| 03-Appendix B LEDs and ports | 165.82 KB |
1 Appendix B LEDs and ports
LEDs
Table 1-1 LED descriptions
LED status |
Off |
No power is present or the LED has been turned off. |
Yellow |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Flashing (twice per second) |
The Ethernet interfaces are down and no mesh links are established. |
Green |
Steady on |
The AP is in standby state and has connected to the Cloudnet platform, but does not have any associated clients. |
Flashing (once per second) |
The AP has connected to the Cloudnet platform and has associated clients. |
The AP is upgrading the image. |
Blue |
Steady on |
The AP is in standby state, but has not connected to the Cloudnet platform and does not have associated clients. |
The AP has not connected to the Cloudnet platform, but has associated clients. |
Ports
UAP662-E
Figure 1-1 Ports on the AP
(1) GE/PoE+ port |
(2) RESET button |
(3) Power port |
(4) Security slot |
Table 1-2 Port descriptions
Port |
Standards and protocols |
GE/PoE+ |
· IEEE802.3 · IEEE802.3ab · IEEE802.3i · IEEE802.3u · IEEE802.3af · IEEE802.3at |
10/100/1000M Ethernet copper port, which can receives PoE power. The port is represented by interface GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
DC12V |
N/A |
Power port, used for receiving +12V power from a local power source. |
RESET button |
N/A |
In E2119 and later: · To reboot the AP, press and hold the button for no more than 5 seconds. · To reset the password, press and hold the button for 5 to 10 seconds until the LED is flashing yellow at 1 Hz. · To restore the AP to the factory defaults, press and hold the button for more than 10 seconds until the LED is flashing yellow at 4 Hz. In versions earlier than E2119: · To reboot the AP, press and hold the button for no more than 5 seconds. To restore the AP to the factory defaults, press and hold the button for more than 5 seconds. |
UAP672-E
Figure 1-2 Ports on the AP
(1) GE/PoE+ port |
(2) RESET button |
(3) Power port |
(4) Security slot |
Table 1-3 Port descriptions
Port |
2.5GE/PoE+ |
10/100/2500M Ethernet copper port, which can receives PoE power. The port is represented by interface SGE1/0/1 in the MAP file and smartrate-ethernet 1 for configuration on the AC. |
DC12V |
N/A |
RESET button |
N/A |
