H3C UAP662-E&UAP672-E Access Point Installation Guide-6W100
HomeSupportInstall & UpgradeInstallation GuidesH3C UAP662-E&UAP672-E Access Point Installation Guide-6W100
02-Appendix A AP view and technical specifications
1 Appendix A  AP view and technical specifications
AP view
Figure1-1 AP view (UAP662-E&UAP672-E)
Technical specifications
UAP662-E
Table1-1 Technical specifications
Item
Specification
Protocol
IEEE802.11a/b/g/n/ac/ax
Dimensions (H × W × D)
220 × 220 × 35 mm (8.66 × 8.66 × 1.38 in)
Weight
370 g (0.82 lb)
Antenna
Built-in omnidirectional antenna:
·     2.4 GHz: 3 dBi gain
·     5.1 GHz: 4 dBi gain
·     5.8 GHz: 4 dBi gain
System power consumption
11.35 W
UAP672-E
Table1-2 Technical specifications
Item
Specification
Protocol
Weight
380 g (0.84 lb)
Antenna
·     5.1 GHz: 5 dBi gain
·     5.8 GHz: 5 dBi gain
13.5 W
