11-MPLS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10011-MPLS
03-HH3C-EVC-MIB
03-HH3C-EVC-MIB 66.44 KB
HH3C-EVC-MIB
About this MIB
Use this MIB to configure EVC related settings.
MIB file name
hh3c-evc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEvc(106)
Tabular objects
hh3cEvcScalarGroup
About this table
Use this table to obtain global EVC information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cEvcSrvInstEncapCapabilities (1.3.6.1.4.1.25506.2.106.1.1.1)
read-only
BITS
encapDefault(0),
encapUntagged(1),
encapTagged(2),
encapSvlanId(3),
encapSvlanIdList(4),
encapSvlanIdOnlyTagged(5),
encapSvlanIdCvlanId(6),
encapSvlanIdCvlanIdList(7),
encapCvlanId(8),
encapCvlanIdList(9)
Capabilities of the EVC service instance.
As per the MIB.
hh3cEvcPortMaxSrvInstNum (1.3.6.1.4.1.25506.2.106.1.1.2)
read-only
Integer32
Integer32 (1..2147483647)
Maximum number of EVC service instances supported on a port.
As per the MIB.
hh3cEvcSrvInstTable
About this table
Use this table to create and delete EVC service instances.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex and hh3cEvcSrvInstId.
Object (OID)
Access
Value range
Implementation
hh3cEvcSrvInstId (1.3.6.1.4.1.25506.2.106.1.2.1.1)
not-accessible
Integer32
Service instance ID.
As per the MIB.
hh3cEvcSrvInstEncap (1.3.6.1.4.1.25506.2.106.1.2.1.2)
read-create
INTEGER
none(0),
default(1),
untagged(2),
tagged(3),
svlanIdList(4),
svlanIdListOnlyTagged(5),
svlanIdCvlanId(6),
svlanIdCvlanIdList(7),
svlanIdCvlanIdAll(8),
cvlanIdList(9)
Encapsulation type of the service instance.
As per the MIB.
hh3cEvcSrvInstSvlanIdListLow (1.3.6.1.4.1.25506.2.106.1.2.1.3)
read-create
OCTET STRING
OCTET STRING (0..256)
Low bit of the SVLAN list.
As per the MIB.
hh3cEvcSrvInstSvlanIdListHigh (1.3.6.1.4.1.25506.2.106.1.2.1.4)
read-create
OCTET STRING
High bit of the SVLAN list.
As per the MIB.
hh3cEvcSrvInstRowStatus (1.3.6.1.4.1.25506.2.106.1.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports active(1), createAndGo(4), and destroy(6).
hh3cEvcSrvInstCvlanIdListLow (1.3.6.1.4.1.25506.2.106.1.2.1.8)
read-create
OCTET STRING
Low bit of the CVLAN list.
As per the MIB.
hh3cEvcSrvInstCvlanIdListHigh (1.3.6.1.4.1.25506.2.106.1.2.1.9)
read-create
OCTET STRING
High bit of the CVLAN list.
As per the MIB.
