01-ISSU Configuration Examples | 103.92 KB |
General restrictions and guidelines
Example: Performing a compatible ISSU
Example: Performing an incompatible ISSU
Introduction
This document provides compatible and incompatible ISSU configuration examples.
Before performing an ISSU, use the display version comp-matrix file command to view the recommended ISSU method in the Upgrade Way field. Table 1 shows a matrix of ISSU types and ISSU methods.
Table 1 Matrix of ISSU types and ISSU methods
ISSU methods |
Compatible |
The ISSU methods are displayed in the Upgrade Way field. · Service Upgrade · File Upgrade · ISSU Reboot · Reboot |
Incompatible |
Only one upgrade method (Incompatible upgrade) is available, which is displayed at the end of command output. |
This document assumes that you have basic knowledge of ISSU.
Before performing an ISSU, you must complete the following preparation tasks:
· Read the software release notes to identify support of the device for ISSU.
· Use the display device command to verify that no member devices are in Fault state.
· Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files.
· For service continuity during an ISSU, verify that the following feature settings are configured:
Feature |
Setting requirements |
GR/NSR |
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF. |
BFD |
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA. |
Ethernet link aggregation |
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups. |
IRF |
Configure IRF bridge MAC persistence as follows: · Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command. · Incompatible upgrade ¡ Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command. ¡ Disable IRF MAD before the ISSU and enable IRF MAD again after the ISSU. |
· Log in to the device through the console port. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
During an ISSU, use the following guidelines:
· In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
· Do not perform any of the following tasks during an ISSU:
¡ Reboot, add, or remove member device.
¡ Execute commands that are not for ISSU.
¡ Modify, delete, or rename image files.
The following describes restrictions and guidelines for an ISSU.
Hardware requirements
· Do not perform an ISSU during hardware upgrade or failure. Otherwise, upgrade failure or system exceptions might occur.
Upgrade restrictions
· Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
Feature restrictions
For service continuity during ISSU, configure the following feature settings:
Feature |
GR or NSR |
BFD |
IRF |
Configure IRF bridge MAC persistence as follows: · Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command. · Incompatible upgrade—Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command. |
Operation restrictions
¡ Execute commands that are irrelevant to the ISSU.
As shown in Figure 1, the two-chassis IRF fabric and the TFTP server can reach each other. Perform a compatible ISSU on the IRF to upgrade startup images from T0001015 to T0001016.
Hardware |
Software version |
S12500G-AF |
Release 8053P05 and later |
S12500CR |
S10500X-G |
Release 7753P05 and later |
S7500X-G |
When you perform the compatible ISSU, follow these restrictions and guidelines:
· The available storage space on each member device must be at least two times the size of the new image.
· Do not execute commands that are irrelevant to the ISSU.
· The automatic rollback timer starts after you execute the issu run switchover command. If no exceptions occur, execute the issu accept or issu commit command to complete the upgrade before this timer expires. If an exception occurs, manually roll back or wait for the system to automatically roll back to the original software images, and then perform a new upgrade.
· After you execute the issu accept or issu commit command, the system automatically deletes the rollback timer.
Procedures
# Download the new image file T0001016.ipe from the TFTP server to the root directory of a file system on the master. The .ipe file includes the boot-t0001016.bin image file and the system-t0001016.bin image file.
<Sysname> tftp 2.2.2.2 get T0001016.ipe
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 52.2M 100 42.8M 0 0 159k 0 0:04:34 0:04:34 --:--:-- 165
# Display current software images.
<Sysname> display install active
Active packages on slot 1:
flash:/boot-t0001015.bin
flash:/system-t0001015.bin
Active packages on slot 2:
# Display the recommended ISSU methods.
<Sysname> display version comp-matrix file ipe flash:/T0001016.ipe
Verifying the file flash:/T0001016.ipe on slot 1..................................Done.
Identifying the upgrade methods...........Done.
Slot Upgrade Way
1 Reboot
2 Reboot
The output shows the two versions are compatible and a reboot is needed to complete upgrade.
# Disable configuration rollback.
[Sysname] issu rollback-timer 0
# Upgrade the subordinate member.
<Sysname> issu load file ipe flash:/T0001016.ipe slot 2
This operation will delete the rollback point information for the previous upgrade
and maybe get unsaved configuration lost. Continue? [Y/N]:y
Successfully copied flash:/boot-t0001016.bin to slot2#flash:/boot-t0001016.bin.
Successfully copied flash:/system-t0001016.bin to slot2#flash:/system-t0001016.bin.
Running Version New Version
Test 0001015 Test 0001016
Slot Upgrade Way
2 Reboot
# After the subordinate member starts up, verify that the ISSU is finished on the subordinate member.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot:
slot 2
Previous version list:
boot: 7.1.070 Test 0001015
system: 7.1.070 Test 0001015
Upgrade version list:
boot: 7.1.070, Test 0001016
system: 7.1.070, Test 0001016
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
Slot Switchover Way
1 Master subordinate switchover
# Verify that the switchover has completed.
ISSU state: switchover
Compatibility: Unknown
Work state: Normal
Upgrade method: card by card
Upgraded chassis: None
Current upgrading chassis: None
Current version list:
boot: 7.1.070, Test 0001015
system: 7.1.070, Test 0001015
Current software images:
// The ISSU state Switchover indicates the switchover has completed.
# Upgrade the original master.
<Sysname> issu commit slot 1
flash: /boot-t0001016.bin
flash: /system-t0001016.bin
Slot Upgrade Way
1 Reboot
# View ISSU state.
ISSU state: Init
Work state: Normal
// The Init state indicates that the ISSU has completed.
# Verify that startup images have been upgraded to T0001016.
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
As shown in Figure 2, the two-chassis IRF fabric and the TFTP server can reach each other. Perform an incompatible ISSU on the IRF to upgrade startup images from T0001015 to T0001017.
Hardware |
Software version |
S12500G-AF |
S12500CR |
S10500X-G |
S7500X-G |
When you perform the incompatible ISSU, follow these restrictions and guidelines:
Procedures
# Download the new image file T0001017.ipe from the TFTP server to the root directory of a file system on the master. The .ipe file includes the boot-t0001017.bin image file and the system-t0001017.bin image file.
<Sysname> tftp 2.2.2.2 get T0001017.ipe
100 50.1M 100 42.8M 0 0 159k 0 0:04:34 0:04:34 --:--:-- 165k
# Display the ISSU method.
<Sysname> display version comp-matrix file ipe flash:/T0001017.ipe
Verifying the file flash:/T0001017.ipe on slot 1..................................Done.
Incompatible upgrade.
The output shows the two versions are incompatible and a reboot is needed to complete upgrade.
<Sysname> issu load file ipe flash:/T0001017.ipe slot 2
Successfully copied flash:/boot-t0001017.bin to slot2#flash:/boot-t0001017.bin.
Successfully copied flash:/system-t0001017.bin to slot2#flash:/system-t0001017.bin.
Test 0001015 Test 0001017
Slot Upgrade Way
2 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]: y
# Verify that the ISSU is finished on the subordinate member.
ISSU state: Loaded
Work state: Normal
Upgraded slot: None
slot 2
boot: 7.1.070, Test 0001017
system: 7.1.070, Test 0001017
# Perform a master/subordinate switchover to complete upgrade.
Slot Upgrade Way
2 Reboot
1 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# View ISSU state.
ISSU state: Init
Work state: Normal
# Verify that startup images have been upgraded to T0001017.
Configuration files
