10-IP Multicast
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10010-IP Multicast
06-HH3C-PIM-STD-MIB
06-HH3C-PIM-STD-MIB 95.94 KB
HH3C-PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
hh3c-pim-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPimStd(213)
Scalar objects
hh3cPimInstanceID (1.3.6.1.4.1.25506.2.213.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Unsigned32
Unsigned32 (0..4294967295)
PIM instance ID.
As per the MIB.
hh3cPimInstanceName (1.3.6.1.4.1.25506.2.213.1.2)
Object (OID)
Access
Value range
Implementation
DisplayString
OCTET STRING (0..255)
PIM instance name.
As per the MIB.
hh3cPimNeighborExpiryTime (1.3.6.1.4.1.25506.2.213.1.3)
Object (OID)
Access
Value range
Implementation
TimeTicks
INTEGER (0..4294967295)
Timeout timer.
As per the MIB.
hh3cPimNotificationLimitType (1.3.6.1.4.1.25506.2.213.1.4)
Object (OID)
Access
Value range
Implementation
INTEGER
sm-star-group(1),
sm-source-group(2)
Type of the PIM route entry.
As per the MIB.
hh3cPimNotificationAddressFamily (1.3.6.1.4.1.25506.2.213.1.5)
Object (OID)
Access
Value range
Implementation
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
Type of the PIM address.
As per the MIB.
hh3cPimNotificationEntryCount (1.3.6.1.4.1.25506.2.213.1.6)
Object (OID)
Access
Value range
Implementation
Unsigned32
Number of current PIM route entries.
As per the MIB.
hh3cPimNotificationLimitCount (1.3.6.1.4.1.25506.2.213.1.7)
Object (OID)
Access
Value range
Implementation
Unsigned32
Maximum number of PIM route entries.
As per the MIB.
hh3cPimNotificationThresholdCnt (1.3.6.1.4.1.25506.2.213.1.8)
Object (OID)
Access
Value range
Implementation
Unsigned32
Upper limit of PIM entries that causes a log message to be generated
As per the MIB.
hh3cPimThresholdReasonType (1.3.6.1.4.1.25506.2.213.1.9)
Object (OID)
Access
Value range
Implementation
INTEGER
entryCreated(1),
configurationChanged(2)
Reason why the number of PIM route entries exceeds the maximum number.
As per the MIB.
hh3cPimRouteEClearReasonType (1.3.6.1.4.1.25506.2.213.1.10)
Object (OID)
Access
Value range
Implementation
INTEGER
entryDeleted(1),
configurationChanged(2),
Reason why the number of PIM route entries falls below the maximum number.
As per the MIB.
hh3cPimThresholdClearReasonType (1.3.6.1.4.1.25506.2.213.1.11)
Object (OID)
Access
Value range
Implementation
INTEGER
entryDeleted(1),
Reason why the number of PIM route entries falls below the upper limit.
As per the MIB.
hh3cPimNotificationSourceAddress (1.3.6.1.4.1.25506.2.213.1.12)
Object (OID)
Access
Value range
Implementation
InetAddress
Source address of a route entry.
As per the MIB.
hh3cPimNotificationGroupAddress (1.3.6.1.4.1.25506.2.213.1.13)
Object (OID)
Access
Value range
Implementation
InetAddress
Group address of a route entry.
As per the MIB.
hh3cPimNbrAddressIfIndex (1.3.6.1.4.1.25506.2.213.1.14)
Object (OID)
Access
Value range
Implementation
InterfaceIndex
Integer32 (1..2147483647)
PIM neighbor interface.
As per the MIB.
hh3cPimNbrAddressType (1.3.6.1.4.1.25506.2.213.1.15)
Object (OID)
Access
Value range
Implementation
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
PIM neighbor address type.
As per the MIB.
hh3cPimNbrAddress (1.3.6.1.4.1.25506.2.213.1.16)
Object (OID)
Access
Value range
Implementation
InetAddress
PIM neighbor address.
As per the MIB.
hh3cPimNeighborUpTime (1.3.6.1.4.1.25506.2.213.1.17)
Object (OID)
Access
Value range
Implementation
TimeTicks
Timeout timer.
As per the MIB.
Notifications
hh3cPimNeighborAdd
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.213.0.1
PIM neighbor created.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when a PIM interface receives a hello packet and a PIM neighbor is created.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable pim new-neighbor command.
CLI: Use the snmp-agent trap enable pim6 new-neighbor command.
OFF
CLI: Use the undo snmp-agent trap enable pim new-neighbor command.
CLI: Use the undo snmp-agent trap enable pim6 new-neighbor command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.213.1.3 (hh3cPimNeighborExpiryTime)
Neighbor timeout time.
N/A
TimeTicks
1.3.6.1.4.1.25506.2.213.1.1 (hh3cPimInstanceID)
PIM instance ID.
N/A
Unsigned32
Unsigned32(0..4294967295)
1.3.6.1.4.1.25506.2.213.1.2 (hh3cPimInstanceName)
PIM instance name.
N/A
DisplayString
1.3.6.1.4.1.25506.2.213.1.15 (hh3cPimNbrAddressType)
N/A
InetAddressType
unknown(0),, ipv4(1), , ipv6(2)
1.3.6.1.4.1.25506.2.213.1.14 (hh3cPimNbrAddressIfIndex)
N/A
InterfaceIndex
Integer32(1..2147483647)
1.3.6.1.4.1.25506.2.213.1.16 (hh3cPimNbrAddress)
N/A
InetAddress
Recommended action
No action is required.
hh3cPimRouteThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.213.0.2
The number of global PIM entries exceeded the upper limit that causes a log message to be generated.
Fault
Major
1.3.6.1.4.1.25506.2.213.0.3 (hh3cPimRouteThresholdExceedClear)
ON
This notification is generated when the number of global PIM entries exceeds the alarm threshold.
System impact
Global PIM entries might not be able to be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.213.1.4 (hh3cPimNotificationLimitType)
PIM entry type.
N/A
INTEGER
sm-star-group(1),, sm-source-group(2)
1.3.6.1.4.1.25506.2.213.1.5 (hh3cPimNotificationAddressFamily)
PIM address type.
N/A
InetAddressType
unknown(0),, ipv4(1), , ipv6(2),
1.3.6.1.4.1.25506.2.213.1.6 (hh3cPimNotificationEntryCount)
Current number of PIM entries.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.8 (hh3cPimNotificationThresholdCnt)
Upper limit of PIM entries that causes a log message to be generated.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.9 (hh3cPimThresholdReasonType)
Reason why the number of PIM entries exceeded the upper limit.
N/A
INTEGER
entryCreated(1),, configurationChanged(2)
Recommended action
To resolve the issue:
1.Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the upper limit of global PIM entries is low.
  - If yes, go to step 2.
  - If no, go to step 3.
2.Use the multicast global limit or ipv6 multicast global limit command to increase the upper limit.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of global PIM entries fell below the upper limit that causes a log message to be generated.
Fault
Major
N/A (N/A)
ON
This notification is generated when the number of global PIM entries falls below the upper limit that causes a log message to be generated.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-threshold-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-threshold-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-threshold-exceed-clear command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.213.1.4 (hh3cPimNotificationLimitType)
PIM entry type.
N/A
INTEGER
PIM address type
N/A
InetAddressType
N/A
Unsigned32
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.11 (hh3cPimThresholdClearReasonType)
N/A
INTEGER
entryDeleted(1),, configurationChanged(2),
Recommended action
hh3cPimRouteExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.213.0.4
The number of global PIM entries exceeded the maximum number.
Fault
Major
1.3.6.1.4.1.25506.2.213.0.5 (hh3cPimRouteExceedClear)
ON
This notification is generated when the number of global PIM entries exceeds the maximum number.
System impact
No global PIM entries can be created any more.
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed command.
Object
OID (object name)
Index
Value range
PIM entry type.
N/A
INTEGER
PIM address type.
N/A
InetAddressType
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.7 (hh3cPimNotificationLimitCount)
Maximum number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.213.1.12 (hh3cPimNotificationSourceAddress)
Source address of the PIM entry.
N/A
InetAddress
1.3.6.1.4.1.25506.2.213.1.13 (hh3cPimNotificationGroupAddress)
Group address of the PIM entry.
N/A
InetAddress
PIM instance name.
N/A
DisplayString
Recommended action
1.Use the display multicast global statistics or display ipv6 multicast global statistics command to identify whether the maximum number of global PIM entries is low.
2.Use the multicast global limit or ipv6 multicast global limit command to increase the maximum number.
Basic information
OID
Event
Severity
Default status
The number of global PIM entries fell below the limit.
Fault
Major
N/A (N/A)
ON
This notification is generated when the number of global PIM entries falls below the maximum number.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the snmp-agent trap enable pim6 route-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable pim route-exceed-clear command.
CLI: Use the undo snmp-agent trap enable pim6 route-exceed-clear command.
Object
OID (object name)
Index
Value range
PIM entry type.
N/A
INTEGER
PIM address type.
N/A
InetAddressType
N/A
Unsigned32
Maximum number.
N/A
Unsigned32
N/A
InetAddress
N/A
InetAddress
1.3.6.1.4.1.25506.2.213.1.10 (hh3cPimRouteEClearReasonType)
Reason why the number of PIM entries fell below the maximum number.
N/A
INTEGER
PIM instance name.
N/A
DisplayString
Recommended action
