05-Network Connectivity Command Reference
HomeSupportWirelessWX5800X Series Access ControllersReference GuidesCommand ReferencesH3C WX5800X Series Access Controllers Command References(E5457)-5W10005-Network Connectivity Command Reference
24-IP forwarding basics commands
24-IP forwarding basics commands 45.98 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ ip-address [ mask | mask-length ] ]
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display FIB entries for topology mt.
<Sysname> display fib topology mt
Destination count: 8 FIB entry count: 8
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
224.0.0.0/4        0.0.0.0         UB       NULL0                    Null
224.0.0.0/24       0.0.0.0         UB       NULL0                    Null
255.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
# Display all FIB entries of the public network.
Destination count: 5 FIB entry count: 5
Flag:
  R:Relay     F:FRR
1.1.1.0/24         192.168.126.1   USGF     M-GE0/0/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
