- 08-MPLS
- 01-HH3C-VSI-MIB
- 02-MPLS-FRR-FACILITY-STD-MIB
- 03-MPLS-FRR-GENERAL-STD-MIB
- 04-MPLS-FTN-STD-MIB
- 05-MPLS-L3VPN-STD-MIB
- 06-MPLS-LDP-STD-MIB
- 07-MPLS-LSR-STD-MIB
- 08-MPLS-TE-STD-MIB
- 09-TE-MIB
- 10-HH3C-EVC-MIB
- 11-HH3C-L3VPN-MIB
- 12-HH3C-MPLSEXT-MIB
- 13-HH3C-MPLSTE-MIB
- 14-HH3C-MPLS-VPN-BGP-MIB
- 15-HH3C-VPN-PEER-MIB
03-MPLS-FRR-GENERAL-STD-MIB | 52.44 KB |
mplsFrrGeneralProtectionMethod
mplsFrrGeneralIngressTunnelInstances
About this MIB
Use this MIB to manage associations between outgoing interfaces and bypass tunnels for FRR.
MIB file name
rfc6445-mpls-frr-general-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).mplsFrrGeneralMIB(202)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrGeneralProtectionMethod (1.3.6.1.2.1.202.1.1) |
read-write |
INTEGER |
unknown(1) oneToOneBackup(2) facilityBackup(3) |
FRR protection method supported by the device. |
Supports only the read operation. Supports only facilityBackup(3). |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrGeneralIngressTunnelInstances (1.3.6.1.2.1.204.1.2) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Number of tunnel instances for detour LSPs and bypass tunnels on the ingress LSR. |
Supports displaying only the number of bypass tunnels. |
Tabular objects
mplsFrrGeneralConstraintsTable
About this table
This table specifies the FRR bypass tunnel setup constraints.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Before the create operation, make sure the bypass tunnel identified by mplsFrrGeneralConstraintsTunnelIndex already exists. The value for mplsFrrGeneralConstraintsTunnelInstance must be 0. The mplsFrrGeneralConstraintsBandwidth object indicates the bandwidth reserved for a bypass tunnel, and it supports only CT0. If you do not specify this object, the default value 0 is used, indicating that the bypass tunnel provides bandwidth protection in best effort mode. For a bypass tunnel to provide guaranteed bandwidth protection, you must specify a specific bandwidth value for this object. |
Not supported |
Supported |
The mplsFrrGeneralConstraintsBandwidth object displays no CT information or displays CT0 bandwidth. For other CTs, this object displays 0. |
Columns
The table indexes are mplsFrrFacilityProtectedIfIndex, mplsFrrFacilityProtectingTunnelIndex, mplsFrrFacilityBackupTunnelIndex, mplsFrrFacilityBackupTunnelInstance, and mplsFrrFacilityBackupTunnelIngressLSRId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrGeneralConstraintsIfIndexOrZero (1.3.6.1.2.1.202.1.3.1.1) |
not-accessible |
Integer32 |
Integer32 (0..2147483647) |
Index of an interface to be protected by an FRR bypass tunnel. |
As per the MIB. |
mplsFrrGeneralConstraintsTunnelIndex (1.3.6.1.2.1.202.1.3.1.2) |
not-accessible |
MplsTunnelIndex |
Gauge (0..65535) |
Index of the bypass tunnel. |
As per the MIB. |
mplsFrrGeneralConstraintsTunnelInstance (1.3.6.1.2.1.202.1.3.1.3) |
not-accessible |
MplsTunnelInstanceIndex |
Gauge (0..65535) |
ID of a protected tunnel instance. |
Supports only 0 for a set operation. |
mplsFrrGeneralConstraintsProtectionType (1.3.6.1.2.1.202.1.3.1.4) |
read-create |
Integer32 |
linkProtection(1) nodeProtection(2) |
Protection method. |
Supports only the read operation. Supports only nodeProtection(2). |
mplsFrrGeneralConstraintsSetupPrio (1.3.6.1.2.1.202.1.3.1.5) |
read-create |
Unsigned32 |
Unsigned32 (0..7) |
Bypass tunnel setup priority. |
Supports only the read operation. |
mplsFrrGeneralConstraintsHoldingPrio (1.3.6.1.2.1.202.1.3.1.6) |
read-create |
Unsigned32 |
Unsigned32 (0..7) |
Bypass tunnel holding priority. |
mplsFrrGeneralConstraintsInclAnyAffinity (1.3.6.1.2.1.202.1.3.1.7) |
read-create |
Unsigned32 |
Unsigned32 (0..65535) |
The include-any constraint for the bypass tunnel. |
mplsFrrGeneralConstraintsInclAllAffinity (1.3.6.1.2.1.202.1.3.1.8) |
read-create |
Unsigned32 |
The include-all constraint for the bypass tunnel. |
mplsFrrGeneralConstraintsExclAnyAffinity (1.3.6.1.2.1.202.1.3.1.9) |
read-create |
Unsigned32 |
Unsigned32(0..2147483647) |
The exclude-any constraint for the bypass tunnel. |
mplsFrrGeneralConstraintsHopLimit (1.3.6.1.2.1.202.1.3.1.10) |
read-create |
Unsigned32 |
Unsigned32 (0..255) |
Maximum number of hops that the bypass tunnel can traverse. |
Not supported. The value is always 255. |
mplsFrrGeneralConstraintsBandwidth (1.3.6.1.2.1.202.1.3.1.11) |
read-create |
Unsigned32 |
Unsigned32 (0..2147483647) |
Bandwidth reserved for the bypass tunnel to provide bandwidth protection. |
Supports only CT0 bandwidth. |
mplsFrrGeneralConstraintsStorageType (1.3.6.1.2.1.202.1.3.1.12) |
read-create |
Integer32 |
other(1), |
Storage type. |
Not supported. The value is always nonvolatile(3). |
mplsFrrGeneralConstraintsRowStatus (1.3.6.1.2.1.202.1.3.1.13) |
read-create |
Integer32 |
active(1), |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
mplsFrrGeneralTunnelARHopTable
About this table
Use this table to obtain AR hop information for FRR protected tunnels.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrGeneralTunnelARHopSessionAttributeFlags (1.3.6.1.2.1.202.1.4.1.1) |
read-only |
BITS |
arHopSessionAttrFlagsUnsupported(0) localProtectionDesired(1) labelRecordingDesired(2) sestyleDesired(3) bandwidthProtectionDesired(4) nodeProtectionDesired(5) |
Values for the SESSION_ATTRIBUTE flags. |
As per the MIB. |
mplsFrrGeneralTunnelARHopRROSubObjectFlags (1.3.6.1.2.1.202.1.4.1.2) |
read-only |
BITS |
arHopRROSubObjectFlagsUnsupported(0) localProtectionAvailable(1) localProtectionInUse(2) bandwidthProtection(3) nodeProtection(4) |
Flags that are currently in use by the associated Record Route Object (RRO) sub-object. |
As per the MIB. |
