- H3C WSG1840X Wireless Integrated Services Gateway Installation Guide-5W103
- 01-Preparing for installation
- 02-Installing the device
- 03-Log in to the device
- 04-Hardware management and maintenance
- 05-Troubleshooting
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 06-Appendix A Chassis views and technical specifications | 150.82 KB |
1 Appendix A Chassis views and technical specifications
Chassis views
(1) Reset button (RESET) |
(2) USB port |
(3) Console port |
(4) SFP+ port |
(5) 2.5G/5GBASE-T autosensing Ethernet port |
(6) 100/1000BASE-T autosensing Ethernet ports WAN 5 and WAN 6 |
(7) 100/1000BASE-T autosensing Ethernet ports LAN 1 to LAN 4 |
Figure1-2 Rear view
(1) AC-input power receptacle |
(2) Grounding screw |
Technical specifications
Table1-1 Technical specifications
Item |
Specification |
Console port |
One, 9600 bps (default) to 115200 bps |
USB port |
USB 2.0, used for data transfer |
GE port |
· 6 × 100/1000BASE-T autosensing Ethernet copper ports · 1 × 2.5G/5GBASE-T autosensing Ethernet copper port |
SFP+ port |
1 × 10G fiber port |
· To restore the device to factory default settings, press and hold the button for more than 5 seconds after the device starts up normally. · To reset the device, press and hold the button for more than 15 ms. NOTE: During startup of the device, you can only use the reset button to reset the device. |
Memory |
2GB DDR4 |
Storage media |
4GB eMMC memory |
Dimensions (H × W × D) (excluding the rubber feet and mounting brackets) |
43.6 × 440 × 165 mm (1.72 × 17.32 × 6.50 in) |
AC power supply |
Rated voltage range: 100 to 240 VAC @ 50/60 Hz |
System power consumption |
6.4W to 14.4 W |
Weight |
1.8 kg (3.97 lb) |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH |
