H3C WSG1800X Series Wireless Integrated Services Gateway Hardware Information and Specifications-6W100
HomeSupportWirelessWSG1800X Wireless Integrated Services GatewayProduct LiteratureHardware Information & SpecificationsH3C WSG1800X Series Wireless Integrated Services Gateway Hardware Information and Specifications-6W100
01-Text
01-Text 1010.98 KB
1 Product overview
Product models
This document is applicable to the WSG1800X series wireless integrated services gateway. Table1-1 describes the WSG1800X series models.
Table1-1 WSG1800X series wireless integrated services gateway models
Product series
Product code
Model
Remarks
WSG1800X series
EWP-WSG1812X-PWR
WSG1812X-PWR
PoE model
EWP-WSG1840X
WSG1840X
Non-PoE model
Technical specifications
Table1-2 Technical specifications
Item
WSG1812X-PWR
WSG1840X
Dimensions (H × W × D)
43.6 × 440 × 220 mm (1.72 × 17.32 × 8.66 in)
43.6 × 440 × 165 mm (1.72 × 17.32 × 6.50 in)
Weight
2.9 kg (6.39 lb)
1.8 kg (3.97 lb)
Console port
1, control port, 9600 bps (default) to 115200 bps
USB port
1 (USB 2.0)
SFP+ port
2 (10GBASE-R-SFP+)
1 (SFP+)
100/1000BASE-T autosensing Ethernet port
2 (WAN interfaces)
6 (2 × WAN interfaces + 4 × LAN interfaces)
100/1000BASE-T-PoE+ autosensing Ethernet port
12 (The 12 LAN interfaces of the device operating as downlink interfaces that can provide PoE+ power. Each can provide a maximum PoE+ power of 30 W.)
N/A
2.5G/5GBASE-T autosensing Ethernet port
N/A
1
Reset button (RESET)
·     To restore the device to factory settings, press and hold the button for more than 5 seconds.
·     To reset the device, press and hold the button for more than 15 milliseconds.
·     To restore the device to factory default settings, press and hold the button for more than 5 seconds after the device starts up normally.
During startup of the device, you can only use the reset button to reset the device.
Memory
2GB DDR4
2GB DDR4
Storage media
4GB eMMC memory
4GB eMMC memory
AC power supply
Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz
System power consumption
11.8W to 173 W (including 150W PoE output)
6.4W to 14.4 W
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
2 Chassis views
WSG1812X-PWR
Front and rear views
Figure2-1 Front view
(1) Reset button (RESET)
(2) USB port
(3) Console port
(4) 100/1000BASE-T autosensing Ethernet ports WAN 1 and WAN 2
(5) 100/1000BASE-T-PoE+ autosensing Ethernet ports LAN 3 to LAN 14
(6) 10GBASE-R-SFP+ ports
Figure2-2 Rear view
(1) Grounding screw
(2) AC-input power receptacle
LED locations
Figure2-3 Front panel LED locations
(1) System status LED (SYS)
(2) 100/1000BASE-T autosensing port LEDs
(3) 100/1000BASE-T-PoE+ autosensing port LEDs
(4) 10GBASE-R-SFP+ port LED
(5) 10GBASE-R-SFP+ port LED
WSG1840X
Figure2-4 Front view
(2) USB port
(3) Console port
(4) SFP+ port
(5) 2.5G/5GBASE-T autosensing Ethernet port
(6) 100/1000BASE-T autosensing Ethernet ports WAN 5 and WAN 6
(7) 100/1000BASE-T autosensing Ethernet ports LAN 1 to LAN 4
Figure2-5 Rear view
(1) AC-input power receptacle
(2) Grounding screw
LED locations
Figure2-6 Front panel LED locations
(2) SFP+ port LED
(3) 2.5G/5G autosensing port LED
(4) 100/1000M autosensing port LEDs
(5) 100/1000M autosensing port LEDs
3 Ports and LEDs
Ports
Console port
Table3-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Port transmission rate
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible devices
All device models
USB port
Table3-2 USB port specifications
Item
Specification
Port type
USB 2.0
Compliant standard
OHCI
Uploads and downloads data at a rate up to 480 Mbps
Functions and services
Accesses the file system on the flash of the device, for example, to upload or download application and configuration files
Compatible devices
All device models
IMPORTANT
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the device. If a USB device fails to operate on the device, replace it with one from another vendor.
SFP+ port
Table3-3 SFP+ port specifications
Item
Specification
Connector type
LC
Compatible transceiver modules
·     GE SFP transceiver modules in Table3-4
·     10GE SFP+ transceiver modules in Table3-5
Compatible devices
·     All device models
Table3-4 GE SFP transceiver modules
Transceiver module type
Transceiver module model
Central wavelength
Receiver sensitivity
Fiber diameter
Data rate
Max transmission distance
GE multi-mode module
SFP-GE-SX-MM850-A
850 nm
–17 dBm
50 µm
1.25 Gbps
550 m (1804.46 ft)
SFP-GE-SX-MM850-D
850 nm
–17 dBm
50 µm
1.25 Gbps
550 m (1804.46 ft)
GE single-mode module
SFP-GE-LX-SM1310-A
1310 nm
–20 dBm
9 µm
1.25 Gbps
10 km (6.21 miles)
SFP-GE-LX-SM1310-D
1310 nm
–20 dBm
9 µm
1.25 Gbps
10 km (6.21 miles)
Table3-5 10GE SFP+ transceiver modules
Central wavelength
Fiber diameter
Data rate
10GE multi-mode module
SFP-XG-SX-MM850-D
850 nm
–9.9 dBm
50 µm
10.31 Gbps
300 m (984.25 ft)
SFP-XG-SX-MM850-E
850 nm
–9.9 dBm
50 µm
10.31 Gbps
300 m (984.25 ft)
10GE single-mode module
SFP-XG-LX-SM1310-D
1310 nm
–14.4 dBm
9 µm
10.31 Gbps
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310 nm
–14.4 dBm
9 µm
10.31 Gbps
10 km (6.21 miles)
·     As a best practice, use H3C transceiver modules for the device.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules, see H3C Transceiver Modules User Guide.
Table3-6 100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Rate, duplex mode, and auto-MDI/MDI-X
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
100 m (328.08 ft)
Transmission medium
Category 5 or above twisted pair cable
Compliant standard
IEEE 802.3i, 802.3u, 802.3ab
Compatible devices
All device models
Table3-7 100/1000BASE-T-PoE+ autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     PoE+ power supply
100 m (328.08 ft)
Transmission medium
Compliant standard
Compatible devices
WSG1812X-PWR
Table3-8 2.5G/5GBASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     2.5 Gbps, full duplex
·     5 Gbps, full duplex
2.5 Gbps: 100 m (328.08 ft)
Transmission medium
Compliant standard
Compatible devices
WSG1840X
LEDs
System status LED
The system status LED shows the operating status of the device.
Table3-9 System status LED description
LED mark
Status
SYS
Flashing green (4 Hz)
The system is starting up.
Flashing green (0.5 Hz)
The system is operating correctly.
Steady red
A critical alarm has occurred, such as a power alarm, high temperature alarm, or software missing alarm.
Off
The device has not started up.
SFP+ port LED
Table3-10 SFP+ port LED description
LED mark
Status
10GBASE-R-SFP+ or SFP+
Steady green
A 1000 Mbps or 10 Gbps link is present on the port.
Flashing green
The port is receiving or sending data at 1000 Mbps or 10 Gbps.
Off
No link is present on the port.
100/1000BASE-T autosensing Ethernet port LED
Table3-11 Description for the 100/1000BASE-T autosensing Ethernet port LEDs on the WSG1840X or WSG1812X-PWR
LED mark
Status
100/1000BASE-T
Steady green
A 100/1000 Mbps link is present on the port.
Flashing green
The port is receiving or sending data at 100/1000 Mbps.
Off
Table3-12 Description for the 100/1000BASE-T-PoE+ autosensing Ethernet port LEDs on the WSG1812X-PWR
LED mark
Status
100/1000BASE-T-PoE+
Steady green
Flashing green
Off
2.5G/5GBASE-T autosensing Ethernet port LED
Table3-13 Description for the 2.5G/5GBASE-T autosensing Ethernet port LED on the WSG1840X
LED mark
Status
2.5G/5GBASE-T
Steady green
A 1000 Mbps, 2.5 Gbps, or 5 Gbps link is present on the port.
Flashing green
The port is receiving or sending data at 1000 Mbps, 2.5 Gbps, or 5 Gbps.
Off
4 Cooling system
To dissipate heat timely and enhance system stability, the device uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the device.
Table4-1 Cooling system
Product series
Product model
Airflow direction
WSG1800X series
WSG1812X-PWR
The device provides airflow from the other three sides to the right side. See Figure4-1.
WSG1840X
Fanless
Figure4-1 Airflow from the other three sides to the right side through the device chassis
