13-Security
HomeSupportRoutersSR8800-X SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-X Routers Alarm Reference-R838x-6W10013-Security
01-HH3C-IPSEC-MONITOR-V2-MIB
01-HH3C-IPSEC-MONITOR-V2-MIB 114.94 KB
About this MIB
Use this MIB to obtain information about IPsec tunnels, IPsec-protected traffic, IPsec SAs, IPsec tunnel packet statistics, and IPsec trap notifications.
MIB file name
hh3c-ipsec-monitor-v2.mib
Notifications
hh3cIPsecTunnelStartV2
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.1
IPsec tunnel created.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when an IPsec tunnel is created.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable ipsec tunnel-start command.
MIB: Set hh3cIPsecTunnelStartTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec tunnel-start command.
MIB: Set hh3cIPsecTunnelStartTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.126.1.2.1.1 (hh3cIPsecTunIndexV2)
Index of an IPsec tunnel.
hh3cIPsecTunIndexV2
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.126.1.2.1.10 (hh3cIPsecTunLocalAddrTypeV2)
Type of the IP address of the IPsec tunnel local end.
hh3cIPsecTunIndexV2
InetAddressType
Standard MIB values.
1.3.6.1.4.1.25506.2.126.1.2.1.11 (hh3cIPsecTunLocalAddrV2)
hh3cIPsecTunIndexV2
InetAddress
1.3.6.1.4.1.25506.2.126.1.2.1.12 (hh3cIPsecTunRemoteAddrTypeV2)
Type of the IP address of the IPsec tunnel remote end.
hh3cIPsecTunIndexV2
InetAddressType
1.3.6.1.4.1.25506.2.126.1.2.1.13 (hh3cIPsecTunRemoteAddrV2)
hh3cIPsecTunIndexV2
InetAddress
1.3.6.1.4.1.25506.2.126.1.2.1.18 (hh3cIPsecTunLifeTimeV2)
Time-based lifetime of the IPsec tunnel, in seconds.
hh3cIPsecTunIndexV2
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.126.1.2.1.17 (hh3cIPsecTunLifeSizeV2)
Time-based lifetime of the IPsec tunnel, in kilobytes.
hh3cIPsecTunIndexV2
Gauge32
Recommended action
No action is required.
hh3cIPsecTunnelStopV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.2
IPsec tunnel deleted.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec tunnel is deleted.
This notification might be generated when the following events occur:
Hard timeout of the phase-2 IKE negotiation occurs.
The IPsec SA is accidentally deleted when you modify other configurations or manually deleted.
A new IPsec SA takes over the old IPsec SA.
IPsec SA idle timer expires.
The remote end asks to delete the IPsec SA.
Other events.
System impact
The IPsec tunnel is deleted.
Status control
ON
CLI: Use the snmp-agent trap enable ipsec tunnel-stop command.
MIB: Set hh3cIPsecTunnelStopTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec tunnel-stop command.
MIB: Set hh3cIPsecTunnelStopTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
hh3cIPsecTunIndexV2
Integer32
1..2147483647
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
1.3.6.1.4.1.25506.2.126.1.2.1.20 (hh3cIPsecTunActiveTimeV2)
Active period of time of the IPsec tunnel.
hh3cIPsecTunIndexV2
Integer32
0..2147483647
Recommended action
To resolve this issue, take the following operations according to the corresponding notification generation reasons:
● Check whether the IPsec SA lifetime is appropriate. If no, modify the IPsec SA lifetime.
● Check whether the reset ipsec sa command has been executed to delete the IPsec SA. If yes, no action is required. Then check whether an IPsec policy application has been removed from the interface and whether the removement is appropriate. If no, apply an IPsec policy to the interface again.
● If a new IPsec SA takes over the old IPsec SA, no action is required.
● Check whether the IPsec SA idle timeout is appropriate. If no, modify the IPsec SA idle timeout.
● View the logs on the remote end and identify the IPsec tunnel deletion reasons.
● Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cIPsecNoSaFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.3
No SA for IPsec tunnel.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when no SA is available for an IPsec tunnel.
System impact
If the IPsec tunnel exists, IPsec-related services are unavailable.
If this notification is generated when negotiation is triggered, there is no impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable ipsec no-sa-failure command.
MIB: Set hh3cIPsecNoSaTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec no-sa-failure command.
MIB: Set hh3cIPsecNoSaTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
hh3cIPsecTunIndexV2
Integer32
1..2147483647
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
Recommended action
To resolve this issue:
1.Check whether this notification is generated when negotiation is triggered:
  - If yes, no action is required.
  - If no, use the reset ipsec sa command to delete IPsec SAs and use the reset ike sa command to delete IKE SAs so as to trigger IKE SA negotiation. If the negotiation is successful and this notification still exists, go to step 2.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cIPsecAuthFailFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.4
IPsec authentication failure.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec authentication failure occurs.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec auth-failure command.
MIB: Set hh3cIPsecAuthFailureTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec auth-failure command.
MIB: Set hh3cIPsecAuthFailureTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
hh3cIPsecTunIndexV2
Integer32
1..2147483647
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
Recommended action
1.Use the reset ipsec sa command to delete IPsec SAs and use the reset ike sa command to delete IKE SAs so as to trigger IKE SA negotiation.
hh3cIPsecEncryFailFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.5
IPsec tunnel encryption failure.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec tunnel has an encryption failure.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec encrypt-failure command.
MIB: Set hh3cIPsecEncryFailureTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec encrypt-failure command.
MIB: Set hh3cIPsecEncryFailureTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
hh3cIPsecTunIndexV2
Integer32
1..2147483647
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
Recommended action
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cIPsecDecryFailFailureV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.6
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec tunnel has a decryption failure.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec decrypt-failure command.
MIB: Set hh3cIPsecDecryFailureTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec decrypt-failure command.
MIB: Set hh3cIPsecDecryFailureTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
hh3cIPsecTunIndexV2
Integer32
1..2147483647
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
hh3cIPsecTunIndexV2
InetAddressType
hh3cIPsecTunIndexV2
InetAddress
Recommended action
hh3cIPsecPolicyAddV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.8
IPsec policy or profile added.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec policy or profile is added.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-add command.
MIB: Set hh3cIPsecPolicyAddTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-add command.
MIB: Set hh3cIPsecPolicyAddTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.126.1.7.1 (hh3cIPsecPolicyNameV2)
Name of an IPsec policy.
N/A
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.126.1.7.2 (hh3cIPsecPolicySeqNumV2)
Sequence number an IPsec policy entry.
N/A
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.126.1.7.3 (hh3cIPsecPolicySizeV2)
Number of the IPsec policy entries.
N/A
InetAddressType
Recommended action
hh3cIPsecPolicyDelV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.9
IPsec policy or profile deleted.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec policy or profile is deleted.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-delete command.
MIB: Set hh3cIPsecPolicyDelTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-delete command.
MIB: Set hh3cIPsecPolicyDelTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
N/A
DisplayString
Sequence number of an IPsec policy entry.
N/A
Integer32
1..2147483647
N/A
InetAddressType
Recommended action
hh3cIPsecPolicyAttachV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.10
IPsec policy or profile applied to interface.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec policy or profile is applied to an interface.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-attach command.
MIB: Set hh3cIPsecPolicyAttachTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-attach command.
MIB: Set hh3cIPsecPolicyAttachTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
N/A
DisplayString
N/A
Integer32
1..2147483647
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of an interface.
ifIndex
InterfaceIndex
Integer32(1..2147483647)
Recommended action
hh3cIPsecPolicyDetachV2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.126.1.9.0.11
IPsec policy or profile application removed from interface.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an IPsec policy or profile application is removed from an interface.
System impact
If an IPsec tunnel exists, the running IPsec tunnel will be disconnected.
If no IPsec tunnel exists, there is no impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable ipsec policy-detach command.
MIB: Set hh3cIPsecPolicyDetachTrapCntlV2 to true(1).
OFF
CLI: Use the undo snmp-agent trap enable ipsec policy-detach command.
MIB: Set hh3cIPsecPolicyDetachTrapCntlV2 to false(2).
Object
OID (object name)
Index
Value range
N/A
DisplayString
N/A
Integer32
1..2147483647
ifIndex
InterfaceIndex
Recommended action
