07-Layer 3 - IP Routing
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R838x-6W10007-Layer 3 - IP Routing
05-HH3C-ISIS-MIB
05-HH3C-ISIS-MIB 39.40 KB
HH3C-ISIS-MIB
About this MIB
Use this MIB to obtain all IS-IS process IDs.
MIB file name
hh3c-isis.mib
Notifications
hh3cIsisSystemIdConflict
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.59.0.2
System ID conflict.
Informational
Warning
ON
Notification triggers
This notification is generated when a system ID conflict is detected in a received LSP.
The SNMP agent generates this notification only when it detects more than five system ID conflicts within two minutes. This can prevent the agent from generating too many hh3cIsisSystemIdConflict notifications within a short time.
System impact
The LSP might be continuously refreshed, resulting in route flapping.
Status control
ON
CLI: Use the snmp-agent trap enable isis system-id-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable isis system-id-conflict command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.59.1.1.1.1.1 (hh3cIsisSysInstance)
IS-IS process ID.
hh3cIsisSysInstance, hh3cIsisCircIndex
Integer32
Integer32 (1..65535)
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex)
System level index.
N/A
IsisLevel
level1(1), level2(2), level1and2(3)
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId)
LSP ID.
N/A
IsisLinkStatePDUID
OCTET STRING (8)
1.3.6.1.2.1.138.1.1.1.3 (isisSysID)
System ID.
N/A
IsisSystemID
OCTET STRING (6)
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex)
Interface index.
N/A
Unsigned32
Unsigned32(1..2147483647)
1.3.6.1.2.1.31.1.1.1.1 (ifName)
Interface name.
ifIndex
DisplayString
OCTET STRING(0..255)
1.3.6.1.4.1.25506.2.59.1.2.1.3
 (hh3cIsisLocalAddressType)
Local IP address type.
N/A
InetAddressType
unknown(0),, ipv4(1),, ipv6(2),, ipv4z(3),, ipv6z(4),, dns(16)
1.3.6.1.4.1.25506.2.59.1.2.1.4
 (hh3cIsisLocalAddress)
Local IP address.
N/A
InetAddress
OCTET STRING(0..16)
1.3.6.1.4.1.25506.2.59.1.2.1.5
 (hh3cIsisPeerAddressType)
Neighbor IP address type.
N/A
InetAddressType
1.3.6.1.4.1.25506.2.59.1.2.1.6 (hh3cIsisPeerAddress)
Neighbor IP address.
N/A
InetAddress
OCTET STRING(0..16)
Recommended action
To resolve the issue:
1.Locate and edit the conflicting system ID to make sure that each device in the IS-IS topology has a unique system ID.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
