H3C WX2800X Series Access Controllers Hardware Information and Specifications-6W100
HomeSupportWirelessWX2800X Series Access ControllersProduct LiteratureHardware Information & SpecificationsH3C WX2800X Series Access Controllers Hardware Information and Specifications-6W100
01-Text
01-Text 1.46 MB
1 Product overview
Product models
This document is applicable to the WX2800X series access controllers. Table1-1 describes the WX2800X series access controller models.
Table1-1 WX2800X series access controller models
Product series
Product code
Model
Remarks
WX2800X series
EWP-WX2812X-PWR
WX2812X-PWR
PoE model
EWP-WX2860X
WX2860X
Non-PoE models
EWP-WX2880X
WX2880X
Technical specifications
Table1-2 Technical specifications
Item
WX2812X-PWR
WX2860X
WX2880X
Dimensions (H × W × D)
43.6 × 440 × 220 mm (1.72 × 17.32 × 8.66 in)
43.6 × 440 × 250 mm (1.72 × 17.32 × 9.84 in)
Weight
2.9 kg (6.39 lb)
3.1 kg (6.83 lb)
3.3 kg (7.28 lb)
Console port
1, control port, 9600 bps (default) to 115200 bps
USB port
1 (USB2.0)
SFP+ port
2 (10GBASE-R-SFP+)
100/1000BASE-T autosensing Ethernet port
2 (WAN interfaces)
8
8
100/1000BASE-T-PoE+ autosensing Ethernet port
12 (The 12 LAN interfaces of the device operating as downlink interfaces that can provide PoE+ power. Each can provide a maximum PoE+ power of 30 W.)
N/A
N/A
2.5G/1000BASE-T autosensing Ethernet port
N/A
2
2
Reset button (RESET)
·     To restore the device to factory settings, press and hold the button for more than 5 seconds.
·     To reset the device, press and hold the button for more than 15 milliseconds.
·     To restore the device to factory default settings, press and hold the button for more than 5 seconds after the device starts up normally.
During startup of the device, you can only use the reset button to reset the device.
Memory
2GB DDR4
2GB DDR4
4GB DDR4
Storage media
4GB eMMC memory
8GB eMMC memory
8GB eMMC memory
AC power supply
Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz
Dual power supplies
System power consumption
11.8W to 173 W (including 150W PoE output)
12.1 W to 29.5 W
14.1 W to 31.3 W
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
2 Chassis views
WX2812X-PWR
Front and rear views
Figure2-1 Front view
(1) Reset button (RESET)
(2) USB port
(3) Console port
(4) 100/1000BASE-T autosensing Ethernet ports WAN 1 and WAN 2
(5) 100/1000BASE-T-PoE+ autosensing Ethernet ports LAN 3 to LAN 14
(6) 10GBASE-R-SFP+ ports
Figure2-2 Rear view
(1) Grounding screw
(2) AC-input power receptacle
LED locations
Figure2-3 Front panel LED locations
(1) System status LED (SYS)
(2) 100/1000MBASE-T autosensing port LEDs
(3) 100/1000BASE-T-PoE+ autosensing port LEDs
(4) 10GBASE-R-SFP+ port LED
(5) 10GBASE-R-SFP+ port LED
WX2860X
Figure2-4 Front view
(1) 100/1000BASE-T autosensing Ethernet ports 1 to 8
(2) 10GBASE-R-SFP+ ports  9 and 10
(3) 2.5G/1000BASE-T autosensing Ethernet ports 11 and 12
(4) USB port
(5) Console port
(6) Reset button (RESET)
Figure2-5 Rear view
(1) AC-input power receptacle
(2) Grounding screw
LED locations
Figure2-6 Front panel LED locations
(1) 100/1000M autosensing port LEDs
(2) 10GBASE-R-SFP+ port LEDs
(3) 2.5G/1000M autosensing port LEDs
(4) System status LED (SYS)
WX2880X
Figure2-7 Front view
(4) USB port
(5) Console port
Figure2-8 Rear view
(1) AC-input power receptacles
(2) Grounding screw
LED locations
Figure2-9 Front panel LED locations
3 Ports and LEDs
Ports
Console port
Table3-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Port transmission rate
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible devices
All device models
USB port
Table3-2 USB port specifications
Item
Specification
Port type
USB 2.0
Compliant standard
OHCI
Uploads and downloads data at a rate up to 480 Mbps
Functions and services
Accesses the file system on the flash of the device, for example, to upload or download application and configuration files
Compatible devices
All device models
IMPORTANT
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the device. If a USB device fails to operate on the device, replace it with one from another vendor.
SFP+ port
Table3-3 SFP+ port specifications
Item
Specification
Connector type
LC
Compatible transceiver modules
·     GE SFP transceiver modules in Table3-4
·     10GE SFP+ transceiver modules in Table3-5
Compatible devices
·     All device models
Table3-4 GE SFP transceiver modules
Transceiver module type
Transceiver module model
Central wavelength
Receiver sensitivity
Fiber diameter
Data rate
Max transmission distance
GE multi-mode module
SFP-GE-SX-MM850-A
850 nm
–17 dBm
50 µm
1.25 Gbps
550 m (1804.46 ft)
SFP-GE-SX-MM850-D
850 nm
–17 dBm
50 µm
1.25 Gbps
550 m (1804.46 ft)
GE single-mode module
SFP-GE-LX-SM1310-A
1310 nm
–20 dBm
9 µm
1.25 Gbps
10 km (6.21 miles)
SFP-GE-LX-SM1310-D
1310 nm
–20 dBm
9 µm
1.25 Gbps
10 km (6.21 miles)
Table3-5 10GE SFP+ transceiver modules
Central wavelength
Fiber diameter
Data rate
10GE multi-mode module
SFP-XG-SX-MM850-D
850 nm
–9.9 dBm
50 µm
10.31 Gbps
300 m (984.25 ft)
SFP-XG-SX-MM850-E
850 nm
–9.9 dBm
50 µm
10.31 Gbps
300 m (984.25 ft)
10GE single-mode module
SFP-XG-LX-SM1310-D
1310 nm
–14.4 dBm
9 µm
10.31 Gbps
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310 nm
–14.4 dBm
9 µm
10.31 Gbps
10 km (6.21 miles)
·     As a best practice, use H3C transceiver modules for the device.
·     The H3C transceiver modules are subject to change over time. For the most recent list of H3C transceiver modules, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules, see H3C Transceiver Modules User Guide.
Table3-6 100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Rate, duplex mode, and auto-MDI/MDI-X
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
100 m (328.08 ft)
Transmission medium
Category 5 or above twisted pair cable
Compliant standard
IEEE 802.3i, 802.3u, 802.3ab
Compatible devices
All device models
Table3-7 100/1000BASE-T-PoE+ autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     PoE+ power supply
100 m (328.08 ft)
Transmission medium
Compliant standard
Compatible devices
WX2812X-PWR
Table3-8 2.5G/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     2.5 Gbps, full duplex
1000 Mbps: 100 m (328.08 ft)
2.5 Gbps: 100 m (328.08 ft)
Transmission medium
Compliant standard
Compatible devices
WX2860X, WX2880X
LEDs
System status LED
The system status LED shows the operating status of the device.
Table3-9 System status LED description
LED mark
Status
SYS
Flashing green (4 Hz)
The system is starting up.
Flashing green (0.5 Hz)
The system is operating correctly.
Steady red
A critical alarm has occurred, such as a power alarm, fan tray alarm, high temperature alarm, or software missing alarm.
Off
The device has not started up.
SFP+ port LED
Table3-10 10GBASE-R-SFP+ port LED description for the WX2860X or WX2880X
LED mark
Status
10GBASE-R-SFP+
Steady yellow
A 1000 Mbps link is present on the port.
Flashing yellow
The port is receiving or sending data at 1000 Mbps.
Steady green
A 10 Gbps link is present on the port.
Flashing green
The port is receiving or sending data at 10 Gbps.
Off
No link is present on the port.
Table3-11 10GBASE-R-SFP+ port LED description for the WX2812X-PWR
LED mark
Status
10GBASE-R-SFP+
Steady green
A 1000 Mbps or 10 Gbps link is present on the port.
Flashing green
The port is receiving or sending data at 1000 Mbps or 10 Gbps.
Off
100/1000BASE-T autosensing Ethernet port LED
Table3-12 Description for the 100/1000BASE-T autosensing Ethernet port LEDs on the WX2860X, WX2880X, or WX2812X-PWR
LED mark
Status
100/1000BASE-T
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
The port is receiving or sending data at 100 Mbps.
Steady green
Flashing green
Off
Table3-13 Description for the 100/1000BASE-T-PoE+ autosensing Ethernet port LEDs on the WX2812X-PWR
LED mark
Status
100/1000BASE-T-PoE+
Steady green
A 100/1000 Mbps link is present on the port.
Flashing green
The port is receiving or sending data at 100/1000 Mbps.
Off
2.5G/1000BASE-T autosensing Ethernet port LED
During device startup, the 2.5G/1000M autosensing Ethernet port LEDs flash yellow and green temporarily. This indicates that the chip is in self test state.
Table3-14 Description for the 2.5G/1000BASE-T autosensing Ethernet port LEDs on the WX2860X or WX2880X
LED mark
Status
2.5G/1000BASE-T
Steady yellow
Flashing yellow
Steady green
A 2.5 Gbps link is present on the port.
Flashing green
The port is receiving or sending data at 2.5 Gbps.
Off
4 Cooling system
To dissipate heat timely and enhance system stability, the device uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the device.
Table4-1 Cooling system
Product series
Product model
Airflow direction
WX2800X series
WX2812X-PWR
The device provides airflow from the other three sides to the right side. See Figure4-1.
WX2860X
The device provides airflow from the left and right sides to the rear side. See Figure4-2.
WX2880X
Figure4-1 Airflow from the other three sides to the right side through the device chassis
Figure4-2 Airflow from the left and right sides to the rear side through the device chassis
