11-Security Command Reference
HomeSupportSwitchesH3C S10500X Switch SeriesReference GuidesCommand ReferencesH3C S10500X Switch Series Command References-Release7634Pxx-6W10011-Security Command Reference
17-ND attack defense commands
17-ND attack defense commands 140.32 KB
Source MAC consistency check commands
ipv6 nd check log enable
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
ipv6 nd mac-check enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND messages.
Use undo ipv6 nd mac-check enable to disable source MAC consistency check for ND messages.
Source MAC consistency check for ND messages is disabled.
Use this command to enable source MAC consistency check on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND message. If an inconsistency is found, the gateway drops the ND message.
# Enable source MAC consistency check for ND messages.
[Sysname] ipv6 nd mac-check enable
ND attack detection commands
display ipv6 nd detection statistics
Use display ipv6 nd detection statistics to display statistics for ND messages dropped by ND attack detection.
display ipv6 nd detection statistics [ interface interface-type interface-number [ service-instance instance-id ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for ND messages dropped by ND attack detection on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays statistics in all Ethernet service instances on the specified interface.
# Display statistics for all ND messages dropped by ND attack detection.
<Sysname> display ipv6 nd detection statistics
ND packets dropped by ND detection:
Interface/AC           Packets dropped
XGE1/0/1              78
XGE1/0/2              0
XGE1/0/3              0
XGE1/0/4              0
XGE1/0/5-srv1        0
XGE1/0/5-srv2        10
Interface/AC
Input interface or AC link of the ND messages.
Packets dropped
Number of ND messages dropped by ND attack detection.
ipv6 nd detection enable
Use ipv6 nd detection enable to enable ND attack detection. This feature checks the ND message validity.
Use undo ipv6 nd detection enable to disable ND attack detection.
ND attack detection is disabled.
VLAN view
VSI view
You cannot enable ND attack detection on the interface that has been configured as an ND trusted interface.
# Enable ND attack detection for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] ipv6 nd detection enable
# Enable ND attack detection for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd detection enable
ipv6 nd detection log enable
Use ipv6 nd detection log enable to enable ND attack detection logging.
Use undo ipv6 nd detection log enable to disable ND attack detection logging.
ND attack detection logging is disabled.
This command allows a device to generate logs when it detects ND attacks. The log information helps administrators locate and solve problems. The ND attack detection logging feature sends the log message to the information center. The information center can then output log messages from different source modules to different destinations. For more information about information center, see Network Management and Monitoring Configuration Guide.
The device performance is degraded when the device outputs a large number of ND attack detection logs. You can disable ND attack detection logging to ensure the device performance.
# Enable ND attack detection logging.
[Sysname] ipv6 nd detection log enable
ipv6 nd detection port-match-ignore
Use ipv6 nd detection port-match-ignore to ignore ingress ports of ND packets in ND attack detection.
Use undo ipv6 nd detection port-match-ignore to remove the configuration.
Ingress ports of ND packets are examined in ND attack detection.
This command configures ND attack detection to ignore the ingress port information of ND packets when the packets are compared with the entries in ND attack detection.
# Ignore ingress ports of ND packets in ND attack detection.
[Sysname] ipv6 nd detection port-match-ignore
ipv6 nd detection trust
Use ipv6 nd detection trust to configure an interface as an ND trusted interface.
Use undo ipv6 nd detection trust to restore the default.
All interfaces are ND untrusted interfaces. All ACs are ND untrusted ACs.
Ethernet service instance view (AC)
You cannot configure the interface that has been enabled with ND attack detection as an ND trusted interface.
# Configure Ten-GigabitEthernet 1/0/1 as an ND trusted interface.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 nd detection trust
# Configure Bridge-Aggregation 1 as an ND trusted interface.
[Sysname-Bridge-Aggregation1] ipv6 nd detection trust
# Configure Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1 as an ND trusted AC.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] ipv6 nd detection trust
reset ipv6 nd detection statistics
Use reset ipv6 nd detection statistics to clear ND attack detection statistics.
reset ipv6 nd detection statistics [ interface interface-type interface-number [ service-instance instance-id ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ND attack detection statistics for all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command clears ND attack detection statistics in all Ethernet service instances on the specified interface.
# Clear all ND attack detection statistics.
<Sysname> reset ipv6 nd detection statistics
RA guard commands
display ipv6 nd raguard policy
Use display ipv6 nd raguard policy to display the RA guard policy configuration.
display ipv6 nd raguard policy [ policy-name ]
policy-name: Specifies an RA guard policy by its name. The policy name is a case-sensitive string of 1 to 31 characters. If you do not specify a policy, this command displays the configuration of all RA guard policies.
When you specify an ACL, follow these restrictions and guidelines:
·     If the ACL does not exist or does not contain a rule, this command displays the RA guard policy configuration for all ACL rules.
·     If you specify the vpn-instance keyword for an ACL rule, the rule takes effect only on VPN packets. If you do not specify the vpn-instance keyword for an ACL rule, the rule takes effect only on public network packets.
# Display the configuration of all RA guard policies.
<Sysname> display ipv6 nd raguard policy
Total number of policies: 2
RA Guard policy: policy1
  if-match ACL 2001
  if-match autoconfig managed-address-flag on
  if-match autoconfig other-flag off
  if-match hop-limit maximum 128
  if-match hop-limit minimum 100
  if-match prefix ACL name aa
  if-match router-preference medium
  applied to VLAN 1-3 7
RA Guard policy: policy2
  if-match ACL name zdd
  if-match prefix ACL 2200
RA Guard policy
Name of the RA guard policy.
if-match ACL
Number of the ACL in the ACL match criterion.
if-match ACL name
Name of the ACL in ACL match criterion.
Match criterion of the advertised M flag:
·     on—The value of the advertised M flag is 1.
·     off—The value of the advertised M flag is 0.
Match criterion of the advertised O flag:
·     on—The value of the advertised O flag is 1.
·     off—The value of the advertised O flag is 0.
The maximum advertised hop limit match criterion.
The minimum advertised hop limit match criterion.
if-match prefix ACL
Number of the ACL used to identify the prefix match criterion.
Name of the ACL used to identify the prefix match criterion.
applied to VLAN
ID of the VLAN to which the RA guard policy is applied.
display ipv6 nd raguard statistics
Use display ipv6 nd raguard statistics to display RA guard statistics.
display ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays RA guard statistics for all interfaces.
# Display RA guard statistics.
<Sysname> display ipv6 nd raguard statistics
RA messages dropped by RA guard:
Interface     Dropped
XGE1/0/1      78
XGE1/0/2      0
XGE1/0/3      32
XGE1/0/4      0
Interface that received the dropped RA messages.
Dropped
Number of RA messages dropped on the interface.
ipv6 nd raguard log enable
reset ipv6 nd raguard statistics
if-match acl
Use if-match acl to specify an ACL match criterion.
Use undo if-match acl to delete the ACL match criterion.
undo if-match acl
No ACL match criterion exists.
RA guard policy view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999.
name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with an English letter. To avoid confusion, the name cannot be all.
RA guard uses the ACL match criterion to match the IP address of the RA message sender. If the sender IP address matches a permit rule, the message passes the check.
·     If the ACL does not exist or does not contain a rule, the ACL match criterion does not take effect.
# Use IPv6 basic ACL 2001 as the ACL match criterion for the RA guard policy policy1.
[Sysname] ipv6 nd raguard policy policy1
[Sysname-raguard-policy-policy1] if-match acl 2001
Use if-match autoconfig managed-address-flag to specify an M flag match criterion.
Use undo if-match autoconfig managed-address-flag to delete the M flag match criterion.
if-match autoconfig managed-address-flag { off | on }
No M flag match criterion exists.
off: Specifies the advertised M flag as 0
on: Specifies the advertised M flag as 1.
The M flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain an IPv6 address.
·     If the M flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
·     If the M flag is set to 0, the host uses stateless autoconfiguration. In stateless autoconfiguration, the host generates an IPv6 address according to its link-layer address and the prefix information in the RA message.
# Specify on as the M flag match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match autoconfig managed-address-flag on
Use if-match autoconfig other-flag to specify an O flag match criterion.
Use undo if-match autoconfig other-flag to delete the O flag match criterion.
if-match autoconfig other-flag { off | on }
No O flag match criterion exists.
off: Specifies the advertised O flag as 0.
on: Specifies the advertised O flag as 1.
The O flag in an RA message determines whether a receiving host uses stateful autoconfiguration to obtain configuration information other than IPv6 address.
·     If the O flag is set to 1, the host uses stateful autoconfiguration, for example, uses a DHCPv6 server.
·     If the O flag is set to 0, the host uses stateless autoconfiguration.
# Specify on as the O flag match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match autoconfig other-flag on
if-match hop-limit
Use if-match hop-limit to specify a maximum or minimum hop limit match criterion.
Use undo if-match hop-limit to delete the maximum or minimum hop limit match criterion.
if-match hop-limit { maximum | minimum } limit
undo if-match hop-limit { maximum | minimum }
No maximum or minimum hop limit match criterion exists.
maximum: Specifies the maximum advertised hop limit. An RA message passes the check if its current hop limit is not higher than the maximum advertised hop limit.
minimum: Specifies the minimum advertised hop limit. An RA message passes the check if its current hop limit is not less than the minimum advertised hop limit.
limit: Specifies the advertised hop limit in the range of 1 to 255.
If a hop limit match criterion is set, and the RA message's current hop limit is 0, the message will be dropped.
# Set the maximum hop limit match criterion to 128 for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match hop-limit maximum 128
if-match prefix
Use if-match prefix to specify a prefix match criterion.
Use undo if-match prefix to delete the prefix match criterion.
if-match prefix acl { ipv6-acl-number | name ipv6-acl-name }
undo if-match prefix acl
No prefix match criterion exists.
An RA message passes the check if the advertised prefixes in the message match the prefixes set by the ACL.
·     If the ACL does not exist or does not contain a rule, the prefix match criterion does not take effect.
# Use IPv6 basic ACL 2000 as the prefix match criterion for the RA guard policy policy1.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 1001:: 64
[Sysname-acl-ipv6-basic-2000] rule permit source 3124:1123:: 64
[Sysname-acl-ipv6-basic-2000] rule deny source any
[Sysname-raguard-policy-policy1] if-match prefix acl 2000
Use if-match router-preference maximum to specify a router preference match criterion.
Use undo if-match router-preference maximum to delete the router preference match criterion.
if-match router-preference maximum { high | low | medium }
No router preference match criterion exists.
high: Sets the maximum router preference to high. An RA message passes the check if its router preference is not higher than high.
low: Sets the maximum router preference to low. An RA message passes the check if its router preference is not higher than low.
medium: Sets the maximum router preference to medium. An RA message passes the check if its router preference is not higher than medium.
A host selects a router as the default gateway according to the router preference in received RA messages. If router preferences are the same, the host selects the default router from which the first RA message is received.
An RA message will not pass the router preference check if the message does not have a preference value. This RA message will be dropped.
# Specify medium as the router preference match criterion for the RA guard policy policy1.
[Sysname-raguard-policy-policy1] if-match router-preference maximum medium
ipv6 nd raguard apply policy
Use ipv6 nd raguard apply policy to apply an RA guard policy to a VLAN.
Use undo ipv6 nd raguard apply policy to remove the RA guard policy from a VLAN.
ipv6 nd raguard apply policy [ policy-name ]
No RA guard policy is applied to a VLAN.
VLAN view
policy-name: Specifies an RA guard policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a policy, RA guard blocks RA messages on all interfaces in the VLAN except interfaces that are defined to be connected to routers.
If an RA message has multiple VLAN tags, RA guard uses the outermost VLAN tag to select the applied RA guard policy.
If the specified RA guard policy does not exist, the command does not take effect.
# Apply the RA guard policy policy1 to VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100] ipv6 nd raguard apply policy policy1
Use ipv6 nd raguard log enable to enable the RA guard logging feature.
Use undo ipv6 nd raguard log enable to disable the RA guard logging feature.
The RA guard logging feature is disabled.
This command allows a device to generate logs when it detects forged RA messages. The log information helps administrators locate and solve problems. Each log records the following information:
·     Name of the interface that received the forged RA message.
·     Source IP address of the forged RA message.
·     Number of RA messages dropped on the interface.
The RA guard logging feature sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable the RA guard logging feature.
[Sysname] ipv6 nd raguard log enable
Use ipv6 nd raguard policy to create an RA guard policy and enter its view, or enter the view of an existing RA guard policy.
Use undo ipv6 nd raguard policy to delete an RA guard policy.
ipv6 nd raguard policy policy-name
undo ipv6 nd raguard policy policy-name
No RA guard policies exist.
policy-name: Assigns a name to the RA guard policy. The name is a case-sensitive string of 1 to 31 characters.
# Create RA guard policy policy1 and enter its view.
ipv6 nd raguard role
Use ipv6 nd raguard role to specify the role of the device attached to the interface.
Use undo ipv6 nd raguard role to remove the role of the device attached to the interface.
ipv6 nd raguard role { host | router }
No role is specified for the device attached to the interface.
host: Specifies the host role. The interface attached to a host drops all received RA messages.
router: Specifies the router role. The interface attached to a router forwards all received RA messages.
Make sure your setting is consistent with the device type. If you are not aware of the attached device type, do not specify a role for the device.
# Specify host as the role for the device attached to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 nd raguard role host
Use reset ipv6 nd raguard statistics to clear RA guard statistics.
reset ipv6 nd raguard statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears RA guard statistics for all interfaces.
# Clear RA guard statistics.
<Sysname> reset ipv6 nd raguard statistics
ND keepalive entry scanning commands
display ipv6 nd scan keepalive entry
Use display ipv6 nd scan keepalive entry to display ND keepalive entries.
display ipv6 nd scan keepalive entry [ interface interface-type interface-number ] [ count ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ND keepalive entries for all interfaces.
count: Displays the total number of ND keepalive entries.
<Sysname> display ipv6 nd scan keepalive entry
IfIndex: 1281                     Slot: 1
IPv6 address: 1::23              MAC address: 08-00-27-00-50-38
VLANID: 1                          SECVLANID: 1
Port index: 1                     VRF index: 0
Scan status: 1                    Probe Cnt: 10
ND scan time: 08:01:01
IfIndex
Index of the interface.
IPv6 address
IPv6 address in the ND keepalive entry.
MAC address
MAC address in the ND keepalive entry.
VLANID
ID of the primary VLAN.
SECVLANID
ID of the secondary VLAN.
Port index
Number of the port.
VRF index
Index of the VRF.
Scan status
Status of the ND keepalive entry:
·     0—Offline.
·     1—Online.
Probe Cnt
Number of scans on the ND keepalive entry.
ND scan time
Time when the ND keepalive entry became offline, in hh:mm:ss format.
·     hh—Represents the hours.
·     mm—Represents the minutes.
·     ss—Represents the seconds.
display ipv6 nd scan keepalive statistics
Use display ipv6 nd scan keepalive statistics to display statistics about ND keepalive entry scanning.
In standalone mode:
display ipv6 nd scan keepalive statistics [ slot slot-number ] [ interface interface-type interface-number ]
In IRF mode:
display ipv6 nd scan keepalive statistics [ chassis chassis-number slot slot-number ] [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics about ND keepalive entry scanning for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays statistics about ND keepalive entry scanning on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays statistics about ND keepalive entry scanning on all cards. (In IRF mode.)
Interfaces enabled with ND keepalive entry scanning send NS packets to the IPv6 addresses in offline ND keepalive entries until the entries restore online state. This command displays the number of the NS packets sent to the IPv6 addresses in the offline keepalive entries in the last five seconds, one minute, and five minutes.
A great many NS packets indicate that the number of offline keepalive entries is great or some offline entries remain in offline state for a long time. The reasons and solutions are as follows:
1.     Use the display ipv6 nd scan keepalive entry command to identify the number of offline keepalive entries.
2.     If the number of offline keepalive entries is large, check the aging time set for offline keepalive entries. Shorten the aging time if it is too long.
3.     If the aging time is proper, the problem might be caused by too many abnormal user offline events. In this case, check the network configuration and condition.
4.     If the number of offline keepalive entries is not large, the problem might be because some offline keepalive entries cannot restore online state through NS packets. In this case, troubleshoot according to the offline entries.
# (In standalone mode.) Display statistics about NS packets sent to the IPv6 addresses in offline keepalive entries on slot 1.
<Sysname> display ipv6 nd scan keepalive statistics slot 1
Scanning statistics for slot 1:
     Total NS packets: 1000 packets
     Start time for statistics: 12:20:30
Interface                     5 secs   1 min    5 mins
Ten-GigabitEthernet1/0/1        123      200      230
Ten-GigabitEthernet1/0/2        0        0         0
Ten-GigabitEthernet1/0/3        0        0         0
Ten-GigabitEthernet1/0/4        0        0         0
Ten-GigabitEthernet1/0/5        0        0         0
Ten-GigabitEthernet1/0/6        0        0         0
Table 5  Command output
Total NS packets
Total number of NS packets sent to the IPv6 addresses in offline keepalive entries.
Time when the device started counting the number of NS packets sent to the IPv6 addresses in offline keepalive entries.
Name of an interface that sends NS packets to the IPv6 addresses in offline keepalive entries.
5 secs
Number of the NS packets sent in the last five seconds.
1 min
Number of the NS packets sent in the last one minute.
5 mins
Number of the NS packets sent in the last five minutes.
reset ipv6 nd scan keepalive statistics
ipv6 nd scan keepalive aging-time
Use ipv6 nd scan keepalive aging-time to set the aging time for ND keepalive entries.
Use undo ipv6 nd scan keepalive aging-time to restore the default.
ipv6 nd scan keepalive aging-time time
The aging time for ND keepalive entries is 60 minutes.
time: Specifies the aging time for ND keepalive entries in minutes. The value range for this argument is 1 to 1440.
With ND keepalive entry scanning enabled, the device generates a keepalive entry in online state for a user that comes online. If the user goes offline abnormally, the device will perform the following tasks:
·     Set the state of the keepalive entry for that user to offline state.
·     Delete the keepalive entry if its state does not restore to online after the aging time elapses.
To enable ND keepalive entry scanning, use the ipv6 nd scan keepalive enable command.
# Set the aging time for ND keepalive entries to 10 minutes.
[Sysname] ipv6 nd scan keepalive aging-time 10
Use ipv6 nd scan keepalive enable to enable ND keepalive entry scanning.
Use undo ipv6 nd scan keepalive enable to disable ND keepalive entry scanning.
ND keepalive entry scanning is disabled on an interface.
VSI interface view
VLAN interface view
L3VE interface view
In a large-scale network, it takes a long time for ND scanning to identify the hosts that go offline abnormally if you specify a large scanning range. After you enable ND keepalive entry scanning, the system can quickly locate those hosts and monitor the host status within the aging time.
When users come online, the system generates ND entries and IPSG binding entries. Enabled with ND keepalive entry scanning, the system also creates online keepalive entries when users come online. If users go offline, the corresponding ND entries are deleted and the status of the keepalive entries is set to offline. The device sends NS packets at intervals to the IPv6 addresses in the offline keepalive entries until the keepalive entries become online again.
The interval varies with the number of NS packets that have been sent to the IPv6 address in an offline keepalive entry:
·     If the number is not greater than 50, the device sends an NS packet every 30 seconds.
·     If the number is greater than 50 but not greater than 100, the device sends an NS packet every 45 seconds.
·     If the number is greater than 100, the device sends an NS packet every 60 seconds.
To view the keepalive entries, use the display ipv6 nd scan keepalive entry command.
For more information about IP source guard configuration, see Security Configuration Guide.
By default, the aging time for ND keepalive entries is 60 minutes. The offline keepalive entries are deleted when the aging time expires.
# Enable ND keepalive entry scanning on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd scan keepalive enable
ipv6 nd scan keepalive send-rate
Use ipv6 nd scan keepalive send-rate to set the NS packet sending rate for keepalive entry scanning.
Use undo ipv6 nd scan keepalive send-rate to restore the default.
ipv6 nd scan keepalive send-rate pps
The device sends NS packets at a rate of 48 pps during keepalive entry scanning.
pps: Specifies the NS packet sending rate, in packets per second (pps). The value range for this argument is 10 to 1000, and the value must be a multiple of 10.
Enabled with keepalive entry scanning, the interface sends NS packets to the IPv6 addresses in the offline keepalive entries. To avoid any impact on the device performance, use this command to set the NS packet sending rate for keepalive entry scanning.
If the status of a keepalive entry is set to offline and does not become online within an interval, the keepalive entry is to be scanned. The interface sends an NS packet per second to the IPv6 address in each keepalive entry to be scanned.
The NS packet sending rate is the maximum number of scanned keepalive entries per second.
·     If the number of keepalive entries to be scanned per second is lower than the sending rate, the device scans all these keepalive entries within a second.
·     If the number of keepalive entries to be scanned per second is greater than the sending rate, the device scans the keepalive entries at the sending rate.
When you set the sending rate to a large value, the device might use a rate lower than the specified rate to ensure the device performance.
# Set the NS packet sending rate to 10 pps during keepalive entry scanning.
[Sysname] ipv6 nd scan keepalive send-rate 10
Use reset ipv6 nd scan keepalive statistics to clear statistics about ND keepalive entry scanning.
In standalone mode:
reset ipv6 nd scan keepalive statistics [ slot slot-number ]
In IRF mode:
reset ipv6 nd scan keepalive statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears statistics about ND keepalive entry scanning on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears statistics about ND keepalive entry scanning on the global active MPU. (In IRF mode.)
This command clears statistics about the NS packets sent to the IPv6 addresses in offline keepalive entries and resets the start time of NS packet statistics collection.
The NS packet count and the statistics start time displayed by the display ipv6 nd scan keepalive statistics command are the data collected since the most recent execution of the reset ipv6 nd scan keepalive statistics command.
# Clear statistics about NS packets sent to the IPv6 addresses in offline keepalive entries.
<Sysname> reset ipv6 nd scan keepalive statistics
