05-HH3C-UI-MAN-MIB | 53.52 KB |
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to define alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
hh3cTerminalUserName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1) |
accessible-for-notify |
DisplayString |
Standard MIB values. |
Name of a login user. |
As per the MIB. |
hh3cTerminalSource
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2) |
DisplayString |
Login method, including Console, AUX, TTY, and VTY. |
As per the MIB. |
hh3cTerminalUserAuthFailureReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTerminalUserAuthFailureReason (1.3.6.1.4.1.25506.2.2.1.1.2.3) |
INTEGER |
exceedRetries(1) authTimeout(2) otherReason(3) |
Failure reason for user authentication. |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-UI-MAN-MIB module.
hh3cLogIn
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.1 |
User login |
Informational |
Warning |
ON |
This notification is generated when a user logs in to the system.
Status control
This alarm cannot be cleared.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName) |
Username. |
No |
DisplayString |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource) |
User line, including console, AUX, TTY, and VTY. |
No |
DisplayString |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cLogOut
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.2 |
User logout |
Informational |
Warning |
ON |
This notification is generated when a user logs out of the system.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Username. |
No |
DisplayString |
User line, including AUX, TTY, and VTY. |
No |
DisplayString |
Recommended action
hh3cLogInAuthenFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.2.1.1.3.0.3 |
User authentication failed |
Informational |
Warning |
ON |
This notification is generated when a user failed to log in to the system.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Username. |
No |
DisplayString |
No |
DisplayString |
1.3.6.1.4.1.25506.2.2.1.1.2.3 (hh3cTerminalUserAuthFailureReason) |
No |
INTEGER |
Recommended action
