11-MPLS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10011-MPLS
23-PW-STD-MIB
23-PW-STD-MIB 131.94 KB
PW-STD-MIB
About this MIB
Use this MIB to configure PW related settings.
MIB file name
rfc5601-pw-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).pwStdMIB(246)
Scalar objects
pwIndexNext (1.3.6.1.2.1.10.246.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Unsigned32 (0..4294967295)
Next available index for creating a PW entry.
As per the MIB.
pwPerfTotalErrorPackets (1.3.6.1.2.1.10.246.1.6)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Counter32 (0..4294967295)
Total number of error at the PW processing level.
Not supported
pwUpDownNotifEnable (1.3.6.1.2.1.10.246.1.9)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
The capability of sending PW up and PW down notifications.
As per the MIB.
pwDeletedNotifEnable (1.3.6.1.2.1.10.246.1.10)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
The capability of sending PW-deleted notifications.
As per the MIB.
pwNotifRate (1.3.6.1.2.1.10.246.1.11)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32 (1..2147483647)
The maximum number of PW notifications that can be sent per second.
Not supported
Tabular objects
pwTable
About this table
Use this table to configure PWs.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is pwIndex.
Object (OID)
Access
Value range
Implementation
pwIndex (1.3.6.1.2.1.10.246.1.2.1.1)
not-accessible
PwIndexType
Index of a PW.
As per the MIB.
pwType (1.3.6.1.2.1.10.246.1.2.1.2)
read-create
IANAPwTypeTC
other(0),
frameRelayDlciMartiniMode(1),
atmAal5SduVcc(2),
atmTransparent(3),
ethernetTagged(4),
ethernet(5),
hdlc(6),
ppp(7),
cem(8),
atmCellNto1Vcc(9),
atmCellNto1Vpc(10),
ipLayer2Transport(11),
atmCell1to1Vcc(12),
atmCell1to1Vpc(13),
atmAal5PduVcc(14),
frameRelayPortMode(15),
cep(16), e1Satop(17),
t1Satop(18),
e3Satop(19),
t3Satop(20),
basicCesPsn(21),
basicTdmIp(22),
tdmCasCesPsn(23),
tdmCasTdmIp(24),
frDlci(25),
wildcard(32767)
Encapsulation type.
The set operation supports only ethernetTagged(4) and ethernet(5).
pwOwner (1.3.6.1.2.1.10.246.1.2.1.3)
read-create
INTEGER
manual(1),
pwIdFecSignaling(2),
genFecSignaling(3),
l2tpControlProtocol(4),
other(5)
PW owner, the protocol used for establishing the PW.
The set operation supports only manual(1), pwIdFecSignaling(2), and genFecSignaling(3).
pwPsnType (1.3.6.1.2.1.10.246.1.2.1.4)
read-create
IANAPwPsnTypeTC
mpls(1),
l2tp(2),
udpOverIp(3),
mplsOverIp(4),
mplsOverGre(5),
other(6)
PSN type for the PW.
Supports only the read operation.
Supports only mpls(1), mplsOverGre (5), and other (6).
pwPeerAddrType (1.3.6.1.2.1.10.246.1.2.1.8)
read-create
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Type of the peer IP address of the PW.
Supports only ipv4(1).
pwPeerAddr (1.3.6.1.2.1.10.246.1.2.1.9)
read-create
InetAddress
OCTET STRING (0..255)
Peer IP address of the PW.
Supports only an IPv4 address.
pwAttachedPwIndex (1.3.6.1.2.1.10.246.1.2.1.10)
read-create
PwIndexOrZeroType
Unsigned32 (0..2147483647)
Index of the attached PW.
pwIfIndex (1.3.6.1.2.1.10.246.1.2.1.11)
read-create
InterfaceIndexOrZero
Integer32 (0..2147483647)
Interface index of the PW when the PW is modeled as an interface.
pwID (1.3.6.1.2.1.10.246.1.2.1.12)
read-create
PwIDType
PW ID.
As per the MIB.
pwLocalGroupID (1.3.6.1.2.1.10.246.1.2.1.13)
read-create
PwGroupID
Local group ID of the PW.
pwGroupAttachmentID (1.3.6.1.2.1.10.246.1.2.1.14)
read-create
PwAttachmentIdentifierType
Local AGI of the PW.
pwLocalAttachmentID (1.3.6.1.2.1.10.246.1.2.1.15)
read-create
Local AII of the PW.
pwRemoteAttachmentID (1.3.6.1.2.1.10.246.1.2.1.16)
read-create
Remote AII of the PW.
pwCwPreference (1.3.6.1.2.1.10.246.1.2.1.17)
read-create
TruthValue
true(1),
false(2)
Indicates whether the control word is set on the local node.
As per the MIB.
pwLocalIfMtu (1.3.6.1.2.1.10.246.1.2.1.18)
read-create
Unsigned32
Unsigned32 (0..65535)
Local interface MTU.
Supports the set operation only on VPWS PWs.
For a VPLS PW, the set operation will be ignored.
Implementation varies by product.
pwLocalCapabAdvert (1.3.6.1.2.1.10.246.1.2.1.20)
read-create
IANAPwCapabilities
pwStatusIndication(0),
pwVCCV(1)
Capabilities the local node will advertise to the peer.
The set operation supports only pwStatusIndication(0).
pwRemoteGroupID (1.3.6.1.2.1.10.246.1.2.1.21)
read-only
PwGroupID
Remote group ID of the PW.
The value is always 0.
pwCwStatus (1.3.6.1.2.1.10.246.1.2.1.22)
read-only
PwCwStatusTC
waitingForNextMsg(1),
sentWrongBitErrorCode(2),
rxWithdrawWithWrongBitErrorCode(3),
illegalReceivedBit(4),
cwPresent(5),
cwNotPresent(6),
notYetKnown(7)
Status of the control word negotiation, indicating whether the control word is to be present for the PW.
Supports only cwPresent(5) and cwNotPresent(6).
pwRemoteIfMtu (1.3.6.1.2.1.10.246.1.2.1.23)
read-only
Unsigned32
Remote interface MTU for the PW.
As per the MIB.
pwRemoteCapabilities (1.3.6.1.2.1.10.246.1.2.1.25)
read-only
IANAPwCapabilities
pwVCCV(1)
Capabilities received from the peer node of the PW.
As per the MIB.
pwOutboundLabel (1.3.6.1.2.1.10.246.1.2.1.30)
read-create
Unsigned32
PW label used in the outbound direction.
pwInboundLabel (1.3.6.1.2.1.10.246.1.2.1.31)
read-create
Unsigned32
PW label used in the inbound direction.
pwAdminStatus (1.3.6.1.2.1.10.246.1.2.1.37)
read-create
INTEGER
up(1),
down(2),
testing(3)
Administrative status of the PW.
Supports only up(1) and down(2).
pwOperStatus (1.3.6.1.2.1.10.246.1.2.1.38)
read-only
PwOperStatusTC
up(1),
down(2),
testing(3),
dormant(4),
notPresent(5),
lowerLayerDown(6)
Operational status of the PW.
Supports up(1), down(2), dormant(4), notPresent(5), and lowerLayerDown(6).
pwLocalStatus (1.3.6.1.2.1.10.246.1.2.1.39)
read-only
PwStatus
pwNotForwarding(0),
servicePwRxFault(1),
servicePwTxFault(2),
psnPwRxFault(3),
psnPwTxFault(4)
Status of the PW on the local node.
Supports only zero and BITS {pwNotForwarding(0)}.
pwRemoteStatusCapable (1.3.6.1.2.1.10.246.1.2.1.40)
read-only
INTEGER
notApplicable(1),
notYetKnown(2),
remoteCapable(3),
remoteNotCapable(4)
Remote node capability to advertise the PW status notification.
As per the MIB.
pwRemoteStatus (1.3.6.1.2.1.10.246.1.2.1.41)
read-only
PwStatus
pwNotForwarding(0),
psnPwRxFault(3),
psnPwTxFault(4)
Status of the PW as was advertised by the remote.
As per the MIB.
pwTimeElapsed (1.3.6.1.2.1.10.246.1.2.1.42)
read-only
Integer32
Integer32 (0..86399)
Number of seconds that have elapsed since the beginning of the current interval measurement period.
As per the MIB.
pwValidIntervals (1.3.6.1.2.1.10.246.1.2.1.43)
read-only
HCPerfValidIntervals
Integer32 (0..96)
Number of valid time intervals for which data was collection.
Value range: 0 to 4.
pwRowStatus (1.3.6.1.2.1.10.246.1.2.1.44)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports active(1), notInService(2), createAndGo(4), and destroy(6).
pwStorageType (1.3.6.1.2.1.10.246.1.2.1.45)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for the PW.
The value is always nonVolatile(3).
pwOamEnable (1.3.6.1.2.1.10.246.1.2.1.46)
read-create
TruthValue
"true(1),
false(2)"
Indicates whether OAM is enabled for the PW.
As per the MIB.
pwGenAGIType (1.3.6.1.2.1.10.246.1.2.1.47)
read-create
PwGenIdType
Unsigned32 (0..254)
AGI type of the PW.
pwGenLocalAIIType (1.3.6.1.2.1.10.246.1.2.1.48)
read-create
PwGenIdType
Unsigned32 (0..254)
Local AII type of the PW.
pwGenRemoteAIIType (1.3.6.1.2.1.10.246.1.2.1.49)
read-create
PwGenIdType
Unsigned32 (0..254)
Remote AII type of the PW.
pwPerfCurrentTable
About this table
This table provides per-PW performance information for the current interval.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
pwPerfCurrentInHCPackets (1.3.6.1.2.1.10.246.1.3.1.1)
read-only
HCPerfCurrentCount
Counter64 (0..18446744073709551615)
High-capacity counter for number of packets received by the PW.
As per the MIB.
pwPerfCurrentInHCBytes (1.3.6.1.2.1.10.246.1.3.1.2)
read-only
HCPerfCurrentCount
High-capacity counter for number of bytes received by the PW.
As per the MIB.
pwPerfCurrentOutHCPackets (1.3.6.1.2.1.10.246.1.3.1.3)
read-only
HCPerfCurrentCount
High-capacity counter for number of packets forwarded by the PW.
As per the MIB.
pwPerfCurrentOutHCBytes (1.3.6.1.2.1.10.246.1.3.1.4)
read-only
HCPerfCurrentCount
High-capacity counter for number of bytes forwarded by the PW.
As per the MIB.
pwPerfCurrentInPackets (1.3.6.1.2.1.10.246.1.3.1.5)
read-only
PerfCurrentCount
Gauge32 (0..4294967295)
Counter for number of packets received by the PW.
As per the MIB.
pwPerfCurrentInBytes (1.3.6.1.2.1.10.246.1.3.1.6)
read-only
PerfCurrentCount
Counter for number of bytes received by the PW.
As per the MIB.
pwPerfCurrentOutPackets (1.3.6.1.2.1.10.246.1.3.1.7)
read-only
PerfCurrentCount
Counter for number of packets forwarded by the PW.
As per the MIB.
pwPerfCurrentOutBytes (1.3.6.1.2.1.10.246.1.3.1.8)
read-only
PerfCurrentCount
Counter for number of bytes forwarded by the PW.
As per the MIB.
pwPerfIntervalTable
About this table
This table provides per-PW performance information for the latest four intervals.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pwIndex and pwPerfIntervalNumber.
Object (OID)
Access
Value range
Implementation
pwPerfIntervalNumber (1.3.6.1.2.1.10.246.1.4.1.1)
not-accessible
Integer32
Integer32 (1..96)
Number of a time interval.
As per the MIB.
pwPerfIntervalValidData (1.3.6.1.2.1.10.246.1.4.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the data for this interval is valid.
As per the MIB.
pwPerfIntervalTimeElapsed (1.3.6.1.2.1.10.246.1.4.1.3)
read-only
HCPerfTimeElapsed
Duration of this interval in seconds.
As per the MIB.
pwPerfIntervalInHCPackets (1.3.6.1.2.1.10.246.1.4.1.4)
read-only
HCPerfIntervalCount
As per the MIB.
pwPerfIntervalInHCBytes (1.3.6.1.2.1.10.246.1.4.1.5)
read-only
HCPerfIntervalCount
As per the MIB.
pwPerfIntervalOutHCPackets (1.3.6.1.2.1.10.246.1.4.1.6)
read-only
HCPerfIntervalCount
As per the MIB.
pwPerfIntervalOutHCBytes (1.3.6.1.2.1.10.246.1.4.1.7)
read-only
HCPerfIntervalCount
As per the MIB.
pwPerfIntervalInPackets (1.3.6.1.2.1.10.246.1.4.1.8)
read-only
PerfIntervalCount
As per the MIB.
pwPerfIntervalInBytes (1.3.6.1.2.1.10.246.1.4.1.9)
read-only
PerfIntervalCount
As per the MIB.
pwPerfIntervalOutPackets (1.3.6.1.2.1.10.246.1.4.1.10)
read-only
PerfIntervalCount
As per the MIB.
pwPerfIntervalOutBytes (1.3.6.1.2.1.10.246.1.4.1.11)
read-only
PerfIntervalCount
As per the MIB.
pwPerf1DayIntervalTable
About this table
This table provides per-PW performance information for the current day's interval and the previous day's interval.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pwIndex and pwPerf1DayIntervalNumber.
Object (OID)
Access
Value range
Implementation
pwPerf1DayIntervalNumber (1.3.6.1.2.1.10.246.1.5.1.1)
read-only
Unsigned32
Unsigned32 (1..31)
As per the MIB.
pwPerf1DayIntervalValidData (1.3.6.1.2.1.10.246.1.5.1.2)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
pwPerf1DayIntervalTimeElapsed (1.3.6.1.2.1.10.246.1.5.1.3)
read-only
HCPerfTimeElapsed
As per the MIB.
pwPerf1DayIntervalInHCPackets (1.3.6.1.2.1.10.246.1.5.1.4)
read-only
Counter64
As per the MIB.
pwPerf1DayIntervalInHCBytes (1.3.6.1.2.1.10.246.1.5.1.5)
read-only
Counter64
As per the MIB.
pwPerf1DayIntervalOutHCPackets (1.3.6.1.2.1.10.246.1.5.1.6)
read-only
Counter64
As per the MIB.
pwPerf1DayIntervalOutHCBytes (1.3.6.1.2.1.10.246.1.5.1.7)
read-only
Counter64
As per the MIB.
pwIndexMappingTable
About this table
This table enables the reverse mapping of the unique PWid parameters [peer IP, PW type, and PW ID] and the pwIndex.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pwIndexMappingPwType, pwIndexMappingPwID, pwIndexMappingPeerAddrType, and pwIndexMappingPeerAddr.
Object (OID)
Access
Value range
Implementation
pwIndexMappingPwType (1.3.6.1.2.1.10.246.1.7.1.1)
not-accessible
IANAPwTypeTC
other(0),
atmAal5SduVcc(2),
atmTransparent(3),
ethernetTagged(4),
ethernet(5),
hdlc(6),
ppp(7),
cem(8),
atmCellNto1Vcc(9),
atmCellNto1Vpc(10),
atmCell1to1Vcc(12),
atmCell1to1Vpc(13),
atmAal5PduVcc(14),
t1Satop(18),
e3Satop(19),
t3Satop(20),
basicCesPsn(21),
basicTdmIp(22),
tdmCasCesPsn(23),
tdmCasTdmIp(24),
frDlci(25),
wildcard(32767)
PW encapsulation type.
As per the MIB.
pwIndexMappingPwID (1.3.6.1.2.1.10.246.1.7.1.2)
not-accessible
PwIDType
Unsigned32
PW ID.
As per the MIB.
pwIndexMappingPeerAddrType (1.3.6.1.2.1.10.246.1.7.1.3)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
IP address type of the peer node.
As per the MIB.
pwIndexMappingPeerAddr (1.3.6.1.2.1.10.246.1.7.1.4)
not-accessible
InetAddress
IP address of the peer node.
As per the MIB.
pwIndexMappingPwIndex (1.3.6.1.2.1.10.246.1.7.1.5)
read-only
PwIndexType
Index of the PW in the pwTable.
As per the MIB.
pwPeerMappingTable
About this table
This table provides information about mappings between the PW parameters and pwIndex.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pwPeerMappingPeerAddrType, pwPeerMappingPeerAddr, pwPeerMappingPwType, and pwPeerMappingPwID.
Object (OID)
Access
Value range
Implementation
pwPeerMappingPeerAddrType (1.3.6.1.2.1.10.246.1.8.1.1)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
As per the MIB.
pwPeerMappingPeerAddr (1.3.6.1.2.1.10.246.1.8.1.2)
not-accessible
InetAddress
As per the MIB.
pwPeerMappingPwType (1.3.6.1.2.1.10.246.1.8.1.3)
not-accessible
IANAPwTypeTC
other(0),
atmAal5SduVcc(2),
atmTransparent(3),
ethernetTagged(4),
ethernet(5),
hdlc(6),
ppp(7),
cem(8),
atmCellNto1Vcc(9),
atmCellNto1Vpc(10),
atmCell1to1Vcc(12),
atmCell1to1Vpc(13),
atmAal5PduVcc(14),
t1Satop(18),
e3Satop(19),
t3Satop(20),
basicCesPsn(21),
basicTdmIp(22),
tdmCasCesPsn(23),
tdmCasTdmIp(24),
frDlci(25),
wildcard(32767)
As per the MIB.
pwPeerMappingPwID (1.3.6.1.2.1.10.246.1.8.1.4)
not-accessible
PwIDType
Unsigned32(0..4294967295)
PW ID
As per the MIB.
pwPeerMappingPwIndex (1.3.6.1.2.1.10.246.1.8.1.5)
read-only
PwIndexType
As per the MIB.
pwGenFecIndexMappingTable
About this table
This table provides information about mappings between the GenFec PW parameters and pwIndex.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pwGenFecIndexMappingAGIType, pwGenFecIndexMappingAGI, pwGenFecIndexMappingLocalAIIType, pwGenFecIndexMappingLocalAII, pwGenFecIndexMappingRemoteAIIType, and pwGenFecIndexMappingRemoteAII.
Object (OID)
Access
Value range
Implementation
pwGenFecIndexMappingAGIType (1.3.6.1.2.1.10.246.1.12.1.1)
not-accessible
PwGenIdType
Unsigned32 (0..254)
AGI type of the PW.
As per the MIB.
pwGenFecIndexMappingAGI (1.3.6.1.2.1.10.246.1.12.1.2)
not-accessible
AGI value of the PW.
As per the MIB.
pwGenFecIndexMappingLocalAIIType (1.3.6.1.2.1.10.246.1.12.1.3)
not-accessible
PwGenIdType
Unsigned32 (0..254)
As per the MIB.
pwGenFecIndexMappingLocalAII (1.3.6.1.2.1.10.246.1.12.1.4)
not-accessible
Local AII value of the PW.
As per the MIB.
pwGenFecIndexMappingRemoteAIIType (1.3.6.1.2.1.10.246.1.12.1.5)
not-accessible
PwGenIdType
Unsigned32 (0..254)
As per the MIB.
pwGenFecIndexMappingRemoteAII  (1.3.6.1.2.1.10.246.1.12.1.6)
not-accessible
Remote AII value of the PW.
As per the MIB.
pwGenFecIndexMappingPwIndex (1.3.6.1.2.1.10.246.1.12.1.7)
read-only
PwIndexType
As per the MIB.
Notifications
pwDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.246.0.1
PW down
Error
Major
1.3.6.1.2.1.10.246.0.2 (pwUp)
OFF
Notification triggers
This notification is generated when the pwOperStatus object for one or more contiguous entries in the pwTable are about to enter the down(2) or lowerLayerDown(6) state from any other state, except for transition from the notPresent(5) state.
Possible reasons for this notification include the following:
The physical link of the PW went down.
The configuration at the two ends of the PW changed.
System impact
Traffic forwarding fails in the PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-up-down command.
OFF
CLI: undo snmp-agent trap enable l2vpn pw-up-down command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.246.1.2.1.38 (pwOperStatus)
PW operational status.
pwIndex
PwOperStatusTC
up(1), down(2), testing(3), dormant(4), notPresent(5), lowerLayerDown(6)
Recommended action
To resolve this issue:
Use the display l2vpn pw verbose command to view the Down Reasons field. Common reasons and solutions are as follows:
BFD session for PW down—The BFD session for PW detection is down. In this case, use the display bfd session command to view the reasons for the BFD session down, and then correct the BFD configuration or troubleshoot the physical link and link quality issues accordingly.
BGP RD was deleted—The BGP RD has been deleted. In this case, execute the route-distinguisher route-distinguisher command in auto-discovery cross-connect group view.
BGP RD was empty—No BGP RD is configured. In this case, execute the route-distinguisher route-distinguisher command in auto-discovery cross-connect group view.
Control word not match—The control word configuration on the two ends of the PW is inconsistent. In this case, configure the same control word setting on the two ends of the PW by using the control-word enable command in the PW class specified for the PW.
Encapsulation not match—The encapsulation types on the two ends of the PW are inconsistent. In this case, configure the same PW data encapsulation type on the two ends of the PW by using the pw-type command in the PW class specified for the PW.
LDP interface parameter not match—The LDP negotiation parameters on the two ends of the PW are inconsistent. In this case, configure the same VCCV CC type on the two ends of the PW by using the vccv cc command in the PW class specified for the PW. Or, configure the same CEM class settings for the CEM interfaces used by the two ends of the PW.
Non-existent remote LDP PW—The remote device has deleted the LDP PW. In this case, reconfigure the PW on the remote device.
Local AC Down—The local AC is down. In this case, verify that the configuration of the AC interface is correct and the state of the AC interface is up on the local device.
Local AC was non-existent—No local AC is configured. In this case, configure a local AC and associate it with the VSI.
MTU not match—The MTU configuration on the two ends of the PW is inconsistent. In this case, configure the same MTU on the two ends of the PW or use the mtu-negotiate disable command to disable PW MTU negotiation.
Remote AC Down—The remote AC is down. In this case, verify that the configuration of the AC interface is correct and the state of the AC interface is up on the remote device.
pwUp
Basic information
OID
Event
Severity
Default status
PW up
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the pwOperStatus object for one or more contiguous entries in the pwTable are about to enter the up(1) state from some other state except the notPresent(5) state and given that the pwDown notification been issued for these entries.
System impact
The service carried on the PW will become available again.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
pwIndex
PwOperStatusTC
Recommended action
No action is required.
pwDeleted
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.246.0.3
PW deleted
Error
Major
N/A (N/A)
OFF
This notification is generated when a PW is deleted.
The peer was deleted in VSI view or the VSI was deleted manually.
The peer was deleted in cross-connect view or the cross-connect was deleted manually.
L2VPN or MPLS was disabled.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-delete command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-delete command.
Object
OID (object name)
Index
Value range
 (pwType)
PW data encapsulation type.
pwIndex
IANAPwTypeTC
other(0), frameRelayDlciMartiniMode(1), atmAal5SduVcc(2), atmTransparent(3), ethernetTagged(4), ethernet(5), hdlc(6), ppp(7), cem(8)  -- Historic type, atmCellNto1Vcc(9), atmCellNto1Vpc(10), ipLayer2Transport(11), atmCell1to1Vcc(12), atmCell1to1Vpc(13), atmAal5PduVcc(14), frameRelayPortMode(15), cep(16),, e1Satop(17), t1Satop(18), e3Satop(19), t3Satop(20), basicCesPsn(21), basicTdmIp(22), tdmCasCesPsn(23), tdmCasTdmIp(24), frDlci(25), wildcard (32767)
 (pwID)
PW ID.
pwIndex
PwIDType
Unsigned32(1..4294967295)
1.3.6.1.2.1.10.246.1.2.1.8 (pwPeerAddrType)
pwIndex
InetAddressType
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16)
1.3.6.1.2.1.10.246.1.2.1.9 (pwPeerAddr)
pwIndex
InetAddress
OCTET STRING (SIZE (0..255))
Recommended action
This is a normal operating message. If the related configuration was deleted mistakenly, restore the configuration as needed.
