01-HH3C-IKE-MONITOR-MIB | 175.67 KB |
About this MIB
Use this MIB to obtain IKE monitor information, including IKE tunnel, IKE trap, and IKE MIB version information.
MIB file name
hh3c-ike-monitor.mib
Notifications
hh3cIKETunnelStart
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
未找到标题 4【Basic information】,请确保其样式为标题 4 |
Accounting server down |
Informational |
Major |
N/A (N/A) |
OFF |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.2
Informational
Major
N/A
OFF
This notification is generated when the state of an accounting server changes from active to blocked.
【System impact】
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506. 2.30.1.6.1.1 (1.3.6.1.4.1.25506. 2.30.1.6.1.1) |
IKE tunnel created. |
Informational |
Warning |
Recommended action
Basic information
OID
Event
Severity
Default status
IKE tunnel created.
Informational
Warning
OFF
This notification is generated when an IKE tunnel is created.
Status control
ON
● CLI: Use the snmp-agent trap enable ike tunnel-start command.
● MIB: Set hh3cIKETunnelStartTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike tunnel-start command
● MIB: Set hh3cIKETunnelStartTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
1.3.6.1.4.1.25506.2.30.1.1.1.5 (hh3cIKETunLocalAddr)
IP address of the tunnel local end.
No
IpAddress
Standard MIB values.
1.3.6.1.4.1.25506.2.30.1.1.1.9 (hh3cIKETunRemoteAddr)
IP address of the tunnel remote end.
No
IpAddress
1.3.6.1.4.1.25506.2.30.1.1.1.16 (hh3cIKETunLifeTime)
Lifetime of the IKE tunnel.
No
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.30.1.1.1.1 (hh3cIKETunIndex)
Index of a tunnel.
Yes
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.30.1.1.1.23 (hh3cIKETunLocalInetAddrType)
IP address type of the tunnel local end.
No
InetAddressType
1.3.6.1.4.1.25506.2.30.1.1.1.24 (hh3cIKETunLocalInetAddr)
No
InetAddress
1.3.6.1.4.1.25506.2.30.1.1.1.25 (hh3cIKETunRemoteInetAddrType)
IP address type of the tunnel remote end.
No
InetAddressType
1.3.6.1.4.1.25506.2.30.1.1.1.26 (hh3cIKETunRemoteInetAddr)
No
InetAddress
Recommended action
No action is required.
hh3cIKETunnelStop
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.2
IKE tunnel deleted.
Informational
Warning
OFF
This notification is generated when an IKE tunnel is deleted.
Status control
ON
● CLI: Use the snmp-agent trap enable ike tunnel-stop command
● MIB: Set hh3cIKETunnelStopTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike tunnel-stop command
● MIB: Set hh3cIKETunnelStopTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
1.3.6.1.4.1.25506.2.30.1.1.1.17 (hh3cIKETunActiveTime)
Active period of time of the tunnel.
No
Integer32
1..2147483647
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKENoSaFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.3
IKE tunnel received nonexistent SA.
Informational
Warning
OFF
This notification is generated when an IKE tunnel receives a nonexistent SA.
Status control
ON
● CLI: Use the snmp-agent trap enable ike no-sa-failure command.
● MIB: Set hh3cIKENoSaTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike no-sa-failure command.
● MIB: Set hh3cIKENoSaTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEEncryFailFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.4
IKE tunnel encryption failure.
Informational
Warning
OFF
This notification is generated when an IKE tunnel has an encryption failure.
Status control
ON
● CLI: Use the snmp-agent trap enable ike encrypt-failure command.
● MIB: Set hh3cIKEEncryFailureTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike encrypt-failure command.
● MIB: Set hh3cIKEEncryFailureTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEDecryFailFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.5
IKE tunnel decryption failure.
Informational
Warning
OFF
This notification is generated when an IKE tunnel has a decryption failure.
Status control
ON
● CLI: Use the snmp-agent trap enable ike decrypt-failure command.
● MIB: Set hh3cIKEDecryFailureTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike decrypt-failure command.
● MIB: Set hh3cIKEDecryFailureTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEInvalidProposalFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.6
Invalid proposal received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an invalid proposal is received during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike invalid-proposal command.
● MIB: SET hh3cIKEInvalidProposalTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike invalid-proposal command.
● MIB: SET hh3cIKEInvalidProposalTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEAuthFailFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.7
IKE Phase-1 authentication failure.
Informational
Warning
OFF
This notification is generated when the IKE Phase-1 authentication fails.
Status control
ON
● CLI: Use the snmp-agent trap enable ike auth-failure command.
● MIB: Set hh3cIKEAuthFailTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike auth-failure command.
● MIB: Set hh3cIKEAuthFailTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEInvalidCookieFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.8
Invalid cookie received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an invalid cookie is received during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike invalid-cookie command.
● MIB: Set hh3cIKEInvalidCookieTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike invalid-cookie command.
● MIB: Set hh3cIKEInvalidCookieTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEAttrNotSuppFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.9
Attributes not supported received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an unsupported attribute is received during IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike attr-not-support command.
● MIB: Set hh3cIKEAttrNotSuppTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike attr-not-support command.
● MIB: Set hh3cIKEAttrNotSuppTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEUnsportExchTypeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.10
Unsupported exchange type received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an unsupported exchange type is received during the IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike unsupport-exch-type command.
● MIB: Set hh3cIKEUnsportExchTypeTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike unsupport-exch-type command.
● MIB: Set hh3cIKEUnsportExchTypeTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEInvalidIdFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.11
Invalid ID received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an invalid ID is received during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike invalid-id command.
● MIB: Set hh3cIKEInvalidIdTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike invalid-id command.
● MIB: Set hh3cIKEInvalidIdTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
1.3.6.1.4.1.25506.2.30.1.4.3 (hh3cIKEIdInformation)
ID of the IKE negotiation.
No
DisplayString
OCTET STRING (SIZE (0..255))
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEInvalidProtocolFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.12
IKE tunnel protocol error.
Informational
Warning
OFF
This notification is generated when a protocol related error occurs during the processing for an IKE tunnel.
Status control
ON
● CLI: Use the snmp-agent trap enable ike invalid-protocol command.
● MIB: Set hh3cIKEInvalidProtocolTrapCntl to enabled(1)
OFF
● CLI: Use the undo snmp-agent trap enable ike invalid-protocol command.
● MIB: Set hh3cIKEInvalidProtocolTrapCntl to disabled(2)
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
1.3.6.1.4.1.25506.2.30.1.4.4 (hh3cIKEProtocolNum)
IKE protocol number
No
Integer32
-2147483648..2147483647
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKECertTypeUnsuppFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.13
Unsupported certificate type received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an unsupported certificate type is received during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike cert-type-unsupport command.
● MIB: Set hh3cIKECertTypeUnsuppTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike cert-type-unsupport command.
● MIB: Set hh3cIKECertTypeUnsuppTrapCntl to disabled(2).
Objects
OID (object name)
Index
Value range
No
IpAddress
No
IpAddress
1.3.6.1.4.1.25506.2.30.1.4.5 (hh3cIKECertInformation)
Certificate information
No
DisplayString
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEInvalidCertAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.14
Invalid certificate received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an invalid certificate is received during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike invalid-cert-auth command.
● MIB: Set hh3cIKEInvalidCertAuthTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike invalid-cert-auth command.
● MIB: Set hh3cIKEInvalidCertAuthTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
Certificate information.
No
DisplayString
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEInvalidSignFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.15
Invalid signature received in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when an invalid signature is received during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike invalid-sign command.
● MIB: Set hh3cIKEInvalidSignTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike invalid-sign command.
● MIB: Set hh3cIKEInvalidSignTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
No
DisplayString
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKECertUnavailableFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.16
Certificate unavailable in IKE Phase-1 negotiation.
Informational
Warning
OFF
This notification is generated when a certificate is unavailable during an IKE Phase-1 SA negotiation.
Status control
ON
● CLI: Use the snmp-agent trap enable ike cert-unavailable command.
● MIB: Set hh3cIKECertUnavailableTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike cert-unavailable command.
● MIB: Set hh3cIKECertUnavailableTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
IpAddress
No
IpAddress
No
DisplayString
Index of a tunnel.
Yes
Integer32
1..2147483647
No
InetAddressType
No
InetAddress
No
InetAddressType
No
InetAddress
Recommended action
hh3cIKEProposalAdd
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.17
IKE proposal added.
Informational
Warning
OFF
This notification is generated when an IKE proposal is added.
Status control
ON
● CLI: Use the snmp-agent trap enable ike proposal-add command.
● MIB: Set hh3cIKEProposalAddTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike proposal-add command.
● MIB: Set hh3cIKEProposalAddTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
1.3.6.1.4.1.25506.2.30.1.4.1 (hh3cIKEProposalNumber)
IKE proposal number.
No
Integer32
1.3.6.1.4.1.25506.2.30.1.4.2 (hh3cIKEProposalSize)
Number of IKE proposals.
No
Integer32
Recommended action
hh3cIKEProposalDel
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.30.1.6.1.18
IKE proposal deleted.
Informational
Warning
OFF
This notification is generated when an IKE proposal is deleted.
Status control
ON
● CLI: Use the snmp-agent trap enable ike proposal-delete command.
● MIB: Set hh3cIKEProposalDelTrapCntl to enabled(1).
OFF
● CLI: Use the undo snmp-agent trap enable ike proposal-delete command.
● MIB: Set hh3cIKEProposalDelTrapCntl to disabled(2).
Objects
OID(object name)
Index
Value range
No
Integer32
No
Integer32
Recommended action
