06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10106-Layer 2 - LAN Switching
08-HH3C-QINQV2-MIB
08-HH3C-QINQV2-MIB 41.52 KB
HH3C-QINQV2-MIB
About this MIB
Use this MIB to manage, configure, and obtain 802.1Q in 802.1Q (QinQ) information.
MIB file name
hh3c-qinqv2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQinQv2(137)
Scalar objects
hh3cQinQv2ServiceTPID
Object (OID)
Access
Value range
Implementation
hh3cQinQv2ServiceTPID (1.3.6.1.4.1.25506.2.137.1.1.1)
read-write
Integer32
Integer32 (1..65535)
SVLAN TPID
Implementation varies by product
hh3cQinQv2CustomerTPID
Object (OID)
Access
Value range
Implementation
hh3cQinQv2CustomerTPID (1.3.6.1.4.1.25506.2.137.1.1.2)
read-write
Integer32
CVLAN TPID
Tabular objects
hh3cQinQv2IfConfigTable
About this table
Use this table to enable QinQ, set the CVLAN TPID and SVLAN TPID, and configure VLAN transparent transmission on a port.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cQinQv2IfState (1.3.6.1.4.1.25506.2.137.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
This variable is used to enable or disable QinQ on the port.
hh3cQinQv2IfServiceTPID (1.3.6.1.4.1.25506.2.137.1.2.1.2)
read-write
Integer32
SVLAN TPID on the port.
hh3cQinQv2IfCustomerTPID (1.3.6.1.4.1.25506.2.137.1.2.1.3)
read-write
Integer32
CVLAN TPID on the port.
hh3cQinQv2IfTransparentVlanList (1.3.6.1.4.1.25506.2.137.1.2.1.4)
read-write
OCTET STRING
OCTET STRING (512)
List of transparent VLANs the port.
