01-HH3C-ISIS-MIB | 44.27 KB |
HH3C-ISIS-MIB
About this MIB
Use this MIB to obtain all IS-IS process IDs by using the hh3cIsisSysInstance node.
MIB file name
hh3c-isis.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIsis(59)
Global objects
hh3cIsisSysInstance
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIsisSysInstance (1.3.6.1.4.1.25506.2.59.1.1.1.1.1) |
read-only |
Integer32 |
Integer32 (1..65535) |
Process node. |
As per the MIB. |
isisNotificationSysLevelIndex
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex) |
System level index. |
No |
IsisLevel |
level1(1) level2(2) level1and2(3) |
isisNotificationCircIfIndex
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex) |
Interface index. |
No |
Unsigned32 |
Unsigned32(1..2147483647) |
isisPduLspId
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId) |
LSP ID. |
No |
IsisLinkStatePDUID |
OCTET STRING (8) |
ifName
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.31.1.1.1.1 (ifName) |
Interface name. |
No |
DisplayString |
OCTET STRING(0..255) |
Tabular objects
hh3cIsisSysTable
About this table
This table contains information about all IS-IS process IDs.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIsisSysInstance.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
read-only |
Integer32 |
Process node. |
As per the MIB. |
