- 05-Layer 3 - IP Services Configuration Guides
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-mDNS relay configuration
- 06-IP forwarding basics configuration
- 07-Fast forwarding configuration
- 08-Adjacency table configuration
- 09-IRDP configuration
- 10-IP performance optimization configuration
- 11-UDP Helper configuration
- 12-IPv6 basics configuration
- 13-DHCPv6 configuration
- 14-IPv6 fast forwarding configuration
- 15-Tunneling configuration
- 16-GRE configuration
- 17-HTTP redirect configuration
06-IP forwarding basics configuration | 80.16 KB |
Configuring IP forwarding basic settings························································ 1
Overview········································································································································· 1
Saving the IP forwarding entries to a file··························································································· 1
Forwarding specific packets received from VXLAN tunnels in hardware·············································· 2
Enabling IPv4 FIB entry consistency check······················································································· 2
Displaying FIB table entries·············································································································· 3
Configuring load sharing··················································································· 4
Overview········································································································································· 4
Configuring load sharing mode········································································································ 4
Enabling local-first load sharing······································································································· 5
Displaying and maintaining load sharing··························································································· 5
Load sharing configuration example································································································· 5
Network requirements··············································································································· 5
Configuration procedure··········································································································· 6
Verifying the configuration········································································································ 7
Overview
The device uses the destination IP address of a received packet to find a match from the forwarding information base (FIB) table. It then uses the matching entry to forward the packet.
FIB table
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Layer 3—IP Routing Configuration Guide.
Use the display fib command to display FIB table entries. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 4 FIB entry count: 4
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
10.2.0.0/16 10.2.1.1 U XGE1/0/1 Null
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
A FIB entry includes the following items:
· Destination—Destination IP address.
· Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
· Nexthop—IP address of the next hop.
· Flag—Route flag.
· OutInterface—Output interface.
· Token—MPLS Label Switched Path index number.
· Label—Inner label.
The feature automatically creates the file if you specify a nonexistent file. If the file already exists, this feature overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
To save the IP forwarding entries to a file:
Task |
Command |
Remarks |
Specify a file to save the IP forwarding entries. |
ip forwarding-table save filename filename |
Executing this command triggers one-time saving of the IP forwarding entries. This command can be executed in any view. |
By default, the device forwards ARP and NS packets received from VXLAN tunnels to the CPU for processing when acting as a VTEP in a distributed EVPN gateway network. If a large number of packets are received, packet loss might occur because of software rate limit, which might cause service exceptions on downlink devices.
To resolve this issue, you can enable the device to forward ARP and NS packets received from VXLAN tunnels in hardware without delivering them to the CPU.
· SG interface modules support this feature only when the operating mode and the proxy mode of the service module are routing, mix-bridging-routing, enhance-ipv6-route, ipv6, or enhance-arp-nd.
FD interface modules support this feature only when the operating mode and the proxy mode of the service module are bridging, routing, mix-bridging-routing, enhance-ipv6-route, ipv6, or enhance-arp-nd.
FE interface modules support this feature only when the operating mode and the proxy mode of the service module are bridging, routing, mix-bridging-routing, enhance-ipv6-route, ipv6, or enhance-arp-nd.
To enable hardware forwarding for specific packets received from VXLAN tunnels:
Task |
Command |
Remarks |
Enter system view. |
system-view |
N/A |
Enable hardware forwarding for specific packets received from VXLAN tunnels. |
forwarding vxlan-packet inner-protocol { ipv4 | ipv6 } * |
By default, packets received from VXLAN tunnels are delivered to the CPU for processing. |
Packet drops or incorrect forwarding might occur when the IPv4 FIB entries in hardware are inconsitent with FIB entries configured in software. To prevent these issues, enable IPv4 FIB entry consistency check.
This feature compares all IPv4 FIB entries in software with the IPv4 FIB entries in hardware regularly. If the device detects an inconsistency, the device performs the following tasks:
· Generates a log.
· Updates the IPv4 FIB entry in hardware with the IPv4 FIB entry in software.
To enable IPv4 FIB entry consistency check:
Task |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable IPv4 FIB entry consistency check. |
fib consistency-check enable |
By default, IPv4 FIB entry consistency check is disabled. |
Task |
Command |
Display FIB entries. |
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] |
Overview
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. The device can identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, and IP protocol number.
In a complex network, when the traffic is not load shared equally, you can use the algorithm keyword to specify an algorithm to improve load sharing.
The algorithm algorithm-number option does not take effect after you configure this option together with the dest-ip, dest-port, ip-pro, src-ip, and src-port keywords.
To configure load sharing mode:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure load sharing mode. |
· In standalone mode: · In IRF mode: |
By default, the device performs per-flow load sharing based on the source IP address, destination IP address, source port number, destination port number, and IP protocol number. |
Local-first load sharing distributes traffic preferentially across the output interfaces on the receiving IRF member device if output interfaces for multiple equal-cost routes are on different members. This feature enhances packets forwarding efficiency.
When you enable local-first load sharing, follow these restrictions and guidelines:
· An aggregate interface always participates in the traffic load sharing if it is an output interface of an equal-cost route but does not reside on the IRF member device that receives the traffic.
· The feature is not available for VXLAN tunnels.
To enable local-first load sharing:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable local-first load sharing. |
ip load-sharing local-first enable |
By default, local-first load sharing is enabled. |
Task |
Command |
Display the load sharing mode in use. |
In standalone mode: display ip load-sharing mode slot slot-number In IRF mode: display ip load-sharing mode chassis chassis-number slot slot-number |
Display the load sharing path selected for a flow. |
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address | flow-label flow-label ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] * |
As shown in Figure 1, Switch A has two equal-cost routes to Switch B. Configure load sharing on Switch A to forward packets through Switch B to the destination IP address 1.2.3.4/24.
# On Switch A, assign GigabitEthernet 1/0/1 to VLAN 10, and GigabitEthernet 1/0/2 to VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 1/0/1
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 1/0/2
[SwitchA-vlan20] quit
# On Switch A, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 10.1.1.1 24
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# On Switch B, assign GigabitEthernet 1/0/1 to VLAN 10, and GigabitEthernet 1/0/2 to VLAN 20.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0/1
[SwitchB-vlan10] quit
[SwitchB] vlan 20
[SwitchB-vlan20] port gigabitethernet 1/0/2
[SwitchB-vlan20] quit
# On Switch B, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchB-Vlan-interface10] ip address 10.1.1.2 24
[SwitchB] interface vlan-interface 20
[SwitchB-Vlan-interface20] ip address 20.1.1.2 24
[SwitchB-Vlan-interface20] quit
# On Switch A, configure two static routes to the destination IP address.
[SwitchA] ip route-static 1.2.3.4 24 10.1.1.2
[SwitchA] ip route-static 1.2.3.4 24 20.1.1.2
[SwitchA] quit
# On Switch A, display FIB entries matching the destination IP address 1.2.3.4.
<SwitchA> display fib 1.2.3.4
Destination count: 1 FIB entry count: 2
Flag:
R:Relay F:FRR
1.2.3.0/24 10.1.1.2 USGR Vlan10 Null
1.2.3.0/24 20.1.1.2 USGR Vlan20 Null
# On Switch A, configure per-flow load sharing based on the source IP address and destination IP address.
[SwitchA] ip load-sharing mode per-flow dest-ip src-ip global
# Verify that Switch A implements load sharing.
<SwitchA> display counters outbound interface GigabitEthernet
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
GE1/0/1 1045 0 0 0
GE1/0/2 1044 0 0 0
