- 17-User Access and Authentication
- 01-HH3C-8021X-EXT2-MIB
- 02-HH3C-AAA-MIB
- 03-HH3C-DOMAIN-MIB
- 04-HH3C-LOCAL-AAA-SERVER-MIB
- 05-HH3C-PORT-SECURITY-MIB
- 06-HH3C-PORTAL-MIB
- 07-HH3C-RADIUS-MIB
- 08-HH3C-USER-MIB
- 09-IEEE8021-PAE-MIB
- 10-IEEE8021-SECY-MIB
- 11-IEEE8021X-PAE-MIB
- 12-RADIUS-ACC-CLIENT-MIB
- 13-RADIUS-AUTH-CLIENT-MIB
| 08-HH3C-USER-MIB | 108.52 KB |
hh3cUserIndexIndicator (1.3.6.1.4.1.25506.2.12.1.5)
hh3cUserIPAddressType (1.3.6.1.4.1.25506.2.12.3.1.1.1)
hh3cUserIPAddress (1.3.6.1.4.1.25506.2.12.3.1.1.2)
hh3cUserGroupUsedNum (1.3.6.1.4.1.25506.2.12.4.1.1)
hh3cUserGroupNumThreshold (1.3.6.1.4.1.25506.2.12.4.1.2)
HH3C-USER-MIB
About this MIB
Use this MIB to manage local users.
MIB file name
hh3c-user.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUser(12)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserIndexIndicator (1.3.6.1.4.1.25506.2.12.1.5) |
read-only |
Integer32 |
Standard MIB values. |
Index to be used for the next local user. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserIPAddressType (1.3.6.1.4.1.25506.2.12.3.1.1.1) |
accessible-for-notify |
InetAddressType |
User IP address type. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserIPAddress (1.3.6.1.4.1.25506.2.12.3.1.1.2) |
InetAddress |
User IP address. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserGroupUsedNum (1.3.6.1.4.1.25506.2.12.4.1.1) |
Unsigned32 |
Number of existing user groups. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserGroupNumThreshold (1.3.6.1.4.1.25506.2.12.4.1.2) |
Integer32 |
User group quantity threshold. |
As per the MIB. |
Tabular objects
hh3cUserInfoTable
About this table
Use this table to configure or obtain basic information of a local user.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cUserIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserName (1.3.6.1.4.1.25506.2.12.1.1.1.1) |
read-create |
DisplayString |
OCTET STRING (1..255) |
Name of a local user. |
The username cannot contain any of the following characters: backslash (\), forward slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), or vertical bar (|). It cannot be a, al, or all and cannot begin with or end with at sign (@). A username that contains a domain name is in the format of localusername@domain. The localusername part in the username cannot contain any of the following characters: backslash (\), forward slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), or vertical bar (|).. The maximum length of this part varies by device model. The username of each local user is unique. You cannot edit an existing username. |
hh3cUserPassword (1.3.6.1.4.1.25506.2.12.1.1.1.2) |
read-create |
DisplayString |
OCTET STRING (0..255) |
Password of the local user. |
When read, this object returns a zero-length string. |
hh3cAuthMode (1.3.6.1.4.1.25506.2.12.1.1.1.3) |
read-create |
Integer32 |
Encrypting type of the user password. |
Value range: 0 or 7. |
hh3cUserState (1.3.6.1.4.1.25506.2.12.1.1.1.5) |
read-create |
INTEGER |
active(0), block(1) |
Status of the local user. |
As per the MIB. |
hh3cUserInfoRowStatus (1.3.6.1.4.1.25506.2.12.1.1.1.6) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Row status. |
As per the MIB. |
hh3cUserIndex (1.3.6.1.4.1.25506.2.12.1.1.1.7) |
not-accessible |
Integer32 |
Integer32 (1..2147483646) |
Index of the local user. |
Value range: 1 to 1024. |
hh3cUserAttributeTable
About this table
This table contains attributes of a local user.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAccessLimit (1.3.6.1.4.1.25506.2.12.1.2.1.1) |
read-write |
Integer32 |
Maximum number of concurrent users that can use a username to access the device. |
Default: No limit is placed on the maximum number of concurrent users that can use a username to access the device. Value range: 0 to 1024. |
hh3cIdleCut (1.3.6.1.4.1.25506.2.12.1.2.1.2) |
read-write |
Integer32 |
Idle timeout period, in seconds. |
This object will round the specified value to the nearest multiple of 60. |
hh3cIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.3) |
read-write |
IpAddress |
IP address of a user. |
Default: 0.0.0.0. |
hh3cNasIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.4) |
read-write |
IpAddress |
IP address of the NAS for the user. |
Not supported. |
hh3cSlotNum (1.3.6.1.4.1.25506.2.12.1.2.1.5) |
read-write |
Integer32 |
Slot number of the user. |
Not supported. |
hh3cSubSlotNum (1.3.6.1.4.1.25506.2.12.1.2.1.6) |
read-write |
Integer32 |
Subslot number of the user. |
Not supported. |
hh3cPortNum (1.3.6.1.4.1.25506.2.12.1.2.1.7) |
read-write |
Integer32 |
Port number of the user. |
Not supported. |
hh3cMacAddress (1.3.6.1.4.1.25506.2.12.1.2.1.8) |
read-write |
MacAddress |
OCTET STRING (6) |
MAC address of the user. |
As per the MIB. |
hh3cVlan (1.3.6.1.4.1.25506.2.12.1.2.1.9) |
read-write |
Integer32 |
Integer32 (0..4094) |
ID of the VLAN to which the user belongs. |
As per the MIB. |
hh3cFtpService (1.3.6.1.4.1.25506.2.12.1.2.1.10) |
read-write |
ServiceType |
enable(1), disable(2) |
FTP service. |
Not supported. |
hh3cFtpDirectory (1.3.6.1.4.1.25506.2.12.1.2.1.11) |
read-write |
OCTET STRING |
FTP directory. |
Not supported. |
hh3cLanAccessService (1.3.6.1.4.1.25506.2.12.1.2.1.12) |
read-write |
ServiceType |
LAN access service. |
As per the MIB. |
hh3cSshService (1.3.6.1.4.1.25506.2.12.1.2.1.13) |
read-write |
ServiceType |
SSH service. |
Not supported. |
hh3cTelnetService (1.3.6.1.4.1.25506.2.12.1.2.1.14) |
read-write |
ServiceType |
Telnet service. |
Not supported. |
hh3cTerminalService (1.3.6.1.4.1.25506.2.12.1.2.1.15) |
read-write |
ServiceType |
Terminal service. |
Not supported. |
hh3cExpirationDate (1.3.6.1.4.1.25506.2.12.1.2.1.16) |
read-write |
DateAndTime |
OCTET STRING (8) |
Expired date of the user. |
Not supported. |
hh3cUserGroup (1.3.6.1.4.1.25506.2.12.1.2.1.17) |
read-write |
DisplayString |
User group of the user. |
A user group name cannot exceed 32 characters. |
hh3cPortalService (1.3.6.1.4.1.25506.2.12.1.2.1.18) |
read-write |
ServiceType |
Portal service. |
As per the MIB. |
hh3cPPPService (1.3.6.1.4.1.25506.2.12.1.2.1.19) |
read-write |
ServiceType |
PPP service. |
As per the MIB. |
hh3cHttpService (1.3.6.1.4.1.25506.2.12.1.2.1.20) |
read-write |
ServiceType |
HTTP service. |
Not supported |
hh3cHttpsService (1.3.6.1.4.1.25506.2.12.1.2.1.21) |
read-write |
ServiceType |
HTTPS service. |
Not supported |
hh3cUserIfIndex (1.3.6.1.4.1.25506.2.12.1.2.1.22) |
read-write |
Integer32 |
Index of the user's access interface. |
As per the MIB. |
hh3cUserRoleTable
About this table
Use this table to configure or obtain basis information of a local user.
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cUserIndex and hh3cUserRole.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserRole (1.3.6.1.4.1.25506.2.12.1.6.1.1) |
not-accessible |
DisplayString |
OCTET STRING (1..63)) |
User role. |
In MDCs, the default user role is mdc-operator. In non-MDCs, the default user role is network-operator. |
hh3cUserRoleStatus (1.3.6.1.4.1.25506.2.12.1.6.1.2) |
read-create |
RowStatus |
Row status. |
You must specify hh3cUserIndex when you create a local user. |
hh3cUserGroupInfoTable
About this table
Use this table to configure or obtain basic information of a user group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cUserGroupName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cUserGroupName (1.3.6.1.4.1.25506.2.12.2.1.1.1) |
not-accessible |
DisplayString |
Name of a user group. |
As per the MIB. |
hh3cUserGroupInfoRowStatus (1.3.6.1.4.1.25506.2.12.2.1.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
Notifications
hh3cUserBlacklistLock
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.12.3.1.0.1 |
A user was locked to the password control blacklist. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when the number of login failures of a user reaches the upper limit. The user is added to the password control blacklist.
System impact
The system may be under login attacks.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-lock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-lock command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.12.1.1.1.1 (hh3cUserName) |
Username. |
hh3cUserIndex |
DisplayString |
1.3.6.1.4.1.25506.2.12.3.1.1.1 (hh3cUserIPAddressType) |
Address type of the user. |
hh3cUserIndex |
INTEGER |
unknown(0),, ipv4(1), , ipv6(2) |
1.3.6.1.4.1.25506.2.12.3.1.1.2 (hh3cUserIPAddress) |
IP address of the user. |
hh3cUserIndex |
InetAddress |
OCTET STRING(0..255) |
Recommended action
Use the display password-control blacklist command to view users in the password control blacklist and analyze whether login user attacks exist. If login user attacks exist, contact the administrator.
hh3cUserBlacklistUnlock
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.12.3.1.0.2 |
A user was unlocked from the password control blacklist. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when a user blacklisted due to login failures is removed from the blacklist because the administrator executed the reset password-control blacklist command or the user lockout timer expires.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-unlock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-unlock command.
Object
OID (object name) |
Index |
Type |
Value range |
Username. |
hh3cUserIndex |
DisplayString |
OCTET STRING (1.. 255) |
User address type. |
hh3cUserIndex |
INTEGER |
User IP address. |
hh3cUserIndex |
InetAddress |
Recommended action
No action is required.
hh3cUserGroupThresholdAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.12.4.0.1 |
Maximum number of user groups already reached. |
Error |
Major |
1.3.6.1.4.1.25506.2.12.4.0.2 (hh3cUserGroupThresholdResume) |
OFF |
This notification is generated when the number of user groups configured on the device reaches the upper limit.
System impact
New user groups cannot be created.
Status control
ON
CLI: Use the snmp-agent trap enable user-group max-count-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable user-group max-count-threshold command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.12.4.1.1 (hh3cUserGroupUsedNum) |
Current number of user groups. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.12.4.1.2 (hh3cUserGroupNumThreshold) |
Maximum number of user groups. |
N/A |
Integer32 |
Recommended action
1.Use the display user-group command in any view to view local user group information and analyze whether unused user groups exist.
- If unused user groups exist, proceed to step 2.
- If no unused user group exists, proceed to step 3.
2.Use the undo user-group command in system view to deleted unused user groups.
3.Collect alarm, log, and configuration information, and contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.12.4.0.2 |
Number of user groups dropped to 90% of the maximum number. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of user groups configured on the device drops below 90% of the maximum value.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Unsigned32 |
N/A |
Integer32 |
Recommended action
