01-HH3C-ACL-MIB | 45.57 KB |
HH3C-ACL-MIB
About this MIB
This MIB provides some basic table for managing ACLs on a switch.
MIB file name
hh3c-acl.mib
Notifications
hh3cAclRuleMatchCount
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.8.5.0.2 |
Notification for the ACL rule matches. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
When a trap interval is set through the table hh3cAclIntervalTable, notifications will be generated at intervals. The notification information includes the number of rule matches in the interval.
System impact
No negative impact on services.
Status control
ON
CLI: Use the acl trap interval interval command.
MIB: Set hh3cAclIntervalType to trap(2), set the hh3cAclIntervalValue to a value in the range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
MIB: Use the table hh3cAclIntervalTable to perform a destroy operation.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.8.3.6.1.1 (hh3cPfilter2ApplyObjType) |
Object to which the ACL is applied. |
hh3cPfilter2ApplyObjType hh3cPfilter2ApplyObjIndex hh3cPfilter2ApplyDirection hh3cPfilter2ApplyAclType hh3cPfilter2ApplyAclIndex hh3cPfilter2AclRuleIndex |
INTEGER |
interface(1), vlan(2), global(3) |
1.3.6.1.4.1.25506.2.8.3.6.1.2 (hh3cPfilter2ApplyObjIndex) |
Object index. |
Integer32 |
0 to 2147483647 |
1.3.6.1.4.1.25506.2.8.3.6.1.3 (hh3cPfilter2ApplyDirection) |
Direction of the packet filter. |
INTEGER |
inbound(1), outbound(2) |
1.3.6.1.4.1.25506.2.8.3.6.1.4 (hh3cPfilter2ApplyAclType) |
Type of the ACL. |
INTEGER |
ipv4(1), ipv6(2), default(3), mac(4), user(5) |
1.3.6.1.4.1.25506.2.8.3.6.1.5 (hh3cPfilter2ApplyAclIndex) |
ACL index. |
OCTET STRING |
SIZE (1 to 63) |
1.3.6.1.4.1.25506.2.8.3.8.1.1 (hh3cPfilter2AclRuleIndex) |
ACL rule index |
Integer32 |
0 to 65534. |
1.3.6.1.4.1.25506.2.8.3.8.1.4 (hh3cPfilter2AclRuleMatchPackets) |
ACL rule match count. |
N/A |
Counter64 |
0 to 18446744073709551615. |
Recommended action
No action is required.
hh3cAclResourceTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.8.7.0.1 |
TCAM resource usage notification. |
Informational |
Warning |
OFF |
Notifications will be generated for violations of threshold set by hh3cAclMib2ResourceThreshold at intervals set by hh3cAclMib2ResourceLogInterval. The notification information includes the Ternary Content Addressable Memory (TCAM) resource usage for each card.
System impact
Status control
ON
CLI: Use the commands:
acl resource threshold percent percent
acl resource log interval interval
MIB: Set hh3cAclMib2ResourceThreshold to a value in the range of 1 to 100, and set hh3cAclMib2ResourceLogInterval to a value in the range of 1 to 60.
OFF
undo acl resource threshold percent
undo acl resource log interval
MIB: Set hh3cAclMib2ResourceThreshold to 0, and set hh3cAclMib2ResourceLogInterval to 0.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.8.6.1 (hh3cAclResourceTypeName) |
Resource type. |
N/A |
OCTET STRING |
SIZE (1 to 255) |
1.3.6.1.4.1.25506.2.8.6.2 (hh3cAclResourceUsage) |
Resource usage. |
N/A |
Integer32 |
0 to 100 |
1.3.6.1.4.1.25506.2.8.6.3 (hh3cAclResourceUsedEntries) |
Number of used resources. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.8.6.4 (hh3cAclResourceTotalEntries) |
Total number of resources. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.8.2.1.1.5 (hh3cAclMib2ResourceThreshold) |
Resource usage alarm threshold. |
N/A |
Integer32 |
0 to 100 |
1.3.6.1.4.1.25506.2.8.6.5 (hh3cAclResourceChassisID) |
Chassis number. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.8.6.6 (hh3cAclResourceSlotID) |
Slot number. |
N/A |
Integer32 |
Recommended action
