10-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series WLAN Access Points Command Reference-6W10010-Network Management and Monitoring Command Reference
01-Feature Matrix
01-Feature Matrix 37.91 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Read this chapter before using an H3C WA series WLAN access point.
H3C WA series WLAN access points include the WA2200 series and WA2600 series. Table 1-1 shows the applicable models and software versions.
Table 1-1 Applicable models and software versions
Series
Model
Software version
WA2200 series
WA2200 series access points (indoors)
WA2210-AG
R 1115
WA2220-AG
WA2200 series access points (outdoors)
WA2210X-G
WA2220X-AG
WA2600 series
WA2600 series access points (indoors)
WA2610-AGN
R 1106
WA2612-AGN
WA2620-AGN
WA2600 series access points (enhanced)
WA2610E-AGN
R 1109
WA2620E-AGN
l          Support of the H3C WA series WLAN access points for features, commands and parameters may vary by device model. See this document for more information.
l          For information about feature support, see Table 2-1. For information about command and parameter support, see Table 3-1.
l          The term AP in this document refers to common APs, wireless bridges, or mesh APs.
Table 2-1 Feature matrix
Document
Feature
WA2200 series
WA2600 series
Fundamentals Configuration Guide
HTTPS
Not supported
Supported
WLAN Configuration Guide
802.11n radio mode
Not supported
Supported
802.11n bandwidth mode
Not supported
Supported
802.11n rate configuration
Not supported
Supported
Layer 2 – LAN Switching Configuration Guide
Optical Ethernet interface
Supported on WA2210X-G/WA2220X-AG only
Not supported
GE interface
Not supported
Supported
Layer 3 – IP Services Configuration Guide
DHCP server configuration
Not supported
Supported
DHCPv6 configuration
Not supported
Supported
IP Multicast Configuration Guide
IGMP snooping configuration
Not supported
Supported
MLD snooping configuration
Not supported
Supported
Security Configuration Guide
SSH2.0
Not supported
Supported
Table 3-1 Command/Parameter matrix
Document
Module
Command/Parameter
WA2200 series
WA2600 series
Fundamentals Command Reference
HTTP commands
display ip https
Not supported
Supported
ip https acl
Not supported
Supported
ip https certificate access-control-policy
Not supported
Supported
ip https enable
Not supported
Supported
WLAN Command Reference
WLAN service commands
a-mpdu enable
Not supported
Supported
a-msdu enable
Not supported
Supported
channel band-width
Not supported
Supported
client dot11n-only
Not supported
Supported
preamble { long | short }
Only APs that support the 802.11b/g radio mode support this command.
radio-type
Keywords dot11an and dot11gn not supported
Supported
short-gi enable
Not supported
Supported
WLAN RRM commands
dot11a { disabled-rate | mandatory-rate | supported-rate } rate-value
Only APs that support 802.11a radio mode support this command.
dot11n mandatory maximum-mcs
Not supported
Supported
dot11n support maximum-mcs
Not supported
Supported
power-constraint power-constraint
Only APs that support the 802.11a radio mode support this command.
Layer 2 – LAN Switching Command Reference
The maximum number of broadcast packets that can be forwarded on an Ethernet interface per second
broadcast-suppression { ratio | pps max-pps }
pps max-pps ranges from 1 to 148810.
pps max-pps ranges from 1 to 1488100.
The maximum number of multicast packets allowed on an Ethernet interface per second
multicast-suppression { ratio | pps max-pps }
The maximum number of unknown unicast packets allowed on an Ethernet interface per second
unicast-suppression { ratio | pps max-pps }
Layer 3 - IP Services Command Reference
DHCP commands
DHCP server configuration commands
Not supported
Supported
DHCPv6 commands
display ipv6 dhcp client [ interface interface-type interface-number ]
Not supported
Supported
display ipv6 dhcp client statistics [ interface interface-type interface-number ]
Not supported
Supported
display ipv6 dhcp duid
Not supported
Supported
reset ipv6 dhcp client statistics [ interface interface-type interface-number ]
Not supported
Supported
