06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10106-Layer 2 - LAN Switching
19-BRIDGE-MIB
19-BRIDGE-MIB 127.65 KB
BRIDGE-MIB
About this MIB
Use this MIB to obtain basic bridge information, collect diagnosis information, and configure the system operating mode.
MIB file name
rfc1493-bridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17)
Scalar objects
dot1dBaseBridgeAddress
Object (OID)
Access
Value range
Implementation
dot1dBaseBridgeAddress (1.3.6.1.2.1.17.1.1)
read-only
OCTET STRING
(0..255)
MAC address used by this bridge when it must be referred to in a unique fashion.
As per the MIB.
dot1dBaseNumPorts
Object (OID)
Access
Value range
Implementation
dot1dBaseNumPorts (1.3.6.1.2.1.17.1.2)
read-only
INTEGER
Standard MIB values.
Number of ports controlled by this bridging entity.
As per the MIB.
dot1dBaseType
Object (OID)
Access
Value range
Implementation
dot1dBaseType (1.3.6.1.2.1.17.1.3)
read-only
INTEGER
unknown(1),
transparent-only(2),
sourceroute-only(3),
srt(4),
Indicates what type of bridging this bridge can perform.
As per the MIB.
dot1dStpProtocolSpecification
Object (OID)
Access
Value range
Implementation
dot1dStpProtocolSpecification (1.3.6.1.2.1.17.2.1)
read-only
INTEGER
unknown(1),
decLb100(2),
ieee8021d(3)
Indication of what version of the Spanning Tree Protocol is being run.
As per the MIB.
dot1dStpPriority
Object (OID)
Access
Value range
Implementation
dot1dStpPriority (1.3.6.1.2.1.17.2.2)
read-write
INTEGER
(0..61440)
Value of the write-able portion of the Bridge ID.
As per the MIB.
dot1dStpTimeSinceTopologyChange
Object (OID)
Access
Value range
Implementation
dot1dStpTimeSinceTopologyChange (1.3.6.1.2.1.17.2.3)
read-only
TimeTicks
Time (in hundredths of a second) since the last time a topology change was detected by the bridge entity.
As per the MIB.
dot1dStpTopChanges
Object (OID)
Access
Value range
Implementation
dot1dStpTopChanges (1.3.6.1.2.1.17.2.4)
read-only
Counter
Total number of topology changes detected by this bridge since the management entity was last reset or initialized.
As per the MIB.
dot1dStpDesignatedRoot
Object (OID)
Access
Value range
Implementation
dot1dStpDesignatedRoot (1.3.6.1.2.1.17.2.5)
read-only
BridgeId
Bridge identifier of the root of the spanning tree as determined by the Spanning Tree Protocol as executed by this node.
As per the MIB.
dot1dStpRootCost
Object (OID)
Access
Value range
Implementation
dot1dStpRootCost (1.3.6.1.2.1.17.2.6)
read-only
INTEGER
Cost of the path to the root as seen from this bridge.
As per the MIB.
dot1dStpRootPort
Object (OID)
Access
Value range
Implementation
dot1dStpRootPort (1.3.6.1.2.1.17.2.7)
read-only
INTEGER
Port number of the port which offers the lowest cost path from this bridge to the root bridge.
As per the MIB.
dot1dStpMaxAge
Object (OID)
Access
Value range
Implementation
dot1dStpMaxAge (1.3.6.1.2.1.17.2.8)
read-only
Timeout
Maximum age of Spanning Tree Protocol information.
As per the MIB.
dot1dStpHelloTime
Object (OID)
Access
Value range
Implementation
dot1dStpHelloTime (1.3.6.1.2.1.17.2.9)
read-only
Timeout
Amount of time between the transmission of Configuration bridge PDUs by this node on any port when it is the root of the spanning tree or trying to become so.
As per the MIB.
dot1dStpHoldTime
Object (OID)
Access
Value range
Implementation
dot1dStpHoldTime (1.3.6.1.2.1.17.2.10)
read-only
INTEGER
Interval length during which no more than two Configuration bridge PDUs shall be transmitted by this node.
As per the MIB.
dot1dStpForwardDelay
Object (OID)
Access
Value range
Implementation
dot1dStpForwardDelay (1.3.6.1.2.1.17.2.11)
read-only
Timeout
Controls how fast a port changes its spanning state when moving towards the Forwarding state.
As per the MIB.
dot1dStpBridgeMaxAge
Object (OID)
Access
Value range
Implementation
dot1dStpBridgeMaxAge (1.3.6.1.2.1.17.2.12)
read-write
Timeout
(600..4000)
Maximum age.
As per the MIB.
dot1dStpBridgeHelloTime
Object (OID)
Access
Value range
Implementation
dot1dStpBridgeHelloTime (1.3.6.1.2.1.17.2.13)
read-write
INTEGER
(100..1000)
Hello time.
As per the MIB.
dot1dStpBridgeForwardDelay
Object (OID)
Access
Value range
Implementation
dot1dStpBridgeForwardDelay (1.3.6.1.2.1.17.2.14)
read-write
INTEGER
(400..3000)
As per the MIB.
dot1dTpAgingTime
Object (OID)
Access
Value range
Implementation
dot1dTpAgingTime (1.3.6.1.2.1.17.4.2)
read-write
INTEGER
(-1 | 10..1000000)
Timeout period in seconds for aging out dynamically learned forwarding information.
Implementation varies by product.
Tabular objects
dot1dBasePortTable
About this table
This table contains generic information about every port that is associated with this bridge.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot1dBasePort.
Object (OID)
Access
Value range
Implementation
dot1dBasePort (1.3.6.1.2.1.17.1.4.1.1)
read-only
INTEGER
(1..65535)
Port number of the port for which this entry contains bridge management information.
As per the MIB.
dot1dBasePortIfIndex (1.3.6.1.2.1.17.1.4.1.2)
read-only
INTEGER
Value of the instance of the ifIndex object for the interface corresponding to this port.
As per the MIB.
dot1dBasePortCircuit (1.3.6.1.2.1.17.1.4.1.3)
read-only
OBJECT IDENTIFIER
Name of an object instance unique to this port.
As per the MIB.
dot1dBasePortDelayExceededDiscards (1.3.6.1.2.1.17.1.4.1.4)
read-only
Counter
Number of frames discarded by this port due to excessive transit delay through the bridge.
As per the MIB.
dot1dBasePortMtuExceededDiscards (1.3.6.1.2.1.17.1.4.1.5)
read-only
Counter
Number of frames discarded by this port due to an excessive size.
As per the MIB.
dot1dStpPortTable
About this table
This table that contains port-specific information for the Spanning Tree Protocol.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is dot1dStpPort.
Object (OID)
Access
Value range
Implementation
dot1dStpPort (1.3.6.1.2.1.17.2.15.1.1)
read-only
INTEGER
(1..65535)
Port number of the port for which this entry contains Spanning Tree Protocol management information.
As per the MIB.
dot1dStpPortPriority (1.3.6.1.2.1.17.2.15.1.2)
read-write
INTEGER
(0..240)
Value of the priority field which is contained in the first (in network byte order) octet of the (2 octet long) Port ID.
As per the MIB.
dot1dStpPortState (1.3.6.1.2.1.17.2.15.1.3)
read-only
INTEGER
disabled(1),
blocking(2),
listening(3),
learning(4),
forwarding(5),
broken(6)
Port's current state as defined by application of the Spanning Tree Protocol.
As per the MIB.
dot1dStpPortEnable (1.3.6.1.2.1.17.2.15.1.4)
read-write
INTEGER
enabled(1),
disabled(2)
Enabled/disabled status of the port.
As per the MIB.
dot1dStpPortPathCost (1.3.6.1.2.1.17.2.15.1.5)
read-write
INTEGER
(1..65535)
Contribution of this port to the path cost of paths towards the spanning tree root which include this port.
In the current software version, this object supports only the IEEE802.1d-1990 standard, and the value range is 1 to 65535. If the actual value is greater than 65535 in another standard, the object value is 65535.
dot1dStpPortDesignatedRoot (1.3.6.1.2.1.17.2.15.1.6)
read-only
BridgeId
Unique Bridge Identifier of the Bridge recorded as the Root in the Configuration BPDUs transmitted by the Designated Bridge for the segment to which the port is attached.
As per the MIB.
dot1dStpPortDesignatedCost (1.3.6.1.2.1.17.2.15.1.7)
read-only
INTEGER
Path cost.
As per the MIB.
dot1dStpPortDesignatedBridge (1.3.6.1.2.1.17.2.15.1.8)
read-only
BridgeId
 Bridge identifier.
As per the MIB.
dot1dStpPortDesignatedPort (1.3.6.1.2.1.17.2.15.1.9)
read-only
OCTET STRING
(SIZE (2))
Port identifier of the port on the Designated Bridge for this port's segment.
As per the MIB.
dot1dStpPortForwardTransition (1.3.6.1.2.1.17.2.15.1.10)
read-only
Counter
Number of times this port has transitioned from the Learning state to the Forwarding state.
As per the MIB.
dot1dTpFdbTable
About this table
This table contains information about unicast entries for which the bridge has forwarding and/or filtering information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot1dTpFdbAddress.
Object (OID)
Access
Value range
Implementation
dot1dTpFdbAddress (1.3.6.1.2.1.17.4.3.1.1)
read-only
OCTET STRING
SIZE (6)
Unicast MAC address entry.
As per the MIB.
dot1dTpFdbPort (1.3.6.1.2.1.17.4.3.1.2)
read-only
INTEGER
Port number of the port on which a frame having a source address equal to the value of the corresponding instance of dot1dTpFdbAddress has been seen.
As per the MIB.
dot1dTpFdbStatus (1.3.6.1.2.1.17.4.3.1.3)
read-only
INTEGER
other(1),
invalid(2),
learned(3),
self(4),
mgmt(5)
Status of this entry.
As per the MIB.
