| 02-HH3C-COMMON-SYSTEM-MIB | 92.62 KB |
hh3cReboot (1.3.6.1.4.1.25506.6.7)
hh3cSysBootType (1.3.6.1.4.1.25506.6.10)
hh3cSystemWorkingModeDefault (1.3.6.1.4.1.25506.6.14.2)
hh3cSystemWorkingModeCurrent (1.3.6.1.4.1.25506.6.14.3)
hh3cSystemWorkingModeNext (1.3.6.1.4.1.25506.6.14.4)
hh3cSysBannerMOTD (1.3.6.1.4.1.25506.6.11.11)
About this MIB
Use this MIB to perform basic operations on the device. For example, access this MIB to reboot the device, obtain basic system information such as reboot mode and system operating mode, and send poweroff alarms. This MIB also contains notifications about device operation changes.
MIB file name
hh3c-common-system.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cReboot (1.3.6.1.4.1.25506.6.7) |
read-write |
INTEGER |
normal(0), reboot(1) |
Reboots the device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysBootType (1.3.6.1.4.1.25506.6.10) |
read-only |
INTEGER |
coldStart(1), warmStart(2) |
Boot mode of the system. |
Implementation varies by the product. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeDefault (1.3.6.1.4.1.25506.6.14.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Default system operating mode. |
Implementation varies by product. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeCurrent (1.3.6.1.4.1.25506.6.14.3) |
read-only |
Integer32 |
Current system operating mode. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeNext (1.3.6.1.4.1.25506.6.14.4) |
read-write |
Integer32 |
The system operating mode for the next startup. |
Implementation varies by product. For the modified operating mode to take effect, reboot the device, The new operating mode will take effect on the entire device. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysBannerMOTD (1.3.6.1.4.1.25506.6.11.11) |
read-write |
OCTETSTRING |
OCTET STRING (0..2000) |
Banner message. |
As per the MIB. |
Tabular objects
hh3cSystemDiagInfoTable
About this table
This table creates diagnosis files for the system.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cSystemDiagInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemDiagInfoIndex (1.3.6.1.4.1.25506.6.13.1.1) |
not-accessible |
Integer32 |
Entry index. |
As per the MIB. |
hh3cSystemDiagInfoFilename (1.3.6.1.4.1.25506.6.13.1.2) |
read-create |
DisplayString |
OCTET STRING (0..255) |
Diagnosis file name. |
As per the MIB. The system uses the default file name if you do not specify a file name during row creation. |
hh3cSystemDiagInfoRowStatus (1.3.6.1.4.1.25506.6.13.1.3) |
read-create |
RowStatus |
active(1),notInService(2),notReady(3),createAndGo(4),createAndWait(5),destroy(6) |
Row status. |
As per the MIB. |
hh3cSystemDiagInfoOperEndTime(1.3.6.1.4.1.25506.6.13.1.4) |
read-only |
TimeStamp |
Standard MIB values. |
Time when the operation was completed. |
As per the MIB. |
hh3cSystemDiagInfoOperState (1.3.6.1.4.1.25506.6.13.1.5) |
read-only |
INTEGER |
opInProgress(1),opSuccess(2),opFailure(3) |
Operation status. |
As per the MIB. |
hh3cSystemDiagInfoOperFailReason (1.3.6.1.4.1.25506.6.13.1.6) |
read-only |
DisplayString |
Failure reason. |
As per the MIB. |
hh3cSystemWorkingModeTable
About this table
This table contains information about the system operating modes supported on the device.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cSystemWorkingModeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeIndex (1.3.6.1.4.1.25506.6.14.1.1.1) |
not-accessible |
Integer32 |
Index of a system operating mode. |
hh3cSystemWorkingModeName (1.3.6.1.4.1.25506.6.14.1.1.2) |
read-only |
DisplayString |
OCTET STRING (1..32) |
Name of the system operating mode. |
hh3cSystemWorkingModeDescr (1.3.6.1.4.1.25506.6.14.1.1.3) |
read-only |
DisplayString |
OCTET STRING (1..128) |
Description of the system operating mode. |
Notifications
hh3cRebootSendTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.6.8.3 |
The device is to reboot |
Informational |
Major |
N/A (N/A) |
ON |
Notification triggers
This notification is generated two seconds before the reboot command is used to reboot the device.
System impact
The system will stop providing services and restart.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
N/A (N/A) |
N/A |
N/A |
N/A |
N/A |
Recommended action
No action is required.
hh3cSysColdStartTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.4 |
A cold boot was performed |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a cold boot is performed on the device.
System impact
No negative impact on the system.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.6.11.10 (hh3cSysFirstTrapTime) |
Time when the alarm occurred. |
N/A |
TimeTicks |
Recommended action
hh3cSysWarmStartTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.5 |
A warm boot was performed |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a warm boot is performed on the device.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
TimeTicks |
Recommended action
hh3cSysDyingGaspTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.7 |
Poweroff alarm |
Informational |
Critical |
N/A (N/A) |
ON |
This notification is generated when the device is powered off.
System impact
The system will be powered off and stop providing services.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A (N/A) |
N/A |
N/A |
N/A |
N/A |
Recommended action
Verify that the power cord is connected correctly.
