- 05-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-HTTP configuration
- 06-IPv6 transition technologies configuration
- 07-IP forwarding basics configuration
- 08-Fast forwarding configuration
- 09-Adjacency table configuration
- 10-IRDP configuration
- 11-IP performance optimization configuration
- 12-UDP helper configuration
- 13-IPv6 basics configuration
- 14-IPv6 neighbor discovery configuration
- 15-DHCPv6 configuration
- 16-IPv6 fast forwarding configuration
| 08-Fast forwarding configuration | 58.15 KB |
Restrictions and guidelines: Fast forwarding configuration
Enabling/disabling fast forwarding
Configuring the aging time for fast forwarding entries
Configuring fast forwarding load sharing
Verifying and maintaining fast forwarding
Displaying the aging time of fast forwarding entries
Displaying and clearing fast forwarding entries
Displaying fast forwarding entries about fragmented packets
About fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields: source IP address, source port number, destination IP address, destination port number, and protocol number. After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
Fast forwarding can process fragmented IP packets, but it does not fragment IP packets.
The fast forwarding feature will create fast forwarding entries for the device to speed up forwarding. A large number of fast forwarding entries will cause high memory usage, which eventually leads to memory allocation failure for other services. In this case, you can disable fast forwarding temporarily to free up the device memory.
Do not disable fast forwarding if the device runs session-based services. Disabling fast forwarding will make these services become ineffective.
1. Enter system view.
2. Configure fast forwarding.
¡ Enable fast forwarding.
ip fast-forwarding enable
¡ Disable fast forwarding.
By default, fast forwarding is enabled.
The fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
2. Configure the aging time for fast forwarding entries.
ip fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds.
Fast forwarding load sharing enables the device to identify a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface.
2. Configure fast forwarding load sharing. Choose one option as needed:
¡ Enable fast forwarding load sharing.
ip fast-forwarding load-sharing
¡ Disable fast forwarding load sharing.
undo ip fast-forwarding load-sharing
By default, fast forwarding load sharing is enabled.
To display the aging time of fast forwarding entries, execute the following command in any view:
display ip fast-forwarding aging-time
To display fast forwarding entries, execute the following command in any view:
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
To clear fast forwarding entries, execute the following command in user view:
reset ip fast-forwarding cache [ slot slot-number ]
To display fast forwarding entries about fragmented packets, execute the following command in any view:
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
