| 06-HH3C-LswDEVM-MIB | 70.77 KB |
HH3C-LswDEVM-MIB
About this MIB
Use this MIB to obtain information the resources on the device. For example, access this MIB to obtain power supply or fan information, including their number or status.
MIB file name
hh3c-splat-devm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswdevMMib(9)
Tabular objects
hh3cdevMFanStatusTable
About this table
This table contains basic fan information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDevMFanNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMFanNum (1.3.6.1.4.1.25506.8.35.9.1.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Fan index. |
Implementation varies by product. |
hh3cDevMFanStatus (1.3.6.1.4.1.25506.8.35.9.1.1.1.2) |
read-only |
INTEGER |
active(1), |
Fan status. |
hh3cDevMFanPosFrame (1.3.6.1.4.1.25506.8.35.9.1.1.1.3) |
read-only |
Integer32 |
ID of the chassis where the fan resides. |
Not supported |
hh3cDevMFanMaxSpeed (1.3.6.1.4.1.25506.8.35.9.1.1.1.6) |
read-only |
Integer32 |
Maximum fan speed. |
Not supported |
hh3cDevMFanCurrentSpeed (1.3.6.1.4.1.25506.8.35.9.1.1.1.7) |
read-only |
Integer32 |
Current fan speed. |
Not supported |
hh3cdevMPowerStatusTable
About this table
This table contains basic power supply information.
Read:Supported
Columns
The table index is hh3cDevMPowerNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMPowerNum (1.3.6.1.4.1.25506.8.35.9.1.2.1.1) |
read-only |
Integer32 |
Power supply index. |
hh3cDevMPowerStatus (1.3.6.1.4.1.25506.8.35.9.1.2.1.2) |
read-only |
INTEGER |
active(1), |
Power supply status. |
hh3cDevMPowerEntIndex (1.3.6.1.4.1.25506.8.35.9.1.2.1.3) |
read-only |
Integer32 |
Entity index of the power supply. |
hh3cDevMPowerRatedVoltage (1.3.6.1.4.1.25506.8.35.9.1.2.1.4) |
read-only |
Integer32 |
Rated voltage of the power supply, in mV. |
hh3cDevMPowerRatedCurrent (1.3.6.1.4.1.25506.8.35.9.1.2.1.5) |
read-only |
Integer32 |
Rated current of the power supply, in mA. |
hh3cDevMPowerLoadFactor (1.3.6.1.4.1.25506.8.35.9.1.2.1.6) |
read-only |
Integer32 |
Load factor of the power supply. |
hh3cDevMPowerUsedPower (1.3.6.1.4.1.25506.8.35.9.1.2.1.7) |
read-only |
Integer32 |
Used power of the power supply, in mW. |
hh3cDevMPowerRemainingPower (1.3.6.1.4.1.25506.8.35.9.1.2.1.8) |
read-only |
Integer32 |
Remaining power of the power supply, in mW. |
hh3cDevMPowerSupplyType (1.3.6.1.4.1.25506.8.35.9.1.2.1.9) |
read-only |
Integer32 |
AC(1), DC (2), HVDC(3) |
Power supply type. |
hh3cdevMSlotEnvironmentTable
About this table
This table contains environment information for a card.
Read:Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cdevMSlotEnvironmentType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdevMSlotEnvironmentType (1.3.6.1.4.1.25506.8.35.9.1.3.1.1) |
not-accessible |
INTEGER |
temperature(1), |
Type of the environment elements. |
hh3cDevMSlotEnvironmentStatus (1.3.6.1.4.1.25506.8.35.9.1.3.1.2) |
read-only |
INTEGER |
normal(1), upper(2), lower(3) |
Status of the environment where the card resides. |
Not supported. |
hh3cDevMSlotEnvironmentValue (1.3.6.1.4.1.25506.8.35.9.1.3.1.3) |
read-only |
Integer32 |
Environment data for the card. |
hh3cDevMSlotEnvironmentUpperLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.4) |
read-write |
Integer32 |
Upper limit for the environment requirements. |
Not supported. |
hh3cDevMSlotEnvironmentLowerLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.5) |
read-write |
Integer32 |
Lower limit for the environment requirements. |
Not supported. |
