| 10-ISIS-MIB | 177.49 KB |
ISIS-MIB
About this MIB
ISIS-MIB is a standard MIB implemented based on RFC4444. Use this MIB to define MIB variables on managed devices according to associated IS-IS configuration at the CLI.
MIB file name
rfc4444-isis.mib
Notifications
isisDatabaseOverload
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.138.0.1 |
LSDB overload state changes. |
Informational |
Informational |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the system enters or exits the overload status after one of the following events occurs:
Event 1: You configure the set-overload command or the undo set-overload command in IS-IS view.
Event 2: Memory application fails.
The number of times for generating and clearing this notification is recorded in isisSysStatLSPDbaseOloads.
System impact
If event 1 is the cause of this notification, route selection of IS-IS neighbors will be affected.
If event 2 is the cause of this notification, the IS-IS database is untrustable.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsdboverload-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsdboverload-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex) |
IS level index. |
N/A |
IsisLevel |
level1(1), level2(2), level1and2(3) |
1.3.6.1.2.1.138.1.2.1.1.4 (isisSysLevelState) |
Overload state of the IS level. |
isisSysLevelIndex |
IsisLevelState |
off (1), on (2), waiting (3), overloaded(4) |
Recommended action
To resolve this issue:
1.Use the display this command in IS-IS view to identify whether the set-overload command is configured for the current IS-IS process:
- If the set-overload command is configured, no action is required.
- If the set-overload command is not configured, proceed to step 2.
2.Use the display history-command command in IS-IS view to identify whether the undo set-overload command is configured for the current IS-IS process:
- If the undo set-overload command is configured, no action is required.
- If the undo set-overload command is not configured, proceed to step 3.
3.Use the display memory command to view the memory usage on the device.
- If the device has high memory usage, proceed to step 4.
- If the device does not have high memory usage, proceed to step 5.
4.View log information on the device to determine the cause of high memory usage.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisManualAddressDrops
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.2 |
This notification is generated for invalid area addresses. |
Informational |
Warning |
N/A (N/A) |
ON |
When IS-IS leaks Level-1 area addresses to the Level-2 area on a Level-1-2 device, the number of Level-2 area addresses might exceed three. In this situation, IS-IS keeps only the lowest three addresses as Level-2 area addresses. As a result, some local Level-2 area addresses might be discarded.
This notification might be generated when the Level-2 area has more than three area addresses after IS-IS leaks Level-1 area addresses to the Level-2 area on a Level-1-2 device.
The number of times for generating this notification is recorded in isisSysStatManAddrDropFromAreas.
The agent must throttle the generation of consecutive isisManualAddressDrops notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Some local Level-2 area addresses might be discarded.
Status control
ON
CLI: Use the snmp-agent trap enable isis manual-address-drop command.
OFF
CLI: Use the undo snmp-agent trap enable isis manual-address-drop command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.138.1.10.1.15 (isisNotificationAreaAddress) |
Manually configured area addresses that have been dropped. |
N/A |
IsisOSINSAddress |
OCTET STRING (0..20) |
Recommended action
To resolve the issue:
1.Use the display isis lsdb level-1 verbose command to view detailed Level-1 LSDB information. View the Area address field in the command output. This field records the total number of Level-1 area addresses.
- If the total number of Level-1 area addresses is greater than 3, proceed to step 2.
- If the total number of Level-1 area addresses is less than 3, proceed to step 4.
2.Use the display isis lsdb level-2 verbose command to identify whether the Level-1 area addresses are the same as the Level-2 area addresses:
- If they are exactly the same, proceed to step 4.
- If some of them are different, proceed to step 3.
3.Use the undo network-entity command to reduce the number of invalid or unused area addresses, and then identify whether the notification is cleared:
- If the notification is cleared, the troubleshooting is complete.
- If the notification is not cleared, proceed to step 4.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisCorruptedLSPDetected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.3 |
LSP errors. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when an LSP stored in the memory is damaged. This issue might occur when a memory occurs and an LSP is changed within an LSP refresh interval.
The number of times for generating this notification is recorded in isisSysCorrLSPs.
System impact
If an LSP check failure occurs, the current IS-IS process will restart and the corresponding services will be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-corrupt command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-corrupt command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId) |
String that uniquely identifies a link state PDU. |
N/A |
IsisLinkStatePDUID |
OCTET STRING (8) |
Recommended action
1.Use the display memory command to view the value of the FreeRatio field. This field records the free memory ratio on the device.
- If the value is less than 80%, proceed to step 2.
- If the value is greater than 80%, proceed to step 3.
2.Use the reset isis all command to restart the current IS-IS process, and then identify whether the notification is cleared:
- If the notification is not cleared, proceed to step 3.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisAttemptToExceedMaxSequence
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.4 |
Attempts to exceed the maximum LSP sequence number |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when the sequence number of an LSP reaches or exceeds the maximum value, 65535. This issue might occur when the sequence number of an LSP generated by the local device reaches the maximum value, 0xFFFFFFFF.
The first six bytes of an LSP ID contain system ID information, and the remaining two bytes contain valid information.
System impact
When this notification is generated for an LSP three times in a row, IS-IS stops running temporarily to wait for the LSP to expire on other devices. By default, IS-IS stops running for 20 minutes, which is the maximum LSP age. After the LSP expires and is deleted from other devices, IS-IS continues to generate LSPs with sequence number starting from 1. As a result, some IS-IS routes will be deleted and incorrect traffic forwarding will occur.
Status control
ON
CLI: Use the snmp-agent trap enable isis max-seq-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable isis max-seq-exceeded command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
N/A |
OCTET STRING (8) |
Recommended action
If the notification is cleared automatically, no action is required.
If the notification remains, perform the following tasks:
1.Wait for the LSP with sequence number 0xFFFFFFFF to expire. When IS-IS continues LSP generation, use the display isis lsdb local command multiple times to view the Seq Num field. This field displays the sequence number of an LSP generated by the local device.
- If the speed of LSP sequence number increment matches the LSP refresh interval, no action is required.
- If the LSP sequence number increases at a fast pace, proceed to step 2.
2.Identify whether the local device uses the same system ID or vSystem ID as another device in the routing domain:
- If yes, proceed to step 3.
- If no, proceed to step 4.
3.Perform the following tasks to clear the notification:
Enter the IS-IS view of the local device or the device that uses the same system ID or vSystem ID as the local device.
Use the undo network-entity command or the undo virtual-system command to remove the conflicting system ID or vSystem ID.
Use the network-entity command or the virtual-system command to specify a different system ID or vSystem ID.
Identify whether the notification is cleared:
isisIDLenMismatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.5 |
System ID length mismatches. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the device receives a PDU with different system ID length. This issue occurs when one of the following conditions exists:
The local device and the source device of the PDU support different system ID length values.
The value of the System ID Length field is changed.
This notification includes the index of the link through which the PDU is received and packet header information, which might help a network manager identify the source of the PDU.
The agent must throttle the generation of consecutive isisIDLenMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Route flapping might occur.
If this notification is generated due to a device communication error, the local device and the source device of the PDU cannot establish a neighbor relationship or cannot learn routes from each other.
Status control
ON
CLI: Use the snmp-agent trap enable isis id-length-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis id-length-mismatch command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
1.3.6.1.2.1.138.1.10.1.5 (isisPduFieldLen) |
System ID length in the received PDU. |
N/A |
IsisUnsigned8TC |
Unsigned32 (0..255) |
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex) |
Interface index. |
N/A |
Unsigned32 |
Unsigned32(1..2147483647) |
1.3.6.1.2.1.138.1.10.1.4 (isisPduFragment) |
First 64 bytes in the PDU that triggers the notification. |
N/A |
IsisPDUHeader |
OCTET STRING (0..64) |
Recommended action
1.Check the IS-IS PDU format defined by ISO 10589, find the pdu-fragment field in the notification, and then identify whether the system ID length of the source device is neither 0 nor 6:
- If the system ID length of the source device is neither 0 nor 6, proceed to step 2.
- If the system ID length of the source device is 0 or 6, proceed to step 3.
The method to find the system ID varies by IS-IS PDU type as follows:
- For hello PDUs, the value for the fifth byte of the pdu-fragment field is 0f, 10, or 11. The System ID portion in the pdu-fragment field is the consecutive 6 bytes from the tenth byte to the fifteenth byte.
- For LSPs, the value for the fifth byte of the pdu-fragment field is 12 or 14. The System ID portion in the pdu-fragment field is the consecutive 6 bytes from the thirteenth byte to the eighteenth byte.
- For SNPs, the value for the fifth byte of the pdu-fragment field is 18, 19, 1A, or 1B. The System ID portion in the pdu-fragment field is the consecutive 6 bytes from the eleventh byte to the sixteenth byte.
2.Change the system ID length of the source device to 6, and then identify whether the notification is cleared:
isisMaxAreaAddressesMismatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.6 |
Maximum area address mismatches. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the device receives a PDU with MaxAreaAddresses value mismatch. The MaxAreaAddresses field of a PDU records the maximum number of area addresses supported by the source device. This issue occurs when one of the following conditions exists:
The local device and the source device of the PDU support different quantities of area addresses.
The value of the MaxAreaAddresses field is changed.
This notification includes packet header information, which might help a network manager identify the source of the PDU.
The agent must throttle the generation of consecutive isisMaxAreaAddressesMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Route flapping might occur and the CPU usage of the device will rise.
If this notification is generated due to a device communication error, the local device and the source device of the PDU cannot establish a neighbor relationship and therefore cannot learn routes from each other.
Status control
ON
CLI: Use the snmp-agent trap enable isis maxarea-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis maxarea-mismatch command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
1.3.6.1.2.1.138.1.10.1.6 (isisPduMaxAreaAddress) |
Maximum address in the received PDU. |
N/A |
IsisUnsigned8TC |
Interface index. |
N/A |
Unsigned32 |
N/A |
IsisPDUHeader |
Recommended action
1.Check the IS-IS packet format defined by ISO 10589, and then find the system ID of the source device in the pdu-fragment field of the notification.
2.Identify whether the value of the pdu-max-area field in the notification is neither 0 nor 3:
- If the system ID length of the source device is neither 0 nor 3, proceed to step 3.
- If the system ID length of the source device is 0 or 3, proceed to step 4.
3.Change the maximum number of area addresses supported by the source device to 3, and then identify whether the notification is cleared:
isisOwnLSPPurge
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.7 |
Attempts to remove the local LSP. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when the device receives a PDU with the local system ID and a lifetime value of 0. This issue occurs when one of the following conditions exists:
The local device does not refresh its LSPs timely. After these LSPs expire, LSP purge packets are generated and are flooded to the local device.
The PDU is rewritten due to a transmission error, which triggers LSP purging.
After the local device restarts, it receives an LSP with the local system ID and a lifetime value of 0.
This notification includes the link index and router ID, which may help a network manager identify the source of the PDU.
System impact
If this notification occurs after the device restarts, you can ignore this notification.
If this notification occurs frequently, IS-IS routing will be interrupted and packet forwarding might fail.
Status control
ON
CLI: Use the snmp-agent trap enable isis own-lsp-purge command.
OFF
CLI: Use the undo snmp-agent trap enable isis own-lsp-purge command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
OCTET STRING (8) |
Recommended action
1.Identify whether the local device restarted:
- If the local device restarted, no action is required.
- If the local device did not restart, proceed to step 2.
2.Identify whether an IS-IS authentication configuration change occurred on non-local devices. Such a change leads to the generation of LSP purge packets and triggers this notification.
- If an IS-IS authentication configuration change occurred on non-local devices, no action is required.
- If no IS-IS authentication configuration change occurred on non-local devices, proceed to step 3.
isisSequenceNumberSkip
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.8 |
LSP sequence number duplications. |
Informational |
Informational |
N/A (N/A) |
ON |
When an IS-IS process on the local device receives a PDU with the local system ID and different content, the system might redeploy the LSP by using a greater sequence number. This notification is generated when the sequence number increases by a value greater than 1. This issue occurs when one of the following conditions exists:
After an IS-IS process restarts, it generates LSPs whose sequence numbers increase from 1. The IS-IS process then receives a neighbor LSP with the local system ID and a greater sequence number.
LSP updates occur frequently, because the local device uses the same system ID as another device.
When two ISs has the same system ID, a large number of such notifications will be generated.
System impact
If this notification occurs due to incorrect system ID configuration, route flapping might occur frequently.
Status control
ON
CLI: Use the snmp-agent trap enable isis skip-sequence-number command.
OFF
CLI: Use the undo snmp-agent trap enable isis skip-sequence-number command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
OCTET STRING (8) |
Recommended action
1.Use the display history-command command in IS-IS view to identify whether the reset isis all command was configured to restart the current IS-IS process:
- If the reset isis all command is configured, no action is required.
- If the reset isis all command is not configured, proceed to step 2.
2.Use the display isis lsdb command multiple times to identify whether the value for the Seq Num field increases at a fast pace. This field displays the sequence number of an LSP generated by the local device.
- If the value for the Seq Num field increases at a fast pace, the real LSP refresh interval is shorter than the LSP refresh interval specified with the timer lsp-refresh command. In this situation, proceed to step 3.
- If the value for the Seq Num field increases at a normal pace, proceed to step 5.
3.Identify whether the local device uses the same system ID or vSystem ID as another device on the network:
- If yes, proceed to step 4.
- If no, proceed to step 5.
4.Perform the following tasks to clear the notification:
If the notification is not cleared, proceed to step 5.
isisAuthenticationTypeFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.9 |
Authentication type errors. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the following conditions exist:
An authentication mode is configured for the IS-IS process on the local device.
The IS-IS process receives one of the following PDUs:
LSP, CSNP, PSNP, or hello PDU that does not contain any authentication.
This issue occurs when the local device is configured with an IS-IS authentication mode and the source device of the PDU does not have any IS-IS authentication configuration. You can configure IS-IS authentication on an interface or IS-IS process.
Packet with authentication type mismatch.
This issue occurs when the local device and the source device of the PDU use different IS-IS authentication modes. You can configure IS-IS authentication on an interface or IS-IS process. For example, the authentication type is MD5 for the local device and is Simple for the source device of the PDU.
This notification includes packet header information, which may help a network manager identify the source of the PDU.
The agent must throttle the generation of consecutive isisAuthenticationTypeFailure notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
If this notification occurs due to a hello PDU authentication failure, the local device and the source device of the PDU cannot establish a neighbor relationship.
If this notification occurs due to an LSP or SNP authentication failure, the local device and the source device of the PDU can establish a neighbor relationship, but they cannot synchronize LSDB information.
Status control
ON
CLI: Use the snmp-agent trap enable isis authentication-type command.
OFF
CLI: Use the undo snmp-agent trap enable isis authentication-type command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
IsisPDUHeader |
Recommended action
1.View the following fields in the notification:
sysInstance—This field displays the ID of the IS-IS process that received the incorrect PDU.
sysLevel—This field displays the IS level of the received PDU.
IfName—This field displays the interface that received the incorrect PDU. You can find this field according to the IS-IS PDU format defined by ISO 10589.
PduFrag—This field displays the PDU type and the system ID of the source device.
If the PDU type is hello, proceed to steps 2 and 3.
If the PDU type is LSP or SNP, proceed to step 5.
2.Use the display isis peer command on the source device to view the interface that sent the PDU.
3.In the view of the interface that sent the PDU, use the display this command on the source device to identify whether the interface is configured with an IS-IS authentication mode. Then, compare the authentication mode with that of the local interface that received the PDU.
- If the two authentication modes are different, proceed to step 4.
- If the two authentication modes are the same, the troubleshooting is complete.
4.In the view of the interface that sent the PDU, use the isis authentication-mode command to change its authentication mode. This operation ensures that the interface and the local interface can use the same authentication mode and the same authentication key.
Then, identify whether the notification is cleared:
- If the notification is not cleared, proceed to step 7.
5.Use the display current-configuration configuration isis command on the source device to identify whether the IS-IS process is configured with an area or routing domain authentication mode. Then, compare the authentication mode with that of the local device.
- If the source device and the local device use the same authentication mode and the same authentication key, the troubleshooting is complete.
- If the source device and the local device use different authentication modes, proceed to step 6.
6.In the IS-IS view of the source device, use the area-authentication-mode command or the domain-authentication-mode command to change its area or routing domain authentication mode. This operation ensures that the source device and the local device can use the same area or routing domain authentication mode and the same authentication key.
7.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisAuthenticationFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.10 |
Authentication failures. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the IS-IS process on the local device is configured with an authentication mode and receives an LSP, CSNP, PSNP, or hello PDU that meet the following requirements:
The PDU and the local IS-IS process use the same authentication mode.
The PDU and the local IS-IS process use different authentication keys.
This issue occurs when the local device and the source device of the PDU use the same authentication mode but different authentication keys. You can configure IS-IS authentication on an interface or IS-IS process.
The agent must throttle the generation of consecutive isisAuthenticationFailure notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis authentication command.
OFF
CLI: Use the undo snmp-agent trap enable isis authentication command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
IsisPDUHeader |
Recommended action
If the PDU type is hello, proceed to step 2.
If the PDU type is LSP or SNP, proceed to step 4.
In the view of the interface that sent the PDU, use the display this command on the source device to identify the authentication mode of the interface.
3.In the view of the source interface or the local interface, use the isis authentication-mode command to change its authentication mode. This operation ensures that the two interfaces can use the same authentication mode and the same authentication key.
- If the notification is not cleared, proceed to step 6.
4.Use the display current-configuration configuration isis command on the source device to identify whether the IS-IS process is configured with an area or routing domain authentication mode.
5.In the IS-IS view of the source device or the local device, use the area-authentication-mode command or the domain-authentication-mode command to change its authentication mode and authentication key. This operation ensures that the two devices can use the same area or routing domain authentication mode and the same authentication key.
6.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisVersionSkew
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.11 |
Hello packet version mismatches. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device receives a hello PDU with IS-IS version number mismatch. This issue occurs when one of the following conditions exists:
The local device and the source device of the hello PDU support different IS-IS versions.
The IS-IS version number of the PDU is changed during transmission.
The agent must throttle the generation of consecutive isisVersionSkew notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
If this notification is generated because the IS-IS version number of the PDU was changed, route flapping might occur and the CPU usage of the device will rise.
Status control
ON
CLI: Use the snmp-agent trap enable isis version-skew command.
OFF
CLI: Use the undo snmp-agent trap enable isis version-skew command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
1.3.6.1.2.1.138.1.10.1.7 (isisPduProtocolVersion) |
Protocol version in the received PDU. |
N/A |
IsisUnsigned8TC |
N/A |
IsisPDUHeader |
Recommended action
1.Check the IS-IS PDU format defined by ISO 10589, and then find the system ID of the source device in the pdu-fragment field of the notification.
2.Identify whether the value of the version field in the notification is 1 on the source device:
- If the value of the version field is 1, proceed to step 5.
- If the value of the version field is not 1, proceed to step 3.
3.Identify whether you can edit the IS-IS version number of the source device:
- If the IS-IS version number of the source device is editable, proceed to step 4.
- If the IS-IS version number of the source device is not editable, proceed to step 5.
4.Change the IS-IS version number of the source device to that of the local device, and then identify whether the notification is cleared:
- If the notification is not cleared, proceed to step 5.
isisAreaMismatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.12 |
Area address mismatches. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device receives a hello PDU with area address mismatch. This issue occurs when one of the following conditions exists:
An area address configuration error exists.
The area addresses of the hello PDU is changed during transmission.
The agent must throttle the generation of consecutive isisAreaMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
If this notification is generated due to an area address configuration error, the local device and the source device of the PDU cannot establish a neighbor relationship and therefore cannot learn routes from each other.
Status control
ON
CLI: Use the snmp-agent trap enable isis area-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis area-mismatch command.
Object
OID (object name) |
Index |
Type |
Value range |
Interface index. |
N/A |
Unsigned32 |
N/A |
IsisPDUHeader |
Recommended action
2.In the IS-IS view of the source device, use the display this command to identify whether the source device and the local device use the same area addresses:
- If the source device and the local device use the same area addresses, proceed to step 4.
- If the source device and the local device do not use the same area addresses, proceed to step 3.
3.In the IS-IS view of the source device, use the network-entity command to change its area addresses. This operation ensures that the source device and the local device can use the same area addresses.
isisRejectedAdjacency
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.13 |
Adjacency creation failures. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device cannot establish a neighbor relationship with a remote device upon receiving a hello PDU from that remote device.
The agent must throttle the generation of consecutive isisRejectedAdjacency notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
The local device cannot establish a neighbor relationship with the source device of the hello PDU.
Status control
ON
CLI: Use the snmp-agent trap enable isis rejected-adjacency command.
OFF
CLI: Use the undo snmp-agent trap enable isis rejected-adjacency command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
IsisPDUHeader |
Recommended action
1.View the IfName field of the notification to determine the interface that received the hello PDU.
- If the network type of the interface is broadcast, proceed to steps 2 and 3.
- If the network type of the interface is P2P, proceed to step 7.
2.Check the IS-IS PDU format defined by ISO 10589, and then find the system ID of the source device in the pdu-fragment field of the notification. The System ID portion in the pdu-fragment field is the consecutive 6 bytes from the tenth byte to the fifteenth byte.
3.Use the display this command in the interface view and the IS-IS view of the source device to view its IS-IS level and circuit level.
Use the display this command in the interface view and the IS-IS view of the local device to view its IS-IS level and circuit level.
Identify whether the source device and the local device use the same IS-IS level and circuit level.
- If they use the same IS-IS level and circuit level, proceed to step 4.
- If they do not use the same IS-IS level and circuit level, proceed to step 7.
4.Use the isis circuit-level command in the interface view of the source device or the local device to change its IS-IS level and circuit level, so the two devices can use the same IS-IS level and circuit level.
5.Use the display ip interface command to identify the IP address of the source interface and that of the local interface are in the same network segment. The local interface refers to the interface that received the hello PDU on the local device and the source interface refers to the interface that sent the hello PDU on the source device.
- If the two interface addresses are in the same network segment, proceed to step 8.
- If the two interface addresses are in different network segments, proceed to step 6.
6.Use the ip address command in the interface view of the source device or the local device to specify a new interface address. This operation ensures that the IP address of the source interface and that of the local interface can be in the same network segment.
- If the notification is not cleared, proceed to step 8.
7.Identify whether the source device and the local device use the same Level-1 area addresses.
- If they use the same Level-1 area addresses, proceed to step 10.
- If they do not use the same Level-1 area addresses, proceed to step 8.
8.Use the network-entity command in the IS-IS view of the source device to change its Level-1 area addresses, so the source device and the local device can use the same Level-1 area addresses. Then, identify whether the notification is cleared:
- If the notification is not cleared, proceed to step 9.
9.Use the display current-configuration command to identify whether the source device uses the same system ID or vSystem ID as the local device:
- If yes, proceed to step 10.
- If no, proceed to step 12.
10.Use the network-entity command or the virtual-system command to specify a different system ID or vSystem ID for the source device or the local device. This operation ensures that the two devices use different system IDs or vSystem IDs.
- If the notification is not cleared, proceed to step 11.
11.Use the display this command in the interface view of the local interface and the source interface to identify whether the two interfaces use the same IS-IS authentication mode:
- If they use the same IS-IS authentication mode, proceed to step 13.
- If they do not use the same IS-IS authentication mode, proceed to step 12.
12.Use the isis authentication-mode command on the local interface or the source interface to change its authentication mode and authentication key. This operation ensures that the two interfaces use the same IS-IS authentication configuration. Alternatively, you can use the undo isis authentication-mode command on both the local interface and the source interface to remove their IS-IS authentication configurations.
- If the notification is not cleared, proceed to step 13.
13.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisLSPTooLargeToPropagate
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.14 |
Propagation failures caused by oversized LSPs. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device attempts to propagate a PDU larger than the link MTU. This issue might occur when the device forwards an LSP larger than the MTU of the output interface.
The agent must throttle the generation of consecutive isisLSPTooLargeToPropagate notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
LSP loss occurs.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-size-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-size-exceeded command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
1.3.6.1.2.1.138.1.10.1.8 (isisPduLspSize) |
Size of the LSP that is too large to be forwarded. |
N/A |
Unsigned32 |
N/A |
OCTET STRING (8) |
Recommended action
1.Use the display ip interface interface-type interface-number command to view the value of the The Maximum Transmit Unit field. This field displays the MTU of an interface.
2.Use the display current-configuration configuration isis command in the current IS-IS process to view the configuration of the lsp-length originate command. If the lsp-length originate command is not configured for the IS-IS process, the maximum LSP length equals the default value, 1497 bytes.
- If the maximum LSP length is greater than the interface MTU, proceed to step 3.
- If the maximum LSP length is less than the interface MTU, proceed to step 4.
3.Use the lsp-length originate command in IS-IS view to change the maximum LSP length to a value less than the interface MTU. Then, identify whether the notification is cleared:
isisOrigLSPBuffSizeMismatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.15 |
Buffer size mismatches of IS-IS packets. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device receives an LSP (Level-1 or Level-2) that is larger than the local isisSysLevelOrigLSPBuffSize value or has a Buffer Size value not matching the local isisSysLevelOrigLSPBuffSize value. This issue might occur when the device receives an LSP larger than the size of the local buffer for received LSPs.
The agent must throttle the generation of consecutive isisOrigLSPBuffSizeMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
The local device cannot learn routes from the received LSP, which affects traffic forwarding.
Status control
ON
CLI: Use the snmp-agent trap enable isis buffsize-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis buffsize-mismatch command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
OCTET STRING (8) |
1.3.6.1.2.1.138.1.10.1.9 (isisPduOriginatingBufferSize) |
Peer isisSysOrigLSPBuffSize value in the TLV. |
N/A |
IsisUnsigned16TC |
Unsigned32 (0..16000) |
1.3.6.1.2.1.138.1.10.1.10 (isisPduBufferSize) |
Maximum received LSP size. |
N/A |
IsisUnsigned16TC |
Recommended action
1.Use the display current-configuration configuration isis command in the IS-IS process of the local device to view the configuration of the lsp-length receive command. If the lsp-length receive command is not configured for the IS-IS process, the maximum length of received LSPs equals the default value, 1497 bytes.
2.Use the LSP ID in the lsp-id field of the notification to find the source device of the received LSP.
Then, use the display current-configuration configuration isis command in the IS-IS process of the source device to view the configuration of the lsp-length originate command. If the lsp-length originate command is not configured for the IS-IS process, the maximum length of generated LSPs equals the default value, 1497 bytes.
3.Identify whether the maximum length of received LSPs is less than that of generated LSPs:
- If the maximum length of received LSPs is less than that of generated LSPs, proceed to step 4.
- If the maximum length of received LSPs is greater than that of generated LSPs, proceed to step 7.
4.Choose one of the following operations as needed:
- If the buffer size for LSPs received on the local device equals the default value, proceed to step 5.
- If the maximum length of received LSPs on the source device equals the default value, proceed to step 6.
5.Use the lsp-length originate command in the IS-IS process of the source device to change the maximum length of generated LSPs. This operation ensures that the maximum length of LSPs generated by the source device is not greater than the buffer size for LSPs received on the local device.
6.Use the lsp-length receive command in the IS-IS process of the local device to change the maximum length of received LSPs. This operation ensures that the maximum length of LSPs received on the local device is not less than the maximum length of LSPs generated by the source device.
isisProtocolsSupportedMismatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.16 |
Supported-protocol mismatches. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device receives an LSP that carries a TLV (type value: 0x81) and the TLV supports different protocols from the local device. This issue might occur when the local device and the source device of the LSP support different protocols.
The agent must throttle the generation of consecutive isisProtocolsSupportedMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
System impact
The local device cannot learn routes from the received LSP.
Status control
ON
CLI: Use the snmp-agent trap enable isis protocol-support command.
OFF
CLI: Use the undo snmp-agent trap enable isis protocol-support command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
1.3.6.1.2.1.138.1.10.1.11 (isisPduProtocolsSupported) |
Protocol list supported by the neighbor. |
N/A |
OCTET STRING |
OCTET STRING (0..255) |
N/A |
OCTET STRING (8) |
N/A |
IsisPDUHeader |
Recommended action
1.Wait for 10 minutes after you receive the notification, and then identify whether the notification is cleared:
- If the notification is not cleared, proceed to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisAdjacencyChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.17 |
IS-IS adjacency status changes. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a neighbor enters or exits UP state. This issue occurs when one of the following conditions exists:
An IS-IS adjacency goes up or goes down.
An IS-IS configuration error exists.
The system is so busy that an IS-IS neighbor relationship flaps.
The state of an IS-IS neighbor relationship changes due to link failure.
The isisAdjState variable represents the most recent state of the neighbor.
System impact
IS-IS might recalculate routes, which causes route flapping and traffic flapping.
Status control
ON
CLI: Use the snmp-agent trap enable isis adjacency-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis adjacency-state-change command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
Interface index. |
N/A |
Unsigned32 |
N/A |
OCTET STRING (8) |
1.3.6.1.2.1.138.1.10.1.12 (isisAdjState) |
Adjacency state. |
isisCircIndex, isisISAdjIndex |
INTEGER |
down (1), initializing (2), up (3), failed(4) |
1.3.6.1.2.1.31.1.1.1.1 (ifName) |
Interface name. |
ifIndex |
DisplayString |
OCTET STRING(0..255) |
Recommended action
1.Check the IS-IS PDU format defined by ISO 10589, obtain the system ID of the source device from the LspID field of the notification, and then identify whether the neighbor states of the source device and the local device are as configured.
- If yes, proceed to step 12.
- If no, proceed to step 2.
2.Download the user log of the source device, and then find the cause of the neighbor state change.
- If the neighbor state change occurs because of an interface down event, proceed to step 3.
- If the neighbor state change is not caused by an interface down event, proceed to step 10.
3.Find information about the local interface, check its state, and make sure both the local interface and the source interface are up. The local interface refers to the interface that received the LSP on the local device and the source interface refers to the interface that sent the LSP on the source device.
Then, identify whether the neighbor states of the source device and the local device are as configured.
- If yes, the troubleshooting is complete.
4.View the system IDs of the source device and the local device, and make sure their system IDs are configured correctly.
5.View the IS level of the IS-IS process on the source device and the IS level of the IS-IS process on the local device. Make sure the two IS levels are the same.
- If no, proceed to step 6.
6.View the area IDs of the source device and the local device, and make sure their area IDs are the same.
- If no, proceed to step 7.
7.View the IP addresses of the source interface and the local interface, and make sure their addresses are in the same network segment.
- If no, proceed to step 8.
8.Identify whether the source device and the local device has IS-IS authentication configuration, and make sure they use the same IS-IS authentication mode and authentication key.
- If no, proceed to step 9.
9.Identify whether the source device and the local device can receive and send hello packets, and make sure they can receive and send hello packets.
- If no, proceed to step 10.
10.Use the display cpu-usage command to identify whether the CPU usage remained 100% during a period.
- If yes, proceed to step 11.
11.Use the isis timer hello command in interface view to prolong the interval for sending hello packets. This operation slows down network failure detection and route convergence.
12.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
isisLSPErrorDetected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.138.0.18 |
LSP packet parse failures. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when the local device fails to parse a received LSP. This issue occurs when one of the following conditions exists:
The LSP carries a malformed TLV.
The LSP has a header error.
The LSP is of unknown type.
The checksum of the LSP is 0.
A checksum error occurs.
isisCircIfIndex records the index of the link that received the PDU. isisPduFragment records the starting bytes of the PDU. isisErrorOffset indicates the problem.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-parse-error command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-parse-error command.
Object
OID (object name) |
Index |
Type |
Value range |
IS level index. |
N/A |
IsisLevel |
N/A |
OCTET STRING (8) |
Interface index. |
N/A |
Unsigned32 |
N/A |
IsisPDUHeader |
1.3.6.1.2.1.138.1.10.1.13 (isisErrorOffset) |
Offset of the error TLV. |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.2.1.138.1.10.1.14 (isisErrorTLVType) |
Type of the error TLV. |
N/A |
Unsigned32 |
Unsigned32(0..255) |
Recommended action
1.Use the display isis packet command to view IS-IS packet statistics, determine the cause of the LSP error, and then correct the corresponding configurations accordingly.
