05-Network Connectivity Command Reference
HomeSupportWirelessWX5800X Series Access ControllersReference GuidesCommand ReferencesH3C WX5800X Series Access Controllers Command References(E5457)-5W10005-Network Connectivity Command Reference
20-IPv6 policy-based routing commands
20-IPv6 policy-based routing commands 113.92 KB
apply continue
Use apply continue to compare packets with the next policy node upon failure on the current node.
Use undo apply continue to restore the default.
apply continue
undo apply continue
IPv6 PBR does not compare packets with the next policy node upon failure on the current node.
IPv6 policy node view
This command takes effect only when the mode of the node is permit.
This command applies when either of the following conditions exist:
·     None of the following clauses is configured for packet forwarding:
¡     apply next-hop
¡     apply output-interface
¡     apply default-next-hop
¡     apply default-output-interface
·     A clause listed above is configured, but it has become invalid. Then, a routing table lookup also fails for the matching packet.
A clause might become invalid because the specified next hop is unreachable or the specified output interface is down.
# Compare with the next policy node upon failure on the current node.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply continue
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop { ipv6-address [ direct ] [ track track-entry-number ] }&<1-4>
undo apply default-next-hop [ ipv6-address&<1-4> ]
No default next hop is set.
ipv6-address: Specifies  the IPv6 address of a default next hop.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-4>: Indicates that you can specify up to four default next hops, each of which can be associated with a track entry.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
apply loadshare
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply default-output-interface [ { interface-type interface-number }&<1-4> ]
No default output interface is set.
&<1-4>: Indicates that you can specify up to four interfaces, each of which can be associated with a track entry.
You can specify multiple default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and non-broadcast multi-access (NBMA) interfaces such as Ethernet and virtual-template interfaces. In NBMA networks, packets are sent in unicast.
With a default output interface specified, the undo apply default-output-interface command removes the default output interface.
Without any default output interface specified, the undo apply default-output-interface command removes all default output interfaces.
# Specify VLAN-interface 2 as the default output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply default-output-interface vlan-interface 2
apply loadshare
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops, output interfaces, default next hops, or default output interfaces.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
undo apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in primary/backup mode.
default-next-hop: Enables load sharing among multiple default next hops.
default-output-interface: Enables load sharing among multiple default output interfaces.
next-hop: Enables load sharing among multiple next hops.
output-interface: Enables load sharing among multiple output interfaces.
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in either primary/backup or load sharing mode. For example:
·     Primary/backup mode—The first configured output interface is used. When the primary output interface fails, the first configured backup output interface takes over.
·     Load sharing mode—Multiple output interfaces load share traffic on a per-packet basis in turn, according to the configuration order.
Multiple next hops load share traffic according to their weights. By default, all next hops have the same weight and traffic is load balanced among them.
# Enable load sharing among multiple next hops.
[Sysname-pbr6-aa-11] apply next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare next-hop
# Enable load sharing among multiple output interfaces.
[Sysname-pbr6-aa-11] apply output-interface vlan-interface 1 vlan-interface 2
[Sysname-pbr6-aa-11] apply loadshare output-interface
# Enable load sharing among multiple default next hops.
[Sysname-pbr6-aa-11] apply default-next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare default-next-hop
# Enable load sharing among multiple default output interfaces.
[Sysname-pbr6-aa-11] apply default-output-interface vlan-interface 1 vlan-interface 2
[Sysname-pbr6-aa-11] apply loadshare default-output-interface
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop  { ipv6-address [ direct ] [ track track-entry-number ] } &<1-4>
undo apply next-hop [ ipv6-address&<1-4> ]
No next hop is set.
ipv6-address: Specifies the IPv6 address of a next hop.
direct: Specifies that the next hop must be directly connected to take effect.
&<1-4>: Indicates that you can specify up to four next hops, each of which can be associated with a track entry.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1::1.
apply loadshare
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply output-interface [ { interface-type interface-number }&<1-4> ]
No output interface is set.
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify VLAN-interface 2 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface vlan-interface 2
apply loadshare
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
display ipv6 policy-based-route
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
    apply next-hop 1000::1
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares IPv6 packets with IPv6 ACL.
apply next-hop
Specifies a next hop for permitted IPv6 packets.
ipv6 policy-based-route (system view)
display ipv6 policy-based-route interface
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 interface PBR configuration and statistics for the master device.
# Display IPv6 PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ipv6 policy-based-route interface Vlan-inerface2
Policy based routing information for interface Vlan-inerface2:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit(no resource):
    if-match acl 2000
    apply output-interface Vlan-inerface3 track 1 (down)
    apply output-interface Vlan-inerface4 track 2 (inactive)
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
Policy based routing information for interface XXXX(failed)
IPv6 PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
Compares IPv6 packets with the IPv6 ACL.
apply next-hop
apply output-interface  track 1 (down)
Specifies an output interface for permitted packets. The interface status includes the following:
·     up—The interface is up.
·     down—The interface is down at network layer.
·     inactive—The interface is not in position.
Matched
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
Total matched
Total number of successful matches on all nodes.
reset ipv6 policy-based-route statistics
display ipv6 policy-based-route local
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 local PBR configuration and statistics for the master device.
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 1::1
  Matched: 0
  node 5 permit:
    if-match acl 3101
    apply next-hop 2::2
  Matched: 0
Total matched: 0
node 0 deny/node 2 permit
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
Matched: 0
Total matched
display ipv6 policy-based-route setup
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name              Type               Interface
pr01                     Forward            Vlan-interface 2
pr02                     Local              N/A
Table 5 Command output
Policy name
Name of the IPv6 PBR policy.
IPv6 PBR type:
·     Forward—IPv6 interface PBR.
·     Local—IPv6 local PBR.
Interface where the IPv6 PBR policy is applied.
This field displays N/A for IPv6 local PBR.
ipv6 policy-based-route (interface view)
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic or advanced ACL.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
ipv6 local policy-based-route
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name
No IPv6 is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
snmp-agent trap enable ipv6 policy-based-route
Use snmp-agent trap enable ipv6 policy-based-route to enable SNMP notifications for IPv6 PBR.
Use undo snmp-agent trap enable ipv6 policy-based-route to disable SNMP notifications for IPv6 PBR.
SNMP notifications are enabled for IPv6 PBR.
After you enable this feature, IPv6 PBR can generate notifications and send them to the SNMP module when the next hop becomes invalid. For the IPv6 PBR notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for IPv6 PBR.
[Sysname] snmp-agent trap enable ipv6 policy-based-route
