01-Fundamentals Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C S12500G-AF&S12500CR&S10500X-G&S7500X-G Switch Series Configuration Examples-R7753Pxx[R8053Pxx]-6W10001-Fundamentals Configuration Examples
04-Software Patching Examples
04-Software Patching Examples 74.45 KB
Introduction
This document provides software patching examples that use install commands.
This document assumes that you have basic knowledge of software patching that use install commands .
Example: Patching software (in standalone mode)
As shown in Figure 1, the device and the TFTP server can reach each other. The device has two MPUs: active MPU in slot 0 and standby MPU in slot 1. The device is running BOOT-R7753P05 and SYSTEM-R7753P05.
Use the patch image file SYSTEM-R7753P05H01.bin to fix bugs without rebooting the device.
Figure 1 Network diagram
Hardware
Software version
S12500G-AF
Release 8053P05 and later
S12500CR
S10500X-G
Release 7753P05 and later
S7500X-G
When you patch software, follow these restrictions and guidelines:
·     The first time you install patch images, you must start with the active MPU. For subsequent patch installations, you must start with the standby MPU.
·     The patch image version must match the device model and Comware version. For example, to fix bugs in R7753P05, you must use SYSTEM-R7753P05H01.bin.
Procedures
# Download the patch image file SYSTEM-R7753P05H01.bin from the TFTP server to the root directory of the flash memory on the active MPU.
<Sysname> tftp 2.2.2.2 get R7753P05H01.bin
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 25.2M    0 25.2M    0     0   210k      0 --:--:--  0:02:02 --:--:--  209k
# Activate the patch images on the active MPU first and then on the standby MPU.
<Sysname> install activate patch flash:/SYSTEM-R7753P05H01.bin slot 0
This operation maybe take several minutes, please wait.............Done.
<Sysname> install activate patch flash:/SYSTEM-R7753P05H01.bin slot 1
The patch images take effect immediately after they are activated.
# For the patch images to take effect after a reboot, commit the software changes.
<Sysname> install commit
# Verify that the patch images have been activated successfully.
<Sysname> display install active
Active packages on slot 0:
  flash:/BOOT-R7753P05.bin
  flash:/SYSTEM-R7753P05.bin
Active packages on slot 1:
Active packages on slot 3:
# Verify that the patch image file has been added to the main startup software image list so the images can take effect after a reboot.
<Sysname> display install committed
Committed packages on slot 0:
Committed packages on slot 1:
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
Example: Patching software (in IRF mode)
As shown in Figure 2, the two-chassis IRF fabric and the TFTP server can reach each other. The active MPU of the master device is in slot 0, and the standby MPU of the master device is in slot 1. The active MPU of the subordinate device is in slot 0, and the standby MPU of the subordinate device is in slot 1. The IRF members are running BOOT-R7753P05 and SYSTEM-R7753P05.
Use the patch image file SYSTEM-R7753P05H01.bin to fix bugs without rebooting the members.
Figure 2 Network diagram
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
·     To install an image, you must begin with the master. On each member device, you must begin with the active MPU. To upgrade an image, you must begin with a subordinate device. On each member device, you must begin with the standby MPU.
Procedures
# Download the patch image file SYSTEM-R7753P05H01.bin from the TFTP server to the root directory of the flash memory on the active MPU of the master.
<Sysname> tftp 2.2.2.2 get SYSTEM-R7753P05H01.bin
# Activate the patch images on the global active MPU first and then on the global standby MPUs.
<Sysname> install activate patch flash:/SYSTEM-R7753P05H01.bin chassis 2 slot 1
<Sysname> install activate patch flash:/SYSTEM-R7753P05H01.bin chassis 2 slot 0
<Sysname> install activate patch flash:/SYSTEM-R7753P05H01.bin chassis 1 slot 1
<Sysname> install activate patch flash:/SYSTEM-R7753P05H01.bin chassis 1 slot 0
Active packages on chassis 1 slot 0:
Active packages on chassis 1 slot 1:
Active packages on chassis 1 slot 3:
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 1:
Active packages on chassis 2 slot 3:
Committed packages on chassis 1 slot 0:
Committed packages on chassis 1 slot 1:
Committed packages on chassis 2 slot 0:
Committed packages on chassis 2 slot 1:
Configuration files
