11-Security
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10011-Security
02-HH3C-IPSEC-MONITOR-V2-MIB
02-HH3C-IPSEC-MONITOR-V2-MIB 166.58 KB
About this MIB
Use this MIB to obtain information about IPsec tunnels, IPsec-protected traffic, IPsec SAs, IPsec tunnel packet statistics, and IPsec trap notifications.
MIB file name
hh3c-ipsec-monitor-v2.mib
Notifications
hh3cIPsecTunnelStartV2
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.1
IPsec tunnel created.
Informational
Warning
OFF
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec tunnel is created.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec tunnel-start command.
MIB: Set hh3cIPsecTunnelStartTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec tunnel-start command.
MIB: Set hh3cIPsecTunnelStartTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.126.1.2.1.1 (hh3cIPsecTunIndexV2)
Index of an IPsec tunnel.
Yes
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.126.1.2.1.10 (hh3cIPsecTunLocalAddrTypeV2)
Type of the IP address of the IPsec tunnel local end.
No
InetAddressType
Standard MIB values.
1.3.6.1.4.1.25506.2.126.1.2.1.11 (hh3cIPsecTunLocalAddrV2)
No
InetAddress
1.3.6.1.4.1.25506.2.126.1.2.1.12 (hh3cIPsecTunRemoteAddrTypeV2)
Type of the IP address of the IPsec tunnel remote end.
No
InetAddressType
1.3.6.1.4.1.25506.2.126.1.2.1.13 (hh3cIPsecTunRemoteAddrV2)
No
InetAddress
1.3.6.1.4.1.25506.2.126.1.2.1.18 (hh3cIPsecTunLifeTimeV2)
Time-based lifetime of the IPsec tunnel, in seconds.
No
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.126.1.2.1.17 (hh3cIPsecTunLifeSizeV2)
Time-based lifetime of the IPsec tunnel, in kilobytes.
No
Gauge32
Recommended action
No action is required.
hh3cIPsecTunnelStopV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.2
IPsec tunnel deleted.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec tunnel is deleted.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec tunnel-stop command.
MIB: Set hh3cIPsecTunnelStopTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec tunnel-stop command.
MIB: Set hh3cIPsecTunnelStopTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
1.3.6.1.4.1.25506.2.126.1.2.1.20 (hh3cIPsecTunActiveTimeV2)
Active period of time of the IPsec tunnel.
No
Integer32
0..2147483647
Recommended action
hh3cIPsecNoSaFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.3
No SA for IPsec tunnel.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when no SA is available for an IPsec tunnel.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec no-sa-failure command.
MIB: Set hh3cIPsecNoSaTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec no-sa-failure command.
MIB: Set hh3cIPsecNoSaTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIPsecAuthFailFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.4
IPsec authentication failure.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec authentication failure occurs.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec auth-failure command.
MIB: Set hh3cIPsecAuthFailureTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec auth-failure command.
MIB: Set hh3cIPsecAuthFailureTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIPsecEncryFailFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.5
IPsec tunnel encryption failure.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec tunnel has an encryption failure.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec encrypt-failure command.
MIB: Set hh3cIPsecEncryFailureTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec encrypt-failure command.
MIB: Set hh3cIPsecEncryFailureTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIPsecDecryFailFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.6
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec tunnel has a decryption failure.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec decrypt-failure command.
MIB: Set hh3cIPsecDecryFailureTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec decrypt-failure command.
MIB: Set hh3cIPsecDecryFailureTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIPsecPolicyAddV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.8
IPsec policy or profile added.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec policy or profile is added.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-add command.
MIB: Set hh3cIPsecPolicyAddTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-add command.
MIB: Set hh3cIPsecPolicyAddTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.126.1.7.1 (hh3cIPsecPolicyNameV2)
Name of an IPsec policy.
No
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.126.1.7.2 (hh3cIPsecPolicySeqNumV2)
Sequence number an IPsec policy entry.
No
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.126.1.7.3 (hh3cIPsecPolicySizeV2)
Number of the IPsec policy entries.
No
InetAddressType
Recommended action
hh3cIPsecPolicyDelV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.9
IPsec policy or profile deleted.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec policy or profile is deleted.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-delete command.
MIB: Set hh3cIPsecPolicyDelTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-delete command.
MIB: Set hh3cIPsecPolicyDelTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
No
DisplayString
Sequence number of an IPsec policy entry.
No
Integer32
1..2147483647
No
InetAddressType
Recommended action
hh3cIPsecPolicyAttachV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.10
IPsec policy or profile applied to interface.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec policy or profile is applied to an interface.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-attach command.
MIB: Set hh3cIPsecPolicyAttachTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-attach command.
MIB: Set hh3cIPsecPolicyAttachTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
No
DisplayString
No
Integer32
1..2147483647
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of an interface.
Yes
InterfaceIndex
Integer32(1..2147483647)
Recommended action
hh3cIPsecPolicyDetachV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.11
IPsec policy or profile application removed from interface.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when an IPsec policy or profile application is removed from an interface.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-detach command.
MIB: Set hh3cIPsecPolicyDetachTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-detach command.
MIB: Set hh3cIPsecPolicyDetachTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
No
DisplayString
No
Integer32
1..2147483647
Yes
InterfaceIndex
Recommended action
