14-High Availability
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10114-High Availability
03-HH3C-SMLK-MIB
03-HH3C-SMLK-MIB 56.86 KB
HH3C-SMLK-MIB
About this MIB
HH3C-SMLK-MIB is a private MIB defined to implement network management on the Smart Link feature. You can use this MIB to create, modify, and delete smart link groups. Smart link group settings include preemption mode, control VLAN, and protected VLAN. You can also configure primary and secondary ports for a smart link group, configure the flush message receiving function, and obtain configuration information.
MIB file name
hh3c-smlk.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cSmlk(147)
Tabular objects
hh3cSmlkGroupTable
About this table
Use this table to obtain and set basic smart link group information.
Support for operations
Create
Edit/Modify
Delete
Read
If a valid value is set for hh3cSmlkSpeedThreshold, hh3cSmlkPreemptionMode must be set to speed.
hh3cSmlkInstanceListLow and hh3cSmlkInstanceListHigh are optional. If configuration is required, they must be both configured.
hh3cSmlkInstanceListLow and hh3cSmlkInstanceListHigh must be both configured.
If member ports are configured for a smart link group, hh3cSmlkInstanceListLow and hh3cSmlkInstanceListHigh cannot be both set to 0.
To delete a smart link group with member ports configured, delete the member ports from the group first.
Supported
Columns
The table index is hh3cSmlkGroupID.
Object (OID)
Access
Value range
Implementation
hh3cSmlkGroupID (1.3.6.1.4.1.25506.2.147.1.1.1.1)
accessible-for-notify
Integer32
Integer32(1..256)
Table index.
Smart link group ID. The valid value range is 1 to 256. Supported value varies by device model.
hh3cSmlkDeviceID (1.3.6.1.4.1.25506.2.147.1.1.1.2)
read-only
MacAddress
OCTET STRING (6)
Device ID.
As per the MIB.
hh3cSmlkPreemptionMode (1.3.6.1.4.1.25506.2.147.1.1.1.3)
read-create
INTEGER
none(1),
role(2),
speed(3)
Preemption mode.
As per the MIB.
hh3cSmlkSpeedThreshold (1.3.6.1.4.1.25506.2.147.1.1.1.4)
read-create
Integer32
Integer32(0..10000)
Speed preemption threshold that applies only to speed preemption mode.
Default: 0.
The value takes effect when hh3cSmlkPreemptionMode is set to speed.
hh3cSmlkPreemptionDelay (1.3.6.1.4.1.25506.2.147.1.1.1.5)
read-create
Integer32
Integer32(0..300)
Preemption delay.
As per the MIB.
hh3cSmlkControlVlanID (1.3.6.1.4.1.25506.2.147.1.1.1.6)
read-create
Integer32
Integer32(1..4094|65535)
Control VLAN.
Default: 1.
The value 65535 is invalid, indicating not configured.
hh3cSmlkInstanceListLow (1.3.6.1.4.1.25506.2.147.1.1.1.7)
read-create
OCTET STRING
OCTET STRING (256)
Low bits of MSTIs mapped to protected VLANs.
As per the MIB.
hh3cSmlkInstanceListHigh (1.3.6.1.4.1.25506.2.147.1.1.1.8)
read-create
OCTET STRING
OCTET STRING (256)
High bits of MSTIs mapped to protected VLANs.
As per the MIB.
hh3cSmlkGroupRowStatus (1.3.6.1.4.1.25506.2.147.1.1.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
hh3cSmlkPortTable
About this table
Use this table to obtain and set Smart Link port information.
Create
Edit/Modify
Delete
Read
Before creating hh3cSmlkPortTable, you must create protected VLANs.
Do not enable STP, RRPP, or ERPS for the port.
When assigning a port to multiple smart link groups, configure each group with a different protected VLAN.
Port roles must be specified for the smart link group.
Once set, the port roles of the smart link group cannot be modified.
Supported
Supported
Columns
The table indexes are hh3cSmlkGroupID and hh3cSmlkPortIfIndx.
Object (OID)
Access
Value range
Implementation
hh3cSmlkPortIfIndex (1.3.6.1.4.1.25506.2.147.1.2.1.1)
InterfaceIndex
Integer32 (1..2147483647)
Interface index of the smart link group.
As per the MIB.
hh3cSmlkPortRole (1.3.6.1.4.1.25506.2.147.1.2.1.2)
read-create
INTEGER
primary(1),
secondary(2)
Port role.
As per the MIB.
hh3cSmlkPortStatus
(1.3.6.1.4.1.25506.2.147.1.2.1.3)
read-only
INTEGER
down(1),
active(2),
standby(3)
Port state.
As per the MIB.
hh3cSmlkFlushCount
(1.3.6.1.4.1.25506.2.147.1.2.1.4)
read-only
Counter64
Standard MIB values.
Number of flush messages sent by the port.
As per the MIB.
hh3cSmlkLastFlushTime
(1.3.6.1.4.1.25506.2.147.1.2.1.5)
read-only
TimeStamp
Most recent time when flush messages were sent.
As per the MIB.
hh3cSmlkPortRowStatus
(1.3.6.1.4.1.25506.2.147.1.2.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
hh3cSmlkFlushEnableTable
About this table
Use this table to enable flush message receiving on a port and obtain flush message configuration information.
Create
Edit/Modify
Delete
Read
Not supported
hh3cSmlkControlVlanListLow and hh3cSmlkControlVlanListHigh must be both specified.
Not supported
Supported
Columns
The table index is hh3cSmlkIfIndx.
Object (OID)
Access
Value range
Implementation
hh3cSmlkIfIndex (1.3.6.1.4.1.25506.2.147.1.3.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
hh3cSmlkControlVlanListLow (1.3.6.1.4.1.25506.2.147.1.3.1.2)
read-write
OCTET STRING
OCTET STRING (256)
Low bits of control VLANs for receiving flush messages.
As per the MIB.
(1.3.6.1.4.1.25506.2.147.1.3.1.3)
read-write
OCTET STRING
OCTET STRING (256)
High bits of control VLANs for receiving flush messages.
As per the MIB.
Notifications
hh3cSmlkGroupLinkActive
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.147.2.0.1
A member port becomes active.
Informational
Warning
ON
A notification sent when the port of the smart link group changes to forwarding state.
Status control
This alarm cannot be closed.
Objects
OID (object name)
Index
Value range
(hh3cSmlkGroupID)
No
Integer32
1..256
(hh3cSmlkPortIfIndex)
Index of the member port.
Yes
InterfaceIndex
1..2147483647
Recommended action
Check the link to which the blocked port is attached.
