| 03-HH3C-PIM-STD-MIB | 70.18 KB |
HH3C-PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
hh3c-pim-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPimStd(213)
Notifications
hh3cPimNeighborAdd
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.213.0.1 |
PIM neighbor created. |
Fault |
Major |
N/A |
ON |
This notification is generated when a PIM neighbor is created.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } neighbor-add command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } neighbor-add command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.213.1.3 (hh3cPimNeighborExpiryTime) |
Neighbor timeout time. |
No |
TimeTicks |
INTEGER (0..4294967295) |
1.3.6.1.4.1.25506.213.1.1 (hh3cPimInstanceID) |
PIM instance ID. |
No |
Unsigned32 |
Unsigned32(0..4294967295) |
1.3.6.1.4.1.25506.213.1.2 (hh3cPimInstanceName) |
PIM instance name. |
No |
DisplayString |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.213.1.15 (hh3cpimNbrAddressType) |
PIM neighbor address type. |
No |
InetAddressType |
unknown(0), ipv4(1), ipv6(2) |
1.3.6.1.4.1.25506.213.1.14 (hh3cpimNbrAddressIfIndex) |
PIM neighbor interface. |
No |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.4.1.25506.213.1.16 (hh3cpimNbrAddress) |
PIM neighbor address. |
No |
InetAddress |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cPimRouteThresholdExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.213.0.2 |
The number of multicast routing entries exceeded the alarm threshold. |
Fault |
Major |
1.3.6.1.4.1.25506.213.2.2 (hh3cPimRouteThresholdExceedClear) |
ON |
This notification is generated when the number of multicast routing entries exceeds the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-threshold-exceed command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.213.1.4 (hh3cPimNotificationLimitType) |
Multicast routing entry type. |
No |
INTEGER |
sm-star-group(1), sm-source-group(2) |
1.3.6.1.4.1.25506.213.1.5 (hh3cPimNotificationAddressFamily) |
Multicast address type. |
No |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), |
1.3.6.1.4.1.25506.213.1.6 (hh3cPimNotificationEntryCount) |
Current number of multicast routing entries. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.213.1.8 (hh3cPimNotificationThresholdCnt) |
Alarm threshold. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.213.1.9 (hh3cPimThresholdReasonType) |
Reason why the number of multicast routing entries exceeded the alarm threshold. |
No |
INTEGER |
entryCreated(1), configurationChanged(2) |
Recommended action
To resolve the issue:
1. Increase the alarm threshold for multicast routing entries.
2. Reduce the number of multicast routing entries.
3. If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.213.2.3 |
The number of multicast routing entries fell below the alarm threshold. |
Fault |
Major |
N/A |
ON |
This notification is generated when the number of multicast routing entries falls below the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-threshold-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-threshold-exceed-clear command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
Multicast address type |
No |
InetAddressType |
Current number of multicast routing entries |
No |
Unsigned32 |
Alarm threshold |
No |
Unsigned32 |
1.3.6.1.4.1.25506.213.1.11 ( hh3cPimNotificationThreshReType ) |
Reason why the number of multicast routing entries fell below the alarm threshold. |
No |
INTEGER |
entryDeleted(1), configurationChanged(2), |
Recommended action
hh3cPimRouteExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.213.0.4 |
The number of multicast routing entries exceeded the limit. |
Fault |
Major |
1.3.6.1.4.1.25506.213.0.5 (hh3cPimRouteExceedClear) |
ON |
This notification is generated when the number of multicast routing entries exceeds the limit.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-exceed command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
InetAddressType |
No |
Unsigned32 |
1.3.6.1.4.1.25506.213.1.7 (hh3cPimNotificationLimitCount) |
Limit value. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.213.1.12 (hh3cPimNotificationSourceAddress) |
Source address of the multicast routing entry. |
No |
InetAddress |
1.3.6.1.4.1.25506.213.1.13 (hh3cPimNotificationGroupAddress) |
Group address of the multicast routing entry. |
No |
InetAddress |
No |
DisplayString |
Recommended action
1. Increase the limit for multicast routing entries.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.213.2.5 |
The number of multicast routing entries fell below the limit. |
Fault |
Major |
N/A |
ON |
This notification is generated when the number of multicast routing entries falls below the limit.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-exceed-clear command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
InetAddressType |
No |
Unsigned32 |
Limit value. |
No |
Unsigned32 |
No |
InetAddress |
No |
InetAddress |
1.3.6.1.4.1.25506.213.1.10 (hh3cPimRouteEClearReasonType) |
Reason why the number of multicast routing entries fell below the limit. |
No |
INTEGER |
DisplayString |
Recommended action
