| 00-Preface | 110.22 KB |
Preface
The installation guide describes product models, technical specifications, ports,and LEDs of the H3C S5560S-SI, S5500V3-SI, S5130S-SI, S5130S-LI, S5120V2-SI, S5120V2-LI, S5110V2-SI, S5000V3-EI, S5000V5-EI, and S3100V3-SI Switch Series.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
