- H3C WSG1840X Wireless Integrated Services Gateway Installation Guide-5W103
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 07-Appendix B LEDs | 91.63 KB |
1 Appendix B LEDs
LEDs
(1) System status LED (SYS) |
(2) SFP+ port LED |
(3) 2.5G/5G autosensing port LED |
(4) 100/1000M autosensing port LEDs |
(5) 100/1000M autosensing port LEDs |
LED description
LED |
Mark |
Status |
System status LED |
SYS |
Flashing green (4 Hz) |
The system is starting up. |
Flashing green (0.5 Hz) |
The system is operating correctly. |
Steady red |
A critical alarm has occurred, such as a high temperature alarm, or software missing alarm. |
Off |
The device has not started up. |
100/1000BASE-T |
Steady green |
A 100/1000 Mbps link is present on the port. |
Flashing green |
The port is receiving or transmitting data at 100/1000 Mbps. |
Off |
No link is present on the port. |
SFP+ port LED |
SFP+ |
Steady green |
A 1000 Mbps or 10 Gbps link is present on the port. |
Flashing green |
The port is receiving or sending data at 1000 Mbps or 10 Gbps. |
Off |
2.5G/5GBASE-T |
Steady green |
A 1000 Mbps, 2.5 Gbps, or 5 Gbps link is present on the port. |
Flashing green |
The port is receiving or sending data at 1000 Mbps, 2.5 Gbps, or 5 Gbps. |
Off |
