H3C S5560S-SI&S5500V3-SI&S5130S-SI[LI]&S5120V2-SI[LI]&S5110V2-SI&S5000V3[V5]-EI&S3100V3-SI Hardware Information and Specifications-6W108
HomeSupportProduct LiteratureHardware Information & SpecificationsH3C S5560S-SI&S5500V3-SI&S5130S-SI[LI]&S5120V2-SI[LI]&S5110V2-SI&S5000V3[V5]-EI&S3100V3-SI Hardware Information and Specifications-6W108
01-Hardware Information and Specifications
01-Hardware Information and Specifications 9.02 MB
Product models and technical specifications· 3
Product models· 3
Technical specifications· 6
S5560S-SI switch series· 6
S5500V3-SI switch series· 8
S5130S-SI & S5130S-LI switch series· 12
S5120V2-SI & S5120V2-LI switch series· 14
S5110V2-SI switch series· 17
S5000V3-EI switch series· 18
S5000V5-EI switch series· 20
S3100V3-SI switch series· 24
Chassis views· 28
S5560S-SI switch series· 28
S5560S-28P-SI 28
S5560S-52P-SI 28
S5560S-28S-SI 29
S5560S-52S-SI 30
S5560S-28F-SI 30
S5560S-28DP-SI 31
S5500V3-SI switch series· 32
S5500V3-24P-SI 32
S5500V3-48P-SI 33
S5500V3-28S-SI 33
S5500V3-28PS-SI 34
S5500V3-54S-SI 35
S5500V3-54PS-SI 35
S5500V3-36F-SI 36
S5500V3-28S-DP-SI 37
S5500V3-54S-DP-SI 38
S5500V3-36F-DP-SI 39
S5500V3-54F-DP-SI 40
S5130S-SI & S5130S-LI switch series· 41
S5130S-28S-SI & S5130S-28S-LI 41
S5130S-28S-SI-MM & S5130S-28S-LI-MM·· 41
S5130S-28S-SI-SM & S5130S-28S-LI-SM·· 42
S5130S-52S-SI & S5130S-52S-LI 43
S5130S-28F-SI 44
S5130S-28S-PWR-LI 45
S5130S-28S-HPWR-LI 45
S5130S-52S-PWR-LI 46
S5120V2-SI & S5120V2-LI switch series· 47
S5120V2-10P-SI & S5120V2-10P-LI 47
S5120V2-20P-LI 47
S5120V2-28P-SI & S5120V2-28P-LI 48
S5120V2-52P-SI & S5120V2-52P-LI 49
S5120V2-10P-PWR-LI 49
S5120V2-28P-PWR-LI 50
S5120V2-28P-HPWR-LI 51
S5120V2-52P-PWR-LI 51
S5120V2-12TP-HPWR-LI 52
S5110V2-SI switch series· 53
S5110V2-28P-SI 53
S5110V2-52P-SI 53
S5000V3-EI switch series· 54
S5016PV3-EI 54
S5024PV3-EI 55
S5048PV3-EI 55
S5024PV3-EI-PWR· 56
S5024PV3-EI-HPWR· 57
S5048PV3-EI-PWR· 57
S5024FV3-EI 58
S5000V5-EI switch series· 59
S5008PV5-EI 59
S5008PV5-EI-S· 60
S5016PV5-EI 60
S5016PV5-EI-S· 61
S5024PV5-EI 61
S5024PV5-EI-S· 62
S5048PV5-EI 63
S5008PV5-EI-HPWR· 63
S5008PV5-EI-HPWR-S· 64
S5016PV5-EI-PWR-S· 65
S5024PV5-EI-PWR· 66
S5024PV5-EI-PWR-S· 66
S5024PV5-EI-HPWR· 67
S5048PV5-EI-PWR· 68
S3100V3-SI switch series· 68
S3100V3-10TP-SI 68
S3100V3-18TP-SI 69
S3100V3-28TP-SI 70
S3100V3-52TP-SI 70
S3100V3-10TP-PWR-SI 71
S3100V3-20TP-PWR-SI 72
S3100V3-28TP-PWR-SI 72
Removable components· 74
Power supplies· 74
Ports and LEDs· 76
Ports· 76
Console port 76
Management Ethernet port 76
USB port 77
10/100BASE-T autosensing Ethernet port 77
10/100/1000BASE-T autosensing Ethernet port 77
SFP port (LS-5008PV5-EI and LS-5008PV5-EI-HPWR switches) 78
SFP port (S5500V3-SI switch series) 79
SFP port (switches other than the S5008PV5-EI and S5008PV5-EI-HPWR) 82
SFP+ port 86
Combo interface· 89
LEDs· 89
System status LED·· 89
Management Ethernet port LED·· 90
Power supply status LED·· 90
RPS status LED·· 90
Mode LED (MODE) 91
SFP port LED (S5500V3-36F-DP-SI switch) 91
SFP/SFP+ port LED·· 91
10/100BASE-T autosensing Ethernet port LED and 10/100/1000BASE-T autosensing Ethernet port LED   92
Product models
This document provides an installation guide for the following switch series:
·     S5560S-SI switch series
·     S5500V3-SI switch series
·     S5130S-SI switch series
·     S5130S-LI switch series
·     S5120V2-SI switch series
·     S5120V2-LI switch series
·     S5110V2-SI switch series
·     S5000V3-EI switch series
·     S5000V5-EI switch series
·     S3100V3-SI switch series
Table 1 describes the switch models that each switch series includes.
Table 1 Switch series and models
Switch series
Model
Product code (PID)
Non-PoE models
S5560S-28P-SI
LS-5560S-28P-SI
LS-5560S-28P-SI-GL
S5560S-52P-SI
LS-5560S-52P-SI
LS-5560S-52P-SI-GL
S5560S-28S-SI
LS-5560S-28S-SI
LS-5560S-28S-SI-GL
S5560S-52S-SI
LS-5560S-52S-SI
LS-5560S-52S-SI-GL
S5560S-28F-SI
LS-5560S-28F-SI
S5560S-28DP-SI
LS-5560S-28DP-SI
Non-PoE models
S5130S-28S-SI
LS-5130S-28S-SI
S5130S-28S-SI-MM
LS-5130S-28S-SI-MM
S5130S-28S-SI-SM
LS-5130S-28S-SI-SM
S5130S-52S-SI
LS-5130S-52S-SI
S5130S-28F-SI
LS-5130S-28F-SI
Non-PoE models
S5130S-28S-LI
LS-5130S-28S-LI
LS-5130S-28S-LI-GL
S5130S-28S-LI-MM
LS-5130S-28S-LI-MM
S5130S-28S-LI-SM
LS-5130S-28S-LI-SM
S5130S-52S-LI
LS-5130S-52S-LI
LS-5130S-52S-LI-GL
PoE models
S5130S-28S-PWR-LI
LS-5130S-28S-PWR-LI
S5130S-28S-HPWR-LI
LS-5130S-28S-HPWR-LI
S5130S-52S-PWR-LI
LS-5130S-52S-PWR-LI
Non-PoE models
S5120V2-10P-SI
LS-5120V2-10P-SI
S5120V2-28P-SI
LS-5120V2-28P-SI
S5120V2-52P-SI
LS-5120V2-52P-SI
Non-PoE models
S5120V2-10P-LI
LS-5120V2-10P-LI
LS-5120V2-10P-LI-GL
S5120V2-20P-LI
LS-5120V2-20P-LI
LS-5120V2-20P-LI-GL
S5120V2-28P-LI
LS-5120V2-28P-LI
LS-5120V2-28P-LI-GL
S5120V2-52P-LI
LS-5120V2-52P-LI
LS-5120V2-52P-LI-GL
PoE models
S5120V2-10P-PWR-LI
LS-5120V2-10P-PWR-LI
LS-5120V2-10P-PWR-LI-GL
S5120V2-28P-PWR-LI
LS-5120V2-28P-PWR-LI
LS-5120V2-28P-PWR-LI-GL
S5120V2-28P-HPWR-LI
LS-5120V2-28P-HPWR-LI
LS-5120V2-28P-HPWR-LI-GL
S5120V2-52P-PWR-LI
LS-5120V2-52P-PWR-LI
LS-5120V2-52P-PWR-LI-GL
LS-5120V2-12TP-HPWR-LI
Non-PoE models
S5110V2-28P-SI
LS-5110V2-28P-SI
S5110V2-52P-SI
LS-5110V2-52P-SI
Non-PoE models
S5016PV3-EI
LS-5016PV3-EI
LS-5016PV3-EI-GL
S5024PV3-EI
LS-5024PV3-EI
LS-5024PV3-EI-GL
S5048PV3-EI
LS-5048PV3-EI
LS-5048PV3-EI-GL
S5024FV3-EI
LS-5024FV3-EI
LS-5024FV3-EI-GL
PoE models
S5024PV3-EI-PWR
LS-5024PV3-EI-PWR
LS-5024PV3-EI-PWR-GL
S5024PV3-EI-HPWR
LS-5024PV3-EI-HPWR
LS-5024PV3-EI-HPWR-GL
S5048PV3-EI-PWR
LS-5048PV3-EI-PWR
LS-5048PV3-EI-PWR-GL
Non-PoE models
S5008PV5-EI
LS-5008PV5-EI
LS-5008PV5-EI-H1
S5008PV5-EI-S
LS-5008PV5-EI-S-GL
S5016PV5-EI
LS-5016PV5-EI
S5016PV5-EI-S
LS-5016PV5-EI-GL
S5024PV5-EI
LS-5024PV5-EI
LS-5024PV5-EI-GL
S5024PV5-EI-S
LS-5024PV5-EI-S-GL
S5048PV5-EI
LS-5048PV5-EI
LS-5048PV5-EI-GL
PoE models
S5008PV5-EI-HPWR
LS-5008PV5-EI-HPWR
LS-5008PV5-EI-HPWR-H1
LS-5008PV5-EI-HPWR-GL
S5008PV5-EI-HPWR-S
LS-5008PV5-EI-HPWR-S-GL
S5016PV5-EI-PWR-S
LS-5016PV5-EI-PWR-S-GL
S5024PV5-EI-PWR
LS-5024PV5-EI-PWR
S5024PV5-EI-PWR-S
LS-5024PV5-EI-PWR-S-GL
S5024PV5-EI-HPWR
LS-5024PV5-EI-HPWR
LS-5024PV5-EI-HPWR-GL
S5048PV5-EI-PWR
LS-5048PV5-EI-PWR
LS-5048PV5-EI-PWR-GL
Non-PoE models
S5500V3-24P-SI
LS-5500V3-24P-SI
S5500V3-48P-SI
LS-5500V3-48P-SI
S5500V3-28S-SI
LS-5500V3-28S-SI
S5500V3-28PS-SI
LS-5500V3-28PS-SI
S5500V3-54S-SI
LS-5500V3-54S-SI
S5500V3-54PS-SI
LS-5500V3-54PS-SI
S5500V3-36F-SI
LS-5500V3-36F-SI
S5500V3-28S-DP-SI
LS-5500V3-28S-DP-SI
S5500V3-54S-DP-SI
LS-5500V3-54S-DP-SI
S5500V3-36F-DP-SI
LS-5500V3-36F-DP-SI
S5500V3-54F-DP-SI
LS-5500V3-54F-DP-SI
Non-PoE models
S3100V3-10TP-SI
LS-3100V3-10TP-SI
LS-3100V3-10TP-SI-H1
S3100V3-18TP-SI
LS-3100V3-18TP-SI
LS-3100V3-18TP-SI-H1
S3100V3-28TP-SI
LS-3100V3-28TP-SI
LS-3100V3-28TP-SI-H1
S3100V3-52TP-SI
LS-3100V3-52TP-SI
LS-3100V3-52TP-SI-H1
PoE models
S3100V3-10TP-PWR-SI
LS-3100V3-10TP-PWR-SI
LS-3100V3-10TP-PWR-SI-H1
S3100V3-20TP-PWR-SI
LS-3100V3-20TP-PWR-SI
LS-3100V3-20TP-PWR-SI-H1
S3100V3-28TP-PWR-SI
LS-3100V3-28TP-PWR-SI
LS-3100V3-28TP-PWR-SI-H1
Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel.
Table 2 Technical specifications for the S5560S-SI switch series (1)
Item
S5560S-28P-SI
S5560S-52P-SI
S5560S-28S-SI
S5560S-52S-SI
Dimensions (H × W × D)
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)
43.6 × 440 × 230 mm (1.72 × 17.32 × 9.06 in)
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
1 × serial console port
·     1 × micro USB console port
·     1 × serial console port
Only the micro USB console port is available when you connect both ports.
24
48
24
48
SFP port
4
4
N/A
N/A
SFP+ port
N/A
N/A
4
4
Input voltage
·     Rated voltage: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage: 90 VAC to 264 VAC @ 47 to 63 Hz
Minimum power consumption
9 W
18 W
10 W
19 W
Maximum power consumption
23 W
41 W
24 W
44 W
Chassis leakage current compliance
UL 62368-1/EN 62368-1/IEC 62368-1/UL 60950-1/EN 60950-1/IEC 60950-1/GB4943.1
Melting current of power supply fuse
2 A/250 V
3.15 A/250 V
2 A/250 V
3.15 A/250 V
Cooling system
Natural cooling without fan trays
Using fixed fan trays to intake cool air from the chassis left side and right side and exhaust hot air from the chassis power supply side
Using fixed fan trays to intake cool air from the chassis left and right sides and the port side and exhaust hot air from the power supply side
Operating temperature
–5°C to +45°C (23°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
Fire resistance compliance
Table 3 Technical specifications for the S5560S-SI switch series (2)
Item
S5560S-28F-SI
S5560S-28DP-SI
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in)
Weight
≤ 6 kg (13.23 lb)
≤ 8 kg (17.64 lb)
Console port
·     Only the micro USB console port is available when you connect both ports.
USB port
N/A
1
1
1
8 (Each and its corresponding SFP port form a combo interface.)
24 (The eight highest-numbered 10/100/1000BASE-T autosensing Ethernet port and their corresponding SFP ports form combo interfaces.)
SFP port
24 (The eight highest-numbered SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces.)
12 (The eight highest-numbered SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces.)
SFP+ port
4
N/A
Power supply slot
2, on the rear panel
Input voltage
·     AC input
¡     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
¡     Max voltage range: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
·     High-voltage DC input
¡     Rated voltage range: 240 VDC
¡     Max voltage range: 180 VDC to 320 VDC
·     AC input
·     Single PSR75-12A: 15 W
·     Dual PSR75-12A: 17 W
·     Single PSR75-12A: 12 W
·     Dual PSR75-12A: 13 W
·     Single PSR75-12A: 45 W
·     Dual PSR75-12A: 48 W
·     Single PSR75-12A: 29 W
·     Dual PSR75-12A: 32 W
3.15 A/250 V
Cooling system
Using fixed fan trays to intake cool air from the chassis left side and port side and exhaust hot air from the chassis right side.
Operating humidity
Table 4 Technical specifications for S5500V3-SI switch models (1)
Item
S5500V3-24P-SI
S5500V3-48P-SI
S5500V3-28S-SI
S5500V3-28PS-SI
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
≤ 2.2 kg (4.85 lb)
≤ 2.2 kg (4.85 lb)
Console port
Only the micro USB console port is active when you connect both ports.
24
48
24
24
SFP port
2
2
N/A
2
SFP+ port
2
2
4
2
Input voltage
10 W
19 W
17 W
17 W
24 W
44 W
37 W
37 W
2 A/250 V
3.15 A/250 V
2 A/250 V
2 A/250 V
Cooling system
Using fixed fan trays to intake cool air from the chassis left side, right side, and port side and exhaust hot air from the power supply side
Left-right air aisle, intaking cool air from the chassis left side and exhausting hot air from the chassis right side
Operating humidity
Table 5 Technical specifications for S5500V3-SI switch models (2)
Item
S5500V3-54S-SI
S5500V3-54PS-SI
S5500V3-36F-SI
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
Weight
≤ 4 kg (8.82 lb)
≤ 4 kg (8.82 lb)
≤ 3.5 kg (7.72 lb)
Console port
48
48
8
SFP port
N/A
4
24
SFP+ port
6
2
4
Input voltage
·     Rated voltage range: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage range: 85 VAC to 264 VAC @ 47 to 63 Hz
·     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
19 W
19 W
27 W
53 W
53 W
54 W
3.15 A/250 V
Cooling system
Left-right air aisle, intaking cool air from the chassis left side and exhausting hot air from the chassis right side.
Operating humidity
Table 6 Technical specifications for S5500V3-SI switch models (3)
Item
S5500V3-28S-DP-SI
S5500V3-54S-DP-SI
S5500V3-36F-DP-SI
S5500V3-54F-DP-SI
Weight
≤ 5.6 kg (12.35 lb)
≤ 6 kg (13.23 lb)
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
Console port
N/A
1
24
48
8
N/A
SFP port
N/A
N/A
24
48
SFP+ port
4
6
4
6
Input voltage
CA-70A12 power supply:
·     Max voltage: 90 VAC to 290 VAC @ 47 to 63 Hz
PSR75-12A power supply:
PSR150-D1 power supply (–48 VDC power source in the equipment room or an H3C RPS1600-A):
·     Rated voltage: –48 VDC to –60 VDC
·     Max voltage: –36 VDC to –72 VDC
·     Single AC: 16 W
·     Single DC: 22 W
·     Dual AC: 18 W
·     Dual DC: 27 W
·     Single AC: 18 W
·     Single DC: 23 W
·     Dual AC: 23 W
·     Dual DC: 29 W
·     Single AC: 29 W
·     Single DC: 30 W
·     Dual AC: 35 W
·     Dual DC: 35 W
·     Single AC: 36 W
·     Single DC: 38 W
·     Dual AC: 43 W
·     Dual DC: 43 W
·     Single AC: 37 W
·     Single DC: 41 W
·     Dual AC: 39 W
·     Dual DC: 45 W
·     Single AC: 55 W
·     Single DC: 56 W
·     Dual AC: 57 W
·     Dual DC: 61 W
·     Single AC: 52 W
·     Single DC: 54 W
·     Dual AC: 58 W
·     Dual DC: 60 W
·     Single AC: 77 W
·     Single DC: 77 W
·     Dual AC: 80 W
·     Dual DC: 84 W
·     CA-70A12 power supply: 10 A/250 V
·     PSR75-12A power supply: 3.15 A/250 V
·     PSR150-D1 power supply: 8 A/250 V
Cooling system
Operating humidity
Table 7 Technical specifications for the S5130S-SI & S5130S-LI non-PoE switch models
Item
S5130S-28S-SI
S5130S-28S-SI-MM
S5130S-28S-SI-SM
S5130S-28S-LI
S5130S-28S-LI-MM
S5130S-28S-LI-SM
S5130S-52S-SI
S5130S-52S-LI
S5130S-28F-SI
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
≤ 6 kg (13.23 lb)
Console port
N/A
1
24
48
SFP port
N/A
SFP+ port
4 (A 10-GE SFP+ transceiver module is built into port 28 on the S5130S-28S-SI-MM, S5130S-28S-SI-SM, S5130S-28S-LI-MM, and S5130S-28S-LI-SM switches. For the built-in transceiver module specifications, see Table 36.)
Power supply slot
N/A
Input voltage
·     AC input
10 W
19 W
24 W
44 W
2 A/250 V
3.15 A/250 V
3.15 A/250 V
Cooling system
Using fixed fan trays to intake cool air from the left side and right side and exhaust hot air from the power supply side
Operating humidity
Table 8 Technical specifications for the S5130S-LI PoE switch models
Item
S5130S-28S-PWR-LI
S5130S-52S-PWR-LI
S5130S-28S-HPWR-LI
43.6 × 440 × 260 mm (1.72 × 17.32 ×10.24 in)
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
Weight
≤ 4 kg (8.82 lb)
≤ 6 kg (13.23 lb)
≤ 4.5 kg (9.92 lb)
Console port
24
48
24 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports and their corresponding SFP ports form combo interfaces.)
SFP port
N/A
SFP+ port
4
4
4
Input voltage
AC input:
H3C RPS1600-A DC input (only for the S5130S-52S-PWR-LI and S5130S-28S-HPWR-LI):
·     Rated voltage range: –54 VDC to –57 VDC
¡     Single DC input: –44 VDC to –60 VDC
¡     DC and AC inputs: –54 VDC to –57 VDC
Maximum PoE power per port
30 W
Total PoE power
170 W
AC: 370 W
DC: 740 W
AC: 370 W
DC: 740 W
20 W
AC: 37 W
DC: 29 W
AC: 24 W
DC: 17 W
235 W
AC: 478 W
DC: 825 W
AC: 451 W
DC: 793 W
10 A/250 V
15 A/250 V
15 A/250 V
Cooling system
Using fixed fan trays to intake cool air from the chassis left side and exhaust hot air from the chassis right side
Operating humidity
Table 9 Technical specifications for the S5120V2-SI & S5120V2-LI non-PoE switch models
Item
S5120V2-10P-SI
S5120V2-10P-LI
S5120V2-20P-LI
S5120V2-28P-SI
S5120V2-28P-LI
S5120V2-52P- SI
S5120V2-52P- LI
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
43.6 × 330 × 230 mm (1.72 × 12.99 × 9.06 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 2 kg (4.41 lb)
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
8
16
24
48
SFP port
2
4
4
4
Input voltage
7 W
9 W
9 W
18 W
12 W
19 W
23 W
41 W
2 A/250 V
2 A/250 V
2 A/250 V
3.15 A/250 V
Cooling system
Operating humidity
Table 10 Technical specifications for S5120V2-SI & S5120V2-LI PoE switch models
Item
S5120V2-10P-PWR-LI
S5120V2-28P-PWR-LI
S5120V2-52P-PWR-LI
S5120V2-28P-HPWR-LI
Weight
≤ 3 kg (6.61 lb)
≤ 4 kg (8.82 lb)
≤ 6 kg (13.23 lb)
≤ 4.5 kg (9.92 lb)
≤ 3 kg (6.61 lb)
Console port
8
24
48
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports.)
10 (The two highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports.)
SFP port
2
4
4
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
4 (The two lowest-numbered SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet port form combo interfaces.)
Input voltage
AC input:
H3C RPS1600-A DC input (only for the S5120V2-28P-HPWR-LI and S5120V2-52P-PWR-LI switches):
·     Rated voltage: –54 VDC to –57 VDC
·     Max voltage:
¡     AC and DC inputs: –54 VDC to –57 VDC
30 W
30 W
30 W
30 W
The combo copper ports do not support PoE power supply.
30 W
Total PoE power
125 W
170 W
AC: 370 W
DC: 740 W
AC: 370 W
DC: 740 W
125 W
13 W
19 W
AC: 36 W
DC: 26 W
AC: 23 W
DC: 16 W
14 W
153 W
230 W
AC: 467 W
DC: 807 W
AC: 446 W
DC: 790 W
156 W
6.3 A/250 V
10 A/250 V
15 A/250 V
15 A/250 V
6.3 A/250 V
Cooling system
Using fixed fan trays to intake cool air from the chassis left side and port side and exhaust hot air from the right side
Operating humidity
Table 11 Technical specifications for the S5110V2-SI switch series
Item
S5110V2-28P-SI
S5110V2-52P-SI
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
24
48
SFP port
4
4
Input voltage
9 W
18 W
23 W
41 W
2 A/250 V
3.15 A/250 V
Cooling system
Using fixed fan trays to intake cool air from chassis the left side and right side and exhaust hot air from the chassis power supply side
Operating humidity
Table 12 Technical specifications for the S5000V3-EI non-PoE switch models
Item
S5016PV3-EI
S5024PV3-EI
S5048PV3-EI
S5024FV3-EI
43.6 × 440 × 230 mm (1.72 × 17.32 × 9.06 in)4
Weight
≤ 2 kg (4.41 lb)
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
≤ 3 kg (6.61 lb)
Console port
16
24
48
2 (Each and its corresponding SFP ports form a combo interface.)
SFP port
4
4
4
28 (SFP ports 25 and 26 form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet port, respectively.)
Input voltage
9 W
9 W
18 W
12 W
19 W
23 W
41 W
37 W
2 A/250 V
2 A/250 V
3.15 A/250 V
3.15 A/250 V
Cooling system
Using fixed fan trays to intake cool air from the chassis right side and port side and exhaust hot air from the power supply side
Operating humidity
Table 13 Technical specifications for S5000V3-EI PoE switch models
Item
S5024PV3-EI-PWR
S5024PV3-EI-HPWR
S5048PV3-EI-PWR
Weight
≤ 4 kg (8.82 lb)
≤ 4.5 kg (9.92 lb)
≤ 6 kg (13.23 lb)
Console port
24
24
48
SFP port
4
4
4
Input voltage
AC input:
H3C RPS1600-A DC input (only for the S5024PV3-EI-HPWR and S5048PV3-EI-PWR switches):
·     Max voltage:
30 W
30 W
30 W
Total PoE power
170 W
AC: 370 W
DC: 740 W
AC: 370 W
DC: 740 W
19 W
AC: 19 W
DC: 11 W
AC: 36 W
DC: 26 W
230 W
AC: 448 W
DC: 782 W
AC: 467 W
DC: 807 W
10 A/250 V
15 A/250 V
15 A/250 V
Cooling system
Operating humidity
Table 14 Technical specifications for the S5000V5-EI non-PoE switch models (1)
Item
S5008PV5-EI with product code LS-5008PV5-EI
S5008PV5-EI with product code LS-5008PV5-EI-H1
S5016PV5-EI
S5024PV5-EI
44 × 264 × 162 mm (1.73 × 10.39 × 6.38 in)
Weight
≤ 1 kg (2.20 lb)
≤ 1.5 kg (3.31 lb)
≤ 2 kg (4.41 lb)
≤ 2.5 kg (5.51 lb)
Console port
8
8
16
24
SFP port
2
2
4
4
Input voltage
5 W
8 W
9 W
12 W
14 W
19 W
23 W
3.15 A/250 V
2 A/250 V
2 A/250 V
2 A/250 V
Cooling system
Operating humidity
Table 15 Technical specifications for the S5000V5-EI non-PoE switch models (2)
Item
S5008PV5-EI-S
S5016PV5-EI-S
S5024PV5-EI-S
S5048PV5-EI
43.6 × 266 × 160 mm (1.72 × 10.47 × 6.30 in)
43.6 × 294 × 179 mm (1.72 × 11.57 × 7.05 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 2 kg (4.41 lb)
≤ 1.6 kg (3.53 lb)
≤ 3.5 kg (7.72 lb)
Console port
8
16
24
48
SFP port
2
4
4
4
Input voltage
·     Rated voltag: 100 VAC to 240 VAC @ 50 or 60 Hz
8 W
9 W
11 W
18 W
14 W
19 W
20 W
41 W
2 A/250 V
2 A/250 V
2 A/250 V
3.15 A/250 V
Cooling system
Operating humidity
Table 16 Technical specifications for S5000V5-EI PoE switch models (1)
Item
S5008PV5-EI-HPWR with product code LS-5008PV5-EI-HPWR
S5008PV5-EI-HPWR with product code LS-5008PV5-EI-HPWR-H1
S5008PV5-EI-HPWR-S
S5016PV5-EI-PWR-S
44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 3 kg (6.61 lb)
≤ 2 kg (4.41 lb)
≤ 3 kg (6.61 lb)
Console port
8
8
8
16
SFP port
2
2
4
2
Input voltage
30 W
30 W
30 W
30 W
Total PoE power
125 W
125 W
125 W
140 W
5 W
10 W
12 W
18 W
150 W
155 W
160 W
150 W
6.3 A/250 V
6.3 A/250 V
6.3 A/250 V
6.3 A/250 V
Cooling system
Operating humidity
Table 17 Technical specifications for S5000V5-EI PoE switch models (2)
Item
S5024PV5-EI-PWR
S5024PV5-EI-PWR-S
S5024PV5-EI-HPWR
S5048PV5-EI-PWR
43.6 × 330 × 230 mm (1.72 ×  12.992 ×  9.06 in)
Weight
≤ 4 kg (8.82 lb)
≤ 3 kg (6.61 lb)
≤ 4.5 kg (9.92 lb)
≤ 6 kg (13.23 lb)
Console port
24
24
24
48
SFP port
4
2
4
4
Input voltage
30 W
30 W
30 W
30 W
Total PoE power
240 W
140 W
370 W
370 W
15 W
18 W
19 W
36 W
294 W
150 W
448 W
467 W
6.3 A/250 V
10 A/250 V
15 A/250 V
Cooling system
Operating humidity
Table 18 Technical specifications for S3100V3-SI non-PoE switch models
Item
S3100V3-10TP-SI
S3100V3-18TP-SI
S3100V3-28TP-SI
S3100V3-52TP-SI
Weight
≤ 1.5 kg (3.31 lb)
≤ 1.5 kg (3.31 lb)
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
4
8
16
32
4
8
8
16
SFP port
2
2
4
4
Input voltage
6.5 W
7 W
9 W
18 W
11 W
15 W
19 W
33 W
2 A/250 V
2 A/250 V
2 A/250 V
3.15 A/250 V
Cooling system
Operating humidity
Table 19 Technical specifications for S3100V3-EI PoE switch models
Item
S3100V3-10TP-PWR-SI
S3100V3-20TP-PWR-SI
S3100V3-28TP-PWR-SI with product code LS-3100V3-28TP-PWR-SI)
S3100V3-28TP-PWR-SI with product code LS-3100V3-28TP-PWR-SI-H1
Weight
≤ 3 kg (6.61 lb)
≤ 3 kg (6.61 lb)
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
Console port
4
8
16
16
4
8
12 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports each form a combo interface with its corresponding SFP port.)
SFP port
2
4
Input voltage
AC input:
H3C RPS1600-A DC input (only for an S3100V3-28TP-PWR-SI switch with product code LS-3100V3-28TP-PWR-SI):
·     Max voltage:
30 W
30 W
30 W
30 W
Total PoE power
125 W
185 W
AC: 370 W
DC: 740 W
370 W
13 W
Models with product code LS-3100V3-20TP-PWR-SI: 18 W
Models with product code LS-3100V3-20TP-PWR-SI-H1: 15 W
AC: 23 W
DC: 16 W
15 W
150 W
Models with product code LS-3100V3-20TP-PWR-SI: 220 W
Models with product code LS-3100V3-20TP-PWR-SI-H1: 235 W
AC: 439 W
DC: 788 W
443 W
6.3 A/250 V
6.3 A/250 V
15 A/250 V
15 A/250 V
Cooling system
Operating humidity
Chassis views
S5560S-28P-SI
Figure 1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) SFP port LED
(4) System status LED (SYS)
(5) Console port (CONSOLE)
(6) SFP port
Figure 2 Rear panel
(1) Grounding screw
(2) AC-input power receptacle
S5560S-52P-SI
Figure 3 Front panel
(3) Console port (CONSOLE)
(4) SFP port LED
(5) System status LED (SYS)
(6) SFP port
Figure 4 Rear panel
(1) Grounding screw
S5560S-28S-SI
Figure 5 Front panel
(3) SFP+ port LED
(5) Micro USB console port
(6) Console port (CONSOLE)
(7) SFP+ port
Figure 6 Rear panel
(1) Grounding screw
S5560S-52S-SI
Figure 7 Front panel
(4) Micro USB console port
(5) SFP+ port LED
(6) System status LED (SYS)
(7) SFP+ port
Figure 8 Rear panel
(1) Grounding screw
S5560S-28F-SI
Figure 9 Front panel
(1) SFP port
(2) SFP port LED
(3) 10/100/1000BASE-T autosensing Ethernet port
(4) 10/100/1000BASE-T autosensing Ethernet port LED
(5) Management Ethernet port
(7) Micro USB console port
(8) System status LED (SYS)
(9) Power supply 2 status LED (PWR2)
(10) Power supply 1 status LED (PWR1)
(11) SFP+ port LED
(12) Management Ethernet port LED (ACT/LINK)
(13) SFP+ port
Figure 10 Rear panel
(1) Grounding screw
(2) Power supply slot 1 (PWR1)
(3) Power supply slot 2 (PWR2)
An S5560S-28F-SI switch comes with power supply slot 1 installed with a PSR75-12A or CA-70A12 power supply and power supply slot 2 installed with a filler panel.
S5560S-28DP-SI
Figure 11 Front panel
(3) Management Ethernet port
(4) Console port (CONSOLE)
(6) Mode button
(7) Mode LED (MODE)
(8) USB port
(9) System status LED (SYS)
(10) SFP port
(11) Power supply 2 status LED (PWR2)
(12) Power supply 1 status LED (PWR1)
(13) Management Ethernet port LED (ACT/LINK)
(14) SFP port LED
Figure 12 Rear panel
(1) Grounding screw
An S5560S-28DP-SI switch comes with power supply slot 1 installed with a PSR75-12A or CA-70A12 power supply and power supply slot 2 installed with a filler panel.
S5500V3-24P-SI
Figure 13 Front panel
(3) SFP+ port LED
(5) SFP port LED
(6) Micro USB console port
(7) Console port (CONSOLE)
(8) SFP+ port
(9) SFP port
Figure 14 Rear panel
(1) Grounding screw
S5500V3-48P-SI
Figure 15 Front panel
(3) SFP port LED
(6) SFP+ port LED
(7) System status LED (SYS)
(8) SFP+ port
(9) SFP port
Figure 16 Rear panel
(1) Grounding screw
S5500V3-28S-SI
Figure 17 Front panel
(2) SFP+ port
(6) SFP+ port LED
Figure 18 Rear panel
(1) Grounding screw
S5500V3-28PS-SI
Figure 19 Front panel
(2) SFP port
(3) SFP+ port
(5) 10/100/1000BASE-T autosensing Ethernet port LED
(6) SFP port LED
(8) SFP+ port LED
Figure 20 Rear panel
(1) Grounding screw
S5500V3-54S-SI
Figure 21 Front panel
(3) SFP+ port
(4) SFP+ port LED
Figure 22 Rear panel
(1) AC-input power receptacle
(2) Grounding screw
S5500V3-54PS-SI
Figure 23 Front panel
(3) SFP port LED
(4) SFP+ port LED
(7) SFP+ port
(8) SFP port
Figure 24 Rear panel
(2) Grounding screw
S5500V3-36F-SI
Figure 25 Front panel
(1) 1000BASE-X SFP port
(3) SFP+ port
(5) 1000BASE-X SFP port LED
(6) 10/100/1000BASE-T autosensing Ethernet port LED
(8) SFP+ port LED
Figure 26 Rear panel
(2) Grounding screw
S5500V3-28S-DP-SI
Figure 27 Front panel
(2) SFP+ port
(6) Mode LED (MODE)
(7) Power supply 1 status LED (PWR1)
(8) Power supply 2 status LED (PWR2)
(9) SFP+ port LED
(10) Mode button
Figure 28 Rear panel
(1) Grounding screw
(2) Power supply 1
(3) Power supply 2
The S5500V3-28S-DP-SI switch provides two power supply slots and comes with power supply slot 1 installed with a CA-70A12 power supply and power supply slot 2 installed with a filler panel. As shown in Figure 28, two CA-70A12 power supplies are installed in the S5500V3-28S-DP-SI switch.
S5500V3-54S-DP-SI
Figure 29 Front panel
(3) SFP+ port
(4) SFP+ port LED
(6) Mode button
(8) Mode LED (MODE)
Figure 30 Rear panel
(1) Grounding screw
(2) Power supply 1
(3) Power supply 2
The S5500V3-54S-DP-SI switch provides two power supply slots and comes with power supply slot 1 installed with a CA-70A12 power supply and power supply slot 2 installed with a filler panel. As shown in Figure 30, two CA-70A12 power supplies are installed in the S5500V3-54S-DP-SI switch.
S5500V3-36F-DP-SI
Figure 31 Front panel
(3) SFP+ port
(8) Mode LED (MODE)
(9) Power supply 1 status LED (PWR1)
(10) Power supply 2 status LED (PWR2)
(11) SFP+ port LED
(12) Mode button
Figure 32 Rear panel
(1) Grounding screw
(2) Power supply 1
(3) Power supply 2
The S5500V3-36F-DP-SI switch provides two power supply slots and comes with power supply slot 1 installed with a CA-70A12 power supply and power supply slot 2 installed with a filler panel. As shown in Figure 32, two CA-70A12 power supplies are installed in the S5500V3-36F-DP-SI switch.
S5500V3-54F-DP-SI
Figure 33 Front panel
(2) 1000BASE-X SFP port LED
(3) SFP+ port
(4) SFP+ port LED
(6) Management Ethernet port
(8) Management Ethernet port LED
Figure 34 Rear panel
(1) Grounding screw
(2) Power supply 1
(3) Power supply 2
The S5500V3-54F-DP-SI switch provides two power supply slots and comes with power supply slot 1 installed with a CA-70A12 power supply and power supply slot 2 installed with a filler panel. As shown in Figure 34, two CA-70A12 power supplies are installed in the S5500V3-54F-DP-SI switch.
Figure 35 Front panel
(3) SFP+ port LED
(7) SFP+ port
Figure 36 Rear panel
(1) Grounding screw
Figure 37 Front panel
(3) SFP+ port LED
(7) 10GBASE-SX-FD-MM-SR port
(8) SFP+ port
A 10-GE SFP+ transceiver module is built into the 10GBASE-SX-FD-MM-SR port on the S5130S-28S-SI-MM and S5130S-28S-LI-MM switches. For the built-in transceiver module specifications, see Table 36.
Figure 38 Rear panel
(1) Grounding screw
Figure 39 Front panel
(3) SFP+ port LED
(7) 10GBASE-LX-FD-SM-IR port
(8) SFP+ port
A 10-GE SFP+ transceiver module is built into the 10GBASE-LX-FD-SM-IR port on the S5130S-28S-SI-SM and S5130S-28S-LI-SM switches. For the built-in transceiver module specifications, see Table 36.
Figure 40 Rear panel
(1) Grounding screw
Figure 41 Front panel
(5) SFP+ port LED
(7) SFP+ port
Figure 42 Rear panel
(1) Grounding screw
S5130S-28F-SI
Figure 43 Front panel
(1) SFP port
(2) SFP port LED
(11) SFP+ port LED
(13) SFP+ port
Figure 44 Rear panel
(1) Grounding screw
An S5130S-28F-SI switch comes with power supply slot 1 installed with a PSR75-12A or CA-70A12 power supply and power supply slot 2 installed with a filler panel.
S5130S-28S-PWR-LI
Figure 45 Front panel
(2) Mode button
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) SFP+ port LED
(6) Mode LED (MODE)
(8) Console port (CONSOLE)
(9) SFP+ port
Figure 46 Rear panel
(1) Grounding screw
S5130S-28S-HPWR-LI
Figure 47 Front panel
(2) SFP port
(4) Mode button
(7) RPS status LED (RPS)
(8) Mode LED (MODE)
(9) SFP+ port LED
(10) SFP port LED
(11) Micro USB console port
(12) SFP+ port
Figure 48 Rear panel
(1) Grounding screw
(3) DC-input power receptacle
S5130S-52S-PWR-LI
Figure 49 Front panel
(4) Mode button
(6) RPS status LED (RPS)
(7) Mode LED (MODE)
(8) Micro USB console port
(9) SFP+ port
(10) SFP+ port LED
Figure 50 Rear panel
(1) Grounding screw
Figure 51 Front panel
(3) SFP port LED
(6) SFP port
Figure 52 Rear panel
(1) Grounding screw
S5120V2-20P-LI
Figure 53 Front panel
(3) SFP port LED
(6) SFP port
Figure 54 Rear panel
(2) Grounding screw
Figure 55 Front panel
(3) SFP port LED
(6) SFP port
Figure 56 Rear panel
(1) Grounding screw
Figure 57 Front panel
(4) SFP port LED
(6) SFP port
Figure 58 Rear panel
(1) Grounding screw
S5120V2-10P-PWR-LI
Figure 59 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(6) Mode button
(8) SFP port
Figure 60 Rear panel
(2) Grounding screw
S5120V2-28P-PWR-LI
Figure 61 Front panel
(2) Mode button
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure 62 Rear panel
(1) Grounding screw
S5120V2-28P-HPWR-LI
Figure 63 Front panel
(2) Console port (CONSOLE)
(3) Mode button
(7) Mode LED (MODE)
(8) SFP port LED
(9) SFP port
Figure 64 Rear panel
(1) Grounding screw
S5120V2-52P-PWR-LI
Figure 65 Front panel
(4) Mode button
(7) Mode LED (MODE)
(8) SFP port
(9) SFP port LED
Figure 66 Rear panel
(1) Grounding screw
Figure 67 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(6) Mode button
(8) SFP port
Figure 68 Rear panel
(2) Grounding screw
S5110V2-28P-SI
Figure 69 Front panel
(3) SFP port LED
(6) SFP port
Figure 70 Rear panel
(1) Grounding screw
S5110V2-52P-SI
Figure 71 Front panel
(4) SFP port LED
(6) SFP port
Figure 72 Rear panel
(1) Grounding screw
S5016PV3-EI
Figure 73 Front panel
(3) SFP port LED
(6) SFP port
Figure 74 Rear panel
(2) Grounding screw
S5024PV3-EI
Figure 75 Front panel
(3) SFP port LED
(6) SFP port
Figure 76 Rear panel
(1) Grounding screw
S5048PV3-EI
Figure 77 Front panel
(4) SFP port LED
(6) SFP port
Figure 78 Rear panel
(1) Grounding screw
S5024PV3-EI-PWR
Figure 79 Front panel
(2) Mode button
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure 80 Rear panel
(1) Grounding screw
S5024PV3-EI-HPWR
Figure 81 Front panel
(2) Mode button
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure 82 Rear panel
(1) Grounding screw
S5048PV3-EI-PWR
Figure 83 Front panel
(4) Mode button
(7) Mode LED (MODE)
(8) SFP port
(9) SFP port LED
Figure 84 Rear panel
(1) Grounding screw
S5024FV3-EI
Figure 85 Front panel
(1) SFP port
(3) SFP port LED
Figure 86 Rear panel
(2) Grounding screw
S5008PV5-EI
Figure 87 Front panel (product code LS-5008PV5-EI)
(1) 10/100/1000BASE-T copper port
(2) 100/1000BASE-X SFP port
(4) Port status LED
(5) Power status LED (Power)
Figure 88 Front panel (product code LS-5008PV5-EI-H1)
(3) SFP port LED
(6) SFP port
Figure 89 Rear panel (product code LS-5008PV5-EI)
(1) Grounding screw
(3) Security slot
Figure 90 Rear panel (product code LS-5008PV5-EI-H1)
(1) Grounding screw
S5008PV5-EI-S
Figure 91 Front panel
(3) SFP port LED
(6) SFP port
Figure 92 Rear panel
(1) Grounding screw
S5016PV5-EI
Figure 93 Front panel
(3) SFP port LED
(6) SFP port
Figure 94 Rear panel
(2) Grounding screw
S5016PV5-EI-S
Figure 95 Front panel
(3) SFP port LED
(6) SFP port
Figure 96 Rear panel
(2) Grounding screw
S5024PV5-EI
Figure 97 Front panel
(3) SFP port LED
(6) SFP port
Figure 98 Rear panel
(1) Grounding screw
S5024PV5-EI-S
Figure 99 Front panel
(3) System status LED (SYS)
(4) SFP port LED
(6) SFP port
Figure 100 Rear panel
(2) Grounding screw
S5048PV5-EI
Figure 101 Front panel
(4) SFP port LED
(6) SFP port
Figure 102 Rear panel
(1) Grounding screw
S5008PV5-EI-HPWR
Figure 103 Front panel (product code LS-5008PV5-EI-HPWR)
(4) Port status LED
Figure 104 Front panel (product code LS-5008PV5-EI-HPWR-H1)
(3) SFP port LED
(5) Mode LED (MODE)
(6) Port LED mode switching button
(8) SFP port
Figure 105 Rear panel (product code LS-5008PV5-EI-HPWR)
(2) Grounding screw
(3) Security slot
Figure 106 Rear panel (product code LS-5008PV5-EI-HPWR-H1)
(2) Grounding screw
S5008PV5-EI-HPWR-S
Figure 107 Front panel
(4) Mode LED (MODE)
(5) SFP port LED
(8) SFP port
Figure 108 Rear panel
(2) Grounding screw
S5016PV5-EI-PWR-S
Figure 109 Front panel
(2) Port LED mode switching button
(4) SFP port LED
(6) Mode LED (MODE)
(7) Console port
(7) SFP port
Figure 110 Rear panel
(2) Grounding screw
S5024PV5-EI-PWR
Figure 111 Front panel
(2) Mode button
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure 112 Rear panel
(1) Grounding screw
S5024PV5-EI-PWR-S
Figure 113 Front panel
(4) Mode LED (MODE)
(5) SFP port LED
(8) SFP port
Figure 114 Rear panel
(1) Grounding screw
S5024PV5-EI-HPWR
Figure 115 Front panel
(2) Mode button
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure 116 Rear panel
(1) Grounding screw
S5048PV5-EI-PWR
Figure 117 Front panel
(4) Mode button
(6) Mode LED (MODE)
(7) SFP port LED
(8) SFP port
Figure 118 Rear panel
(1) Grounding screw
S3100V3-10TP-SI
Figure 119 Front panel
(1) 10/100BASE-T autosensing Ethernet port
(3) 10/100BASE-T autosensing Ethernet port LED
(4) SFP port LED
(8) SFP port
Figure 120 Rear panel
(1) Grounding screw
S3100V3-18TP-SI
Figure 121 Front panel
(5) SFP port LED
(8) SFP port
Figure 122 Rear panel
(1) Grounding screw
S3100V3-28TP-SI
Figure 123 Front panel
(5) SFP port LED
(8) SFP port
Figure 124 Rear panel
(1) Grounding screw
S3100V3-52TP-SI
Figure 125 Front panel
(2) 10/100BASE-T autosensing Ethernet port LED
(7) SFP port
(8) SFP port LED
Figure 126 Rear panel
(1) Grounding screw
S3100V3-10TP-PWR-SI
Figure 127 Front panel
(4) SFP port LED
(6) Mode LED (MODE)
(7) 10/100/1000BASE-T autosensing Ethernet port LED
(8) Mode button
(9) Console port (CONSOLE)
(10) SFP port
Figure 128 Rear panel
(2) Grounding screw
S3100V3-20TP-PWR-SI
Figure 129 Front panel
(5) SFP port LED
(7) Mode LED (MODE)
(8) Mode button
(10) SFP port
Figure 130 Rear panel
(2) Grounding screw
S3100V3-28TP-PWR-SI
Figure 131 Front panel (product code LS-3100V3-28TP-PWR-SI)
(5) RPS status LED (RPS)
(6) Mode LED (MODE)
(7) SFP port LED
(8) 10/100/1000BASE-T autosensing Ethernet port LED
(9) Mode button
(10) Console port (CONSOLE)
(11) SFP port
Figure 132 Front panel (product code LS-3100V3-28TP-PWR-SI-H1)
(5) Mode LED (MODE)
(6) SFP port LED
(8) Port LED mode switching button
(10) SFP port
Figure 133 Rear panel (product code LS-3100V3-28TP-PWR-SI)
(1) Grounding screw
Figure 134 Rear panel (product code LS-3100V3-28TP-PWR-SI-H1)
(1) Grounding screw
IMPORTANT
IMPORTANT:
The removable components available for the device might change over time. For the most recent removable components available for the device, see the release notes.
Power supplies
CAUTION
CAUTION:
·     You can replace one power supply for an S5560S-28F-SI, S5560S-28DP-SI, S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, S5500V3-54F-DP-SI, or S5130S-28F-SI switch while the other one is supplying power correctly to the switch. To avoid device damage or body injury, power off the power supply before installing or removing it.
·     If the S5500V3-54F-DP-SI switch uses the CA-70A12 or PSR75-12A power supplies, you can install a maximum of twelve GE copper transceiver modules (SFP-GE-T or SFP-GE-T-D) on the switch.
The S5560S-28F-SI, S5560S-28DP-SI, S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, S5500V3-54F-DP-SI, and S5130S-28F-SI switches each provide two power supply slots. One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for redundancy.
Table 20 describes the power supplies available for the S5560S-28F-SI, S5560S-28DP-SI, S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, S5500V3-54F-DP-SI, and S5130S-28F-SI switches. Table 21 describes the power supply specifications
Table 20 Power supplies available for the switches
Power supply
S5560S-28F-SI
S5560S-28DP-SI
S5130S-28F-SI
S5500V3-28S-DP-SI
S5500V3-54S-DP-SI
S5500V3-36F-DP-SI
S5500V3-54F-DP-SI
CA-70A12
Supported only on the S5130S-28F-SI and S5560S-28F-SI swtiches
Supported
PSR75-12A
Supported
Supported
PSR150-D1
N/A
Supported
Table 21 Power supply specifications
Power supply
Specifications
Reference
CA-70A12
·     Rated input voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max input voltage range: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
·     Max output power: 70 W
H3C CA-70A12 Power Supply User Manual
PSR75-12A
¡     AC: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
¡     DC: 240 VDC
¡     AC: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
¡     DC: 180 VDC to 320 VDC
·     Max output power: 75 W
H3C PSR75-12A Power supply User Manual
PSR150-D1
·     Rated input voltage range: –48 VDC to –60 VDC
·     Max input voltage range: –36 VDC to –72 VDC
·     Max output power: 150 W
H3C PSR150-A & PSR150-D Series Power Supplies User Manual
Ports and LEDs
Ports
Console port
Table 22 Console port specifications
Item
Serial console port
Connector type
RJ-45
Micro USB Type B
Compliant standard
EIA/TIA-232
USB 2.0
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
·     Provides connection to the USB port of a local PC running terminal emulation program.
Switch models that provide a console port
All switch models
·     S5560S-28S-SI, S5560S-52S-SI, S5560S-28F-SI, and S5560S-28DP-SI switches
·     S5500V3-24P-SI and S5500V3-48P-SI switches
·     S5130S-SI & S5130S-LI switch series
If you connect both the serial console port and micro USB console port, only the micro USB console port takes effect.
Table 23 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Port rate and duplex mode
·     10/100 Mbps, half/full duplex
·     1000 Mbps, full duplex
Auto-MDI/MDI-X
Supported
Transmission medium
Category-5 and above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i, 802.3u, 802.3ab
Functions and services
Connects to a PC or a remote management station for software and Boot ROM upgrade and network management
Switch models that provide a management Ethernet port
·     S5560S-28F-SI switch
·     S5560S-28DP-SI switch
·     S5500V3-54F-DP-SI switch
·     S5130S-28F-SI switch
USB port
IMPORTANT
IMPORTANT:
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from all vendors on the S5560S-28DP-SI switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
Table 24 USB port specifications
Item
Specification
Port type
USB2.0
Compliant standard
OHC standards
Port rate
480 Mbps for uploading and downloading
Exchange files, such as software images and configuration files, with the flash file system on the switch
Switch models that provide a USB port
S5560S-28DP-SI
Table 25 10/100BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Auto-MDI/MDI-X
Supported
100 m (328.08 ft)
Transmission medium
Compatible standards
Switch models that provide a 10/100BASE-T autosensing Ethernet port
Table 26 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Auto-MDI/MDI-X
Supported
100 m (328.08 ft)
Transmission medium
Category-5 (or above) twisted pair cable
Switch models that provide a 10/100/1000BASE-T autosensing Ethernet port
All switch models
The SFP ports on the S5008PV5-EI and S5008PV5-EI-HPWR switches support GE SFP transceiver modules described in Table 27 and FE SFP transceiver modules described in Table 28.
Table 27 GE SFP transceiver modules
Central wavelength (nm)
Connector
Cable specifications
Modal bandwidth (MHz*km)
Copper SFP transceiver module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
Fiber SFP transceiver module
SFP-GE-SX-MM850-A
850
LC
50/125 µm, multi-mode optical fiber (MMF)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125 µm, single-mode optical fiber (SMF)
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
Table 28 FE SFP transceiver modules
Connector
SFP-FE-SX-MM1310-A
1310
LC
·     50/125 µm, MMF
·     62.5/125 µm, MMF
2 km (1.24 miles)
SFP-FE-LX-SM1310-A
1310
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules, the SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, and the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     H3C transceiver modules and cables are subject to change over time. For the most up-to-date list of H3C transceiver modules and cables, contact your H3C sales representative or technical support engineer.
·     For the specifications of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Only the S5500V3-24P-SI and S5500V3-48P-SI switches do not support the SFP-GE/FE-LX10-SM1310 transceiver module.
Only the S5500V3-24P-SI and S5500V3-48P-SI switches support SFP-GE-SX-MM850-S and SFP-GE-LX-SM1310-S transceiver modules.
Table 29 FE SFP transceiver modules available for the SFP ports
FE SFP module
Connector
SFP-FE-SX-MM1310-A
1310
LC
50/125 µm, MMF
2 km (1.24 miles)
62.5/125 µm, MMF
1310
LC
9/125 µm, SMF
10 km (6.21 miles)
SFP-FE-LX-SM1310-A
1310
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
9/125 µm, SMF
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
9/125 µm, SMF
80 km (49.71 miles)
TX: 1310
RX: 1550
LC
9/125 µm, SMF
15 km (9.32 miles)
TX: 1550
RX: 1310
Table 30 GE SFP transceiver modules and cables available for the SFP ports
GE SFP transceiver module and cable
Connector
Modal bandwidth (MHz × km)
SFP copper transceiver module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP fiber transceiver module
SFP-GE-SX-MM850-A
850
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500 or 400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-D
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
9/125 µm, SMF
N/A
100 km (62.14 miles)
TX: 1310
RX: 1490
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
TX: 1490
RX: 1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
TX: 1310
RX: 1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
TX: 1550
RX: 1310
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
9/125 µm, SMF
N/A
70 km (43.49 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
9/125 µm, SMF
N/A
70 km (43.49 miles)
SFP cable
SFP-STACK-Kit
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules, the SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use only H3C SFP transceiver modules and cables for the SFP ports.
·     The H3C SFP transceiver modules and cables available for the SFP ports are subject to change over time. For the most recent list of SFP transceiver modules and cables available for the SFP port, contact your H3C Support or marketing staff.
·     For the specifications of H3C SFP transceiver modules and cables, see H3C Transceiver Modules User Guide.
Table 31 SFP port specifications
Switch models
Supported transceiver models and cables
S5560S-28P-SI
S5560S-52P-SI
S5560S-28DP-SI
All the SFP ports support GE SFP transceiver modules and cables in Table 32. The SFP ports 17 to 24 on an S5560S-28DP-SI switch support also the FE SFP transceiver modules in Table 33.
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S5560S-28P-SI switch, make sure the ambient temperature does not exceed 40°C (104°F).
S5560S-28F-SI
·     GE SFP transceiver modules and cables in Table 32.
·     FE SFP transceiver modules in Table 33.
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles), make sure the ambient temperature does not exceed 40°C (104°F).
S5130S-28F-SI
S5130S-28S-HPWR-LI
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S5130S-28F-SI switch, make sure the ambient temperature does not exceed 40°C (104°F).
All the SFP ports support GE SFP transceiver modules and cables in Table 32. The SFP ports on an S5120V2-28P-HPWR-LI switch support also FE SFP transceiver modules in Table 33. The SFP ports 9 and 10 on an S5120V2-12TP-HPWR-LI switch support also FE SFP transceiver modules in Table 33.
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the following switches, make sure the ambient temperature does not exceed 40°C (104°F).
·     S5120V2-10P-SI
·     S5120V2-28P-SI
·     S5120V2-10P-LI
·     S5120V2-20P-LI
·     S5120V2-28P-LI
·     S5120V2-10P-PWR-LI
·     S5120V2-12TP-HPWR-LI
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S5110V2-28P-SI switch, make sure the ambient temperature does not exceed 40°C (104°F).
All the SFP ports support GE SFP transceiver modules and cables in Table 32. The SFP ports 1 to 26 on an S5024FV3-EI switch support also FE SFP transceiver modules in Table 33.
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the S5016PV3-EI and S5024PV3-EI switches, make sure the ambient temperature does not exceed 40°C (104°F).
S5000V5-EI switch series (except for the LS-5008PV5-EI and LS-5008PV5-EI-HPWR switches)
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the S5016PV5-EI, S5016PV5-EI-S, S5024PV5-EI, S5008PV5-EI-S, S5008PV5-EI with product code LS-5008PV5-EI-H1, and S5008PV5-EI-HPWR with product code LS-5008PV5-EI-HPWR-H1 switches, make sure the ambient temperature does not exceed 40°C (104°F).
All the SFP ports support GE SFP transceiver modules and cables in Table 32. The SFP ports on an S3100V3-28TP-PWR-SI switch support also FE SFP transceiver modules in Table 33.
·     S3100V3-10TP-SI
·     S3100V3-18TP-SI
·     S3100V3-28TP-SI
·     S3100V3-10TP-PWR-SI
Table 32 GE SFP transceiver modules and cables
GE SFP transceiver module/cable
Connector
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
SFP-GE-SX-MM850-A
850
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500/400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
1310
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
9/125 µm, SMF
N/A
TX: 1310
RX: 1490
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
TX: 1490
RX: 1310
TX: 1310
RX: 1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
TX: 1550
RX: 1310
TX: 1490
RX: 1550
LC
9/125 µm, SMF
N/A
70 km (43.49 miles)
TX: 1550
RX: 1490
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
Table 33 FE SFP transceiver modules
Connector
SFP-FE-SX-MM1310-A
1310
LC
·     50/125 µm, MMF
·     62.5/125 µm, MMF
2 km (1.24 miles)
SFP-FE-LX-SM1310-A
1310
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
9/125 µm, SMF
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
9/125 µm, SMF
80 km (49.71 miles)
TX: 1310
RX: 1550
LC
9/125 µm, SMF
15 km (9.32 miles)
TX: 1550
RX: 1310
IMPORTANT
IMPORTANT:
SFP+ port
Table 34 SFP+ port specifications
Item
Specifications
Port type
SFP+ port
Supported transceiver modules and cables
·     10-GE SFP+ transceiver modules and cables in Table 35
Switch models that provide SFP+ ports
·     S5560S-28S-SI, S5560S-52S-SI, and S5560S-28F-SI switches
·     A 10-GE SFP+ transceiver module is built into each 10GBASE-SX-FD-MM-SR port on the S5130S-28S-SI-MM and S5130S-28S-LI-MM switches and each 10GBASE-LX-FD-SM-IR port on the S5130S-28S-SI-SM and S5130S-28S-LI-SM switches. Select optical fibers for these ports based on the port type and transmission distance.
·     All S5500V3-SI switches except for the S5500V3-24P-S and S5500V3-48P-SI support a maximum of two 10-GE transceiver modules with a maximum transmission distance of 80 km (49.71 miles).
·     All S5500V3-SI switches except for the 5500V3-24P-SI and S5500V3-48P-SI do not support the SFP-XG-SX-MM850-S, SFP-XG-SX-MM850-E, SFP-XG-LX-SM1310-S, or SFP-XG-LX-SM1310-E transceiver module, or the LSTM1STK cable.
·     Only S5500V3-SI switches (except for the S5500V3-24P-SI and S5500V3-48P-SI) support SFP-GE/FE-LX10-SM1310, SFP-XG-SX-MM850-A, SFP-XG-LX-SM1310, SFP-XG-LH80-SM1490-BIDI, and SFP-XG-LH80-SM1550-BIDI transceiver modules.
Table 35 10-GE SFP+ transceiver modules and cables available for the SFP+ ports
10-GE SFP+ transceiver module/cable
Connector
SFP-XG-SX-MM850-A
850
LC
50/125 µm, MMF
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850
LC
50/125 µm, MMF
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
50/125 µm, MMF
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
50/125 µm, MMF
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
TX: 1490
RX: 1550
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
TX: 1550
RX: 1490
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP+ copper cable
LSWM1STK
N/A
0.65 m (2.13 ft)
LSWM2STK
N/A
1.2 m (3.94 ft)
LSWM3STK
N/A
3 m (9.84 ft)
LSTM1STK
N/A
5 m (16.40 ft)
SFP+ optical cable
SFP-XG-D-AOC-7M
N/A
7 m (22.97 ft)
SFP-XG-D-AOC-10M
N/A
10 m (32.81 ft)
SFP-XG-D-AOC-20M
N/A
20 m (65.62 ft)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and the SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table 36 Built-in SFP+ transceiver module specifications
Connector
10GBASE-SX-FD-MM-SR
850 nm
LC
50/125 µm, MMF
2000
300 m (984.25 ft)
10GBASE-LX-FD-SM-IR
1310 nm
LC
9/125µm, SMF
N/A
10 km (6.21 miles)
H3C provides SFP+ cables of multiple lengths. For the available SFP+ cables, see Table 35.
Figure 135 SFP+ cable
(1) Connector
(2) Pull latch
Combo interface
Table 37 Combo interface specifications
Item
Specifications
Interface type
Combo interface.
Interface attributes
Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of the two ports is active at a time.
Switch models that provide combo interfaces
·     S5560S-28F-SI, S5560S-28DP-SI, and S5130S-28F-SI switches—Eight combo interfaces on the front panel.
·     S5130S-28S-HPWR-LI, S5120V2-28P-HPWR-LI, and S3100V3-28TP-PWR-SI switches—Four combo interfaces on the front panel.
·     S5120V2-12TP-HPWR-LI and S5024FV3-EI switches—Two combo interfaces on the front panel.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table 38 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
The device provides a LED for each management Ethernet port to indicate its operating status.
Table 39 Management Ethernet port LED description
Management Ethernet port LED (ACT/LINK) status
Steady green
A link is present on the port.
Flashing yellow
The port is sending or receiving data.
Off
No link is present on the port.
Each removable power supply provides a status LED on the front panel to indicate its operating status.
Table 40 Power supply status LED description
LED mark
Status
PWR1/PWR1
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or no power is being supplied to the power supply.
Off
No power supply is installed in the power supply slot.
RPS status LED
All switches that use fixed power supplies and support RPS DC power input (except for the S5024PV3-EI-HPWR) have an RPS status LED to indicate the power input status.
Table 41 RPS status LED description
LED mark
Status
RPS
Steady green
Both the RPS input and the AC input are normal.
Steady yellow
Normal RPS input, no or abnormal AC input.
Off
No or abnormal DC input.
Mode LED (MODE)
In addition to port status LEDs, some switches provide a mode button and mode LED. You can use the mode button to change the indication of the mode LED. The mode LED and port status LED work in combination to indicate the port status from different aspects.
Table 42 Description for the mode LED
LED mark
Status
Mode LED (MODE)
Steady green
The port LEDs are showing link state of the ports.
Flashing green (Available only for PoE switch models)
The port LEDs are showing the PoE status of the ports.
Flashing yellow
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5.
Table 43 SFP port LED description
Mode LED status
SFP port LED status
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing yellow (IRF mode)
Steady green
The SFP port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
SFP/SFP+ port LED
Table 44 SFP/SFP+ port LED description
Status
Steady green
Flashing green
Off
·     No link is present on the port.
·     The mode LED is operating in IRF mode (available only for switch models with a mode button)
·     The mode LED is operating in PoE mode (available only for PoE switch models)
For switch models that supports port LED mode switching, see Table 45 for the 10/100BASE-T autosensing Ethernet port and 10/100/1000BASE-T autosensing Ethernet port LED description.
For switch models that do not support port LED mode switching, see Table 46 for the  10/100BASE-T autosensing Ethernet port and 10/100/1000BASE-T autosensing Ethernet port LED description.
Table 45 10/100BASE-T autosensing Ethernet port LED and 10/100/1000BASE-T autosensing Ethernet port LED description
Mode LED status
10/100BASE-T autosensing Ethernet port or 10/100/1000BASE-T autosensing Ethernet port LED status
Steady green
Flashing green
Off
Flashing green (PoE mode) (available only for PoE switch models)
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or short-circuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Steady green
The 10/100/1000BASE-T autosensing Ethernet port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
Table 46 10/100BASE-T autosensing Ethernet port LED and 10/100/1000BASE-T autosensing Ethernet port LED description
LED status
Steady green
Flashing green
Off
