09-MPLS
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R838x-6W10009-MPLS
17-TE-MIB
17-TE-MIB 49.13 KB
TE-MIB
About this MIB
Use this MIB to manage TE tunnel interface and explicit path settings.
MIB file name
rfc3970-te.mib
Notifications
teTunnelUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.122.0.1
TE tunnel up
Recovery
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the tunnel specified by teTunnelName transitions to the up state.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.122.1.2.1.2
 (teTunnelName)
TE tunnel name
teTunnelIndex
SnmpAdminString
OCTET STRING (SIZE (1..32))
1.3.6.1.2.1.122.1.3.1.2 (tePathName)
Name of the TE tunnel's path
teTunnelIndex
SnmpAdminString
OCTET STRING (SIZE (0..32))
Recommended action
No action is required.
teTunnelDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.2
TE tunnel down
Error
Major
N/A (N/A)
ON
For all types of tunnels, possible reasons for this notification include the following:
The interface went Down.
The configuration of the tunnel was deleted.
The link was faulty.
The tunnel was manually shut down.
Others
For RSVP-TE tunnels, possible reasons for this notification also include the following:
RSVP-TE LSP resources were preempted.
Transmission of an RSVP message timed out.
RSVP Hello mechanism detected a downstream node failure.
CSPF failed to calculate a path.
For Segment Routing TE tunnels, possible reasons for this notification also include the following:
IGP calculation or verification failed.
For static TE tunnels, possible reasons for this notification also include:
A static CR-LSP went Down.
A static SR-LSP went Down.
System impact
Service traffic carried on the tunnel will be interrupted.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (teTunnelName)
TE tunnel name
teTunnelIndex
SnmpAdminString
teTunnelIndex
SnmpAdminString
Recommended action
To resolve this issue:
1.Check the current tunnel interface configuration, IGP configuration, and the whole tunnel path.
  - If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
If yes, clear link faults.
If no, execute step 2 or 3 according to the tunnel type.
  - If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2 or 3 according to the tunnel type.
2.For an RSVP-TE tunnel, check whether the link bandwidth and link affinity settings are correct.
  - If the settings are correct but the issue persists, go to step 4.
  - If the settings are not correct, edit the related configuration.
3.For a static MPLS TE tunnel, check whether static CRLSP or SRLSP settings are correct.
4.If the issue persists, collect log messages and configuration data, and then contact H3C Support for help..
teTunnelChanged
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.3
TE tunnel path change
Informational
Warning
ON
This notification is generated when the active path for the tunnel specified by teTunnelName changes or a new path becomes active. The value of tePathName is the new active path.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (teTunnelName)
TE tunnel name
teTunnelIndex
SnmpAdminString
teTunnelIndex
SnmpAdminString
Recommended action
