12-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5580X-EI[HI] & S5580S-EI Switch Series Configuration Guides-R1213P50-6W10012-Security Configuration Guide
07-Packet filter configuration
07-Packet filter configuration 99.08 KB
Configuring packet filter
About packet filtering with ACLs
This section describes procedures for using an ACL to filtering packets. For example, you can apply an ACL to an interface to filter incoming or outgoing packets.
Packet filter tasks at a glance
To configure packet filtering, perform the following tasks:
·     Configure packet filtering with ACLs. Choose one option as needed:
¡     Applying an ACL to filter packets globally
¡     Applying an ACL to an interface for packet filtering
·     (Optional.) Configuring the applicable scope of packet filtering on a VLAN interface
·     (Optional.) Setting the packet filtering default action
You can apply a maximum of three ACLs to the same direction globally: one IPv4 ACL, one IPv6 ACL, and one Layer 2 ACL.
If you do not specify the ipv6 keyword for a basic or advanced ACL, you specify an IPv4 ACL.
2.     (Optional.) Enable the packet filtering continuous mode.
packet-filter continuous enable
By default, the packet filtering continuous mode is disabled.
3.     Apply an ACL globally.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } global { inbound | outbound } [ hardware-count ]
By default, global packet filtering is not configured.
You can apply a maximum of four ACLs to the same direction of an interface: one IPv4 ACL, one IPv6 ACL, and one Layer 2 ACL.
The share-mode keyword is not supported in the outbound direction.
If you specify ipv6-ah for the protocol argument in an advanced IPv6 ACL rule, the rule does not take effect after the ACL is applied.
3.     Enter interface view.
4.     Apply an ACL to the interface to filter packets.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ] [ share-mode ]
By default, an interface does not filter packets.
You can configure the packet filtering on a VLAN interface to filter the following packets:
·     Packets forwarded at Layer 3 by the VLAN interface.
·     All packets, including packets forwarded at Layer 3 by the VLAN interface and packets forwarded at Layer 2 by the physical ports associated with the VLAN interface.
2.     Create a VLAN interface and enter its view.
interface vlan-interface vlan-interface-id
If the VLAN interface already exists, you directly enter its view.
By default, no VLAN interface exists.
3.     Specify the applicable scope of packet filtering on the VLAN interface.
packet-filter filter  [ route | all ]
By default, the packet filtering filters packets forwarded at Layer 3.
The packet filtering default action does not take effect on zone pair packet filtering. The default action for zone pair packet filtering is always deny.
2.     Set the packet filtering default action to deny.
packet-filter default deny
By default, the packet filter permits packets that do not match any ACL rule to pass.
Verifying and maintaining packet filter
Verifying the packet filter running status
·     Display ACL application information for packet filtering.
display packet-filter { global | interface [ interface-type interface-number ] } [ inbound | outbound ] [ slot slot-number ]
·     Display detailed ACL packet filtering information.
display packet-filter verbose { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ] [ slot slot-number ]
Displaying packet filter statistics
·     Display match statistics for packet filtering ACLs.
display packet-filter statistics { global | interface interface-type interface-number } { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ] [ brief ]
·     Display the accumulated statistics for packet filtering ACLs.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac ] { acl-number | name acl-name } [ brief ]
Clearing packet filter statistics
To clear match statistics for packet filtering ACLs, execute the following command in user view:
reset packet-filter statistics { global | interface [ interface-type interface-number ] } { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ]
Packet filter configuration examples
Example: Configuring interface-based packet filter
A company interconnects its departments through the device. Configure a packet filter to:
·     Permit access from the President's office at any time to the financial database server.
·     Permit access from the Finance department to the database server only during working hours (from 8:00 to 18:00) on working days.
·     Deny access from any other department to the database server.
Figure 1 Network diagram
# Create a periodic time range from 8:00 to 18:00 on working days.
[Device] time-range work 08:0 to 18:00 working-day
# Create an IPv4 advanced ACL numbered 3000.
[Device] acl advanced 3000
# Configure a rule to permit access from the President's office to the financial database server.
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.1.0 0.0.0.255 destination 192.168.0.100 0
# Configure a rule to permit access from the Finance department to the database server during working hours.
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.0.100 0 time-range work
# Configure a rule to deny access to the financial database server.
[Device-acl-ipv4-adv-3000] rule deny ip source any destination 192.168.0.100 0
# Apply IPv4 advanced ACL 3000 to filter outgoing packets on interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] packet-filter 3000 outbound
# Verify that a PC in the Finance department can ping the database server during working hours. (All PCs in this example use Windows XP).
C:\> ping 192.168.0.100
Pinging 192.168.0.100 with 32 bytes of data:
Reply from 192.168.0.100: bytes=32 time=1ms TTL=255
Reply from 192.168.0.100: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.0.100:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
# Verify that a PC in the Marketing department cannot ping the database server during working hours.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
# Display configuration and match statistics for IPv4 advanced ACL 3000 on the device during working hours.
[Device] display acl 3000
Advanced IPv4 ACL 3000, 3 rules,
ACL's step is 5
 rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.0.100 0
 rule 5 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.0.100 0 time-range work (Active)
 rule 10 deny ip destination 192.168.0.100 0
The output shows that rule 5 is active. Rule 5 and rule 10 have been matched four times as the result of the ping operations.
