10-IP Multicast
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10010-IP Multicast
12-PIM-BSR-MIB
12-PIM-BSR-MIB 93.42 KB
PIM-BSR-MIB
About this MIB
Use this MIB to manage PIM BSR settings.
MIB file name
rfc5240-pim-bsr.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pimBsrMIB(172)
Tabular objects
pimBsrCandidateRPTable
About this table
This table contains the IP multicast group for which the local router is to advertise itself as a Candidate-RP.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pimBsrCandidateRPAddressType, pimBsrCandidateRPAddress, pimBsrCandidateRPGroupAddress, and pimBsrCandidateRPGroupPrefixLength.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.1.1.1)
not-accessible
InetAddressType
ipv4(1),
ipv6(2),
Address type of a C-RP.
Supports only values ipv4(1) and ipv6(2).
(1.3.6.1.2.1.172.1.1.1.2)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the C-RP.
As per the MIB.
(1.3.6.1.2.1.172.1.1.1.3)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the multicast group for which the C-RP is advertised.
Supports only multicast group addresses.
(1.3.6.1.2.1.172.1.1.1.4)
not-accessible
InetAddressPrefixLength
Unsigned32(4..128)
Mask of the multicast group for which the C-RP is advertised.
pimBsrCandidateRPBidir
(1.3.6.1.2.1.172.1.1.1.5)
read-create
TruthValue
true(1),
false(2)
PIM mode of the multicast group range for the RP, BIDIR-PIM or PIM-SM.
Read-only.
pimBsrCandidateRPAdvTimer
(1.3.6.1.2.1.172.1.1.1.6)
read-only
TimeTicks
Standard MIB values.
Time remaining before the local router sends a Candidate-RP-Advertisement to the elected BSR for this zone.
To disable this timer, set the value of this object to 0.
pimBsrCandidateRPPriority
(1.3.6.1.2.1.172.1.1.1.7)
read-create
Unsigned32
Unsigned32(0..255)
Priority for the C-RP.
Read-only.
pimBsrCandidateRPAdvInterval
(1.3.6.1.2.1.172.1.1.1.8)
read-create
Unsigned32
Unsigned32(1..26214)
Time interval between two consecutive advertisements, in seconds.
Read-only.
pimBsrCandidateRPHoldtime
(1.3.6.1.2.1.172.1.1.1.9)
read-create
Unsigned32
Unsigned32(0..65535)
Holdtime for the C-RP.
Read-only.
Value table: 1:1..65535.
pimBsrCandidateRPStatus
(1.3.6.1.2.1.172.1.1.1.10)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
Read-only.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
pimBsrCandidateRPStorageType
(1.3.6.1.2.1.172.1.1.1.11)
read-create
StorageType
other(1)
Row storage type.
Read-only.
Supports only value other(1).
pimBsrElectedBSRRPSetTable
About this table
This table contains BSR-specific information about PIM group mappings. It supports only the public network.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pimBsrElectedBSRGrpMappingAddrType, pimBsrElectedBSRGrpMappingGrpAddr,
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.2.1.2)
not-accessible
InetAddressType
ipv4(1),
ipv6(2)
Address type of a multicast group.
(1.3.6.1.2.1.172.1.2.1.3)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the multicast group.
As per the MIB.
pimBsrElectedBSRGrpMappingGrpPrefixLen
(1.3.6.1.2.1.172.1.2.1.4)
not-accessible
Unsigned32(4..128)
Mask of the multicast group address.
As per the MIB.
pimBsrElectedBSRGrpMappingRPAddr
(1.3.6.1.2.1.172.1.2.1.5)
not-accessible
InetAddress
OCTET STRING (4|16)
IP address of the RP to be used for the multicast group.
As per the MIB.
pimBsrElectedBSRRPSetPriority
(1.3.6.1.2.1.172.1.2.1.6)
read-only
Unsigned32
Unsigned32(0..255)
Priority of the RP.
As per the MIB.
pimBsrElectedBSRRPSetHoldtime
(1.3.6.1.2.1.172.1.2.1.7)
read-only
Unsigned32
Holdtime of the RP.
As per the MIB.
pimBsrElectedBSRRPSetExpiryTime
(1.3.6.1.2.1.172.1.2.1.8)
read-only
TimeTicks
Minimum time remaining before this entry will be aged out.
Value zero indicates that the entry will age out immediately.
pimBsrElectedBSRRPSetGrpBidir
(1.3.6.1.2.1.172.1.2.1.9)
read-only
TruthValue
true(1),
false(2)
PIM mode used for the multicast group, BIDIR-PIM or PIM-SM.
As per the MIB.
pimBsrCandidateBSRTable
About this table
This table contains C-BSR settings.
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is pimBsrCandidateBSRZoneIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.3.1.1)
not-accessible
InetZoneIndex
Unsigned32(1..4294967295)
Index of the zone to which a C-BSR is attached.
Supports only 0xFFFFFFFF 0X7FFFFFFF.
pimBsrCandidateBSRAddressType
(1.3.6.1.2.1.172.1.3.1.2)
read-create
InetAddressType
ipv4(1),
ipv6(2)
Address type of the C-BSR.
(1.3.6.1.2.1.172.1.3.1.3)
read-create
InetAddress
OCTET STRING (4|16)
IP address of the C-BSR.
As per the MIB.
pimBsrCandidateBSRPriority
(1.3.6.1.2.1.172.1.3.1.4)
read-create
Unsigned32
Unsigned32(0..255)
Priority of the C-BSR.
Default: 1:64 (int).
Value range: 1:0..255.
pimBsrCandidateBSRHashMaskLength
(1.3.6.1.2.1.172.1.3.1.5)
read-create
Unsigned32
Unsigned32(0..32)
Mask length for the IP address of the C-BSR.
Value range: 1:0..32.
pimBsrCandidateBSRElectedBSR
(1.3.6.1.2.1.172.1.3.1.6)
read-only
TruthValue
true(1),
false(2)
Whether this router is a BSR.
As per the MIB.
pimBsrCandidateBSRBootstrapTimer
(1.3.6.1.2.1.172.1.3.1.7)
read-only
TimeTicks
Time remaining for this router to send the next BSR message.
As per the MIB.
pimBsrCandidateBSRStatus
(1.3.6.1.2.1.172.1.3.1.8)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
pimBsrCandidateBSRStorageType
(1.3.6.1.2.1.172.1.3.1.9)
read-create
StorageType
other(1)
Row storage type.
Read-only.
pimBsrElectedBSRTable
About this table
This table contains BSR settings. It supports only the public network and does not support administratively-scoped zones.
CreateNot supported
DeleteNot supported
ReadSupported.
Supports only index 0xffffffff.
Supports only IPv4.
Columns
The table index is pimBsrElectedBSRZoneIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.172.1.4.1.1)
not-accessible
InetZoneIndex
pimBsrElectedBSRAddressType
(1.3.6.1.2.1.172.1.4.1.2)
read-only
InetAddressType
ipv4(1),
ipv6(2)
Address type of a BSR.
(1.3.6.1.2.1.172.1.4.1.3)
read-only
InetAddress
OCTET STRING (4|16)
IP address of the BSR.
As per the MIB.
pimBsrElectedBSRPriority
(1.3.6.1.2.1.172.1.4.1.4)
read-only
Unsigned32
Unsigned32(0..255)
Priority of the BSR.
As per the MIB.
pimBsrElectedBSRHashMaskLength
(1.3.6.1.2.1.172.1.4.1.5)
read-only
Unsigned32
Unsigned32(0..128)
Mask length for the BSR's IP address.
Value range: 1:0..128.
pimBsrElectedBSRExpiryTime
(1.3.6.1.2.1.172.1.4.1.6)
read-only
TimeTicks
Time remaining before the BSR ages out.
As per the MIB.
Notifications
pimBsrElectedBSRLostElection
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.172.0.1
The device changed from the BSR to a C-BSR.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the BSR becomes a C-BSR because another device is elected as the new BSR.
System impact
The BSR change might affect the advertisement of RP information, interrupt the exchange of source and group member information, and affect multicast traffic forwarding.
Status control
ON
CLI: Use the snmp-agent trap enable pim elected-bsr-lost-election command.
CLI: Use the snmp-agent trap enable pim6 elected-bsr-lost-election command.
OFF
CLI: Use the undo snmp-agent trap enable pim elected-bsr-lost-election command.
CLI: Use the undo snmp-agent trap enable pim6 elected-bsr-lost-election command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.172.1.4.1.2 (pimBsrElectedBSRAddressType)
Address type of the BSR.
InetAddressType
ipv4(1), ipv6(2)
1.3.6.1.2.1.172.1.4.1.3 (pimBsrElectedBSRAddress)
InetAddress
OCTET STRING (4|16)
1.3.6.1.2.1.172.1.4.1.4 (pimBsrElectedBSRPriority)
Unsigned32
Unsigned32(0..255)
Recommended action
To resolve the issue:
1.Check whether the configuration of the old BSR is modified.
  - If yes, no action is required.
  - If no, proceed to step 2.
2.Check whether the new BSR has recovered from a failure, whether the link between the old BSR and the new BSR has recovered from a failure, whether the new BSR is newly added, .or whether the configuration of the new BSR has been modified.
  - If no, proceed to step 3.
3.Use the display this command to check whether the old BSR has been configured with a correct BSR address.
  - If no, configure a correct BSR address.
  - If yes, proceed to step 4.
4.Use the display pim bsr-info or display ipv6 pim bsr-info command to check whether the old BSR is a C-BSR.
  - If no, proceed to step 5.
  - If yes, proceed to step 6.
5.Use the display pim bsr-info or display ipv6 pim bsr-info command to check whether a PIM interface exists for the old BSR.
  - If no, configure a PIM interface.
6.Use the display memory command to check whether the memory is sufficient.
  - If no, solve the memory issue.
  - If yes, proceed to step 7.
7.Collect alarm information and configuration data, and then contact H3C Support for help.
pimBsrCandidateBSRWinElection
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.172.0.2
The device changed from a C-BSR to the BSR.
Informational
Warning
N/A (N/A)
ON
This notification is generated when a C-BSR was elected as the new BSR. A C-BSR can be elected as the new BSR for the following possible reasons:
The configuration of the old BSR is modified.
The link between the new BSR and the old BSR fails.
The old BSR fails.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim candidate-bsr-win-election command.
CLI: Use the snmp-agent trap enable pim6 candidate-bsr-win-election command.
OFF
CLI: Use the undo snmp-agent trap enable pim candidate-bsr-win-election command.
CLI: Use the undo snmp-agent trap enable pim6 candidate-bsr-win-election command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.172.1.3.1.6 (pimBsrCandidateBSRElectedBSR)
Whether this router is the E-BSR.
TruthValue
true(1), false(2)
Recommended action
2.Check whether the old BSR has failed, whether the link between the old BSR and the new BSR has recovered from a failure, or whether the old BSR has been removed as a C-BSR.
3.Use the display pim bsr-info or display ipv6 pim bsr-info command to check whether a PIM interface exists for the old BSR.
4.Use the display memory command to check whether the memory is sufficient.
  - If yes, proceed to step 5.
5.Use the ping or ping ipv6 command to check whether the new BSR can reach the old BSR.
  - If no, solve the connectivity issue.
6.Collect alarm information and configuration data, and then contact H3C Support for help.
