13-Security
HomeSupportRoutersSR8800-X SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-X Routers Alarm Reference-R838x-6W10013-Security
03-HH3C-IPSGT-MIB
03-HH3C-IPSGT-MIB 43.56 KB
HH3C-IPSGT-MIB
About this MIB
Use this table to obtain the operation status of IP-SGT and report corresponding alarm events.
MIB file name
hh3c-ipsgt.mib
Notifications
hh3cIpsgtCloudConnectionUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.247.0.1
Cloud connection is established to the EIA server.
Informational
Warning
OFF
Notification triggers
This notification is generated when the number of packets dropped because of packet mismatching with IPSG bindings drops below the threshold.
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when the device establishes a cloud connection to a cloud-based EIA server that supports IP-SGT.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable ipsgt command.
OFF
CLI: Use the undo snmp-agent trap enable ipsgt command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.247.1.1.1 (hh3cIpsgtNotifyDomain)
Domain name
N/A
OCTET STRING
SIZE (1..255)
1.3.6.1.4.1.25506.2.247.1.1.2 (hh3cIpsgtNotifyPort)
Server port number
N/A
Integer32
(0..65534)
1.3.6.1.4.1.25506.2.247.1.1.3 (hh3cIpsgtNotifyServerType)
IP-SGT tunnel type
N/A
INTEGER
unknown (1), master (2), backup (3)
Recommended action
No action is required.
hh3cIpsgtCloudConnectionDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.247.0.2
Cloud connection is disconnected from the EIA server.
Informational
Warning
OFF
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when the cloud connection is disconnected between the device and the cloud-based EIA server that supports IP-SGT.
System impact
The IP-SGT service is interrupted.
Status control
ON
CLI: snmp-agent trap enable ipsgt
OFF
CLI: undo snmp-agent trap enable ipsgt
Object
OID (object name)
Index
Value range
Domain name
N/A
OCTET STRING
SIZE (1..255)
Server port number
N/A
Integer32
(0..65534)
IP-SGT tunnel type
N/A
INTEGER
Recommended action
1.Verify that IP-SGT related settings (such as the IP address of the cloud server) are configured correctly.
2.If the issue persists, contact Technical Support.
