10-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series WLAN Access Points Command Reference-6W10010-Network Management and Monitoring Command Reference
02-NTP Commands
02-NTP Commands 82.54 KB
l          Support of the H3C WA series WLAN access points (APs) for commands may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
NTP Configuration Commands
display ntp-service sessions
display ntp-service sessions [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays the detailed information of all NTP sessions. If you do not specify this keyword, only the brief information of the NTP sessions will be displayed.
Use the display ntp-service sessions command to view the information of all NTP sessions.
# View the brief information of NTP service sessions.
<Sysname> display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]127.127.1.0     127.127.1.0        3     1   64   33    0.0    0.0    0.0
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations :  1
Table 1-1 display ntp-service sessions command output description
source
IP address of the clock source
reference
Reference clock ID of the clock source
1)        If the reference clock is the local clock, the value of this field is related to the value of the stra field:
l       When the value of the stra field is 0 or 1, this field will be “LOCL”;
l      When the stra field has another value, this filed will be the IP address of the local clock.
2)        If the reference clock is the clock of another AP on the network, the value of this field will be the IP address of that AP.
stra
Stratum level of the clock source, which determines the clock precision. The value range is 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
reach
Reachability count of the clock source. 0 indicates that the clock source in unreachable.
poll
Poll interval, namely, the maximum interval between successive NTP messages.
now
The length of time in minutes from when the last NTP message was received or when the local clock was last updated to the current time
The time is in second by default. If the time length is greater than 2048 seconds, it is displayed in minute; if greater than 300 minutes, in hour; if greater than 96 hours, in day.
offset
The offset of the system clock relative to the reference clock, in milliseconds
delay
the roundtrip delay from the local AP to the clock source, in milliseconds
disper
The maximum error of the system clock relative to the reference source.
[12345]
1: Clock source selected by the system, namely, the current reference source, with a system clock stratum level less than or equal to 15.
2: Stratum level of this system source is less than or equal to 15.
3: This clock source has passed the clock selection process.
4: This clock source is a candidate clock source.
5: This clock source was created by a configuration command.
Total associations
Total number of associations
# View the detailed information of all NTP sessions.
<Sysname> display ntp-service sessions verbose
 clock source: 127.127.1.0
 clock stratum: 3
 clock status: configured, master, sane, valid
 reference clock ID: 127.127.1.0
 local mode: client, local poll: 6
 peer mode: server, peer poll: 6
 offset: 0.0000 ms,delay: 0.00 ms,  disper: 0.02 ms
 root delay: 0.00 ms, root disper: 10.00 ms
 reach: 1, sync dist: 0.010, sync state: 2
 precision: 2^18, version: 3, peer interface: InLoopBack0
 reftime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 orgtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 rcvtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.7149E881)
 xmttime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71464DC2)
 filter delay :  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter offset:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter disper:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 reference clock status: working abnormally
 timecode:
Table 1-2 display ntp-service sessions verbose command output description
clock source
clock stratum
clock status
Status of the clock source corresponding to this session, including
l      configured: The session was created by a configuration command.
l      dynamic: This session is established dynamically.
l      master: The clock source is the primary reference source of the current system.
l      selected: The clock source has survived the clock selection algorithm.
l      candidate: The clock source is the candidate reference source.
l      sane: The clock source has passed the sane authentication.
l      insane: The clock source has failed the sane authentication.
l      valid: The clock source is valid, which means the clock source meet the following requirements: it has passed the authentication and is being synchronized; its stratum level is valid; its root delay and root dispersion values are within their ranges.
l      invalid: The clock source is invalid.
l      unsynced: The clock source has not been synchronized or the value of the stratum level is invalid.
reference clock ID
1)        If the reference clock is the local clock, the value of this field is related to the stratum level of the clock source:
l       When the stratum level of the clock source is 0 or 1, this field will be “LOCL”;
l      When the stratum level of the clock source has another value, this field will be the IP address of the local clock.
local mode
Operation mode of the local AP, including
l      unspec: The mode is unspecified.
l      active: Active mode.
l      passive: Passive mode.
l      client: Client mode.
l      server: Server mode.
l      bdcast: Broadcast server mode.
l      control: Control query mode.
l      private: Private message mode.
local poll
Poll interval of the local AP, in seconds. The value displayed is a power of 2, for example, if the displayed value is 6, it indicates that the poll interval of the local AP is 26, that is, 64 seconds.
peer mode
Operation mode of the peer AP, including
peer poll
Poll interval of the peer AP, in seconds. The value displayed is a power of 2, for example, if the displayed value is 6, it indicates that the poll interval of the local AP is 26, that is, 64 seconds.
offset
delay
The roundtrip delay from the local AP to the clock source, in milliseconds
disper
The maximum error of the system clock relative to the reference clock
root delay
The roundtrip delay from the local AP to the primary reference source, in milliseconds
root disper
The maximum error of the system clock relative to the primary reference clock, in milliseconds
reach
Reachability count of the clock source. 0 indicates that the clock source is unreachable.
sync dist
The synchronization distance relative to the upper-level clock, in seconds, and calculated from dispersion and roundtrip delay values.
sync state
State of the state machine
The displayed value is an integral that ranges from 0 to 5.
precision
Precision of the system clock
version
NTP version
The displayed value is an integral that ranges from 1 to 3.
peer interface
Source interface
If the source interface is not specified, this field will be wildcard.
reftime
Reference timestamp in the NTP message
orgtime
Originate timestamp in the NTP message
rcvtime
Receive timestamp in the NTP message
xmttime
Transmit timestamp in the NTP message
filter delay
Delay information
filter offset
Offset information
filter disper
Dispersion information
Status of the reference clock, including
l      working normally
l      working abnormally
timecode
Time code
Total associations
When an AP is working in the NTP broadcast/multicast server mode, the display ntp-service sessions command executed on the AP will not display the NTP session information corresponding to the broadcast/multicast server, but the sessions will be counted in the total number of associations.
display ntp-service status
View
Default Level
1: Monitor level
None
Use the display ntp-service status command to view the NTP service status information.
# View the NTP service status information.
<Sysname> display ntp-service status
Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^17
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Table 1-3 display ntp-service status command output description
Clock status
Status of the system clock
Clock stratum
Stratum level of the local clock
Reference clock ID
After the system clock is synchronized to a remote time server or a local reference source, this field indicates the address of the remote time server or the identifier of the local clock source respectively:
l      When the local clock has a stratum level of 1, the value of this field is “LOCL”;
l      When the stratum of the local clock has another value, the value of this filed is the IP address of the local clock.
Nominal frequency
The nominal frequency of the local system hardware clock
Actual frequency
The actual frequency of the local system hardware clock
Clock precision
The precision of the system clock
Clock offset
The offset of the system clock relative to the reference source
Root delay
Root dispersion
The maximum error of the system clock relative to the primary reference source
Peer dispersion
Reference time
Reference timestamp
display ntp-service trace
View
Default Level
1: Monitor level
None
Use the display ntp-service trace command view the brief information of each NTP server along the NTP server chain from the local AP back to the primary reference source.
The display ntp-service trace command takes effect only if routes are available between the local AP and all the APs on the NTP server chain; otherwise, this command will fail to display all the NTP servers on the NTP chain due to timeout.
# View the brief information of each NTP server from the local AP back to the primary reference source.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
 server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
 refid LOCL
The information above shows an NTP server chain for the server 127.0.0.1: The server 127.0.0.1 is synchronized to the server 133.1.1.1, and the server 133.1.1.1 is synchronized to the local clock source.
Table 1-4 display ntp-service trace command output description
server
IP address of the NTP server
stratum
The stratum level of the corresponding system clock
offset
The clock offset relative to the upper-level clock, in seconds.
synch distance
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL; otherwise, it is displayed as the IP address of the primary reference clock.
ntp-service access
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
View
Default Level
3: Manage level
peer: Specifies to permit full access. This level of right permits the peer APs to perform synchronization and control query to the local AP and also permits the local AP to synchronize its clock to that of a peer AP. Control query refers to query of NTP status information, such as alarm information, authentication status, and clock source information.
query: Specifies to permit control query. This level of right permits the peer APs to perform control query to the NTP service on the local AP but does not permit a peer AP to synchronize its clock to that of the local AP.
server: Specifies to permit server access and query. This level of right permits the peer APs to perform synchronization and control query to the local AP but does not permit the local AP to synchronize its clock to that of a peer AP.
synchronization: Specifies to permit server access only. This level of right permits a peer AP to synchronize its clock to that of the local AP but does not permit the peer APs to perform control query.
acl-number: Basic ACL number, in the range of 2000 to 2999
Use the ntp-service access command to configure the NTP service access-control right for a peer AP to access the local AP.
Use the undo ntp-service access command to remove the configured NTP service access-control right to the local AP.
By default, the local NTP service access-control right for a peer AP to access the local AP is set to peer.
From the highest NTP service access-control right to the lowest one are peer, server, synchronization, and query. When an AP receives an NTP request, it will perform an access-control right match and will use the first matched right.
Before specifying an ACL number in the ntp-service access command, make sure you have already created and configured this ACL.
The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication. The related command is ntp-service authentication enable.
# Configure APs on the subnet 10.10.0.0/16 to have the full access right to the local AP.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
undo ntp-service authentication enable
View
Default Level
3: Manage level
None
Use the ntp-service authentication enable command to enable NTP authentication.
Use the undo ntp-service authentication enable command to disable NTP authentication.
By default, NTP authentication is disabled.
Related commands: ntp-service authentication-keyid and ntp-service reliable authentication-keyid.
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
ntp-service authentication-keyid keyid authentication-mode md5 value
undo ntp-service authentication-keyid keyid
View
Default Level
3: Manage level
keyid: Authentication key ID, which ranges from 1 to 4294967295.
authentication-mode md5 value: Specifies to use the MD5 algorithm for key authentication, where value represents authentication key and is a string of 1 to 32 characters.
Use the ntp-service authentication-keyid command to set the NTP authentication key.
Use the undo ntp-service authentication-keyid command to remove the set NTP authentication key.
By default, no NTP authentication key is set.
In a network where there is a high security demand, the NTP authentication feature should be enabled for a system running NTP. This feature enhances the network security by means of the client-server key authentication, which prohibits a client from synchronizing with an AP that has failed authentication.
After the NTP authentication key is configured, you need to configure the key as a trusted key by using the ntp-service reliable authentication-keyid command.
l          Presently the system supports only the MD5 algorithm for key authentication.
l          You can set a maximum of 1,024 keys for each AP.
l          If an NTP authentication key is specified as a trusted key, the key automatically changes to untrusted after you delete the key. In this case, you do not need to execute the undo ntp-service reliable authentication-keyid command.
Related commands: ntp-service reliable authentication-keyid.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
ntp-service broadcast-client
undo ntp-service broadcast-client
View
Interface view
Default Level
3: Manage level
None
Use the ntp-service broadcast-client command to configure the AP to work in the NTP broadcast client mode and use the current interface to receive NTP broadcast packets.
Use the undo ntp-service broadcast-client command to cancel the configuration.
By default, the AP does not work in the NTP broadcast client mode.
# Configure the AP to work in the broadcast client mode and receive NTP broadcast messages on VLAN-interface 1.
[Sysname-Vlan-interface1] ntp-service broadcast-client
ntp-service broadcast-server
undo ntp-service broadcast-server
View
Interface view
Default Level
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid ranges from 1 to 4294967295. This parameter is not meaningful if authentication is not required.
version number: Specifies the NTP version, where number is in the range of 1 to 3 and defaults to 3.
Use the ntp-service broadcast-server command to configure the AP to work in the NTP broadcast server mode and use the current interface to send NTP broadcast packets.
Use the undo ntp-service broadcast-server command to cancel the configuration.
By default, the AP does not work in the NTP broadcast server mode.
# Configure the AP to work in the broadcast server mode and send NTP broadcast messages on VLAN-interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
ntp-service in-interface disable
undo ntp-service in-interface disable
View
Interface view
Default Level
3: Manage level
None
Use the ntp-service in-interface disable command to disable an interface from receiving NTP messages.
Use the undo ntp-service in-interface disable command to restore the default.
By default, all interfaces are enabled to receive NTP messages.
# Disable VLAN-interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Default Level
3: Manage level
number: Maximum number of dynamic NTP sessions that are allowed to be established, in the range of 0 to 100.
Use the ntp-service max-dynamic-sessions command to set the maximum number of dynamic NTP sessions that are allowed to be established locally.
Use the undo ntp-service max-dynamic-sessions command to restore the maximum number of dynamic NTP sessions to the system default.
By default, the number is 100.
A single AP can have a maximum of 128 associations at the same time, including static associations and dynamic associations. A static association refers to an association that a user has manually created by using an NTP command, while a dynamic association is a temporary association created by the system during operation. A dynamic association will be removed if the system fails to receive messages from it over a specific long time. In the client/server mode, for example, when you carry out a command to synchronize the time to a server, the system will create a static association, and the server will just respond passively upon the receipt of a message, rather than creating an association (static or dynamic). In the symmetric mode, static associations will be created at the symmetric-active peer side, and dynamic associations will be created at the symmetric-passive peer side; in the broadcast or multicast mode, static associations will be created at the server side, and dynamic associations will be created at the client side.
# Set the maximum number of dynamic NTP sessions allowed to be established to 50.
[Sysname] ntp-service max-dynamic-sessions 50
ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
Interface view
Default Level
3: Manage level
ip-address: Multicast IP address, defaulting to 224.0.1.1.
Use the ntp-service multicast-client command to configure the AP to work in the NTP multicast client mode and use the current interface to receive NTP multicast packets.
Use the undo ntp-service multicast-client command to cancel the configuration.
By default, the AP does not work in the NTP multicast client mode.
# Configure the AP to work in the multicast client mode and receive NTP multicast messages on VLAN-interface 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
ntp-service multicast-server
undo ntp-service multicast-server [ ip-address ]
View
Interface view
Default Level
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending multicast messages to multicast clients, where keyid is in the range of 1 to 4294967295. This parameter is not meaningful if authentication is not required.
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number is in the range of 1 to 255 and defaults to 16.
Use the ntp-service multicast-server command to configure the AP to work in the NTP multicast server mode and use the current interface to send NTP multicast packets.
Use the undo ntp-service multicast-server command to cancel the configuration.
By default, the AP does not work in the NTP multicast server mode.
# Configure the AP to work in the multicast server mode and send NTP multicast messages on VLAN-interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
undo ntp-service reliable authentication-keyid keyid
View
Default Level
3: Manage level
keyid: Authentication key number, in the range of 1 to 4294967295.
Use the ntp-service reliable authentication-keyid command to specify that the created authentication key is a trusted key. When NTP authentication is enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Use the undo ntp-service reliable authentication-keyid command to remove a trusted authentication key.
No authentication key is configured to be trusted by default.
# Enable NTP authentication, specify to use MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
# Specify this key as a trusted key.
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Default Level
3: Manage level
interface-type interface-number: Specifies an interface by its interface type and interface number.
Use the ntp-service source-interface command to specify the source interface for sending NTP messages.
Use the undo ntp-service source-interface command to restore the default.
By default, no source interface is specified for NTP messages, and the system uses the IP address of the interface determined by the matched route as the source IP address of NTP messages.
If you do not wish the IP address of a certain interface on the local AP to become the destination address of response messages, you can use this command to specify the source interface for sending all NTP messages, so that the source address in all NTP messages is the primary IP address of this interface.
# Specify VLAN-interface 1 as the source interface for all NTP messages.
[Sysname] ntp-service source-interface vlan-interface 1
ntp-service unicast-server
ntp-service unicast-server { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-server { ip-address | server-name }
View
Default Level
3: Manage level
ip-address: IP address of the NTP server. It must be a unicast address, rather than a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid is in the range of 1 to 4294967295.
priority: Specifies this NTP server as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for sending NTP messages. In an NTP message the local AP sends to the NTP server, the source IP address is the primary IP address of this interface. interface-type interface-number represents the interface type and number.
Use the ntp-service unicast-server command to designate an NTP server for the AP.
Use the undo ntp-service unicast-server command to remove an NTP server designated for the AP.
No NTP server is designated for the AP by default.
# Designate NTP server 10.1.1.1 for the AP, and configure the AP to run NTP version 3.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
