPv6 interface-leased user, use the undo form of the command to delete the user, and then reconfigure it with new parameter settings.
# Configure an IPv6 interface-leased user with a username of intuser and a plaintext password of pw123 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber interface-leased username intuser password plaintext pw123
ipv6 subscriber nas-port-id format
Use ipv6 subscriber nas-port-id format to configure NAS-Port-ID formats for IPv6 users.
Use undo ipv6 subscriber nas-port-id format to restore the default.
ipv6 subscriber nas-port-id format cn-telecom { version1.0 | version2.0 }
NAS-Port-ID for IPv6 users is encapsulated in the format of version 1.0.
context-admin
Table 17 Version 1.0 encapsulation formats
Interface type |
Table 18 Version 1.0 format parameter description
Parameter |
slot_num |
subslot_num |
port_num |
vlan_id |
inner-vlan |
outer-vlan |
vpi |
vci |
Table 19 Version 2.0 format parameter description
Parameter |
{eth|trunk|atm} |
NAS_slot |
NAS_subslot |
NAS_port |
svlan |
cvlan |
ANI_rack |
ANI_frame |
ANI_slot |
ANI_subslot |
ANI_port |
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber nas-port-id format cn-telecom version2.0
ipv6 subscriber nas-port-id nasinfo-insert
Use ipv6 subscriber nas-port-id nasinfo-insert to include NAS information and information obtained from DHCPv6 Option 18 in NAS-Port-ID.
Use undo ipv6 subscriber nas-port-id nasinfo-insert to restore the default.
The BRAS uses information obtained from DHCPv6 Option 18 as NAS-Port-ID.
context-admin
· If DHCP packets contain Option 18, this command includes NAS information and the obtained option information in NAS-Port-ID. Option 18 is not affected.
· If DHCP packets do not contain Option 18, this command includes NAS information in NAS-Port-ID and sets non-NAS parts to zeros in the following format:
# Include NAS information and the obtained Option 18 information in NAS-Port-ID on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber trust option18
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber nas-port-id nasinfo-insert
ipv6 subscriber nas-port-type
Use ipv6 subscriber nas-port-type to configure NAS-Port-Type for an IPv6 interface.
Use undo ipv6 subscriber nas-port-type to restore the default.
ipv6 subscriber nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
NAS-Port-Type for an IPv6 interface is Ethernet.
context-admin
# Configure the port type as sdsl for IPv6 interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber nas-port-type sdsl
ipv6 subscriber ndrs domain
Use ipv6 subscriber ndrs domain to configure an ISP domain for IPv6-ND-RS users.
Use undo ipv6 subscriber ndrs domain to restore the default.
ipv6 subscriber ndrs domain domain-name
IPv6-ND-RS users use the default system ISP domain.
context-admin
This command specifies an ISP domain for IPv6-ND-RS users. The specified ISP domain must exist on the BRAS.
If you do not use this command to configure the ISP domain, the default system domain is used.
# Configure ISP domain ipoe for IPv6-ND-RS users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs domain ipoe
ipv6 subscriber ndrs max-session
Use ipv6 subscriber ndrs max-session to configure the maximum number of IPoE sessions for IPv6-ND-RS users on an interface.
Use undo ipv6 subscriber ndrs max-session to restore the default.
ipv6 subscriber ndrs max-session max-number
The maximum number of IPoE sessions for IPv6-ND-RS users on an interface is not configured.
context-admin
max-number: Specifies the maximum number of IPoE sessions for IPv6-ND-RS users. The value range for this argument is 1 to 64000.
If IPoE sessions for IPv6-ND-RS user reach the maximum, no more IPoE session can be initiated IPv6 ND RS packets.
# Set the maximum number of IPoE sessions to 100 for IPv6-ND-RS users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs max-session 100
ipv6 subscriber ndrs username
Use ipv6 subscriber ndrs username to configure an authentication user naming convention for IPv6-ND-RS users.
Use undo ipv6 subscriber ndrs username to restore the default.
ipv6 subscriber ndrs username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
An IPv6-ND-RS user uses its source MAC address as the authentication username.
context-admin
port: Includes the number of the port that receives the user packets in a username.
second-vlan: Includes the inner VLAN ID in a username.
slot: Includes the number of the slot that receives the user packets in a username.
source-mac: Includes the source MAC address in a username.
separator separator: Specifies any printable character as the separator for the MAC address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated MAC address (xxxx-xxxx-xxxx). If you do not specify a separator, the username is the non-separated MAC address (xxxxxxxxxxxx). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
subslot: Includes the number of the subslot that receives the user packets in a username.
sysname: Includes the name of the device that receives the user packets in a username.
vlan: Includes the outer VLAN ID in a username.
separator separator: Specifies a character for separating an option and the option that follows. Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
You can specify one or more keywords in a naming convention. If you use a combination of keywords, a username obtained based on the naming convention includes the specified options in the configuration order.
# Configure the source MAC addresses as the authentication usernames for IPv6-ND-RS users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs username include source-mac
# Configure an authentication user naming convention for IPv6-ND-RS users on GigabitEthernet 1/0/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber ndrs username include sysname separator # slot separator # subslot separator # port separator # vlan
Use ipv6 subscriber password to configure passwords for IPv6 individual users.
Use undo ipv6 subscriber password to restore the default.
ipv6 subscriber password { ciphertext | plaintext } string
The password for IPv6 individual users is vlan.
context-admin
Passwords configured by this command are used for authentication, and must be the same as those configured on the AAA server.
A DHCPv6 user can obtain a password in various ways. For password priority, see "ipv6 subscriber dhcp password option16."
ciphertext string: Specifies a ciphertext password, a case-sensitive string of 1 to 117 characters.
plaintext string: Specifies a plaintext password, a case-sensitive string of 1 to 63 characters. For security purposes, the password specified in plaintext form will be stored in encrypted form.
# Configure the plaintext password as 123 for IPv6 individual users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber password plaintext 123
ipv6 subscriber unclassified-ip username
Use ip subscriber service-identify to configure service identifier for IPv6 unclassified-IP users, static individual users, and leased users.
Use undo ipv6 subscriber service-identify to restore the default.
ipv6 subscriber service-identify { 8021p { second-vlan | vlan } | dscp | second-vlan | vlan }
ipv6 subscriber service-identify { 8021p vlan } | dscp | vlan }
No service identifier is configured for IPv6 unclassified-IP users, static individual users, and leased users.
context-admin
IPv6 unclassified-IP users, static individual users, and leased users whose IP packets containing the specified service identifier will be assigned a service-specific ISP domain.
# Configure dscp as the service identifier on GigabitEthernet 1/0/1 for IPv6 unclassified-IP users, static individual users, and leased users.
ipv6 subscriber vlan
ipv6 subscriber session static
Use ipv6 subscriber session static to configure IPv6 static IPoE sessions.
Use undo ipv6 subscriber session static to delete IPv6 static IPoE sessions.
ipv6 subscriber session static ipv6 ipv6-address [ vlan vlan-id [ second-vlan vlan-id ] ] [ mac mac-address ] [ domain domain-name ] [ description string ]
undo ipv6 subscriber session static ipv6 ipv6-address [ vlan vlan-id [ second-vlan vlan-id ] ]
No IPv6 static IPoE session exists.
context-admin
ip ip-address: Specifies a user IPv6 address.
domain domain-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain the slash (/), back slash (\), vertical bar (|), quotation mark ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@). If you do not specify an ISP domain, the default system domain is used. For more information about the default system domain, see Security Configuration Guide.
Static IPoE sessions have higher priority than dynamic IPoE sessions. If a user IP, DHCP, or ND RS packet matches a static IPoE session, the static IPoE session overwrites the existing dynamic IPoE session.
When the IPv6 address specified in a static session overlaps with the assignable IPv6 addresses in the DHCP address pool, you must use the ipv6 dhcp server forbidden-address command to exclude the overlapping IPv6 address in the DHCPv6 address pool from dynamic address allocation. For more information about excluding IPv6 addresses from dynamic allocation, see DHCPv6 configuration in Layer 3—IP Services Configuration Guide.
You can configure multiple static IPoE sessions on an interface. Static IPv6 IPoE sessions include the following types:
· A session with a specified IPv6 address.
· A session with a specified IPv6 address and outer VLAN ID.
· A session with a specified IPv6 address, outer VLAN ID, and inner VLAN ID.
# Configure an IPv6 static IPoE session with an IP address of 2000::1 and an ISP domain of dm1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber session static ipv6 2000::1 domain dm1
Use ipv6 subscriber subnet-leased to configure IPv6 subnet-leased users.
Use undo ipv6 subscriber subnet-leased to delete IPv6 subnet-leased users.
ipv6 subscriber subnet-leased ipv6 ipv6-address prefix-length username name password { ciphertext | plaintext } string [ domain domain-name ]
undo ipv6 subscriber subnet-leased ipv6 ipv6-address prefix-length
No IPv6 subnet-leased user exists.
context-admin
prefix-length: Specified the IPv6 prefix length in the range of 1 to 127.
An IPv6 subnet-leased user is a group of IPv6 hosts that rent the same subnet of an interface and share the same IPoE session. The BRAS authenticates, authorizes, and bills all hosts of the same subnet-leased user.
You can configure only one IPv6 subnet-leased user on each subnet.
# Configure an IPv6 subnet-leased user with an IPv6 prefix of 2001:10::100, prefix length of 64, a username of netuser, and a plaintext password of pw123 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber subnet-leased ipv6 2001:10::100 64 username netuser password plaintext pw123
ipv6 subscriber timer quiet
Use ipv6 subscriber timer quiet to configure a quiet timer for IPv6 users.
Use undo ipv6 subscriber timer quiet to restore the default.
ipv6 subscriber timer quiet time
No quite timer is configured for IPv6 users.
context-admin
# Set the quiet time to 100 seconds for IPv6 users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber timer quiet 100
Use ipv6 subscriber trust to configure a trusted option for DHCPv6 users.
Use undo ipv6 subscriber trust to cancel a trusted option.
ipv6 subscriber trust { option16 | option18 | option37 }
undo ipv6 subscriber trust { option16 | option18 | option37 }
No trusted options are configured for DHCPv6 users.
context-admin
option16: Specifies Option 16 as the trusted option.
option18: Specifies Option 18 as the trusted option.
option37: Specifies Option 37 as the trusted option.
If the BRAS trusts DHCPv6 Option 16, the following option information is used as the ISP domain:
· All information in Option 16 if the option does not contain invalid characters or the at sign (@).
If the BRAS does not trust DHCPv6 Option 16, the ISP domains are used in the following order:
1. Domain specified in the ipv6 subscriber dhcp domain command.
If the BRAS trusts DHCPv6 Option 18 or Option 37, it obtains the following information from the option and uses the information to encapsulate RADIUS attributes:
· Obtains information from Option 18 and uses it to encapsulate NAS-Port-ID that adopts version 2.0 as the encapsulation format.
· Obtains information from Option 18 and uses it to encapsulate DSL_AGENT_CIRCUIT_ID.
· Obtains information from Option 37 and uses it to encapsulate DSL_AGENT_REMOTE_ID.
# Configure DHCPv6 Option 18 as a trusted option on GigabitEthernet 1/0/1.
ipv6 subscriber unclassified-ip domain
Use ipv6 subscriber unclassified-ip domain to configure an ISP domain for IPv6 unclassified-IP users, static individual users, and leased users.
Use undo ipv6 subscriber unclassified-ip domain to restore the default.
ipv6 subscriber unclassified-ip domain domain-name
IPv6 unclassified-IP users, static individual users, and leased users use the default system ISP domain.
context-admin
This command configures an ISP domain for IPv6 unclassified-IP users, static individual users, and leased users. The configured ISP domain must exist on the BRAS.
The BRAS selects an ISP domain for an IPv6 unclassified-IP user, static individual user, or leased user in the following order:
2. Domain specified by this command.
3. Default system domain.
# Configure ISP domain ipoe for IPv6 unclassified-IP users, static individual users, and leased users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip domain ipoe
ipv6 subscriber unclassified-ip max-session
Use ipv6 subscriber unclassified-ip max-session to configure the maximum number of IPoE sessions for IPv6 unclassified-IP users on an interface.
Use undo ipv6 subscriber unclassified-ip max-session to restore the default.
ipv6 subscriber unclassified-ip max-session max-number
The maximum number of IPoE sessions for IPv6 unclassified-IP users on an interface is not configured.
context-admin
max-number: Specifies the maximum number of IPoE sessions for IPv6 unclassified-IP users. The value range for this argument is 1 to 64000.
If IPoE sessions for IPv6 unclassified-IP users reach the maximum, no more IPoE session can be initiated for IPv6 unclassified-IP users.
# Set the maximum number of IPoE sessions to 100 for IPv6 unclassified-IP users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip max-session 100
Use ipv6 subscriber unclassified-ip username to configure an authentication user naming convention for IPv6 unclassified-IP users and static individual users.
Use undo ipv6 subscriber unclassified-ip username to restore the default.
ipv6 subscriber unclassified-ip username include { nas-port-id [ separator separator ] | port [ separator separator ] | second-vlan [ separator separator ] | slot [ separator separator ] | source-ip [ address-separator address-separator ] [ separator separator ] | source-mac [ address-separator address-separator ] [ separator separator ] | subslot [ separator separator ] | sysname [ separator separator ] | vlan [ separator separator ] } *
An IPv6 unclassified-IP user or static individual user uses its source IPv6 address as the authentication username.
context-admin
address-separator address-separator: Specifies any printable character as the separator for the IPv6 address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated IPv6 address (x-x-x). If you do not specify a separator, the username is the colon-separated IPv6 address (x::x:x). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
address-separator address-separator: Specifies any printable character as the separator for the MAC address. For example, if you specify a hyphen (-) as the separator, the username is the hyphen-separated MAC address (xxxx-xxxx-xxxx). If you do not specify a separator, the username is the non-separated MAC address (xxxxxxxxxxxx). Do not use the at sign (@) as the separator. The AAA server cannot parse a username containing the at sign (@).
# Configure the source IPv6 addresses as the authentication usernames for IPv6 unclassified-IP users and static individual users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip username include source-ip
# Configure an authentication user naming convention for IPv6 unclassified-IP users and static individual users on GigabitEthernet 1/0/1. Each username contains the device name, slot number, subslot number, port number, and outer VLAN, separated by the pound sign (#).
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber unclassified-ip username include sysname separator # slot separator # subslot separator # port separator # vlan
ipv6 subscriber user-detect
Use ipv6 subscriber user-detect to configure online detection for IPv6 individual users.
Use undo ipv6 subscriber user-detect to restore the default.
ipv6 subscriber user-detect { icmpv6 | nd } retry retries interval interval
Online detection for IPv6 individual users is disabled.
context-admin
icmpv6: Specifies the ICMPv6 request packet as detection packets.
nd: Specifies the NS packet of the ND protocol as detection packets.
interval interval: Configures the detection timer in the range of 30 to 1200 seconds.
Online detection enables the BRAS to periodically detect the status of an IPv6 individual user. It uses NS requests of the ND protocol and ICMPv6 requests to detect IPv6 individual users. If IPv6 individual users and the interface are in different subnets, only ICMPv6 request packets can be used for detection.
# Configure online detection on GigabitEthernet 1/0/1. The maximum number of detection attempts is 3, the detection timer is 50 seconds, and the detection packet type is ND.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber user-detect nd retry 3 interval 50
Use ipv6 subscriber vlan to bind an ISP domain to a VLAN list for IPv6 unclassified-IP users, static individual users, and leased users.
Use undo ipv6 subscriber vlan to remove the binding between an ISP domain and a VLAN list.
ipv6 subscriber vlan vlan-list domain domain-name
undo ipv6 subscriber vlan vlan-list
No ISP domain is bound to a VLAN list for IPv6 unclassified-IP users, static individual users, and leased users.
L3VE subinterface view
VEth subinterface view
VLAN interface view
context-admin
This command configures an ISP domain for IPv6 unclassified-IP users, static individual users, and leased users who send IP packets with the specified VLAN IDs.
# Configure ISP domain vlandm for IPv6 users who send IP packets with the specified VLAN IDs on GigabitEthernet 1/0/1.100. The specified VLAN IDs are in the range of 2 to 100.
[Sysname] interface gigabitethernet 1/0/1.100
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber service-identify second-vlan
[Sysname-GigabitEthernet1/0/1.100] ipv6 subscriber vlan 2 to 100 domain vlandm
ipv6 subscriber whitelist enable
Use ipv6 subscriber whitelist enable to enable the IPv6 IPoE whitelist feature.
Use undo ipv6 subscriber whitelist enable to disable the IPv6 IPoE whitelist feature.
The IPv6 IPoE whitelist feature is disabled.
context-admin
With this feature enabled, only IPv6 traffic matching static IPv6 IPoE sessions can initiate IPoE authentication, and IPoE directly permits the other traffic without any processing.
In some scenarios, an interface might need to have both IPoE and portal authentication enabled. For example, both dumb terminals and broadband dial-up users exist on an interface. Dumb terminals (for example, monitoring cameras) need to come online through IPoE without portal authentication, and broadband dial-up users need to come online through portal Web authentication. In this case, you can enable the IPv6 IPoE whitelist feature on the interface. When both the IPv6 IPoE whitelist feature and portal authentication are enabled on an interface, the following rules apply:
· If the IPv6 traffic of a user matches a static IPv6 IPoE session, the user is processed by the static IPv6 IPoE authentication flow. For an IPoE user to bypass authentication, specify the authentication and authorization modes as none in the ISP domain of the IPoE user.
· If the IPv6 traffic of a user does not match any IPv6 IPoE session, the user is processed by portal authentication.
# Enable the IPv6 IPoE whitelist feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 subscriber whitelist enable
Use reset ipv6 subscriber offline statistics to remove offline statistics for IPv6 users.
reset ipv6 subscriber offline statistics [ interface interface-type interface-number ]
context-admin
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command removes offline statistics for IPv6 users for all interfaces.
# Remove offline statistics for all IPv6 users on GigabitEthernet1/0/1.
<Sysname> reset ipv6 subscriber offline statistics
Use reset ipv6 subscriber session to delete dynamic IPv6 IPoE sessions and log out users.
reset ipv6 subscriber session [ interface interface-type interface-number ] [ domain domain-name | ipv6 ipv6-address [ vpn-instance vpn-instance-name ]| mac mac-address | username name ]
context-admin
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command deletes dynamic IPv6 IPoE sessions for all interfaces.
ipv6 ipv6-address: Specifies the IPv6 address of the IPoE session to be deleted.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command deletes IPv6 IPoE sessions on the public network.
mac mac-address: Specifies the MAC address of an IPv6 IPoE session to be deleted, in the format of H-H-H.
username name: Specifies the username of the IPv6 IPoE session to be deleted, a case-sensitive string of 1 to 255 characters.
If you do not specify any parameters, this command deletes all dynamic IPv6 IPoE sessions.
# Delete dynamic IPv6 IPoE sessions and log out users on GigabitEthernet 1/0/1.
<Sysname> reset ipv6 subscriber session interface gigabitethernet 1/0/1
