11-ACL and QoS
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10011-ACL and QoS
01-HH3C-ACL-MIB
01-HH3C-ACL-MIB 45.57 KB
HH3C-ACL-MIB
About this MIB
This MIB provides some basic table for managing ACLs on a switch.
MIB file name
hh3c-acl.mib
Notifications
hh3cAclRuleMatchCount
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.8.5.0.2
Notification for the ACL rule matches.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
When a trap interval is set through the table hh3cAclIntervalTable, notifications will be generated at intervals. The notification information includes the number of rule matches in the interval.
System impact
No negative impact on services.
Status control
ON
CLI: Use the acl trap interval interval command.
MIB: Set hh3cAclIntervalType to trap(2), set the hh3cAclIntervalValue to a value in the range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
MIB: Use the table hh3cAclIntervalTable to perform a destroy operation.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.8.3.6.1.1 (hh3cPfilter2ApplyObjType)
Object to which the ACL is applied.
hh3cPfilter2ApplyObjIndex
hh3cPfilter2ApplyDirection
hh3cPfilter2ApplyAclType
hh3cPfilter2ApplyAclIndex
hh3cPfilter2AclRuleIndex
INTEGER
interface(1), vlan(2), global(3)
1.3.6.1.4.1.25506.2.8.3.6.1.2 (hh3cPfilter2ApplyObjIndex)
Object index.
Integer32
0 to 2147483647
1.3.6.1.4.1.25506.2.8.3.6.1.3 (hh3cPfilter2ApplyDirection)
Direction of the packet filter.
INTEGER
inbound(1), outbound(2)
1.3.6.1.4.1.25506.2.8.3.6.1.4 (hh3cPfilter2ApplyAclType)
Type of the ACL.
INTEGER
ipv4(1), ipv6(2), default(3), mac(4), user(5)
1.3.6.1.4.1.25506.2.8.3.6.1.5 (hh3cPfilter2ApplyAclIndex)
ACL index.
OCTET STRING
SIZE (1 to 63)
1.3.6.1.4.1.25506.2.8.3.8.1.1 (hh3cPfilter2AclRuleIndex)
ACL rule index
Integer32
0 to 65534.
1.3.6.1.4.1.25506.2.8.3.8.1.4 (hh3cPfilter2AclRuleMatchPackets)
ACL rule match count.
N/A
Counter64
0 to 18446744073709551615.
Recommended action
No action is required.
hh3cAclResourceTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.8.7.0.1
TCAM resource usage notification.
Informational
Warning
OFF
Notifications will be generated for violations of threshold set by hh3cAclMib2ResourceThreshold at intervals set by hh3cAclMib2ResourceLogInterval. The notification information includes the Ternary Content Addressable Memory (TCAM) resource usage for each card.
System impact
Status control
ON
CLI: Use the commands:
acl resource threshold percent percent
acl resource log interval interval
MIB: Set hh3cAclMib2ResourceThreshold to a value in the range of 1 to 100, and set hh3cAclMib2ResourceLogInterval to a value in the range of 1 to 60.
OFF
undo acl resource threshold percent
undo acl resource log interval
MIB: Set hh3cAclMib2ResourceThreshold to 0, and set hh3cAclMib2ResourceLogInterval to 0.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.8.6.1 (hh3cAclResourceTypeName)
Resource type.
N/A
OCTET STRING
SIZE (1 to 255)
1.3.6.1.4.1.25506.2.8.6.2 (hh3cAclResourceUsage)
Resource usage.
N/A
Integer32
0 to 100
1.3.6.1.4.1.25506.2.8.6.3 (hh3cAclResourceUsedEntries)
Number of used resources.
N/A
Integer32
1.3.6.1.4.1.25506.2.8.6.4 (hh3cAclResourceTotalEntries)
Total number of resources.
N/A
INTEGER
1.3.6.1.4.1.25506.2.8.2.1.1.5 (hh3cAclMib2ResourceThreshold)
Resource usage alarm threshold.
N/A
Integer32
0 to 100
1.3.6.1.4.1.25506.2.8.6.5 (hh3cAclResourceChassisID)
Chassis number.
N/A
Integer32
1.3.6.1.4.1.25506.2.8.6.6 (hh3cAclResourceSlotID)
Slot number.
N/A
Integer32
Recommended action
