09-MPLS
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R838x-6W10009-MPLS
13-MPLS-L3VPN-STD-MIB
13-MPLS-L3VPN-STD-MIB 87.55 KB
MPLS-L3VPN-STD-MIB
About this MIB
Use this MIB to obtain MPLS VPN information.
MIB file name
rfc4382-mpls-l3vpn-std.mib
Notifications
mplsL3VpnVrfUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.11.0.1
An interface associated with a VRF comes up.
Recovery
Informational
N/A (N/A)
ON
Notification triggers
This notification is generated for a VPN instance (VRF) in the following conditions:
When the VPN instance is not bound to any interface, bind the VPN instance with an interface whose state (ifOperStatus) is up.
The VPN instance is bound to only one interface, and the bound interface's state (ifOperStatus) changes from down to up.
The VPN instance is bound to multiple interfaces. When all the interfaces are in down state (ifOperStatus), one of the interfaces changes from down state to up state.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn command.
OFF
CLI: Use the undo snmp-agent trap enable l3vpn command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.11.1.2.1.1.5 (mplsL3VpnIfConfRowStatus)
Row status used to create, modify, and delete a row in this table.
mplsL3VpnVrfName
mplsL3VpnIfConfIndex
INTEGER
active(1)
1.3.6.1.2.1.10.166.11.1.2.2.1.6 (mplsL3VpnVrfOperStatus)
Operational state of the VPN.
mplsL3VpnVrfName
INTEGER
up(1), down(2)
Recommended action
No action is required.
mplsL3VpnVrfDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.2
An interface associated with a VRF goes down.
Error
Major
1.3.6.1.2.1.10.166.11.0.1 (mplsL3VpnVrfUp)
ON
The VPN instance is bound to only one interface and the interface’s state (ifOperStatus) is up. The interface state changes from up to down or the interface is unbound from the VPN instance.
The VPN instance is bound to multiple interfaces. The ifOperStatus state of the last bound interface changes from up to down, or the last up interface is unbound from the VPN instance.
System impact
The VPN instance does not have an interface to forward IPv4 traffic.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
mplsL3VpnVrfName
INTEGER
active(1)
mplsL3VpnVrfName
INTEGER
up(1), down(2)
Recommended action
To resolve this issue, perform the following tasks:
Identify whether the VPN instance is in use. If the VPN instance is not in use, unbinding the VPN instance from interfaces is normal and no action is required. If the VPN instance is in use, execute the display ip vpn-instance instance-name vpn-instance-name command to view the Interfaces field in the output.
If the Interfaces field is not displayed, it indicates that no interface is bound to the VPN instance. In this case, identify the interface for the VPN instance, execute the ip binding vpn-instance command to bind the interface to the VPN instance, and then execute the ip address command to configure an IPv4 address for the interface.
If the value of the Interfaces field is an interface or multiple interfaces, execute the display ip interface command to view interface state.
  - If the interface physical state (current state) is down, troubleshoot the physical link faults.
  - If the interface physical state (current state) is Administratively DOWN, execute the undo shutdown command to bring up the interface.
  - If the interface does not have an IPv4 address, execute the iP address command to assign an IPv4 address to the interface.
If the issue persists, collect log messages, configuration data, and alarm information, and then contact Technical Support.
1.
mplsL3VpnVrfRouteMidThreshExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.3
The number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of route prefixes in the routing table of the VPN instance exceeds the warning threshold.
System impact
The number of routes in the routing table of the VPN instance has reached the warning threshold. New routes can still be added to the VPN routing table and no route loss or traffic disruption will occur currently.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.11.1.3.1.1.3 (mplsL3VpnVrfPerfCurrNumRoutes)
Total number of active IPv4 and IPv6 routes.
mplsL3VpnVrfName
Gauge32
INTEGER(0..4294967295)
1.3.6.1.2.1.10.166.11.1.2.2.1.9 (mplsL3VpnVrfConfMidRteThresh)
Mid-level water marker for the number of routes that this VRF supports.
mplsL3VpnVrfName
Unsigned32
Standard MIB values.
Recommended action
1.Execute the display ip routing-table vpn-instance vpn-instance-name summary command to view the values for the Max Active Route, Remain Active Route, and Threshold value percentage fields to identify whether the VPN instance route limit has reached the MidRoute warning threshold.
2.Execute the display ip routing-table vpn-instance vpn-instance-name statistics command to view the number of routes of each protocol in the VPN instance. Identify whether the route counts satisfy the expected size.
  - If yes, enter VPN instance view, edit the routing-table limit configuration with a bigger warning threshold value.
  - If no, check the routing protocol whose route count exceeds the expected size and adjust the configuration to remove the exceeding routes. Then, execute the command in step 1 to identify whether the number of route prefixes has dropped below the warning threshold.
3.If the issue persists, collect configuration data, log messages, and alarm information, and then contact Technical Support.
mplsL3VpnVrfNumVrfRouteMaxThreshExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.4
The number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold.
Error
Warning
1.3.6.1.2.1.10.166.11.0.6 (mplsL3VpnNumVrfRouteMaxThreshCleared)
ON
This notification is generated when the number of prefixes in the routing table of a VPN instance exceeds the maximum allowed.
System impact
No new routes can be added to the routing table of the VPN instance, and thus some traffic might be interrupted.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
mplsL3VpnVrfName
Gauge32
1.3.6.1.2.1.10.166.11.1.2.2.1.10 (mplsL3VpnVrfConfHighRteThresh)
High-level water marker for the number of routes that the VRF supports.
mplsL3VpnVrfName
Unsigned32
Recommended action
1.Execute the display ip routing-table vpn-instance vpn-instance-name summary command to view the values for the Max Active Route, Remain Active Route, and Threshold value percentage fields to identify whether the number of route prefixes in the VPN instance has reached the maximum.
  - If yes, enter VPN instance view, edit the routing-table limit configuration with a bigger maximum value.
Basic information
OID
Event
Severity
Default status
The number of routes in a VRF falls below the value of the mplsVrfMaxRouteThreshold object.
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of route prefixes in the routing table of a VPN instance drops below the maximum value.
System impact
The number of routes in the routing table of the VPN instance has dropped below the maximum value. New routes can be added to the VPN instance’s routing table again
Status control
ON
OFF
Object
OID (object name)
Index
Value range
mplsL3VpnVrfName
Gauge32
mplsL3VpnVrfName
Unsigned32
Recommended action
