00-Preface | 100.60 KB |
Preface
This configuration guide describes fundamentals and configuration of Ethernet Virtual Private Network (EVPN). EVPN is a Layer 2 VPN technology that provides both Layer 2 and Layer 3 connectivity between distant network sites across an IP or MPLS network. EVPN uses MP-BGP in the control plane and Virtual eXtensible LAN (VXLAN) or MPLS in the data plane.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S10500X-G switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
