| 04-Appendix A Chassis Views and Technical Specifications | 281.05 KB |
4 Appendix A Chassis views and technical specifications
Chassis views
RA5100
Figure4-1 RA5100 front panel
(1) 10GE fiber ports 0 to 5 |
(2) GE fiber ports 6 to 13 |
(3) GE copper ports 14 to 17 |
(4) ToD port |
(5) CLK port |
(6) Console port (CONSOLE) |
(7) Grounding screw |
(8) DC power receptacles |
(9) Reset button (RESET) |
(10) Management Ethernet port (MANAGEMENT) |
(11) ALMI/ALMO port |
RA5100-HI
Figure4-2 RA5100-HI front panel
(1) 10GE fiber ports 0 to 11 |
(2) GE fiber ports 12 to 19 |
(3) GE copper ports 20 to 23 |
(4) ToD port |
(5) CLK port |
Technical specifications
RA5100
Table4-1 RA5100 technical specifications
Item |
Specifications |
Dimensions (H × W × D), excluding rubber feet and mounting brackets |
44 × 440 × 205 mm (1.73 × 17.32 × 8.07 in) |
Weight |
3 kg (6.61 lb) |
Memory type and size |
4GB DDR4 |
Flash |
4 GB |
DC power adapter |
Rated voltage range: –48 VDC to –60 VDC |
Console port |
1 |
GE copper port |
4 |
GE SFP fiber port |
8 |
10GE SFP+ fiber port |
6 |
1 |
ALMI/ALMO port |
1 |
ToD port |
1 |
CLK port |
1 |
Reset button |
1 |
Ambient temperature |
· Operating: –20°C to +60°C (–4°F to +140°F) · Storage: –40°C to +70°C (–40°F to +158°F) |
Ambient humidity (noncondensing) |
· Operating: 5% RH to 95% RH · Storage: 5% RH to 95% RH |
RA5100-HI
Table4-2 RA5100-HI technical specifications
Item |
Specifications |
Weight |
3.1 kg (6.83 lb) |
4GB DDR4 |
Flash |
4 GB |
DC power adapter |
Console port |
1 |
GE copper port |
4 |
GE SFP fiber port |
8 |
12 |
Management Ethernet port |
1 |
ALMI/ALMO port |
1 |
ToD port |
1 |
CLK port |
1 |
Reset button |
1 |
Power cable specifications
A DC power cable is used to connect a DC power supply to an external DC power supply system. See Table4-3 for the DC power cables supported by the RA5100 and RA5100-HI routers.
Table4-3 DC power cable specifications
BOM No. |
Length |
0404A17L |
5 m (16.40 ft) |
