11-Security Command Reference
HomeSupportSwitchesH3C S10500X Switch SeriesReference GuidesCommand ReferencesH3C S10500X Switch Series Command References-Release7634Pxx-6W10011-Security Command Reference
25-TC commands
25-TC commands 166.47 KB
TC commands
certificate destroy
Use certificate destroy to destroy a TCSM certificate.
In standalone mode:
certificate destroy name certificate-name slot slot-number
In IRF mode:
certificate destroy name certificate-name chassis chassis-number slot slot-number
TCSM view
name certificate-name: Specifies a TCSM certificate by its name, a case-insensitive string of 1 to 31 characters.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command is supported only on the default MDC.
A TCSM certificate can be destroyed only by an administrator or its creator. A system-defined TCSM certificate cannot be destroyed.
# (In standalone mode.) Destroy TCSM certificate cert-abc on a slot.
<Sysname> system
[Sysname] tcsm
[Sysname-tcsm] certificate destroy name cert-abc slot 1
display tcsm certificate list
display tcsm certificate name
certificate subject
Use certificate subject to create a TCSM certificate subject and enter the view of the TCSM certificate subject, or enter the view of an existing TCSM certificate subject.
Use undo certificate subject to delete a TCSM certificate subject.
certificate subject subject-name
undo certificate subject subject-name
No TCSM certificate subjects exist.
TCSM view
subject-name: Specifies the subject name, a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
The current software version supports only one TCSM certificate subject. To change the name of the created TCSM certificate subject, you must delete the subject and then re-create the subject by using the new name.
# Create TCSM certificate subject entry1 and enter its view.
[Sysname] tcsm
[Sysname-tcsm] certificate subject entry1
[Sysname-tcsm-cert-subject-entry1]
common-name
Use common-name to set the common name for a TCSM certificate subject.
Use undo common-name to restore the default.
common-name string
undo common-name
A TCSM certificate subject does not have a common name.
TCSM certificate subject view
string: Specifies the common name, a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
To use a TCSM certificate subject to sign a certificate, you must specify a common name for the subject.
# Set the common name to device for TCSM certificate subject entry1.
[Sysname] tcsm
[Sysname-tcsm-cert-subject-entry1] common-name device
country
Use country to set the country code for a TCSM certificate subject.
Use undo country to restore the default.
country string
undo country
A TCSM certificate subject does not have a country code.
string: Specifies a country code, case sensitive.
A country code is a standard two-character string. For example, CN is the country code for China, and US is the country code for the United States of America.
# Set the country code to CN for TCSM certificate subject entry1.
[Sysname] tcsm
[Sysname-tcsm-cert-subject-entry1] country CN
devid-additional-information
Use devid-additional-information to set the additional information for a DevID certificate subject.
Use undo devid-additional-information to restore the default.
devid-additional-information string
A DevID certificate subject does not have additional information.
string: Specifies the additional information, a case-sensitive string of 1 to 63 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
You can use this command to add additional information to a DevID certificate subject.
# Set the additional information to x00 for DevID certificate subject entry1.
[Sysname] tcsm
[Sysname-tcsm-cert-subject-entry1] devid-additional-information x00
Use display tcsm certificate list to display the TCSM certificate list.
In standalone mode:
display tcsm certificate list [ slot slot-number ]
In IRF mode:
display tcsm certificate list [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays TCSM certificates of all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays TCSM certificates of all cards. (In IRF mode.)
This command displays both system-defined TCSM certificates and user-defined TCSM certificate.
# (In standalone mode.) List the TCSM certificates on all slots.
<Sysname> display tcsm certificate list
Slot 1:
  System-defined certificates:
    default-rsa-akcert:  For attestation key
    default-ecc-akcert:  For attestation key
    rsa-idevid-cert:  For DevID
    ecc-idevid-cert:  For DevID
    default_rsa_ekcert:  For endorsement key
    default_ecc_ekcert:  For endorsement key
  User-defined certificates:
    test_ak_cert:  For attestation key
Use display tcsm certificate name to display detailed information about a TCSM certificate.
In standalone mode:
display tcsm certificate name certificate-name slot slot-number
In IRF mode:
display tcsm certificate name certificate-name chassis chassis-number slot slot-number
certificate-name: Specifies a TCSM certificate by its name, a case-insensitive string.
You can use this command to identify the validity of a TCSM certificate.
# (In standalone mode.) Display detailed information about a TCSM certificate on a slot.
<Sysname> display tcsm certificate name default_rsa_ekcert slot 1
Status:  Enabled
Key name:  default_rsa_ek
User name:
Usage:  EK
Certificate:
    Data:
        Version:  3 (0x2)
        Serial Number:
            89: 0e: cf: 1f: e2: 78: 10: 5d: 31: 80: 4f: e2: b8: c2: b1: 33: e9: 6b: 01: 9f
        Signature Algorithm:  ecdsa-with-SHA256
        Issuer:  C=CN, O=Nationz Technologies Inc, OU=Nationz TPM Device, CN=Nationz TPM Manufacturing CA 001
        Validity
            Not Before:  Jul 25 00: 00: 00 2018 GMT
            Not After :  Jul 25 00: 00: 00 2033 GMT
        Subject:
        Subject Public Key Info:
            Public Key Algorithm:  rsaEncryption
                Public-Key:  (2048 bit)
                Modulus:
                    00: c0: 22: ff: 61: e0: e2: e4: fe: cf: df: c0: 23: 32: 4b:
                    58: 7b: 25: b5: b3: da: 0c: cf: bc: ae: 81: 0c: 8f: 98: 32:
                    67: 43: 4a: 6b: 93: 68: a5: 1d: 59: 36: 65: 50: c0: d7: 61:
                    55: dc: 22: 6f: 17: da: f0: 9a: 97: 6a: 7b: a9: b0: e3: 1a:
                    58: 15: 18: 37: 1b: c5: 49: 7a: 30: f2: bc: 84: 1b: fb: 67:
                    77: ed: a4: 66: cc: df: 24: 3a: 83: a7: d6: b5: c7: 66: 61:
                    aa: f6: 41: 94: 99: 92: cf: a7: 2d: 85: 57: 88: 63: 13: bf:
                    b4: b1: 74: 23: a6: 77: 40: f7: ed: a8: 12: 92: d0: d9: 9d:
                    3d: b2: 33: f3: 55: 91: 7f: 89: 7c: 93: ce: 0c: 19: 23: 47:
                    59: ec: 08: 7b: 74: 27: 26: 4f: 43: 24: 3b: 1f: 51: 9d: 9f:
                    0e: 4f: 49: 18: 48: f6: d2: 0a: e9: 02: b9: 35: 93: 9a: 32:
                    af: 6a: e3: 47: d6: 95: aa: b6: 5d: 56: 01: c0: 13: db: 23:
                    c4: 60: 2a: 4b: 9a: c6: f3: b8: ae: a0: 6b: 49: 59: c5: bd:
                    d8: 9a: 61: 8d: 67: c7: 58: cd: 95: ca: 6e: ea: e6: 36: 8c:
                    e4: 29: 25: 86: d3: 21: c0: fb: 14: ba: 35: 47: 3e: 3f: bd:
                    c7: 94: 3f: 37: 7d: 83: 4f: d3: 62: 2b: 6a: db: 9a: 27: 11:
                    bd: 56: 0e: 97: bb: bc: 11: 09: e8: 0f: f6: df: c0: 8a: 2d:
                    39: ad
                Exponent:  65537 (0x10001)
        X509v3 extensions:
            Authority Information Access:
                CA Issuers - URI: http: //pki.nationz.com.cn/EkMfrCA001/EkMfrCA001.crt
            X509v3 CRL Distribution Points:
                Full Name:
                  URI: http: //pki.nationz.com.cn/EkMfrCA001/EkMfrCA001.crl
            X509v3 Authority Key Identifier:
                keyid: 02: 2C: BE: ED: 5D: 77: 06: 0F: 28: 33: E9: D5: 37: 6B: A8: BC: 30: 8C: D9: BA
            X509v3 Certificate Policies:
                Policy:  1.2.156.100001.1.5.1
            X509v3 Extended Key Usage:
                2.23.133.8.1
            X509v3 Subject Directory Attributes:
0...2.0.....t   0.0...g....1
            X509v3 Key Usage:  critical
                Key Encipherment
            X509v3 Subject Alternative Name:  critical
                DirName: /2.23.133.2.1=id: 4E545A00/2.23.133.2.2=Z32H330TC/2.23.133.2.3=id: 0726
            X509v3 Basic Constraints:  critical
                CA: FALSE
Status
TCSM certificate status:
Enabled—The certificate is active.
User name
Username entered when adding the device on the H3C TPMM.
Usage
Certificate usage:
·     AK—Attestation key.
·     DevID—Device ID.
·     EK—Endorsement key.
display tcsm key list
Use display tcsm key list to display the TCSM key list.
In standalone mode:
display tcsm key list [ endorsement | storage ] [ loaded ] [ ak | devid ] [ slot slot-number ]
In IRF mode:
display tcsm key list [ endorsement | storage ] [ loaded ] [ ak | devid ] [ chassis chassis-number slot slot-number ]
endorsement: Specifies TCSM keys in the endorsement hierarchy.
storage: Specifies TCSM keys in the storage hierarchy.
loaded: Specifies loaded TCSM keys. If you do not specify this keyword, the command displays both loaded and unloaded TCSM keys.
ak: Specifies TCSM keys used as AKs.
devid: Specifies TCSM keys used as DevID keys.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays TCSM keys of all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays TCSM keys of all cards. (In IRF mode.)
If you do not specify the endorsement keyword or storage keyword, this command displays TCSM keys in all hierarchies.
If you do not specify the ak keyword or devid keyword, this command displays TCSM keys used for all purposes, including EKs and ordinary keys.
# (In standalone mode.) List the TCSM keys on all slots.
<System> display tcsm key list
Slot 1:
  Endorsement hierarchy:
    default_rsa_ek:  Primary key
    default_ecc_ek:  Primary key
    default-rsa-sk:  Primary key
    default-ecc-sk:  Primary key
    rsa-idevid-key:  Primary key
    ecc-idevid-key:  Primary key
    default-rsa-ak:  Primary key
    default-ecc-ak:  Primary key
    test_ak:  Primary key
  Storage  hierarchy:
    test_ak10:  Primary key
display tcsm key name
Use display tcsm key name to display detailed information about a TCSM key.
In standalone mode:
display tcsm key name key-name slot slot-number
In IRF mode:
display tcsm key name key-name chassis chassis-number slot slot-number
key-name: Specifies the name of an existing key, a case-insensitive string.
You can use this command to display the attributes of a key and the certificate signed for the key.
# (In standalone mode.) Display detailed information about TCSM key default-rsa-ak on a slot.
<System> display tcsm key name default-rsa-ak slot 1
Key name:  default-rsa-ak
Certificate name:  default-rsa-akcert
Usage:  AK
Parent key name:  N/A
Hierarchy:  endorsement
User name:  xcf
Status:  Loaded/Enabled
Type:  RSA
Name algorithm:  SHA256
Key attribute:  fixedTPM, fixedParent, restricted, sign
RSA parameters:
  Scheme:  RSASSA
  Digest algorithm:  SHA256
  KeyBits:  2048
  Exponent:  65537
  Modulus:  b0 5b 80 78 29 1c 2c 18 2c e0 5e 81 e5 d4 dc 94
           27 b0 d6 24 ea 55 87 55 5e f1 e0 dc ce c1 64 7a
           69 a6 58 11 ef 8d ac 1f 21 d1 b5 cd a8 34 9f a7
           67 5a c9 df 57 b0 08 43 49 d3 c3 88 46 a9 31 e6
           35 15 bf 43 4e c2 f3 ca c5 24 6b 32 c3 cf 0f 40
           f3 ab c7 10 cd 27 f6 7b ac d7 93 c6 b7 36 22 64
           c0 fb 5f a0 ed a4 76 ed 53 d0 55 87 fa 0e e3 c0
           7a 09 e0 39 49 32 7d 46 89 84 e4 00 67 c0 1e b9
           72 7c 10 bb cd f5 5b bc 45 fd 0f ae 3c cb 23 50
           e0 14 0f bf 5e b2 09 19 92 23 00 9c 3d fb 13 ad
           a5 f7 e3 3b f2 3d 6c 48 63 f2 0e f9 77 10 5a 34
           70 f8 27 52 17 83 18 b7 96 a9 70 5f b7 99 48 f7
           c0 69 e1 cd 8b 6d 4d d2 34 9d a7 a7 f8 94 33 c3
           23 0c ea 3a 40 82 d8 52 53 fc 42 57 c4 3c 1d e6
           35 f3 ee bf 19 2d 7d d8 2e 1a e3 aa de 9c a3 99
           5c 89 fb b7 90 39 78 28 50 e3 15 10 e1 80 89 57
Certificate name
Name of the certificate signed for the key.
If no certificate is signed for the key, this field displays N/A.
Usage
Key usage:
·     DevID—Device ID.
·     General—Ordinary key.
Parent key name
Name of the parent key.
If the key does not have a parent key, this field displays N/A.
User name
Status
Key status:
·     Loaded—The key is loaded.
·     Unloaded—The key is not loaded.
·     Enabled—The key is enabled.
·     Disabled—The key is disabled.
Scheme
Scheme for encryption or signing.
If no scheme is specified, this field displays Null.
display tcsm key-template
Use display tcsm key-template to display TCSM key template information.
display tcsm key-template [ { preset | user } template-name ]
preset: Specifies a system-defined key template.
user: Specifies a user-defined key template, which is a global key template received from the manager.
template-name: Specifies the name of an existing TCSM key template on the device, a case-insensitive string.
If you do not specify an option, this command displays summary information about all TCSM key templates.
# Display summary information about all TCSM key templates.
<System> display tcsm key-template
System-defined key template files:
    default-rsa-sk:  rsa storage key
    default-rsa-devid:  rsa signature key
    default-rsa-ak:  rsa attestation key
    default-ecc-sk:  ecc storage key
    default-ecc-devid:  ecc signature key
    default-ecc-ak:  ecc attestation key
User-defined key template files:
  Directory:  /mnt/flash: /safeinfo/template/
    template22:  this key template may be used to create aka storage key
# Display detailed information about system-defined TCSM key template default-rsa-ak.
<System> display tcsm key-template preset default-rsa-ak
Version:  1.0.0
Description:  rsa attestation key
Type:  RSA
RSA parameters:
  Scheme:  RSASSA
  Exponent:  65537
  KeyBits:  2048
Key attribute
Key attributes:
·     fixedParent and fixedTPM—Duplication attributes.
¡     If both attributes are present, the key is protected by the parent key and can be used only in the TPM. The key cannot be duplicated.
¡     If both attributes are absent, the key and its child keys can be duplicated.
¡     If only fixedParent is present, the key can be duplicated together with its parent key but cannot be duplicated separately.
·     decrypt—The key can be used for encryption and decryption. A storage key must have this attribute.
·     sign—The key can be used for signing and signature authentication. An AK or DevID key must have this attribute.
·     restricted—The function of the key is restricted. For example, only data generated by a TPM can be used for signing. AKs and storage keys must have this attribute.
Symmetric mode
Symmetric encryption mode:
·     CFB—Cipher feedback mode.
·     CBC—Cipher block chaining mode.
·     CTR—Counter mode.
·     OFB—Output feedback mode.
·     ECB—Electronic codebook mode.
display tcsm pcr
Use display tcsm pcr to display PCR values.
In standalone mode:
display tcsm pcr [ algorithm algorithm ] [ index index ] [ slot slot-number ]
In IRF mode:
display tcsm pcr [ algorithm algorithm ] [ index index ] [ chassis chassis-number slot slot-number ]
algorithm algorithm: Specifies a hash algorithm, a case insensitive string. To view the available hash algorithms, execute the display tcsm trusted-computing-chip command and view the value of the Active PCR bank field. If you do not specify this option, the command displays the PCR values of all hash algorithms.
index index: Specifies a PCR index value, in the range of 0 to 23. If you do not specify this option, the command displays the PCR values of all index values.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the PCR values on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the PCR values on all cards. (In IRF mode.)
If you do not specify an option, this command displays PCR values of all hash algorithms and all index values.
# (In standalone mode.) Display all PCR values on the TC chip in a slot.
<Sysname> display tcsm pcr slot 1
  PCR information:
    SHA1 (index  0):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SHA1 (index  1):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SHA1 (index  2):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SHA1 (index 23):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SHA256 (index  0):  a8 c0 ee a2 32 27 73 bb 92 7d f2 b2 95 c0 7c de 8a 0c 9d 9a 11 cf 56 1d 07 68 98 ac ea a0 ff 28
    SHA256 (index  1):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SHA256 (index  2):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    SHA256 (index 23):  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
# (In standalone mode.) Display the values of the PCR with an index value of 0 on all TC chips.
<Sysname> display tcsm pcr index 0
Slot 1:
  PCR information:
algorithm (index pcr-index): value
algorithm: Hash algorithm of the PCR.
pcr-index: Index value of the PCR.
value: PCR values.
Use display tcsm trusted-computing-chip to display TC chip information.
In standalone mode:
display tcsm trusted-computing-chip [ slot slot-number ]
In IRF mode:
display tcsm trusted-computing-chip [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays information about TC chips on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays information about TC chips on all cards. (In IRF mode.)
This command displays TC chip information only on devices that have TC chips.
# (In standalone mode.) Display information about the TC chip on a slot.
<Sysname> display tcsm trusted-computing-chip slot 1
Chip information:
    Specifications version:      Family: 2.0 Level: 00 Revision: 01.16
    Firmware version:            7.26
    Current mode:                TPM2.0
    Supported modes:             TPM2.0 TCM
    Supported algorithms:        RSA, SHA1, HMAC, AES, MGF1, KEYEDHASH, XOR,
                                SHA256, RSASSA, RSAES, RSAPSS, OAEP, ECDSA,
                                ECDH, ECDAA, ECSCHNORR, KDF1-SP800-56A,
                                KDF1-SP800-108, ECC, SYMCIPHER, CBC, CFB,
                                ECB
    Available PCR bank:          SHA1, SHA256
    Owner state:                 No
Chip configuration:
    Chip status:                 Enabled
    Active PCR bank:             SHA1, SHA256
    Measurement algorithm:       SHA256
    Endorsement hierarchy:       Enabled
    Storage hierarchy:           Enabled
    Clear operation:             Disabled
Table 5 Command output
Available PCR bank
Available PCR banks.
All PCRs that use the same hash algorithm form a PCR bank.
Owner state
Whether the chip has an owner.
This field is not supported in the current software version. Its value is fixed at No.
Chip status
Status of the chip, Enabled or Disabled.
Active PCR bank
Active PCR banks.
Status of the endorsement hierarchy, Enabled or Disabled.
Storage hierarchy
Status of the storage hierarchy, Enabled or Disabled.
Clear operation
Status of the clear operation:
·     Enabled—You can perform a clear operation.
·     Disabled—You cannot perform a clear operation.
key create
Use key create to create a TCSM key.
In standalone mode:
key create name key-name [ authorization authorization-string ] { endorsement | storage | parent-key parent-name [ parent-authorization parent-authorization ] } { preset-template | user-template } template-name [ ak | devid ] slot slot-number
In IRF mode:
key create name key-name [ authorization authorization-string ] { endorsement | storage | parent-key parent-name [ parent-authorization parent-authorization ] } { preset-template | user-template } template-name [ ak | devid ] chassis chassis-number slot slot-number
TCSM view
name key-name: Specifies a key name, a case-insensitive string of 1 to 31 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), commas (,), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
authorization authorization-string: Specifies the key authorization data, a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), commas (,), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`). If you do not specify this option, the key authorization data is null.
endorsement: Uses the key as a primary key of the endorsement hierarchy.
storage: Uses the key as a primary key of the storage hierarchy.
parent-key parent-name: Specifies the parent key for the key. The parent key must already exist. The parent key name is case insensitive.
parent-authorization parent-authorization: Specifies the key authorization data of the parent, a case-sensitive string. If the parent key authorization data is null, do not specify this option.
preset-template template-name: Specifies the system-defined key template to be used to create the key. The template name is a case-insensitive string of 1 to 31 characters.
user-template template-name: Specifies the user-defined key template to be used to create the key. The template name is a case-insensitive string of 1 to 31 characters.
ak: Uses the key as the AK.
devid: Uses the key as the DevID key.
If you do not specify the ak keyword or devid keyword, the command creates an ordinary key.
A primary key can have a maximum of four levels of child keys.
Before creating a child key, make sure you have use the key load command to load the parent key to the TC chip.
# (In standalone mode.) Use system-defined key template default-rsa-ak to create a primary AK named pk1 for the endorsement hierarchy. Set the key authorization data to pk1.
[Sysname] tcsm
[System-tcsm] key create name pk1 authorization pk1 endorsement preset-template default-rsa-ak ak slot 1
key destroy
key load
key destroy
Use key destroy to destroy a TCSM key.
In standalone mode:
key destroy name key-name slot slot-number
In IRF mode:
key destroy name key-name chassis chassis-number slot slot-number
TCSM view
name key-name: Specifies the name of an existing key, a case-insensitive string.
You can destroy a key successfully only if the following conditions are met:
·     You are an administrator or the key creator.
·     The key is not loaded to the TC chip.
To unload a key, use the undo key load command.
·     The key does not have a child key.
If the key has a child key, you must destroy the child key first.
To identify whether the key has child keys, use the display tcsm key list command.
# (In standalone mode.) Destroy key pKey of a slot.
[Sysname] tcsm
[System-tcsm] key destroy name pKey slot 1
key create
key load
key load
Use key load to load a TCSM key to the TC chip.
Use undo key load to unload a TCSM key from the TC chip.
In standalone mode:
key load name key-name [ parent-authorization { cipher | simple } parent-authorization ] slot slot-number
undo key load name key-name slot slot-number
In IRF mode:
key load name key-name [ parent-authorization { cipher | simple } parent-authorization ] chassis chassis-number slot slot-number
undo key load name key-name chassis chassis-number slot slot-number
Created TCSM keys are not loaded to the TC chip.
TCSM view
parent-authorization: Specifies the parent key authorization data. If the parent key authorization data is null, do not specify this keyword. This keyword is not supported if you are loading a primary key.
cipher: Specifies the parent key authorization data in encrypted form.
simple: Specifies the parent key authorization data in plaintext form. For security purposes, the data specified in plaintext form will be stored in encrypted form.
parent-authorization: Specifies the parent key authorization data. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
You can load only a TCSM key that is created by using the key create command. If the key has a parent key, you must load the parent key first.
To unload a TCSM key that has child keys, you must unload all the child keys first.
# (In standalone mode.) Load key default_rsa_ek to the TC chip in a slot.
[Sysname] tcsm
[System-tcsm] key load name default_rsa_ek slot 1
key create
organization
Use organization to set the organization name for a TCSM certificate subject.
Use undo organization to restore the default.
organization string
undo organization
A TCSM certificate subject does not have an organization name.
string: Specifies the organization name, a case-sensitive string of 1 to 63 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
Setting the organization name helps you identify the organization to which a TCSM subject certificate belongs.
# Set the organization name to abc for TCSM certificate subject entry1.
[Sysname] tcsm
[Sysname-tcsm-cert-subject-entry1] organization abc
organization-unit
Use organization-unit to set the organization unit name for a TCSM certificate subject.
Use undo organization-unit to restore the default.
organization-unit string
A TCSM certificate subject does not have an organization unit name.
string: Specifies the organization unit name, a case-sensitive string of 1 to 63 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
This command enables units in the same organization to have their respective TCSM certificate subjects.
# Set the organization unit name to rd for TCSM certificate subject entry1.
[Sysname] tcsm
[Sysname-tcsm-cert-subject-entry1] organization-unit rd
state
Use state to set the state or province name for a TCSM certificate subject.
Use undo state to restore the default.
state string
undo state
A TCSM certificate subject does not have a state or province name.
string: Specifies the state or province name, a case-sensitive string of 1 to 63 characters. Valid characters include letters, digits, and the following special characters: underscores (_), hyphens (-), at signs (@), pound signs (#), percent signs (%), dollar signs ($), plus signs (+), dots (.), left parenthesis, right parenthesis, ampersand signs (&), left braces ({), right braces (}) colons (:), semicolons (;), exclamation points (!), equal signs (=), tilde signs (~), and apostrophes (`).
Setting the state or province name helps you identify the state or province to which a TCSM subject certificate belongs.
# Set the state or province name to StateA for TCSM certificate subject entry1.
[Sysname] tcsm
[Sysname-tcsm-cert-subject-entry1] state StateA
tcsm
Use tcsm to enter TCSM view.
Use undo tcsm to delete all settings in TCSM view.
tcsm
undo tcsm
In TCSM view, you can manage TCSM keys, TCSM certificates, and TC chips.
# Enter TCSM view.
[Sysname] tcsm
[System-tcsm]
PTS commands
display pts integrity measurement-log
Use display pts integrity measurement-log to display IML information.
In standalone mode:
display pts integrity measurement-log [ bootware | runtime | package ] [ slot slot-number ]
In IRF mode:
display pts integrity measurement-log [ bootware | runtime | package ] [ chassis chassis-number slot slot-number ]
bootware: Displays the BootWare IMLs.
runtime: Displays the runtime IML.
package: Displays the Comware image IML.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays IML information about all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays IML information about all cards. (In IRF mode.)
This command displays IML information only on devices that have TC chips and have the PTS service enabled.
If you do not specify the bootware, runtime, or package keyword, this command display information about all types of IMLs.
# (In standalone mode.) Display information about all types of IMLs on slot 1.
<Sysname> display pts integrity measurement-log slot 1
BootWare:
Total IMLs:  9
  Object file:  !/Bootware/Basic/Version
  RM file:  BOOTWARE_BASIC_2F00.rm
  Measurement time (seconds.nanoseconds):  12.32000000
  PCR index:  0
  Template hash algorithm:  SHA256
  Template hash value:  927908c6a5e93d221afa93d7f936631166addcabf48f7b0719bcefde2b691695
  File hash algorithm:  SHA256
  File hash value:  1e80e1e3912c9d30fb9db697be3f2fe5128fccc97672412556868cef723f8813
  Object file:  !/Bootware/Basic/Code
  Measurement time (seconds.nanoseconds):  12.42000000
  PCR index:  0
  Template hash value:  06c89f99da10c12864ab23ecd0a8760a5a87092d969ed7ebfab8b81b3eb0db4f
  File hash value:  847d6e8b9ce157d7a3569b1bbd473ecdb4c52b6dcf5926d2fa94282c107c9fac
Table 6 Command output
BootWare
BootWare IMLs.
Runtime
Runtime IMLs.
Package
Comware image IMLs.
Object file
File that is measured.
RM file
Name of the file that contains the integrity measurement reference hash values.
PCR index
PCR index, 0, 4, 8, 10, or 12.
pts
display pts integrity selfverify
Use display pts integrity selfverify to display integrity self-verification information.
In standalone mode:
display pts integrity selfverify [ slot slot-number ]
In IRF mode:
display pts integrity selfverify [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays integrity self-verification information about all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On an IRF fabric, this command displays integrity self-verification information about all member devices if you do not specify a member device. On an IRF 3 system, this command displays integrity self-verification information about all IRF member devices and PEXs if you do not specify an IRF member device or PEX. (In IRF mode.)
This command displays integrity self-verification information only on devices that have TC chips and have the PTS service enabled.
If periodic integrity self-verification is enabled, this command displays information only about the most recent integrity self-verification.
# (In standalone mode.) Display integrity self-verification information.
<Sysname> display pts integrity selfverify
Slot 1:
  Latest self-verification:  2019-07-01 10: 55: 16
  Integrity self-verification passed.
Table 7 Command output
Time when the most recent integrity self-verification is performed.
If no integrity self-verifications have been performed, this field displays a hyphen (-).
Object file hash value in IML is different from that in RM file.
The hash value of a file in the IML is different from the integrity measurement reference hash value of the file.
Object file hash value in RM file
Integrity measurement reference hash value.
TPM PCR
Hash values stored in the PCRs of the TPM.
Calculated PCR
Hash values calculated by the PTS process.
integrity periodic-selfverify enable
Use integrity periodic-selfverify enable to enable periodic integrity self-verification.
Use undo integrity periodic-selfverify enable to disable periodic integrity self-verification.
Periodic integrity self-verification is disabled.
PTS view
Integrity self-verification is supported only on devices that have TC chips.
When you enable periodic integrity self-verification, the device immediately performs an integrity self-verification. Then, the device performs integrity self-verifications at intervals.
# Enable periodic integrity self-verification.
[Sysname] pts
[Sysname-pts] integrity periodic-selfverify enable
integrity periodic-selfverify interval
Use integrity periodic-selfverify interval to set the integrity self-verification interval.
Use undo integrity periodic-selfverify interval to restore the default.
integrity periodic-selfverify interval interval
The integrity self-verification interval is 7 days.
PTS view
interval: Specifies the integrity self-verification interval in days. The value range is 1 to 30.
The integrity periodic-selfverify enable command starts the integrity self-verification timer. If the specified integrity self-verification interval is equal to or shorter than the time that has elapsed, the device immediately performs an integrity self-verification.
# Set the integrity self-verification interval to 15 days.
[Sysname] pts
[Sysname-pts] integrity periodic-selfverify interval 15
integrity report attestation-key
Use integrity report attestation-key to specify the AK for integrity reporting.
Use undo integrity report attestation-key to restore the default.
In standalone mode:
integrity report attestation-key key-name [ authorization { cipher | simple } authorization-string ] slot slot-number
In IRF mode:
integrity report attestation-key key-name [ authorization { cipher | simple } authorization-string ] chassis chassis-number slot slot-number
No AK is specified for integrity reporting.
PTS view
key-name: Specifies the name of an existing AK, a case-insensitive string of 1 to 31 characters.
authorization: Specifies the key authorization data. If the key authorization data is null, do not specify this keyword.
cipher: Specifies the key authorization data in encrypted form.
simple: Specifies the key authorization data in plaintext form. For security purposes, the data specified in plaintext form will be stored in encrypted form.
authorization-string: Specifies the authorization data. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
The key authorization data specified for this command must be the same as the key authorization data used to create the AK.
The specified key must meet the following requirements:
·     It already exists and is an AK.
You can create a key by using the key create command.
·     It is already loaded to the TC chip.
You can load a key to a TC chip by using the key load command.
·     It is used by a certificate.
You can verify whether a key is used by a certificate by using the display tcsm key name command.
# (In standalone mode.) Specify key h3c.dat as the AK for integrity reporting on slot 1 and specify the key authorization data in plaintext form.
[Sysname] pts
[Sysname-pts] integrity report attestation-key h3c.dat authorization simple 123456 slot 1
key create
key load
Use integrity selfverify to perform an integrity self-verification.
In standalone mode:
In IRF mode:
PTS view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command performs integrity self-verification on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command performs integrity self-verification on all cards. (In IRF mode.)
# Perform an integrity self-verification.
[Sysname] pts
[Sysname-pts] integrity selfverify
pts
Use pts to enable the PTS service and enter PTS view.
Use undo pts to disable the PTS service and delete all settings in PTS view.
pts
undo pts
The PTS service is disabled.
After you enable the PTS service on the device, the device can provide IMLs and integrity measurement reference hash values for the manager.
# Enable the PTS service and enter PTS view.
<Sysname> system
[Sysname] pts
[Sysname-pts]
