11-ACL and QoS
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10011-ACL and QoS
02-HH3C-CBQOS2-MIB
02-HH3C-CBQOS2-MIB 54.54 KB
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Notifications
hh3cCBQoSGlobalAclNotSupport
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.3
The global ACL is not supported.
Informational
Warning
OFF
Notification triggers
The notification is generated when you apply a QoS policy globally and a card does not support the ACL used in the QoS policy.
System impact
The QoS policy applied globally does not take effect on the card.
Status control
ON
CLI: Use the snmp-agent trap enable qos command.
OFF
CLI: Use the undo snmp-agent trap enable qos command.
Object
OID (object name)
Index
Value range
hh3cCBQoSChassis
 (1.3.6.1.4.1.25506.2.65.2.1.8.1)
Chassis number
N/A
Integer32
0 to 65534
hh3cCBQoSSlot
 (1.3.6.1.4.1.25506.2.65.2.1.8.2)
Slot number
N/A
Integer32
0 to 65534
hh3cCBQoSCPU
 (1.3.6.1.4.1.25506.2.65.2.1.8.3)
CPU number
N/A
Integer32
0 to 65534
hh3cCBQoSDirection (1.3.6.1.4.1.25506.2.65.2.1.8.4)
Application direction
N/A
DirectionTyp
As per the MIB.
Recommended action
None.
hh3cCBQoSGlobalQPPBNotSupport
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.4
QPPB is not supported.
Informational
Warning
OFF
The notification is generated when you apply a QoS policy globally in QPPB mode and a card does not support QPPB.
System impact
The QoS policy applied globally in QPPB mode does not take effect on the card.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cCBQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cCBQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cCBQoSCPU
CPU number
N/A
Integer32
0 to 65534
N/A
DirectionTyp
As per the MIB.
Recommended action
Apply a QoS policy in QPPB mode to the interfaces on the card that support the QPPB mode.
hh3cCBQoSRedirectInvalidAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.5
The redirection next hop is unreachable.
Fault
Major
hh3cCBQoSRedirectInvalidAlarmRecover (hh3cCBQoSRedirectInvalidAlarmRecover)
OFF
The notification is generated when the redirection next hop is unreachable.
System impact
The QoS policy containing the redirection action does not take effect.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.65.2.1.8.5 (hh3cCBQoSRedirectAlarmBehaviorName)
Traffic behavior name
N/A
OCTET STRING
SIZE (1 to 31)
1.3.6.1.4.1.25506.2.65.2.1.8.6 (hh3cCBQoSRedirectAlarmProtoFamily)
Protocol family of the next-hop address
N/A
InetAddressType
As per the MIB.
1.3.6.1.4.1.25506.2.65.2.1.8.7 (hh3cCBQoSRedirectAlarmNextHop)
Next-hop address
N/A
InetAddress
As per the MIB.
Recommended action
To resolve the issue, identify whether the next hop exists in the routing table. If the next hop does not exist in the routing table, configure a routing protocol for the next hop to be learned to the routing table.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.2.1.7.0.6
The redirection next hop is reachable.
Fault
Major
N/A (N/A)
OFF
The notification is generated when the redirection next hop is reachable.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
SIZE (1 to 31)
N/A
InetAddressType
As per the MIB.
Next-hop address
N/A
InetAddress
As per the MIB.
Recommended action
None.
