03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command Reference(V7)-6W60203-Security Command Reference
12-MAC authentication commands
12-MAC authentication commands 169.53 KB
display mac-authentication
Use display mac-authentication to display MAC authentication settings and statistics.
display mac-authentication [ ap ap-name [ radio radio-id ] | interface interface-type interface-number ]
context-admin
context-operator
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays MAC authentication information for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number. If the specified port is not enabled with MAC authentication, this command displays only global MAC authentication information.
If you do not specify any parameters, this command displays all MAC authentication information including the global settings, port-specific settings, MAC authentication statistics, and online user statistics.
# Display all MAC authentication settings and statistics.
   MAC authentication     : Enabled
   User name format       : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
           Username       : mac
           Password       : Not configured
   Offline detect period  : 300 s
   Quiet period           : 60 s
   Server timeout         : 100 s
   Authentication domain  : Not configured, use default domain
 Online MAC-auth wired users    : 1
 Silent MAC users:
          MAC address       VLAN ID  From port                   Port index
          0001-0000-0001    100      GigabitEthernet1/0/2        21
          0001-0000-0003    12       GigabitEthernet1/0/4        301
 GigabitEthernet1/0/1  is link-up
   Carry User-IP              : Disabled
   Auth-delay timer           : Enabled
       Auth-delay period      : 60 s
   Guest VLAN                 : 100
   Guest VLAN auth-period     : 150 s
   Critical VLAN              : Not configured
   Critical voice VLAN        : Disabled
   Host mode                  : Multiple VLAN
   Max online users           : 256
   Authentication attempts    : successful 2, failed 3
   Current online users       : 1
          MAC address       Auth state
          0001-0000-0001    Unauthenticated
 AP name: AP1  Radio ID: 1  SSID: wlan_maca_ssid
   BSSID                      : 1111-1111-1111
   Authentication attempts    : successful 1, failed 0
   Current online users       : 2
          0001-0000-0002    Authenticated
          0001-0000-0003    Unauthenticated
MAC authentication
Whether MAC authentication is enabled globally.
Support for MAC authentication depends on the device model. The MAC authentication configuration does not take effect on some device models.
User name format
User account type: MAC-based or shared.
·     If MAC-based accounts are used, this field displays the format settings for the username. For example, MAC address in lowercase(xx-xx-xx-xx-xx-xx) indicates that the MAC address is in six-section format, and letters are in lower case.
·     If a shared account is used, this field displays Fixed account.
Username
Username for MAC authentication.
·     If MAC-based accounts are used, this field displays mac. The device uses the MAC address of each user as the username and password for MAC authentication.
·     If a shared account is used, this field displays the username of the shared account for MAC authentication users. By default, the username is mac.
Password
Password for MAC authentication.
·     If MAC-based accounts are used or if a shared account is used but no password is configured, this field displays Not configured.
·     If a shared account is used and a password is configured, this field displays a string of asterisks (******).
Offline detect timer.
Quiet period
Quiet timer.
Server timeout
Server timeout timer.
MAC authentication domain specified in system view.
If no authentication domain is specified in system view, this field displays Not configured, use default domain.
Number of wired online MAC authentication users, including users that have passed MAC authentication and users that are performing MAC authentication.
Silent MAC users
Information about silent MAC addresses.
MAC address
Silent MAC address.
VLAN ID
ID of the VLAN to which the silent MAC address belongs.
From port
Name of the port that marks the MAC address as a silent MAC address.
Port index
Index of the port that marks the MAC address as a silent MAC address.
Status of the link on GigabitEthernet 1/0/1. In this example, the link is up.
MAC authentication
Whether MAC authentication is enabled on the port.
Carry User-IP
Whether user IP addresses are included in MAC authentication requests.
MAC authentication domain specified for the port.
Auth-delay timer
Whether MAC authentication delay is enabled on the port.
Auth-delay period
MAC authentication delay timer.
Action taken when no server is reachable for MAC reauthentication:
·     Logoff—Logs off online MAC authentication users.
·     Online—Keeps MAC authenticated users online.
Guest VLAN
MAC authentication guest VLAN configured on the port.
If no MAC authentication guest VLAN is configured, this field displays Not configured.
Authentication interval for users in the MAC authentication guest VLAN on the port.
Critical VLAN
MAC authentication critical VLAN configured on the port.
If no MAC authentication critical VLAN is configured, this field displays Not configured.
Critical voice VLAN
Whether the MAC authentication critical voice VLAN feature is enabled on the port.
Host mode
·     If multi-VLAN mode is enabled, this field displays Multiple VLAN.
·     If multi-VLAN mode is disabled, this field displays Single VLAN.
Max online users
Maximum number of concurrent online users allowed on the port.
Authentication attempts: successful 1, failed 0
MAC authentication statistics, including the number of successful and unsuccessful authentication attempts.
MAC address
MAC address of the online user.
Auth state
User status:
·     Authenticated—The user has passed MAC authentication.
·     Unauthenticated—The user failed MAC authentication.
display mac-authentication connection
Use display mac-authentication connection to display information about online MAC authentication users.
display mac-authentication connection [ interface interface-type interface-number | slot slot-number | user-mac mac-addr | user-name user-name ]
context-admin
context-operator
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays information about online MAC authentication users for all ports.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about online MAC authentication users for all member devices.
user-mac mac-address: Specifies an online MAC authentication user by its MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an online MAC authentication user, this command displays online user information for all MAC authentication users.
user-name user-name: Specifies an online MAC authentication user by its username. The user name is a case-sensitive string of 1 to 55 characters, and it can include the domain name. If you do not specify an online MAC authentication user, this command displays online user information for all MAC authentication users.
If you do not specify any parameters, this command displays information about online MAC authentication users for all ports.
If you do not specify any parameters, this command displays information about online MAC authentication users for all member devices.
# Display all online MAC authentication user information.
Total connections: 1
Slot ID: 0
Username: ias
Authentication domain: h3c
Initial VLAN: 1
Session timeout period: 2 s
Online from: 2013/03/02  13:14:15
Online duration: 0h 2m 15s
User MAC address              : 0015-e9a6-7cfe
AP name                       : ap1
Radio ID                      : 1
SSID                          : wlan_dot1x_ssid
BSSID                         : 0015-e9a6-7cf0
User name                     : ias
Authentication domain         : 1
Initial VLAN                  : 1
Authorization VLAN   : 100
Authorization ACL number      : 3001
Authorization user profile    : N/A
Authorization CAR             :
  Average input rate          : 102400 bps
  Average output rate         : 102400 bps
Authorization URL             : N/A
Termination action            : Radius-request
Session timeout period        : 2 sec
Online from                   : 2014/06/02 13:14:15
Online duration               : 0h 2m 15s
Total connections
Total number of online MAC authentication users.
User MAC address
MAC address of the user.
Access interface
Interface through which the user accesses the device.
MAC authentication domain to which the user belongs.
IPv4 address
IPv4 address of the user.
If no user IPv4 address is available, this field is not displayed.
IPv6 address
IPv6 address of the user.
If no user IPv6 address is available, this field is not displayed.
Initial VLAN
VLAN that holds the user before MAC authentication.
Untagged VLAN authorized to the user.
Tagged VLAN authorized to the user.
Authorization VLAN
Number or name of the ACL authorized to the user.
If no ACL is authorized, this field displays N/A.
If ACL authorization fails, this field displays (NOT effective) after the ACL number or name.
User profile authorized to the user.
Authorization CAR
Authorization CAR attributes assigned by the server.
·     Average input rate—Average rate of inbound traffic in bps.
·     Average output rate—Average rate of outbound traffic in bps.
If no authorization CAR attributes are assigned, this field displays N/A.
Authorization URL
URL authorized to the user.
Termination action
Action attribute assigned by the server to terminate the user session:
·     Default—Logs off the online authenticated user when the session timeout timer expires.
·     Radius-request—Reauthenticates the online user when the session timeout timer expires.
If the device performs local authentication, this field displays N/A.
Session timeout timer assigned by the server.
Online from
Time from which the MAC authentication user came online.
Online duration
Online duration of the MAC authentication user.
mac-authentication
Use mac-authentication to enable MAC authentication globally or on a port.
Use undo mac-authentication to disable MAC authentication globally or on a port.
mac-authentication
MAC authentication is disabled globally or on any port.
context-admin
To use MAC authentication on a port, you must enable the feature both globally and on the port.
Support for MAC authentication depends on the device model. MAC authentication does not take effect on some device models.
# Enable MAC authentication globally.
[Sysname] mac-authentication
# Enable MAC authentication on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication
mac-authentication access-user log enable
Use mac-authentication access-user log enable to enable MAC authentication user logging.
Use undo mac-authentication access-user log enable to disable MAC authentication user logging.
MAC authentication user logging is disabled.
context-admin
failed-login: Logs MAC authentication user login failures.
logoff: Logs MAC authentication user logoffs.
successful-login: Logs successful MAC authentication user logins.
To prevent excessive MAC authentication user log entries, use this feature only if you need to analyze abnormal MAC authentication user logins or logouts.
If you do not specify any parameters, this command enables all types of MAC authentication user logs.
# Enable logging MAC authentication user login failures.
info-center source maca logfile deny (Network Management and Monitoring Command Reference)
mac-authentication critical vlan
Use mac-authentication critical vlan to configure a MAC authentication critical VLAN on a port.
Use undo mac-authentication critical vlan to restore the default.
No MAC authentication critical VLAN exists on a port.
context-admin
critical-vlan-id: Specifies a VLAN as the MAC authentication critical VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
The MAC authentication critical VLAN accommodates users that have failed MAC authentication because all the servers in their ISP domains are unreachable. Users in the critical VLAN can access network resources in the critical VLAN.
The critical VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication user fails local authentication after RADIUS authentication, the user is not assigned to the critical VLAN.
Before you delete a VLAN that has been set as a MAC authentication critical VLAN, use the undo mac-authentication critical vlan command to remove the critical VLAN configuration.
# Configure VLAN 100 as the MAC authentication critical VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication critical vlan 100
reset mac-authentication critical-vlan
mac-authentication domain
Use mac-authentication domain to specify a global or port-specific authentication domain.
Use undo mac-authentication domain to restore the default.
The system default authentication domain is used. For more information about the default authentication domain, see the domain default enable command in "AAA commands."
context-admin
domain-name: Specifies the name of an ISP domain, a case-insensitive string of 1 to 255 characters.
The global authentication domain applies to all MAC authentication-enabled ports. An authentication domain specified in Layer 2 Ethernet interface view applies only to the port. You can specify different authentication domains on different ports.
A port chooses an authentication domain for MAC authentication users in the following order:
1.     Authentication domain specified on the port.
2.     Global authentication domain specified in system view.
3.     Default authentication domain.
# Specify ISP domain domain1 as the global MAC authentication domain.
# Specify ISP domain aabbcc as the MAC authentication domain on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication domain aabbcc
mac-authentication guest-vlan
Use mac-authentication guest-vlan to configure a MAC authentication guest VLAN on a port.
Use undo mac-authentication guest-vlan to restore the default.
No MAC authentication guest VLAN exists on a port.
context-admin
guest-vlan-id: Specifies a VLAN as the MAC authentication guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created.
The MAC authentication guest VLAN accommodates users that have failed MAC authentication for any reason other than server unreachable. For example, the VLAN accommodates users with invalid passwords entered. You can deploy a limited set of network resources in the MAC authentication guest VLAN. For example, a software server for downloading software and system patches.
Before you delete a VLAN that has been set as a MAC authentication guest VLAN, use the undo mac-authentication guest-vlan command to remove the guest VLAN configuration.
# Configure VLAN 100 as the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication guest-vlan 100
reset mac-authentication guest-vlan
mac-authentication guest-vlan auth-period
Use mac-authentication guest-vlan auth-period to set the interval at which the device authenticates users in the MAC authentication guest VLAN.
Use undo mac-authentication guest-vlan auth-period to restore the default.
The device authenticates users in the MAC authentication guest VLAN every 30 seconds.
context-admin
period-value: Specifies the authentication interval for users in the MAC authentication guest VLAN. The value range is 1 to 3600, in seconds.
# Set the authentication interval to 150 seconds for users in the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication guest-vlan auth-period 150
mac-authentication host-mode multi-vlan
Use mac-authentication host-mode multi-vlan to enable MAC authentication multi-VLAN mode on a port.
Use undo mac-authentication host-mode to restore the default.
MAC authentication multi-VLAN mode is disabled on a port. When the port receives a packet sourced from an authenticated MAC address in a VLAN not matching the existing MAC-VLAN mapping, the device logs off and reauthenticates the user.
context-admin
The MAC authentication multi-VLAN mode prevents an authenticated online user from service interruption caused by VLAN changes on a port. When the port receives a packet sourced from the user in a VLAN not matching the existing MAC-VLAN mapping, the device neither logs off the user nor reauthenticates the user. The device creates a new MAC-VLAN mapping for the user, and traffic transmission is not interrupted. The original MAC-VLAN mapping for the user remains on the device until it dynamically ages out. As a best practice, configure this feature on hybrid or trunk ports.
# Enable MAC authentication multi-VLAN mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication host-mode multi-vlan
mac-authentication max-user
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication users on a port.
Use undo mac-authentication max-user to restore the default.
The default is 4294967295.
context-admin
max-number: Sets the maximum number of concurrent MAC authentication users on the port. The value range for this argument is 1 to 4294967295.
Set the maximum number of concurrent MAC authentication users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent MAC authentication users.
# Configure GigabitEthernet 1/0/1 to support a maximum of 32 concurrent MAC authentication users.
[Sysname-GigabitEthernet1/0/1] mac-authentication max-user 32
mac-authentication re-authenticate server-unreachable keep-online
Use mac-authentication re-authenticate server-unreachable keep-online to enable the keep-online feature on a port.
Use undo mac-authentication re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online MAC authentication users if no server is reachable for MAC reauthentication.
context-admin
The keep-online feature keeps authenticated MAC authentication users online when no server is reachable for MAC reauthentication.
# Enable the keep-online feature for authenticated MAC authentication users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer
Use mac-authentication timer to configure a MAC authentication timer.
Use undo mac-authentication timer to restore the default of a MAC authentication timer.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
undo mac-authentication timer { offline-detect | quiet | server-timeout }
The following MAC authentication timers apply:
·     The offline detect timer is 300 seconds.
·     The quiet timer is 60 seconds.
·     The server timeout timer is 100 seconds.
context-admin
offline-detect offline-detect-value: Sets the offline detect timer in seconds, in the range of 60 to 2147483647.
quiet quiet-value: Sets the quiet timer in seconds, in the range of 1 to 3600.
server-timeout server-timeout-value: Sets the server timeout timer in seconds, in the range of 100 to 300.
MAC authentication uses the following timers:
·     Offline detect timer—Sets the interval that the device waits for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user.
·     Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
·     Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device determines that the RADIUS server is unavailable. If the timer expires during MAC authentication, the user cannot access the network.
# Set the server timeout timer to 150 seconds.
mac-authentication user-name-format
Use mac-authentication user-name-format to configure the type of user accounts for MAC authentication users.
Use undo mac-authentication user-name-format to restore the default.
mac-authentication user-name-format { fixed [ account name ] [ password { cipher | simple } string ] | mac-address [ { with-hyphen [ six-section | three-section ] | without-hyphen } [ lowercase | uppercase ] ] }
Each user's MAC address is used as the username and password for MAC authentication. The MAC addresses are in hexadecimal notation without hyphens, and letters are in lower case.
context-admin
fixed: Uses a shared account for all MAC authentication users.
account name: Specifies the username for the shared account. The name is a case-sensitive string of 1 to 55 characters, excluding the at sign (@). If you do not specify a username, the default name mac applies.
password: Specifies the password for the shared user account. If you do not specify a password for the shared account, the shared account does not have a password.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
mac-address: Uses MAC-based user accounts for MAC authentication users. You can also specify the format of username and password by using the following keywords:
·     with-hyphen: Includes hyphens in the MAC address.
¡     six-section: Hyphenates the MAC address into six groups of two hexadecimal digits, for example, xx-xx-xx-xx-xx-xx or XX-XX-XX-XX-XX-XX.
¡     three-section: Hyphenates the MAC address into three groups of four hexadecimal digits, for example, xxxx-xxxx-xxxx or XXXX-XXXX-XXXX.
If you do not specify the six-section or three-section keyword, the MAC address is in six-section format.
·     without-hyphen: Excludes hyphens from the MAC address, for example, xxxxxxxxxxxx or XXXXXXXXXXXX.
·     lowercase: Specifies letters in lower case.
·     uppercase: Specifies letters in upper case.
If you specify the MAC-based user account, the device uses the MAC address of a user as the username and password for MAC authentication of the user. This user account type ensures high authentication security. However, you must create on the authentication server a user account for each user, using the MAC address of the user as both the username and password.
If you specify a shared user account, the device uses the specified username and password for MAC authentication of all users. Because all MAC authentication users use a single account for authentication, you only need to create one account on the authentication server. This user account type is suitable for trusted networks.
# Configure a shared account for MAC authentication users, and set the username to abc and password to plaintext string of xyz.
# Use MAC-based user accounts for MAC authentication users. The MAC addresses must be in hexadecimal notation without hyphens, and letters are in upper case.
[Sysname] mac-authentication user-name-format mac-address without-hyphen uppercase
reset mac-authentication access-user
Use reset mac-authentication access-user to log off MAC authentication users.
reset mac-authentication access-user [ interface interface-type interface-number | mac mac-address | username username | vlan vlan-id | vsi vsi-name ]
context-admin
mac mac-address: Specifies a MAC authentication user by its MAC address. The mac-address argument is in the format of H-H-H.
username username: Specifies a MAC authentication user by its name. The username argument is a case-sensitive string of 1 to 253 characters.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The value range for the vlan-id argument is 1 to 4094.
vsi vsi-name: Specifies a VSI by its name. The vsi-name argument is a case-sensitive string of 1 to 31 characters.
Use this command to log off the specified MAC authentication users and clear information about these users from the device. These users must perform MAC authentication to come online again.
With a VSI specified, this command logs off a MAC authentication user if that user has passed authentication and its authorization VSI is the specified VSI.
With a VLAN specified, this command logs off the following MAC authentication users:
·     Users that have passed MAC authentication and have been assigned the specified VLAN as their authorization VLAN by the server.
·     Users that stay in the specified VLAN after they have passed MAC authentication, because they have not been assigned an authorization VLAN yet.
·     Users that are performing MAC authentication in the specified VLAN.
To identify the VLAN in which a user is staying, use the display mac-address command.
If you do not specify any parameters, the reset mac-authentication access-user command logs off all MAC authentication users on the device.
# Log off all MAC authentication users on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication access-user interface gigabitethernet 1/0/1
Use reset mac-authentication critical-vlan to remove users from the MAC authentication critical VLAN on a port.
reset mac-authentication critical-vlan interface interface-type interface-number [ mac-address mac-address ]
context-admin
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication critical VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
Use reset mac-authentication guest-vlan to remove users from the MAC authentication guest VLAN on a port.
context-admin
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication guest VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication guest-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
reset mac-authentication statistics
Use reset mac-authentication statistics to clear MAC authentication statistics.
reset mac-authentication statistics [ ap ap-name [ radio radio-id ] | interface interface-type interface-number ]
context-admin
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command clears MAC authentication statistics for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command clears MAC authentication statistics for all radios on the specified AP.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears both global and port-specific MAC authentication statistics.
If you do not specify any parameters, this command clears all MAC authentication statistics.
# Clear MAC authentication statistics on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication statistics interface gigabitethernet 1/0/1
