17-User Access and Authentication
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R838x-6W10017-User Access and Authentication
12-RADIUS-ACC-CLIENT-MIB
12-RADIUS-ACC-CLIENT-MIB 68.02 KB
About this MIB
Use this MIB to collect statistics about accounting packets of different types that a RADIUS client receives from RADIUS servers.
MIB file name
radius-acc-client.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).radiusMIB(67).radiusAccounting(2).radiusAccClientMIB(2)
Scalar objects
radiusAccClientInvalidServerAddresses (1.3.6.1.2.1.67.2.2.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Standard MIB values.
Number of unrecognizable IP addresses of accounting servers.
As per the MIB.
radiusAccClientIdentifier (1.3.6.1.2.1.67.2.2.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
OCTET STRING (SIZE (0..255))
ID of a client.
As per the MIB.
Tabular objects
radiusAccServerTable
About this table
This table contains the statistics about accounting packets that a RADIUS client receives from a RADIUS server.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is radiusAccServerIndex.
Object (OID)
Access
Value range
Implementation
radiusAccServerIndex (1.3.6.1.2.1.67.2.2.1.1.3.1.1)
not-accessible
Integer32
1..2147483647
Index of an accounting server.
As per the MIB.
radiusAccServerAddress (1.3.6.1.2.1.67.2.2.1.1.3.1.2)
read-only
IpAddress
IP address of the accounting server.
As per the MIB.
radiusAccClientServerPortNumber (1.3.6.1.2.1.67.2.2.1.1.3.1.3)
read-only
Integer32
0..65535
Port number of the accounting server.
As per the MIB.
radiusAccClientRoundTripTime (1.3.6.1.2.1.67.2.2.1.1.3.1.4)
read-only
TimeTicks
TimeTick
Round trip time.
As per the MIB.
radiusAccClientRequests (1.3.6.1.2.1.67.2.2.1.1.3.1.5)
read-only
Counter32
Number of accounting requests sent to the server.
As per the MIB.
radiusAccClientRetransmissions (1.3.6.1.2.1.67.2.2.1.1.3.1.6)
read-only
Counter32
Number of accounting requests retransmitted.
As per the MIB.
radiusAccClientResponses (1.3.6.1.2.1.67.2.2.1.1.3.1.7)
read-only
Counter32
Number of accounting responses received.
As per the MIB.
radiusAccClientMalformedResponses (1.3.6.1.2.1.67.2.2.1.1.3.1.8)
read-only
Counter32
Number of malformed accounting responses received.
As per the MIB.
radiusAccClientBadAuthenticators (1.3.6.1.2.1.67.2.2.1.1.3.1.9)
read-only
Counter32
Number of Access-Reject packets received.
As per the MIB.
radiusAccClientPendingRequests (1.3.6.1.2.1.67.2.2.1.1.3.1.10)
read-only
Gauge32
Number of pending authentication requests.
As per the MIB.
radiusAccClientTimeouts (1.3.6.1.2.1.67.2.2.1.1.3.1.11)
read-only
Counter32
Number of timed out accounting requests.
As per the MIB.
radiusAccClientUnknownTypes (1.3.6.1.2.1.67.2.2.1.1.3.1.12)
read-only
Counter32
Number of packets with unknown types.
As per the MIB.
radiusAccClientPacketsDropped (1.3.6.1.2.1.67.2.2.1.1.3.1.13)
read-only
Counter32
Number of packets discarded.
As per the MIB.
